Hello, I'm using BLE, RTC and app_timer to blink a led. I blink the led 10 times when I receive an order from BT (by means of NUS), and then by means of RTC.
uint32_t initBlink()
app_timer_create(&m_seq_timer_id,APP_TIMER_MODE_SINGLE_SHOT,timer_seq_event_handler);
nrf_gpio_cfg_output(25);
return 1;
void timer_seq_event_handler( void* p_context)
nrf_gpio_pin_toggle(25);
ctrSeqTime ++;
if(ctrSeqTime >= 10)
ctrSeqTime = 0;
app_timer_start(m_seq_timer_id, TIMER_VAL_MS, NULL);
void doBlink()
ctrSeqTime = 0;
void rtc_config(void)
app_timer_create(&m_alert_timer_id, APP_TIMER_MODE_REPEATED, alert_timer_handler);
app_timer_start(m_alert_timer_id,4096,NULL);
ctrWait=0;
static void alert_timer_handler(void * p_context)
ctrWait++;
if(ctrWait > 50)
doBlink();
When doBlink is called from BT, the blink is faster than when it is called by alert_timer. I guess it has something to do with the low power, and the processor going faster when receiving BT frames thant when in low power RTC, but I want that the speed be equal in both cases.
