Hi there,
I'm using an input GPIOTE based on SDK11. The interrupt is consistently being fired. On the other hand, if I use "if(Pin_6)" to check the trigger, it does not get fired continuously. Is there a command in the nrf_drv to clear the gpio interrupt flag, the current command i'm using isnt working? I'm using 'globalflag' to turn on certain segments of my main loop. Below is a segment of the code:
void gpiote_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
// Event not clearing
nrf_gpiote_event_clear(NRF_GPIOTE_EVENTS_IN_0);
globalflag = true;
static void gpiote_init(void)
// Initialize GPIO Interrupt Driver
nrf_drv_gpiote_init();
// Initialize PIN_6 as GPIOTE Input Pin
nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
nrf_drv_gpiote_in_init(PIN_6, &config, gpiote_event_handler);
// Enable GPIO event and it's corresponding interrupt
nrf_drv_gpiote_in_event_enable(PIN_6, true);
return;
