The ble_app_hhs_freertos example uses nrf_sdh_freertos.c, which in turn, requires that NRF_SDH_DISPATCH_MODEL be set to NRF_SDH_DISPATCH_MODEL_POLING.
Is there a reason why FreeRTOS requires polling over interrupts?
Infact nrf_sdh_freertos.c only uses interrupt model. The reason the system relies on sdk_config.h to have polling selected is a bit misleading.
Please replace your nrf_sdh.c file with this one.
* Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(NRF_SDH)
#include "nrf_sdh.h"
#include <stdint.h>
#include "nrf_sdm.h"
#include "nrf_nvic.h"
#include "sdk_config.h"
#include "app_error.h"
#define NRF_LOG_MODULE_NAME nrf_sdh
#if NRF_SDH_LOG_ENABLED
#define NRF_LOG_LEVEL NRF_SDH_LOG_LEVEL
#define NRF_LOG_INFO_COLOR NRF_SDH_INFO_COLOR
#define NRF_LOG_DEBUG_COLOR NRF_SDH_DEBUG_COLOR
#else
#define NRF_LOG_LEVEL 0
#endif // NRF_SDH_LOG_ENABLED
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
// Validate configuration options.
#if (NRF_SDH_DISPATCH_MODEL == NRF_SDH_DISPATCH_MODEL_APPSH)
#if (!APP_SCHEDULER_ENABLED)
#error app_scheduler is required when NRF_SDH_DISPATCH_MODEL is set to NRF_SDH_DISPATCH_MODEL_APPSH
#include "app_scheduler.h"
#if ( (NRF_SDH_CLOCK_LF_SRC == NRF_CLOCK_LF_SRC_RC) \
&& (NRF_SDH_CLOCK_LF_ACCURACY != NRF_CLOCK_LF_ACCURACY_500_PPM))
#warning Please select NRF_CLOCK_LF_ACCURACY_500_PPM when using NRF_CLOCK_LF_SRC_RC
// Create section "sdh_req_observers".
NRF_SECTION_SET_DEF(sdh_req_observers, nrf_sdh_req_observer_t, NRF_SDH_REQ_OBSERVER_PRIO_LEVELS);
// Create section "sdh_state_observers".
NRF_SECTION_SET_DEF(sdh_state_observers, nrf_sdh_state_observer_t, NRF_SDH_STATE_OBSERVER_PRIO_LEVELS);
// Create section "sdh_stack_observers".
NRF_SECTION_SET_DEF(sdh_stack_observers, nrf_sdh_stack_observer_t, NRF_SDH_STACK_OBSERVER_PRIO_LEVELS);
static bool m_nrf_sdh_enabled; /**< Variable to indicate whether the SoftDevice is enabled. */
static bool m_nrf_sdh_suspended; /**< Variable to indicate whether this module is suspended. */
static bool m_nrf_sdh_continue; /**< Variable to indicate whether enable/disable process was started. */
/**@brief Function for notifying request observers.
* @param[in] evt Type of request event.
static ret_code_t sdh_request_observer_notify(nrf_sdh_req_evt_t req)
nrf_section_iter_t iter;
NRF_LOG_DEBUG("State request: 0x%08X", req);
for (nrf_section_iter_init(&iter, &sdh_req_observers);
nrf_section_iter_get(&iter) != NULL;
nrf_section_iter_next(&iter))
nrf_sdh_req_observer_t * p_observer;
nrf_sdh_req_evt_handler_t handler;
p_observer = (nrf_sdh_req_observer_t *) nrf_section_iter_get(&iter);
handler = p_observer->handler;
if (handler(req, p_observer->p_context))
NRF_LOG_DEBUG("Notify observer 0x%08X => ready", p_observer);
else
// Process is stopped.
NRF_LOG_DEBUG("Notify observer 0x%08X => blocking", p_observer);
return NRF_ERROR_BUSY;
return NRF_SUCCESS;
/**@brief Function for stage request observers.
* @param[in] evt Type of stage event.
static void sdh_state_observer_notify(nrf_sdh_state_evt_t evt)
NRF_LOG_DEBUG("State change: 0x%08X", evt);
for (nrf_section_iter_init(&iter, &sdh_state_observers);
nrf_sdh_state_observer_t * p_observer;
nrf_sdh_state_evt_handler_t handler;
p_observer = (nrf_sdh_state_observer_t *) nrf_section_iter_get(&iter);
handler(evt, p_observer->p_context);
static void softdevices_evt_irq_enable(void)
#ifdef SOFTDEVICE_PRESENT
ret_code_t ret_code = sd_nvic_EnableIRQ((IRQn_Type)SD_EVT_IRQn);
APP_ERROR_CHECK(ret_code);
#else
// In case of serialization, NVIC must be accessed directly.
NVIC_EnableIRQ(SD_EVT_IRQn);
static void softdevice_evt_irq_disable(void)
ret_code_t ret_code = sd_nvic_DisableIRQ((IRQn_Type)SD_EVT_IRQn);
#else
NVIC_DisableIRQ(SD_EVT_IRQn);
ret_code_t nrf_sdh_enable_request(void)
ret_code_t ret_code;
if (m_nrf_sdh_enabled)
return NRF_ERROR_INVALID_STATE;
m_nrf_sdh_continue = true;
// Notify observers about SoftDevice enable request.
if (sdh_request_observer_notify(NRF_SDH_EVT_ENABLE_REQUEST) == NRF_ERROR_BUSY)
// Enable process was stopped.
return NRF_SUCCESS;
// Notify observers about starting SoftDevice enable process.
sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLE_PREPARE);
nrf_clock_lf_cfg_t const clock_lf_cfg =
.source = NRF_SDH_CLOCK_LF_SRC,
.rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV,
.rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV,
.accuracy = NRF_SDH_CLOCK_LF_ACCURACY
CRITICAL_REGION_ENTER();
#ifdef ANT_LICENSE_KEY
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler, ANT_LICENSE_KEY);
#else
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
m_nrf_sdh_enabled = (ret_code == NRF_SUCCESS);
CRITICAL_REGION_EXIT();
if (ret_code != NRF_SUCCESS)
return ret_code;
m_nrf_sdh_continue = false;
m_nrf_sdh_suspended = false;
// Enable event interrupt.
// Interrupt priority has already been set by the stack.
softdevices_evt_irq_enable();
// Notify observers about a finished SoftDevice enable process.
sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLED);
return NRF_SUCCESS;
ret_code_t nrf_sdh_disable_request(void)
if (!m_nrf_sdh_enabled)
// Notify observers about SoftDevice disable request.
if (sdh_request_observer_notify(NRF_SDH_EVT_DISABLE_REQUEST) == NRF_ERROR_BUSY)
// Disable process was stopped.
return NRF_SUCCESS;
// Notify observers about starting SoftDevice disable process.
sdh_state_observer_notify(NRF_SDH_EVT_STATE_DISABLE_PREPARE);
ret_code = sd_softdevice_disable();
m_nrf_sdh_enabled = false;
return ret_code;
softdevice_evt_irq_disable();
sdh_state_observer_notify(NRF_SDH_EVT_STATE_DISABLED);
return NRF_SUCCESS;
ret_code_t nrf_sdh_request_continue(void)
if (!m_nrf_sdh_continue)
return nrf_sdh_disable_request();
else
return nrf_sdh_enable_request();
bool nrf_sdh_is_enabled(void)
return m_nrf_sdh_enabled;
void nrf_sdh_suspend(void)
return;
m_nrf_sdh_suspended = true;
void nrf_sdh_resume(void)
if ((!m_nrf_sdh_suspended) || (!m_nrf_sdh_enabled))
return;
// Force calling ISR again to make sure that events not previously pulled have been processed.
ret_code_t ret_code = sd_nvic_SetPendingIRQ((IRQn_Type)SD_EVT_IRQn);
#else
NVIC_SetPendingIRQ((IRQn_Type)SD_EVT_IRQn);
bool nrf_sdh_is_suspended(void)
return (!m_nrf_sdh_enabled) || (m_nrf_sdh_suspended);
void nrf_sdh_evts_poll(void)
// Notify observers about pending SoftDevice event.
for (nrf_section_iter_init(&iter, &sdh_stack_observers);
nrf_sdh_stack_observer_t * p_observer;
nrf_sdh_stack_evt_handler_t handler;
p_observer = (nrf_sdh_stack_observer_t *) nrf_section_iter_get(&iter);
handler(p_observer->p_context);
#endif // NRF_MODULE_ENABLED(NRF_SDH)
I have deleted all functionality related to DISPATCH model in the nrf_sdh.c file, since this is not relavant to freertos. FreeRTOS relies on interrupt model only and this is not configurable at the moment. With the change nrf_sdh.c, it does not matter what you select in sdk_config.h file as dispatch model is now removed.
Please test this and let me know if it works for you and you understand this.
Somethings wrong:
[00:00:00.000,000] <info> app: Debug logging for UART over RTT started. [00:00:00.000,000] <info> app: erase_bounds is 0 [00:00:00.000,000] <info> app: ram start = 0x200030C0 messages about POHC services being added to the profile... [00:00:00.000,000] <debug> nrf_ble_lesc: Initialized nrf_crypto. [00:00:00.000,000] <debug> nrf_ble_lesc: Initialized nrf_ble_lesc. [00:00:00.000,000] <debug> nrf_ble_lesc: Generating ECC key pair [00:00:00.000,000] <debug> nrf_sdh_freertos: Creating a SoftDevice task. [00:00:00.000,000] <info> app: FreeRTOS starting... [00:00:00.000,000] <debug> nrf_sdh_freertos: Enter softdevice_task. [00:00:00.000,000] <info> app: Starting fast advertising... Following is from another ticket where we added a low priority LESC task; [00:00:00.003,479] <debug> nrf_sdh_freertos: Enter lesc_task. [00:00:01.096,557] <debug> nrf_ble_gatt: Requesting to update ATT MTU to 128 bytes on connection 0x0. [00:00:01.096,557] <debug> nrf_ble_gatt: Updating data length to 132 on connection 0x0. [00:00:01.096,618] <debug> app: DiagnosticsSrv event POHC services report connection events... [00:00:01.096,618] <debug> app: BLE_GAP_EVT_CONNECTED 0 ... [00:00:01.096,618] <info> app: BLE_GAP_EVT_CONNECTED [00:00:01.096,862] <info> app: PM_EVT_CONN_SEC_PARAMS_REQ [00:00:01.103,149] <info> app: PM_EVT_CONN_SEC_START [00:00:01.103,149] <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Encryption, error: 4102 [00:00:01.103,149] <warning> peer_manager_handler: Disconnecting conn_handle 0. [00:00:01.103,149] <info> app: PM_EVT_CONN_SEC_FAILED POHC services report disconnects ... [00:00:01.108,703] <debug> app: StreaminSrv event [00:00:01.108,764] <debug> app: BLE_GAP_EVT_DISCONNECTED 0, reason: 22 [00:00:01.108,764] <info> app: BLE_GAP_EVT_DISCONNECTED
Note that I changed the dispatch model back to interrupts;
// <i> NRF_SDH_DISPATCH_MODEL_INTERRUPT: SoftDevice events are passed to the application from the interrupt context. // <i> NRF_SDH_DISPATCH_MODEL_APPSH: SoftDevice events are scheduled using @ref app_scheduler. // <i> NRF_SDH_DISPATCH_MODEL_POLLING: SoftDevice events are to be fetched manually. // <0=> NRF_SDH_DISPATCH_MODEL_INTERRUPT // <1=> NRF_SDH_DISPATCH_MODEL_APPSH // <2=> NRF_SDH_DISPATCH_MODEL_POLLING #ifndef NRF_SDH_DISPATCH_MODEL #define NRF_SDH_DISPATCH_MODEL 0 #endif
I'll dig in...
It just doesn't work - I think the problem is the removal of any calls to nrf_sdh_evts_poll().
Perhaps NRF_SDH_DISPATCH_MODEL == NRF_SDH_DISPATCH_MODEL_POLLING is better?
For one thing, it offloads nrf_sdh_evts_poll() from the interrupt and allows observers to block.
And perhaps its is better for thread safety? This is based on my assumption that that the nRF5_SDK non-SVC functions, that is functions that don’t begin with “sd_”, are not thread safe, and need to be serialized in a RTOS environment. Is that a good assumption?
If so…
Thread Safety?
In the app_ble_uart example, the dispatch model is NRF_SDH_DISPATCH_MODEL_INTERRUPT; observers are called in the context of an interrupt handler:
// nrf_sdh.c
void SD_EVT_IRQHandler(void) {
nrf_sdh_evts_poll();
In app_ble_hrs_freertos, the dispatch model is NRF_SDH_DISPATCH_MODEL_POLLING; observers are called in the context of a thread (FreeRTOS task):
// nrf_sdh.c
#elif (NRF_SDH_DISPATCH_MODEL == NRF_SDH_DISPATCH_MODEL_POLLING)
#else
// nrf_sdh_freertos.c
BaseType_t yield_req = pdFALSE;
vTaskNotifyGiveFromISR(m_softdevice_task, &yield_req);
portYIELD_FROM_ISR(yield_req);
static void softdevice_task(void* pvParameter) {
if (m_task_hook != NULL)
m_task_hook(pvParameter);
while (true) {
(void) ulTaskNotifyTake(pdTRUE, portMAX_DELAY
Let’s say that I wanted to add other threads to a project using the app_ble_hrs_freertos model, many of which wish to directly update characteristic values. I could add a mutex to the softdevice_thread to serialize access to the SDK BLE functions. Another approach is to use events and or queues for the other threads issue requests to the softdevice_thread(), and have the service thread (only) call the BLE functions. This is a fairly straight forward approach…
However, if I were using NRF_SDH_DISPATCH_MODEL_INTERRUPT, I’d have to use xSemaphoreTakeFromISR() which doesn’t block the ISR – the interrupt might not be able to proceed. This means that I’d have to have special logic to deal with pending operations.
So the polling dispatch model seems more appropriate for an RTOS?
In my head, polling method is used when app has total control/(different logic) on calling nrf_sdh_evts_poll.
But according to you polling is when you create a logic to block and unblock inside a softdevice_task. Which is also 100% correct and is a subset of what i thought polling should be.
Your understanding is correct, calling the event_poll inside SD_EVT irq handler is not a good idea for your use case
