Is there an example like the PC-BLE-Driver 0.5.0 multi-link example, but using the new serialization interface with "adapter_t * adapter" from git hub
Hi Christian,
I assume you are trying to use the pc-ble-driver on our github ? We only have examples in python here. Maybe it would help ?
This is my adapted Multi-Link main.c to use the pc-ble-driver 1.0.0. Advertising packets are received, but connecting to my connectivity chip with up to date firmware (S130 2.0.0.1 with patch from github) fails with error code 18....
/* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
#include "ble.h"
#include "ble_gap.h"
#include "ble_gattc.h"
#include "ble_types.h"
#include "nrf_error.h"
#include "sd_rpc.h"
#include <string.h>
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
#include <conio.h>
#ifdef _WIN32
#define UART_PORT_NAME "COM7"
#define UART_BAUD_RATE 115200
//#define UART_BAUD_RATE 1000000
#ifdef __APPLE__
#define UART_PORT_NAME "/dev/tty.usbmodem00000"
#ifdef __linux__
#define UART_PORT_NAME "/dev/ttyACM0"
#define ADVERTISING_INTERVAL_40_MS 64 // * 0.625 ms = 40 ms
#define ADVERTISING_TIMEOUT_3_MIN 180 // * 1 sec = 3 min
enum
UNIT_0_625_MS = 625, /**< Number of microseconds in 0.625 milliseconds. */
UNIT_1_25_MS = 1250, /**< Number of microseconds in 1.25 milliseconds. */
UNIT_10_MS = 10000 /**< Number of microseconds in 10 milliseconds. */
#define MSEC_TO_UNITS(TIME, RESOLUTION) (((TIME) * 1000) / (RESOLUTION))
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(60, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define TARGET_DEV_NAME "PT-9" /**< Target device name that application is looking for. */
#define MAX_PEER_COUNT 8 /**< Maximum number of peer's application intends to manage. */
#define HRM_SERVICE_UUID 0x180D
#define HRM_MEAS_CHAR_UUID 0x2A37
#define CCCD_UUID 0x2902
#define CCCD_NOTIFY 0x01
// Power Tool UUID base: 1B59xxxx-1D5C-4829-8BCE-BF626B394318
#define PWRTOOLSRV_UUID_BASE {0x18, 0x43, 0x39, 0x6B, 0x62, 0xBF, 0x8B, 0xCE, 0x48, 0x29, 0x5C, 0x1D, 0x00, 0x00, 0x59, 0x1B}
#define PWRTOOLSRV_UUID_SERVICE 0x1600
/* reserved
#define PWRTOOLSRV_UUID_STATUS_CHAR 0x1601
#define PWRTOOLSRV_UUID_OBJECT_REQUEST_CHAR 0x1611
#define PWRTOOLSRV_UUID_OBJECT_PAYLOAD_CHAR 0x1612
#define PWRTOOLSRV_UUID_MEMORY_REQUEST_CHAR 0x1621
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_HISTORY_HEADER_CHAR 0x1622
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_HISTORY_ENTRY_CHAR 0x1623
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_LOGGER_HEADER_CHAR 0x1624
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_LOGGER_ENTRY_INFO_CHAR 0x1625
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_LOGGER_ENTRY_CHAR 0x1626
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_MANUFACTURER_READY_CHAR 0x1627
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_MANUFACTURER_CHAR 0x1628
#define PWRTOOLSRV_UUID_MEMORY_PAYLOAD_SERVICE_CHAR 0x1629
#define STRING_BUFFER_SIZE 50
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
static uint8_t m_connected_devices = 0;
static uint16_t m_connection_handle = 0;
static uint16_t m_service_start_handle = 0;
static uint16_t m_service_end_handle = 0;
static uint16_t m_hrm_char_handle = 0;
static uint16_t m_hrm_cccd_handle = 0;
static bool m_connection_is_in_progress = false;
static const ble_gap_scan_params_t m_scan_param =
0, // Active scanning set.
0, // Selective scanning not set.
NULL, // White-list not set.
(uint16_t)SCAN_INTERVAL, // Scan interval.
(uint16_t)SCAN_WINDOW, // Scan window.
0 // Never stop scanning unless explicit asked to.
static const ble_gap_conn_params_t m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
0, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
/* Local function declarations */
static void log_handler(adapter_t * adapter, sd_rpc_log_severity_t severity, const char * message);
static uint32_t ble_stack_init(adapter_t * adapter );
static void on_connected(adapter_t * adapter, const ble_gap_evt_t * const p_ble_gap_evt);
static void on_adv_report(adapter_t * adapter, const ble_gap_evt_t * const p_ble_gap_evt);
static void on_timeout(adapter_t * adapter, const ble_gap_evt_t * const p_ble_gap_evt);
static void on_service_discovery_response(adapter_t * adapter, const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_characteristic_discover_response(adapter_t * adapter, const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_descriptor_discover_response(adapter_t * adapter, const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_write_response(adapter_t * adapter, const ble_gattc_evt_t * const p_ble_gattc_evt);
static uint32_t adv_report_parse( uint8_t type, data_t * p_advdata, data_t * p_typedata);
static uint32_t scan_start(adapter_t * adapter );
static uint32_t service_discovery_start(adapter_t * adapter );
static uint32_t char_discovery_start(adapter_t * adapter );
static uint32_t descr_discovery_start(adapter_t * adapter );
static uint32_t hrm_cccd_set(adapter_t * adapter, uint8_t value);
static void ble_address_to_string_convert(ble_gap_addr_t address, uint8_t * string_buffer);
static void status_handler(adapter_t *adapter, sd_rpc_app_status_t code, const char * message) {
switch (code)
case PKT_SEND_MAX_RETRIES_REACHED:
printf("PKT_SEND_MAX_RETRIES_REACHED: %s\n", message); fflush(stdout);
case PKT_UNEXPECTED:
printf("PKT_UNEXPECTED: %s\n", message); fflush(stdout);
case PKT_ENCODE_ERROR:
printf("PKT_ENCODE_ERROR: %s\n", message); fflush(stdout);
case PKT_DECODE_ERROR:
printf("PKT_DECODE_ERROR: %s\n", message); fflush(stdout);
case PKT_SEND_ERROR:
printf("PKT_SEND_ERROR: %s\n", message); fflush(stdout);
case IO_RESOURCES_UNAVAILABLE:
printf("IO_RESOURCES_UNAVAILABLE: %s\n", message); fflush(stdout);
case RESET_PERFORMED:
printf("RESET_PERFORMED: %s\n", message); fflush(stdout);
case CONNECTION_ACTIVE:
printf("CONNECTION_ACTIVE: %s\n", message); fflush(stdout);
switch (severity)
case SD_RPC_LOG_TRACE:
printf("Trace: %s\n", message); fflush(stdout);
case SD_RPC_LOG_DEBUG:
printf("Debug: %s\n", message); fflush(stdout);
case SD_RPC_LOG_INFO:
printf("Info: %s\n", message); fflush(stdout);
case SD_RPC_LOG_WARNING:
printf("Warning: %s\n", message); fflush(stdout);
case SD_RPC_LOG_ERROR:
printf("Error: %s\n", message); fflush(stdout);
case SD_RPC_LOG_FATAL:
printf("Fatal: %s\n", message); fflush(stdout);
printf("Log: %s\n", message); fflush(stdout);
printf("Connection established\n"); fflush(stdout);
m_connected_devices++;
m_connection_handle = p_ble_gap_evt->conn_handle;
service_discovery_start( adapter );
uint32_t err_code;
data_t adv_data;
data_t type_data;
uint8_t str[STRING_BUFFER_SIZE] = {0};
ble_address_to_string_convert(p_ble_gap_evt->params.adv_report.peer_addr, str);
printf("Received advertisment report, address: 0x%s\n", str); fflush(stdout);
adv_data.p_data = (uint8_t *)(p_ble_gap_evt->params.adv_report.data);
adv_data.data_len = p_ble_gap_evt->params.adv_report.dlen;
err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
&adv_data,
&type_data);
if (err_code != NRF_SUCCESS)
// Compare short local name in case complete name does not match.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME,
&adv_data,
&type_data);
return;
if (0 == memcmp(TARGET_DEV_NAME, type_data.p_data, type_data.data_len))
if (m_connected_devices >= MAX_PEER_COUNT)
return;
if (m_connection_is_in_progress)
return;
err_code = sd_ble_gap_connect(adapter, &(p_ble_gap_evt->params.adv_report.peer_addr),
&m_scan_param,
&m_connection_param);
printf("Connection Request Failed, reason %d\n", err_code); fflush(stdout);
return;
m_connection_is_in_progress = true;
if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
else if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
scan_start( adapter );
int count;
int service_index;
const ble_gattc_service_t * service;
if (p_ble_gattc_evt->gatt_status != NRF_SUCCESS)
printf("Error. Service discovery failed. Error code 0x%X\n",
p_ble_gattc_evt->gatt_status);
fflush(stdout);
return;
count = p_ble_gattc_evt->params.prim_srvc_disc_rsp.count;
if (count == 0)
printf("Error. Service not found\n"); fflush(stdout);
return;
printf("Received service discovery response\n"); fflush(stdout);
service_index = 0; /* We specifically requested to discover Heart Rate service, so we can
* safely select the first returned service. */
service = &(p_ble_gattc_evt->params.prim_srvc_disc_rsp.services[service_index]);
m_service_start_handle = service->handle_range.start_handle;
m_service_end_handle = service->handle_range.end_handle;
printf("UUID: 0x%04X, start handle: 0x%04X, end handle: 0x%04X\n",
service->uuid.uuid, m_service_start_handle, m_service_end_handle);
fflush(stdout);
char_discovery_start( adapter );
int i;
int count;
ble_gattc_char_t * p_characteristic;
printf("Error. Characteristic discovery failed. Error code 0x%X\n",
fflush(stdout);
return;
count = p_ble_gattc_evt->params.char_disc_rsp.count;
printf("Received characteristic discovery response, characteristics count: %d\n", count);
fflush(stdout);
for (i = 0; i < count; i++)
p_characteristic = (ble_gattc_char_t *)&(p_ble_gattc_evt->params.char_disc_rsp.chars[i]);
printf("Handle: 0x%04X, UUID: 0x%04X\n",
p_characteristic->handle_decl,
p_characteristic->uuid.uuid);
fflush(stdout);
if (p_characteristic->uuid.uuid == HRM_MEAS_CHAR_UUID)
m_hrm_char_handle = p_characteristic->handle_decl;
descr_discovery_start( adapter );
int i;
int count;
ble_gattc_desc_t * p_descriptor;
printf("Error. Descriptor discovery failed. Error code 0x%X\n",
fflush(stdout);
return;
count = p_ble_gattc_evt->params.desc_disc_rsp.count;
printf("Received descriptor discovery response, descriptor count: %d\n", count);
fflush(stdout);
p_descriptor = (ble_gattc_desc_t *)&(p_ble_gattc_evt->params.desc_disc_rsp.descs[i]);
printf("Handle: 0x%04X, UUID: 0x%04X\n", p_descriptor->handle, p_descriptor->uuid.uuid);
fflush(stdout);
if (p_descriptor->uuid.uuid == CCCD_UUID)
m_hrm_cccd_handle = p_descriptor->handle;
printf("Press enter to toggle notifications\n"); fflush(stdout);
printf("Received write response.\n"); fflush(stdout);
printf("Error. Write operation failed. Error code 0x%X\n",
fflush(stdout);
return;
static void on_hvx(adapter_t * adapter, const ble_gattc_evt_t * const p_ble_gattc_evt)
int i = 0;
int length = p_ble_gattc_evt->params.hvx.len;
printf("Received handle value notification, handle: 0x%04X, value: 0x",
p_ble_gattc_evt->params.hvx.handle);
fflush(stdout);
for (i = 0; i < length; i++)
printf("%02X", p_ble_gattc_evt->params.hvx.data[i]);
fflush(stdout);
printf("\n"); fflush(stdout);
const int address_length = 6;
char temp_str[3];
int i = 0;
for (i = address_length - 1; i >= 0; --i)
sprintf(temp_str, "%02X", address.addr[i]);
strcat((char *)string_buffer, temp_str);
static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata)
uint8_t * p_data;
uint32_t index;
p_data = p_advdata->p_data;
index = 0;
while (index < p_advdata->data_len)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index+1];
if (field_type == type)
p_typedata->p_data = &p_data[index+2];
p_typedata->data_len = field_length-1;
return NRF_SUCCESS;
index += field_length+1;
return NRF_ERROR_NOT_FOUND;
uint32_t err_code;
ble_enable_params_t ble_enable_params;
memset(&ble_enable_params, 0, sizeof(ble_enable_params));
ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
ble_enable_params.gatts_enable_params.service_changed = false;
err_code = sd_ble_enable(adapter, &ble_enable_params, 0); // TODO set APP RAM BASE
if (err_code == NRF_SUCCESS)
return err_code;
if (err_code == NRF_ERROR_INVALID_STATE)
printf("BLE stack already enabled\n"); fflush(stdout);
return NRF_SUCCESS;
printf("Failed to enable BLE stack.\n"); fflush(stdout);
return err_code;
uint32_t error_code = sd_ble_gap_scan_start(adapter, &m_scan_param);
if (error_code != NRF_SUCCESS)
printf("Scan start failed\n"); fflush(stdout);
return error_code;
printf("Scan started\n"); fflush(stdout);
return NRF_SUCCESS;
static uint32_t service_discovery_start( adapter_t * adapter )
ble_uuid128_t base_uuid = { PWRTOOLSRV_UUID_BASE };
uint16_t start_handle;
uint32_t err_code;
ble_uuid_t srvc_uuid;
uint8_t vs_uuid_type;
printf("Discovering primary services\n"); fflush(stdout);
start_handle = 0x0001;
err_code = sd_ble_uuid_vs_add(adapter, &base_uuid, &vs_uuid_type);
srvc_uuid.type = vs_uuid_type;
srvc_uuid.uuid = PWRTOOLSRV_UUID_SERVICE;
err_code = sd_ble_gattc_primary_services_discover(adapter, m_connection_handle, start_handle,
&srvc_uuid);
printf("Failed to discover primary services\n"); fflush(stdout);
return err_code;
return NRF_SUCCESS;
uint32_t err_code;
ble_gattc_handle_range_t handle_range;
printf("Discovering characteristics\n"); fflush(stdout);
handle_range.start_handle = m_service_start_handle;
handle_range.end_handle = m_service_end_handle;
err_code = sd_ble_gattc_characteristics_discover(adapter, m_connection_handle, &handle_range);
return err_code;
uint32_t err_code;
printf("Discovering descriptors\n"); fflush(stdout);
if (m_hrm_char_handle == 0)
printf("Error. No HRM characteristic handle has been found\n"); fflush(stdout);
handle_range.start_handle = m_hrm_char_handle;
err_code = sd_ble_gattc_descriptors_discover(adapter, m_connection_handle, &handle_range);
return err_code;
uint32_t err_code;
ble_gattc_write_params_t write_params;
uint8_t cccd_value[2] = {value, 0};
printf("Setting HRM CCCD\n"); fflush(stdout);
if (m_hrm_cccd_handle == 0)
printf("Error. No CCCD handle has been found\n"); fflush(stdout);
write_params.handle = m_hrm_cccd_handle;
write_params.len = 2;
write_params.p_value = cccd_value;
write_params.write_op = BLE_GATT_OP_WRITE_REQ;
write_params.offset = 0;
err_code = sd_ble_gattc_write(adapter, m_connection_handle, &write_params);
return err_code;
static void ble_evt_dispatch(adapter_t *adapter, ble_evt_t * p_ble_evt)
if (p_ble_evt == NULL)
printf("Received empty ble_event\n"); fflush(stdout);
return;
case BLE_GAP_EVT_CONNECTED:
on_connected(adapter, &(p_ble_evt->evt.gap_evt));
printf("Disconnected, reason: 0x%02X\n", p_ble_evt->evt.gap_evt.params.disconnected.reason);
fflush(stdout);
m_connected_devices--;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(adapter, &(p_ble_evt->evt.gap_evt));
case BLE_GAP_EVT_TIMEOUT:
on_timeout(adapter, &(p_ble_evt->evt.gap_evt));
case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
on_service_discovery_response(adapter, &(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_CHAR_DISC_RSP:
on_characteristic_discover_response(adapter, &(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_DESC_DISC_RSP:
on_descriptor_discover_response(adapter, &(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_WRITE_RSP:
on_write_response(adapter, &(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_HVX:
on_hvx(adapter, &(p_ble_evt->evt.gattc_evt));
printf("Unhandled event with ID: %d\n", p_ble_evt->header.evt_id); fflush(stdout);
int main(int argc, char *argv[])
bool menuActive = true;
uint32_t error_code;
uint8_t cccd_value;
char* serial_port;
physical_layer_t * physical_layer;
data_link_layer_t * data_link_layer;
transport_layer_t * transport_layer;
adapter_t * adapter;
cccd_value = 0;
if (argc > 1)
serial_port = argv[1];
serial_port = UART_PORT_NAME;
printf("Serial port used: %s\n", serial_port); fflush(stdout);
physical_layer = sd_rpc_physical_layer_create_uart(serial_port, UART_BAUD_RATE, SD_RPC_FLOW_CONTROL_HARDWARE, SD_RPC_PARITY_NONE);
data_link_layer = sd_rpc_data_link_layer_create_bt_three_wire(physical_layer, 250);
transport_layer = sd_rpc_transport_layer_create(data_link_layer, 250);
adapter = sd_rpc_adapter_create(transport_layer);
error_code = sd_rpc_open(adapter, status_handler, ble_evt_dispatch, log_handler);
printf("Failed to open the nRF51 BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
error_code = ble_stack_init( adapter );
return error_code;
while (menuActive)
int ch = _getch();
switch (ch) {
case 'q':
case 'x':
menuActive = false;
error_code = sd_rpc_close( adapter );
printf("Failed to close the nRF51 BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
printf("Closed\n"); fflush(stdout);
return 0;
FYI, there is an open issue related to this on Github: github.com/.../17
Thanks for your information. SwissKnife is my identity on GitHub, and now I have updated there too...
I am not sure where you will get more help (on Github or here)...
