Enabling long rage in nRF52840
I am using nRF52840, SDK_16.0.0, S140 SoftDevice and Segger 4.16 for flashing the image. I am using ‘ble_app_blinky’.
As per below mail I changed settings for long range.
https://devzone.nordicsemi.com/f/nordic-q-a/40365/how-to-use-ble_gap_phy_coded-in-ble_app_beacon-example/157628#157628
https://devzone.nordicsemi.com/f/nordic-q-a/36364/enable-coded-phy-long-range-for-peripheral-blinky-code
    //adv_params.primary_phy   = BLE_GAP_PHY_1MBPS; // 1Mbps PHY layer
    adv_params.primary_phy     = BLE_GAP_PHY_CODED; //  For long range
    adv_params.secondary_phy   = BLE_GAP_PHY_CODED;
Even I have gone through ble_app_att_mtu_throughput. It says below changes to be done in advertising_data_set() for long range.
.primary_phy = BLE_GAP_PHY_1MBPS, // Must be changed to connect in long range. (BLE_GAP_PHY_CODED)
.secondary_phy = BLE_GAP_PHY_1MBPS,
But still I am getting fatal error as 7 at sd_ble_gap_adv_set_configure() within advertising_init()
My queries are:
1) Any settings to be enabled further on top of ble_app_blinky.
2) I need only long range but not Extended Advertisement. So I used BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED. Will this cause any issue.
3) As per uart example code below, do I need to comment case BLE_GAP_EVT_PHY_UPDATE_REQUEST under ble_evt_handler() ?
              https://github.com/NordicPlayground/nRF52-ble-long-range-demo
4) As per standards there are two LE Codes (S=2 with 500 Kb/s and the other one is S=8 with 125 Kb/s). Whether both are supported, if so how to set the same in nRF52840. For long range we want S=8. How to set this ?
5) If BLE_GAP_PHY_CODED is enabled, whether can I connect with my Mobile which is not BLE 5.0 compatible.
Below is my code snapshot.
    ret_code_t    err_code;
    ble_advdata_t advdata;  // Advertisement Data
    ble_advdata_t srdata;   // Scan Response Data
    ble_advdata_manuf_data_t manufData;
    // Build and set Advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false; // GAP apperance 0x19
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    // Build and set Scan response data.
    memset(&srdata, 0, sizeof(srdata));
    srdata.name_type          = BLE_ADVDATA_FULL_NAME; // BLE_ADVDATA_NO_NAME;
    srdata.include_appearance = false; // GAP apperance 0x19
    manufData.company_identifier = 0xFFFF;
    manufData.data.p_data        = &u8TadUID[0];
    manufData.data.size          = sizeof(u8TadUID);
    srdata.p_manuf_specific_data  = &manufData;
    advdata.p_manuf_specific_data = &manufData;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    #if 0
    #else
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    //adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY; // Filter policy as part of 'White list'
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
Thanks & Regards
Vishnu Beema
  • Hi Vishnu
    1. You also have to include the following advertising flag for your Coded PHY application to be discovered. adv_data.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    2. You have to use extended advertising in order to use Coded PHY, so this will cause an issue. Please use the BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_SCANNABLE_UNDIRECTED advertising type.
    3. I don't know if I understand this question. Why do you want to comment out BLE_GAP_EVT_PHY_UPDATE_REQUEST?
    4. This example uses S=8 by default.
    5. No, phones that do not support Coded_PHY (BLE 5.0) can not communicate with devices that use Coded_PHY.
    Simon
  • Hi Simon,
    Thank you for your reply.
    1) BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE is already in my code. Please crosscheck with my code snapshot and let me know if other structure I need to add.
    2) I cannot fine BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_SCANNABLE_UNDIRECTED macro in ble_gap.h. I used BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED. But still I am getting fatal error.
    3) As mentioned, the case statement is commented in the code attached in the link.
    4) Is there a way to enable S=2 ?
    5) Ok, got it. Thank you for confirmation.
    To simplify, I did changes on actual code and the same I am attaching fill. Still with point 2 change I am getting fatal error.
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        advdata.include_appearance = true;
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        #if 0
        #else
     * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyze
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        #if 0
        #else
    /**@brief Function for handling Queued Write Module errors.
    static void nrf_qwr_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
        else
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        nrf_ble_qwr_init_t qwr_init = {0};
        // Initialize Queued Write Module.
        err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init);
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
    /**@brief Function for handling a Connection Parameters error.
    static void advertising_start(void)
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // No system attributes have been stored.
                err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            default:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            default:
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Thanks & Regards
    Vishnu Beema
  • Hi Vishnu
    1. The flag seems to be set correctly.
    2. I'm sorry, BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED should be the correct advertising type for Coded PHY.
    3. Please check out this case, where a lot of common mistakes when setting up a long-range project are clarified by my colleague Håvard.
    4. I'm sorry, but our SoftDevices does not support S=2 yet, so there is no way to enable this.
    Simon
  • Hi Simon,
    Finally I am not getting exceptions. I missed setting to null. Its running fine. I need to check further by connecting to Central.
    .scan_rsp_data =
    .p_data = NULL,
    .len = 0
    Attaching file for future reference.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "boards.h"
    #define ENABLE_LONG_RANGE               1
        .adv_data =
        .scan_rsp_data =
            #if ENABLE_LONG_RANGE
            .p_data = 0,
            .len    = 0
            #else
        #if !ENABLE_LONG_RANGE
        //adv_params.scan_req_notification = 1; //recently added MD 7/9/18
        #else
        if (led_state)
        else
        // Initialize LBS.
                                                       NULL,
                                                       NULL);
            } break;
            default:
        switch (pin_no)
            default:
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    Thank you for your support.
    Thanks & Regards
    Vishnu Beema
