when debugging peripheral_uart sample in ncs1.5.0 used nrf5340dk board , a error produced in function static int bt_init(void)
int err;
err = hci_init();
if (err) {
return err;
if (IS_ENABLED(CONFIG_BT_CONN)) {
err = bt_conn_init();
if (err) {
return err;
#if defined(CONFIG_BT_PRIVACY)
k_delayed_work_init(&bt_dev.rpa_update, rpa_timeout);
if (IS_ENABLED(CONFIG_BT_SETTINGS)) {
if (!bt_dev.id_count) {
BT_INFO("No ID address. App must call settings_load()");
return 0;
atomic_set_bit(bt_dev.flags, BT_DEV_PRESET_ID);
below shortcut image is debug error
return 0;
prj.conf is below:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
#Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
# Added
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_RX_BUF_LEN=255
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_ATT_TX_MAX=10
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_L2CAP_RX_MTU=247
CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BOOTLOADER_MCUBOOT=y
