SPI Controller initialization error in Zephyr
Description:
I try to initialize a SPI device in my nRF52DK through the Zephyr‘s driver(drivers/spi.h).
Code seems correct when compile and I got no error when build the whole project.
But when turn to debug, SPI can not initialize as expection.I have tried several initializations in my project.
Situation 1: spi1 compatible = "nordic,nrf-spi"; - when debug, the code will stuck at Exception Stack Frame (ESF)
Situation 2: spi1 compatible = "nordic,nrf-spim"; - when debug, the initialization seem to be fail.
Development environments:
1.OS : Ubuntu 20.04
2.NCS in VsCode (sdk:1.7.1)
3.HW:nRF52DK
Attachments(key code):
main.c:
dts file:
  • Could you test the sample <ncs location>/zephyr/tests/drivers/spi/spi_loopback/ with the board nrf52dk_nrf52832. It will apply the configs from nrf52dk_nrf52832.conf and prj.conf. It is a loopback sample and you need to connect MISO to MOSI, and since SPI_1 is used, which uses the pins 29 and 30 as MISO and MOSI by default, you need to connect these together.
    You should get this output if everything works correctly:
    *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    Running test suite test_spi
    START - test_spi_loopback
    I: SPI test on buffers TX/RX 0x200001ad/0x2000095a
    I: SPI test slow config
    I: Start complete multiple
    I: Passed
    I: Start complete loop
    I: Passed
    I: Start null tx
    I: Passed
    I: Start half start
    I: Passed
    I: Start half end
    I: Passed
    I: Start every 4
    I: Passed
    I: Start async call
    I: Passed
    I: SPI test fast config
    I: Passed
    I: Passed
    I: Start null tx
    I: Passed
    I: Start half start
    I: Passed
    I: Start half end
    I: Passed
    I: Start every 4
    I: Passed
    I: Start async call
    I: Passed
    I: Passed
    I: Passed
    I: All tx/rx passed
     PASS - test_spi_loopback in 0.60 seconds
    Test suite test_spi succeeded
    PROJECT EXECUTION SUCCESSFUL
    When you get this to work, you can inspect the code to get an understanding of how to use the SPI in NCS/zephyr and remove everything related to testing.
    I see that the compatible "nordic,nrf-spi" is used by default for the spi1. If you want to use SPI with EasyDMA (and the compatible "nordic,nrf-spim") you need to enable CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58, see the following note:
    https://github.com/nrfconnect/sdk-zephyr/blob/83f7974bc454e7ff719bd0f32c2ce45317b5c7e7/drivers/spi/Kconfig.nrfx#L39-L41
    Simon
  • Hi, Simon.
    I have tested the example your mentioned, it works well.
    In the aspect of compatible "nrf-spi"&"nrf-spim", I enabled the CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58 in the condition "nrf-spim",it works.
    But in the condition "nrf-spi" , the code will still stuck at Exception Stack Frame (ESF) when debug(as post before).
    Thanks for your help.
    Yida
