cJSON error
Dear Sir.
I am using the cJSON driver .
When it comes to string it works fine .
However when I use integer and swap the lines
//cJSON_AddStringToObject(root, "payload", payload);
cJSON_AddNumberToObject(root, "payload", 1243);
I can use the debug , The program is halted.
Please Advise.
cJSON * createJsonFromParams(void)
  char * command = "periodic" ;//  "holter"  "holtersm" "spot"   "time"
  char * type  = "12";
//  char * start_time  = "1845";
//  char * duration  = "104";
//  char * rest  = "29";
//  char * stop_time  = "27000";
  char * payload =  "Etrog2020";
//  int * payload = 123456; //"Etrog2020"; //  {0x06,0x05,0x04,0x03,0x02,0x01}; //
//  cJSON *number_item = cJSON_CreateNumber(1942);
  cJSON *root = cJSON_CreateObject();
  cJSON_AddStringToObject(root, "command", command);
  cJSON_AddStringToObject(root, "type", type);
//  cJSON_AddStringToObject(root, "start_time", start_time);
//  cJSON_AddStringToObject(root, "duration", duration);
//  cJSON_AddStringToObject(root, "rest", rest);
//  cJSON_AddStringToObject(root, "stop_time", stop_time);
//  cJSON_AddNumberToObject(root, "payload", 1243);
  return root;
  • Hi.
    I have managed to insert  cJSON_AddNumberToObject .
    However a new error
  • Hi
    This problem is over .
    I added the following lines to prj.conf .
    CONFIG_CJSON_LIB=y
    CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y
    However a new problem that I encounter,
    I do able to produce a JSON string .
    In the string I insert a array , I can't fill the array with data like [12,13,45,234,34,5,99]
    The array is always empty [] ,
    I use the following code.
      char * type  = "8";
    //  char * payload =  "Etrog2020";
       cJSON * payload = cJSON_CreateArray();
       cJSON_AddItemToObject(root,payload, cJSON_CreateNumber(129));
        cJSON_AddItemToArray(payload, cJSON_CreateNumber(33));
        // Write the array "payload" to stream.
        cJSON_AddArrayToObject(root, "payload");
      return root;
    This is the JSON Iget
    Thanks
  • Hi, Ephraim!
    Good that you are progressing. Some comments:
    - One line 22 of your code you are adding a number object to the array in the wrong way, which in itself may cause trouble.
    - On line 27 you are creating an entirely new array. If you want to add the existing array use cJSON_AddItemToObject(root, "payload", payload).
    Anyway, I got this working with the code below:
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    #include <sys/printk.h>
    #include <cJSON.h>
    #include <cJSON_os.h>
    void createJsonFromParams(void)
    	char *command = "periodic"; //  "holter"  "holtersm" "spot"   "time"
    	char *type = "8";
       //cJSON_AddNumberToObject(root, "number", 33);
       cJSON * payload = cJSON_AddArrayToObject(root, "payload");
       printk("%s",cJSON_Print(root));
       cJSON_Delete(root);
    void main(void)
       cJSON_Init();
    	while (1) {
          createJsonFromParams();
    		k_sleep(K_MSEC(5000));
    And the following prj.conf:
    CONFIG_SERIAL=y
    CONFIG_DK_LIBRARY=y
    CONFIG_CJSON_LIB=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_ASSERT=y
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_MAIN_STACK_SIZE=8192
    Note that cJSON_Init is called at the start of main. This enables use and printing of the number object.
    Best regads,
    Carl Richard
  • Hello ,
    I know this topic is old, but I have this problem and apparently this solution is no longer working, could you give another solution to work with numbers through the cJSON lib?
    I have no problem using cJSON_AddItemToObject, I can send strings, but when I try to send any number I find the problem. I have also configured:
    CONFIG_MAIN_STACK_SIZE=16384
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    I inserted all the recommendations both in prj.conf, and in relation to libraries and cJSON_Init at the beginning of main, but I keep getting a Hard Fault, could you check if this solution still works for you? I'm using NCS 1.8.0!
