nRF9160, SLM Firmware behaves incorrectly after activating Native TLS (critical problems)
We managed to build and flash SLM (SDK 2.1.2) with Native TLS.
To be able to download about 5Kb of data at one time (from AWS broker).
But not everything works fine, we have several critical problems with this build:
1) First, We can't check certificates, the same we did it before.
Previously, I used commands like this (321, is our internal secure tag):
- AT%CMNG=1,321,0 (For check exists the CA certificate);
- AT%CMNG=1,321,1 (For check exists the Client certificate);
- AT%CMNG=1,321,2  (For check exists the Private Key);
But after moving to Native TLC, and generating the new certificates (via commands like the AT#XCMNG=0,321,0...), We see other certificates by AT%CMNG=1 command:
%CMNG: 3210,0,"AD6FB002E6B34C0559FA8F93A3794FF12C4E3F119BD77290C52525123FB9EA74"
%CMNG: 3211,0,"EA89F71E2A945D88A7A71C3C35D2F3BA5466B0ACEC750270134F511FB0CB4143"
%CMNG: 3212,0,"EB569D288E10B1D9D5B1BD45642AD4B8D063E0C48584A6C3A7A700987D671B68"
Can I use them to verify the CA, Client and private key?
- AT%CMNG=1,3210,0 (For CA);
- AT%CMNG=1,3211,0 (For Client);
- AT%CMNG=1,3212,0 (For check exist the Private Key).
2) Second: We lost access to nRF Cloud.
All commands for working with CMNG had to be changed (was AT%CMNG became AT#XCMNG), and it helped for access to AWS broker, but not to nRF Cloud.
Our previous certificates don't work more (with Native TLS).
I tried to reinstall them using the #XCMNG AT command, but that didn't work.
AT commands and answers look fine.
Maybe this is due to the generation and installation of a private key, we use:
AT%KEYGEN=16842753,2,0\r\n
But after using the
AT%KEYGEN=16842753,2,0\r\n, followed by saving the CA/Client certificates, we have the next results (every install certificate command returned OK):
[7/12 17:55:04:025] %CMNG: 16842753,2,"7494C435C484599577AB9B04E85DD594C5B5C9676750CA6DA17284E99A93B9C7"
[7/12 17:55:04:025] %CMNG: 168427530,0,"AD6FB002E6B34C0559FA8F93A3794FF12C4E3F119BD77290C52525123FB9EA74"
[7/12 17:55:04:025] %CMNG: 168427531,0,"D12494EF17B635B10A7511A513CB37B3101D58008ADE0D4BAA381D85A63DA675"
But if we tried to connect to nRF Cloud nothing happened.
We didn't have some ERROR or Event about the nRF Cloud connection.
We received the OK after about 900ms and CSCON: 0 after 6 seconds.
What are we doing wrong with nRF Cloud access now? Is it still because of the  AT%KEYGEN=16842753,2,0  AT command?
3) Third: Something happening with MQTT Disconnect:
After AT#XMQTTCON=0 we received a weird answer (\r\n) and nRF Reset.
AT#XMQTTCON=0
 Ready
    Sorry for the delayed answer here. I am looking into the issue on my side. Will get back to you within tomorrow.
    Øyvind
  • Hello, I've had some issues with my application not allowing to connect to AWS. Trying to find the solution to this first.
    No, the XCMNG command does not support the list or read functionality.
    What do you get when trying to connect to nRF Cloud? Make sure to disable CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID in prj.conf, i.e. setting
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=n.
    You did not receive #XMQTTEVT: 1,0 ?
    Øyvind
  • Hi ,
    But then why after generating new certificates (via commands like the AT#XCMNG=0,321,0...) I see new certificate entries with our security tag ?
    The CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID was activated (in prj.conf file).
    I will recheck without this definition.
    When we execute the command to connect to the nRF cloud, nothing happens, we do not receive anything via UART, and there is no ERROR message or notification of the connection status from the cloud.
    No, we don't get the notification like (#XMQTTEVT: 1,0) via UART, only characters (sometimes it looks like a few characters that don't make sense), and immediately comes "Ready".
    As you can see the security tag is not listed with correct type. The when you use the AT#XCMNG command, it will generate a sec_tag that is your sec_tag * 10 + type. In your case this is 3210, 3211 and 3212, which are all stored as type Root CA certificate. When reading a sec_tag in your native TLS enabled application, the application will handle the mapped sec_tag through the slm_native_tls.x/.h
    The ceritificates that are used by native TLS are not stored in sec_tag 321, but 3210, 3211 and 3212.
    What terminal are you using when trying this? Are you using LTE Link Monitor or e.g. PuTTy? Are you connected directly to the nRF9160 or using an external MCU?
    This sounds like an issue with the communication to the nRF9160 e.g. bad buadrate or similar. What do you receive in RTT?
    -Øyvind
    Sorry my answer was unclear. To clarify, you can use %CMNG to read 3210, 3211 and 3212
    AT%CMNG=1,3210,0
    AT%CMNG=1,3211,0
    AT%CMNG=1,3212,0
