nRF52832 with Thermistor Sensor - ADC
I need a bit of help to fully understand how ADC works on nRF52832.
I am using a Thermistor sensor like the following to measure temperature: Epoxy Thermistor - 3950 NTC
I have followed this setup to connect Thermistor sensor to AIN0(GPIO2) of nRF52-DK: sensor connection
So, I have connected one leg of Thermistor sensor to GND and the other leg to AIN0(GPIO2) of nRF52-DK, with a 10K(0.1% accuracy) pull-up resistor connected to VSHLD(VDD).
Questions:
  1. When I was calibrating my Thermistor sensor I noticed the VDD on nRF52-DK is 2.85V rather than 3.3V! is that normal?
  2. Does that mean my usable ADC resolution is the following, considering .gain = NRF_SAADC_GAIN1_6?
  • ADC value at 2.85 V – 10 bit setup: 2.85V * (1/6) / 0.6 V * 1023 = 810
  • ADC value at 0 V - 10 bit setup: 0V* (1/6) / 0.6 V * 1023 = 0
  • Usable ADC resolution - 10 bit setup: 810 - 0 = 810
  1. Can I increase my usable ADC resolution by making .gain = NRF_SAADC_GAIN1?
I started with saadc_pca10040 example and after a bit of modification to the example code I managed to measure temperature.
  1. How can I change the example code to create a 12 bit setup?
The example code seems a bit complicated for a simple ADC project.
  1. Do I really need PPI and timer_handler() function to perform ADC or I can get rid of them? If it is OK to remove them, how can I do it without breaking the code?
  2. Also, Can I use the internal pull-up resistor on the nRF52-DK instead of an external 10K resistor? If yes, what's the disadvantage of using the internal pull-up resistor over an external one?
  3. To apply such change, do I need to change the NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) in nrf_drv_saadc.h file?
#define NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P)
    .resistor_p = NRF_SAADC_RESISTOR_DISABLED,
    .resistor_n = NRF_SAADC_RESISTOR_DISABLED,
    .gain       = NRF_SAADC_GAIN1_6,
    .reference  = NRF_SAADC_REFERENCE_INTERNAL,
    .acq_time   = NRF_SAADC_ACQTIME_10US,
    .mode       = NRF_SAADC_MODE_SINGLE_ENDED,
    .pin_p      = (nrf_saadc_input_t)(PIN_P),
    .pin_n      = NRF_SAADC_INPUT_DISABLED
to:
    .resistor_p = NRF_SAADC_RESISTOR_PULLUP,
  1. What other changes do you recommend to NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) profile for better and faster ADC? like can I make .acq_time = NRF_SAADC_ACQTIME_3US?
Thanks in advance
