How much of the nRF5340 Shared RAM segment (0x2007000 - 0x207FFFF) does the Nordic BLE Soft Controller require?
We are using the nRF5340 in a multi-protocol application where we use the BLE Soft Controller in one mode and a proprietary protocol in another mode. Both protocols use the Shared RAM in region 0x20070000 - 0x2007FFFF for message and data exchange between their Hosts on the Application CPU and Controllers on the Network CPU.
We currently have 56 kBytes allocated to the Soft Controller (0x20070000 - 0x2007DFFF) and 8 kBytes allocated to our proprietary protocol (0x2007E000-0x2007FFFF). We have run out of space in this allocation for the proprietary protocol and would like to increase it by maybe 4 kBytes.
The question is what is the minimum Shared RAM allocation that the BLE soft controller needs? Our most intensive usage of the BLE soft controller configures it as a peripheral and GATT server. The Kconfig overlay for this configuration is attached.
Thank you,
Kevin
overlay-ble.conf
    Where did you set the allocated SoftDevice controller size, and the proprietary protocol size? I will run this by our SoftDevice team, but I would like to just understand a bit more in detail what you already did before reaching out.
    Edvin
  • From our devicetree:
       reserved-memory {
          /delete-node/ memory@20070000;
          sram_ipc0: memory@20070000 { /* BT HCI rmsgs */
             reg = <0x20070000 0xE000>;
          sram_ipc1: memory@2007E000 {
             reg = <0x2007E000 0x1000>;
            sram_shula: memory@2007F000 {
                compatible = "zephyr,memory-region", "mmio-sram";
                zephyr,memory-region = "SRAMSHULA";
                reg = <0x2007F000 0x1000>;
       ipc {
          /delete-node/ ipc0;
          ipc0: ipc0 {
             compatible = "zephyr,ipc-openamp-static-vrings";
             memory-region = <&sram_ipc0>;
             mboxes = <&mbox 0>, <&mbox 1>;
             mbox-names = "tx", "rx";
             role = "host";
             status = "okay";
          ipc1: ipc1 {
             memory-region = <&sram_ipc1>;
             mboxes = <&mbox 2>, <&mbox 3>;
             role = "host";
             zephyr,priority = <1 PRIO_COOP>;
             status = "okay";
  • Thank you for the details. I have not yet found anyone who can say what a recommended minimum should be, but someone pointed out that the distance measurement sample in NCS is using even less sram for the softdevice controller:
    It is using 20070000 -> 20077FFF for the SoftDevice Controller, and 0x20078000->2007FFFF for the proprietary distance measurement library.
    Please see the nrf5340dk_nrf5340_cpuapp.overlay and nrf5340dk_nrf5340_cpunet.overlay files for the nrf_dm sample.
    Edvin
  • I'm not very familiar with the distance measurement sample, but it seems that the GATT traffic from the server to the client uses infrequent and small-sized PDUs.  Our case is the opposite.  Isn't there a relationship to the MTU size, data length size, ACL tx/rx size, and buffer counts to the amount of SRAM used by the SoftDevice Controller?
  • I would assume it is, but I am not sure how quickly the cores will pick up the data from the SRAM. A BLE packet still ranges from somewhere between 20 bytes to 250 bytes, so still nowhere near the 50kBytes that are reserved by default. That being said, I am not sure how long the data needs to live in the SRAM, and hence, how much SRAM that is required.
    But if you have no other option than increasing the part for the proprietary part, then you need to decrease the softdevice SRAM. I would think it is fine, as you do not reduce it that much (in %).
    Edvin
