is there any example how to reset the hole device? Are there any example codes for using something like system_off or system_on ?
Best regards Nils
Best regards Nils
Hi
Resetting the device can be done as simply as this:
NVIC_SystemReset();
I attached some examples showing how to use the System Off and System On modes. Please be aware that the examples assume no SoftDevice is used, when using the SoftDevice power management have to be handled through the SoftDevice API's.
Best regards Torbjørn
Thanks for the answer :)
Do you also have an example ho to use it when the softdevice is used?
best regards Nils
sd_nvic_SystemReset();
See SoC Library API
how long does the reset take?
