what is the maximum range to connect 2 NRF51822 devices with Gazell
I was looking into Gazell and read that Gazell only allows pairing when Host and Device are in close proximity to each other. This range is about 30 centimeters. I was wondering if this range could be extended? and if this is possible what will be the range it could reach?
Thanks in advance,
Tim
  • This is a security feature implemented in the gazell pairing library, to prevent bonding to any "wrong"/malicious device. This library is delivered as source code in the SDK, so it is possible to change this behavior.
    Basically the gazell library transmits the pairing request using low (-16dBm) tx power, so only devices in close proximity will receive it.
    To be able to do pairing using normal tx power one only needs to change one line in the file nrf_gzp_config.h(line 53):
    Reduced TX power for use during close proximity pairing.
    #define GZP_POWER NRF_GZLL_TX_POWER_N16_DBM
    change to:
    #define GZP_POWER NRF_GZLL_TX_POWER_0_DBM
  • The close proximity pairing feature in Gazell uses the RSSI measurement to detect if a device is in pairing range.
    On the host side, the RSSI is compared against a threshold to decide if the device is in range, and is defined as
    #define GZP_HOST_RX_POWER_THRESHOLD -64 ///< RSSI threshold for when signal strength in RX packet power is high enough.
    If you want to extend the pairing range, you can adjust this threshold to fit your requirements.
