NRF52 Dim LED with PWM Driver
I am migrating from nrf51 to nrf52. Using SDK12.1
On NRF51, I used the PWM Library to use 2 buttons on the DK to dim up or down onboard LED1 (called OUTPUT_LED). It worked great (not sure if it did it properly or not). The code was fairly simple.
I set up the PWM
APP_PWM_INSTANCE(PWM1,1);
I then initialize PWM:
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(5000L, OUTPUT_LED);
app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
app_pwm_enable(&PWM1);
while (app_pwm_channel_duty_set(&PWM1, 0, pwm_value) == NRF_ERROR_BUSY);
I then call the code in the button handler to dim up or down.
if (button_action == APP_BUTTON_PUSH)  {
switch (pin_no)
    case DIM_UP_BUTTON:
        if (pwm_value<100)
           ++pwm_value;
    case DIM_DOWN_BUTTON:
        if (pwm_value >1)
            --pwm_value;
        APP_ERROR_HANDLER(pin_no);
        break;}
I am looking at the examples for using the hardware PWM driver that the nrf52 has. They look super confusing! So many parameters.I just want to dim an LED at a set frequency. Can someone help me with a code example for the PWD driver that will work similarly? I would like to do this using the nrf52 hardware PWM versus using the extra resources needed with the PWM library method. I appreciate the help!, Bryan
