I'm trying to write some data to flash memory (32 bytes) every 1 minute. the data are not NULL but then I noticed that sometimes (not always) the pstroage module write zeros to flash memory. I can check that it's NULL data which are written by dumpting the flash content.
I'm using below function to write a block
I can check that err_code returns nrf_success
my question is
1 - it is mandatory to call pstorage_clear before calling pstorage_store when flash had already data on that location?
are my waiting functions correct for pstorage_clear and pstroage_store??
void save_to_flash(pstorage_handle_t * flash_handler, pstorage_size_t block_id, pstorage_handle_t * block_handle, uint8_t * data, pstorage_size_t size, pstorage_size_t offset)
uint32_t err_code;
uint32_t count;
flash_busy = true;
err_code = pstorage_block_identifier_get(flash_handler, block_id, block_handle);
err_code = pstorage_clear(block_handle, size);
pstorage_wait_handle = block_handle->block_id; //Specify which pstorage handle to wait for
while (pstorage_wait_flag) {
manage_power(); //Sleep until clear operation is finished.
err_code = pstorage_store(block_handle, data, size, offset);
count = 16;
do {
uint32_t ret = pstorage_access_status_get(&count);
} while (count);
flash_busy = false;
void flash_callback_handler(pstorage_handle_t * p_handle,
uint8_t op_code,
uint32_t result,
uint8_t * p_data,
uint32_t data_len)
if (p_handle->block_id == pstorage_wait_handle) {
pstorage_wait_flag = 0; //If we are waiting for this callback, clear the wait flag.
switch (op_code) {
case PSTORAGE_STORE_OP_CODE:
if (result == NRF_SUCCESS) {
; // Nothing to do : Store operation successful.
else {
APP_ERROR_CHECK(result); // Store operation failed.
