TC-CNET-4.10 Test step 11 timeout.
      Our product is about to undergo Matter certification. However, in the testing of TC-CNET-4.10, during the 11th step " ./chip-tool generalcommissioning arm-fail-safe 0 0 1 0", there is a timeout error indicating that the command is not responding. However, when executing it immediately for the second time, it succeeds. This phenomenon is consistently reproducible. Can you provide any guidance on how to resolve this issue? We are anxious to proceed with the product testing.
      I'm urgently looking forward to your reply.
      Jerry.
      22/8/2023
  • Here is the TC-CNET-4.10 chip-tool log :
    ubuntu@ubuntu:~/apps$  ./chip-tool pairing ble-thread 1 hex:0e080000000000010000000300000b35060004001fffe00208695e3bcb08b969680708fd4b099dfa29a57605102b7b7e3d9d0214478ebd7841d79fd392030f4f70656e5468726561642d31303638010210680410725655edc0397183a85837c6ca5703390c0402a0f7f8 89739020 2886 --paa-trust-store-path "/var/paa-root-certs" --trace_decode 1
    [1692344199.655654][79150:79150] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692344199.661062][79150:79150] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692344199.661347][79150:79150] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692344199.661479][79150:79150] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692344199.661833][79150:79150] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-cERONc)
    [1692344199.662475][79150:79150] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692344199.662530][79150:79150] CHIP:DL: NVS set: chip-counters/reboot-count = 16 (0x10)
    [1692344199.663446][79150:79150] CHIP:DL: Got Ethernet interface: eth0
    [1692344199.664030][79150:79150] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692344199.664616][79150:79150] CHIP:DL: Got WiFi interface: wlan0
    [1692344199.664678][79150:79150] CHIP:DL: Failed to reset WiFi statistic counts
    [1692344199.664729][79150:79150] CHIP:IN: UDP::Init bind&listen port=0
    [1692344199.664850][79150:79150] CHIP:IN: UDP::Init bound to port=46912
    [1692344199.664871][79150:79150] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692344199.664888][79150:79150] CHIP:IN: TransportMgr initialized
    [1692344199.664920][79150:79150] CHIP:FP: Initializing FabricTable from persistent storage
    [1692344199.665108][79150:79150] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692344199.666652][79150:79150] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692344199.667144][79150:79150] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692344199.669547][79150:79150] CHIP:ZCL: Using ZAP configuration...
    [1692344199.673071][79150:79150] CHIP:DL: Avahi client registered
    [1692344199.674121][79150:79150] CHIP:CTL: System State Initialized...
    [1692344199.879657][79150:79150] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692344199.879744][79150:79150] CHIP:CTL: Setting attestation nonce to random value
    [1692344199.879796][79150:79150] CHIP:CTL: Setting CSR nonce to random value
    [1692344199.880083][79150:79152] CHIP:DL: CHIP task running
    [1692344199.880283][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692344199.880560][79150:79152] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692344199.880601][79150:79152] CHIP:CTL: Setting attestation nonce to random value
    [1692344199.880751][79150:79152] CHIP:CTL: Setting CSR nonce to random value
    [1692344199.881511][79150:79152] CHIP:CTL: Generating NOC
    [1692344199.882476][79150:79152] CHIP:FP: Validating NOC chain
    [1692344199.884079][79150:79152] CHIP:FP: NOC chain validation successful
    [1692344199.884224][79150:79152] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692344199.884254][79150:79152] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692344199.884273][79150:79152] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692344199.884290][79150:79152] CHIP:TS: Retaining current Last Known Good Time
    [1692344199.890946][79150:79152] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692344199.893559][79150:79152] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692344199.896344][79150:79152] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692344199.917469][79150:79152] CHIP:CTL: Setting thread operational dataset from parameters
    [1692344199.917517][79150:79152] CHIP:CTL: Setting attestation nonce to random value
    [1692344199.917658][79150:79152] CHIP:CTL: Setting CSR nonce to random value
    [1692344199.917696][79150:79152] CHIP:CTL: Commission called for node ID 0x0000000000000001
    [1692344199.921985][79150:79151] CHIP:DL: TRACE: Bus acquired for name C-352e
    [1692344199.934204][79150:79152] CHIP:DL: PlatformBlueZInit init success
    [1692344199.943593][79150:79151] CHIP:BLE: BLE removing known devices.
    [1692344199.945344][79150:79151] CHIP:BLE: BLE initiating scan.
    [1692344199.955527][79150:79151] CHIP:BLE: Device 05:23:A9:68:8B:18 does not look like a CHIP device.
    [1692344199.963698][79150:79151] CHIP:BLE: Device 34:5B:29:16:75:B6 does not look like a CHIP device.
    [1692344199.967406][79150:79151] CHIP:BLE: Device 6C:D3:EE:61:20:42 does not look like a CHIP device.
    [1692344199.968856][79150:79151] CHIP:BLE: Device 6E:02:E0:21:79:69 does not look like a CHIP device.
    [1692344199.984536][79150:79151] CHIP:BLE: Device 50:20:E5:FA:CC:FF does not look like a CHIP device.
    [1692344199.986141][79150:79151] CHIP:BLE: Device 02:24:2A:4B:37:31 does not look like a CHIP device.
    [1692344199.991781][79150:79151] CHIP:BLE: Device F6:BE:A8:60:09:D4 does not look like a CHIP device.
    [1692344200.003238][79150:79151] CHIP:BLE: Device 72:B3:36:6A:2B:82 does not look like a CHIP device.
    [1692344200.013412][79150:79151] CHIP:BLE: New device scanned: FD:6C:6B:84:BB:37
    [1692344200.013479][79150:79151] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1692344200.655265][79150:79151] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: le-connection-abort-by-local (36)
    [1692344201.010385][79150:79151] CHIP:DL: ConnectDevice complete
    [1692344202.494986][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495047][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495085][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495112][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495155][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495182][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495210][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495235][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495264][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495289][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495322][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495347][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495375][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495400][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495428][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495453][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495489][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495515][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495543][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495568][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495596][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0001
    [1692344202.495620][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495652][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495677][79150:79151] CHIP:DL: Char1 /org/bluez/hci0/dev_FD_6C_6B_84_BB_37/service0010
    [1692344202.495713][79150:79151] CHIP:DL: New BLE connection 0xffffa4056040, device FD:6C:6B:84:BB:37, path /org/bluez/hci0/dev_FD_6C_6B_84_BB_37
    [1692344202.495855][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1692344202.495899][79150:79152] CHIP:DIS: Closing all BLE connections
    [1692344202.495964][79150:79152] CHIP:IN: BleConnectionComplete: endPoint 0xaaaae05b01f8
    [1692344202.496173][79150:79152] CHIP:IN: SecureSession[0xffff9c01cf00]: Allocated Type:1 LSID:56692
    [1692344202.496218][79150:79152] CHIP:SC: Assigned local session key ID 56692
    [1692344202.496574][79150:79152] CHIP:EM: <<< [E:51300i S:0 M:131879877] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1692344202.496647][79150:79152] CHIP:IN: (U) Sending msg 131879877 to IP address 'BLE'
    [1692344202.496933][79150:79152] CHIP:DMG: >> to BLE | 131879877 | [Secure Channel  (0) / Password-Based Key Derivation Parameters Request (0x20) / Session = 0 / Exchange = 51300]
    [1692344202.497111][79150:79152] CHIP:DMG: Header Flags =
    [1692344202.497141][79150:79152] CHIP:DMG: {
    [1692344202.497179][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344202.497206][79150:79152] CHIP:DMG:     {
    [1692344202.497233][79150:79152] CHIP:DMG:         SourceNodeId = 3A8F2142DECBD059
    [1692344202.497259][79150:79152] CHIP:DMG:     }
    [1692344202.497294][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344202.497321][79150:79152] CHIP:DMG:     {
    [1692344202.497344][79150:79152] CHIP:DMG:         Initiator = true
    [1692344202.497368][79150:79152] CHIP:DMG:     }
    [1692344202.497401][79150:79152] CHIP:DMG: }
    [1692344202.497426][79150:79152] CHIP:DMG:
    [1692344202.497460][79150:79152] CHIP:DMG: Encrypted Payload (68 bytes) =
    [1692344202.497486][79150:79152] CHIP:DMG: {
    [1692344202.497511][79150:79152] CHIP:DMG:     data = 04000000c553dc0759d0cbde42218f3a012064c800001530012088945430b451d7201397edf4c0167fea6e94660e6f0247d55682d59f35801762250274dd240300280418
    [1692344202.497537][79150:79152] CHIP:DMG:     buffer_ptr = 281473299036288
    [1692344202.497561][79150:79152] CHIP:DMG: }
    [1692344202.497584][79150:79152] CHIP:DMG:
    [1692344202.497620][79150:79152] CHIP:DMG: Decrypted Payload (46 bytes) =
    [1692344202.497646][79150:79152] CHIP:DMG: {
    [1692344202.497670][79150:79152] CHIP:DMG:     data = 1530012088945430b451d7201397edf4c0167fea6e94660e6f0247d55682d59f35801762250274dd240300280418
    [1692344202.497696][79150:79152] CHIP:DMG: }
    [1692344202.497719][79150:79152] CHIP:DMG:
    [1692344202.497777][79150:79152] CHIP:DMG: Parameters =
    [1692344202.497803][79150:79152] CHIP:DMG: {
    [1692344202.497847][79150:79152] CHIP:DMG:     Initiator Random (32) = 88945430B451D7201397EDF4C0167FEA6E94660E6F0247D55682D59F35801762
    [1692344202.497875][79150:79152] CHIP:DMG:     Initiator Session Id = 56692
    [1692344202.497900][79150:79152] CHIP:DMG:     Passcode Id = 0
    [1692344202.497924][79150:79152] CHIP:DMG:     hasPBKDFParameters = false
    [1692344202.497951][79150:79152] CHIP:DMG: }
    [1692344202.497975][79150:79152] CHIP:DMG:
    [1692344202.497999][79150:79152] CHIP:DMG:
    [1692344202.498053][79150:79152] CHIP:IN: Message appended to BLE send queue
    [1692344202.498128][79150:79152] CHIP:SC: Sent PBKDF param request
    [1692344202.942165][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344203.033274][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1692344203.033365][79150:79152] CHIP:BLE: subscribe complete, ep = 0xaaaae05b01f8
    [1692344203.033696][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344203.033923][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344203.034035][79150:79152] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1692344203.034273][79150:79152] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1692344203.034325][79150:79152] CHIP:BLE: local and remote recv window size = 5
    [1692344203.034559][79150:79152] CHIP:IN: BLE EndPoint 0xaaaae05b01f8 Connection Complete
    [1692344203.167567][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344203.170052][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344203.170355][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344203.171391][79150:79152] CHIP:DMG: << from BLE | 205208468 | [Secure Channel  (0) / Password-Based Key Derivation Parameters Response (0x21) / Session = 0 / Exchange = 51300]
    [1692344203.171490][79150:79152] CHIP:DMG: Header Flags =
    [1692344203.171543][79150:79152] CHIP:DMG: {
    [1692344203.171612][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344203.171667][79150:79152] CHIP:DMG:     {
    [1692344203.171723][79150:79152] CHIP:DMG:         DestinationNodeId = 3A8F2142DECBD059
    [1692344203.171773][79150:79152] CHIP:DMG:     }
    [1692344203.171854][79150:79152] CHIP:DMG: }
    [1692344203.171905][79150:79152] CHIP:DMG:
    [1692344203.171998][79150:79152] CHIP:DMG: Encrypted Payload (151 bytes) =
    [1692344203.172051][79150:79152] CHIP:DMG: {
    [1692344203.172101][79150:79152] CHIP:DMG:     data = 01000000943b3b0c59d0cbde42218f3a002164c800001530012088945430b451d7201397edf4c0167fea6e94660e6f0247d55682d59f35801762300220be882320bb8c290a3ae70fc8fc8ea1f843b8c22f33a81de97b234f55b587df2325037b4a35042501983a300220d7c50a59f49e326864b16da24f0ad471d6a39b9e25015835b8bc972d581ce3f01835052501f00a2502e8031818
    [1692344203.172158][79150:79152] CHIP:DMG:     buffer_ptr = 281473299114976
    [1692344203.172208][79150:79152] CHIP:DMG: }
    [1692344203.172275][79150:79152] CHIP:DMG:
    [1692344203.172351][79150:79152] CHIP:DMG: Decrypted Payload (129 bytes) =
    [1692344203.172404][79150:79152] CHIP:DMG: {
    [1692344203.172454][79150:79152] CHIP:DMG:     data = 1530012088945430b451d7201397edf4c0167fea6e94660e6f0247d55682d59f35801762300220be882320bb8c290a3ae70fc8fc8ea1f843b8c22f33a81de97b234f55b587df2325037b4a35042501983a300220d7c50a59f49e326864b16da24f0ad471d6a39b9e25015835b8bc972d581ce3f01835052501f00a2502e8031818
    [1692344203.172508][79150:79152] CHIP:DMG: }
    [1692344203.172555][79150:79152] CHIP:DMG:
    [1692344203.172673][79150:79152] CHIP:DMG: Parameters =
    [1692344203.172756][79150:79152] CHIP:DMG: {
    [1692344203.172813][79150:79152] CHIP:DMG:     Initiator Random (32) = 88945430B451D7201397EDF4C0167FEA6E94660E6F0247D55682D59F35801762
    [1692344203.172871][79150:79152] CHIP:DMG:     Responder Random (32) = BE882320BB8C290A3AE70FC8FC8EA1F843B8C22F33A81DE97B234F55B587DF23
    [1692344203.172923][79150:79152] CHIP:DMG:     Responder Session Id = 19067
    [1692344203.172981][79150:79152] CHIP:DMG:     Iteration Count = 15000
    [1692344203.173069][79150:79152] CHIP:DMG:     Salt (32) = D7C50A59F49E326864B16DA24F0AD471D6A39B9E25015835B8BC972D581CE3F0
    [1692344203.173132][79150:79152] CHIP:DMG:     SED =
    [1692344203.173182][79150:79152] CHIP:DMG:     {
    [1692344203.173236][79150:79152] CHIP:DMG:         Idle Retransmit Timeout = 2800
    [1692344203.173291][79150:79152] CHIP:DMG:         Active Retransmit Timeout = 1000
    [1692344203.173345][79150:79152] CHIP:DMG:     }
    [1692344203.173418][79150:79152] CHIP:DMG: }
    [1692344203.173464][79150:79152] CHIP:DMG:
    [1692344203.173512][79150:79152] CHIP:DMG:
    [1692344203.173592][79150:79152] CHIP:DMG: Additional Fields =
    [1692344203.173646][79150:79152] CHIP:DMG: {
    [1692344203.173700][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344203.173752][79150:79152] CHIP:DMG: }
    [1692344203.173823][79150:79152] CHIP:DMG:
    [1692344203.173894][79150:79152] CHIP:EM: >>> [E:51300i S:0 M:205208468] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1692344203.173966][79150:79152] CHIP:EM: Found matching exchange: 51300i, Delegate: 0xffff9c00f0d0
    [1692344203.174063][79150:79152] CHIP:SC: Received PBKDF param response
    [1692344203.174220][79150:79152] CHIP:SC: Peer assigned session ID 19067
    [1692344203.174294][79150:79152] CHIP:SC: Found MRP parameters in the message
    [1692344203.251023][79150:79152] CHIP:EM: <<< [E:51300i S:0 M:131879878] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1692344203.251095][79150:79152] CHIP:IN: (U) Sending msg 131879878 to IP address 'BLE'
    [1692344203.251282][79150:79152] CHIP:DMG: >> to BLE | 131879878 | [Secure Channel  (0) / Password Authenticated Session Establishment '1' (0x22) / Session = 0 / Exchange = 51300]
    [1692344203.251318][79150:79152] CHIP:DMG: Header Flags =
    [1692344203.251336][79150:79152] CHIP:DMG: {
    [1692344203.251360][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344203.251377][79150:79152] CHIP:DMG:     {
    [1692344203.251395][79150:79152] CHIP:DMG:         SourceNodeId = 3A8F2142DECBD059
    [1692344203.251412][79150:79152] CHIP:DMG:     }
    [1692344203.251436][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344203.251473][79150:79152] CHIP:DMG:     {
    [1692344203.251488][79150:79152] CHIP:DMG:         Initiator = true
    [1692344203.251505][79150:79152] CHIP:DMG:     }
    [1692344203.251528][79150:79152] CHIP:DMG: }
    [1692344203.251544][79150:79152] CHIP:DMG:
    [1692344203.251568][79150:79152] CHIP:DMG: Encrypted Payload (92 bytes) =
    [1692344203.251594][79150:79152] CHIP:DMG: {
    [1692344203.251612][79150:79152] CHIP:DMG:     data = 04000000c653dc0759d0cbde42218f3a012264c80000153001410479e9e9a3eb54ae63f6dcb2d6b729e0b643b08160aab3558a916f7d37bf559deb6c2708b1034b65bdda64c81e487717c56bbb4cf7e8124485e1c252920f277dc518
    [1692344203.251630][79150:79152] CHIP:DMG:     buffer_ptr = 187651732855296
    [1692344203.251646][79150:79152] CHIP:DMG: }
    [1692344203.251662][79150:79152] CHIP:DMG:
    [1692344203.251687][79150:79152] CHIP:DMG: Decrypted Payload (70 bytes) =
    [1692344203.251704][79150:79152] CHIP:DMG: {
    [1692344203.251731][79150:79152] CHIP:DMG:     data = 153001410479e9e9a3eb54ae63f6dcb2d6b729e0b643b08160aab3558a916f7d37bf559deb6c2708b1034b65bdda64c81e487717c56bbb4cf7e8124485e1c252920f277dc518
    [1692344203.251749][79150:79152] CHIP:DMG: }
    [1692344203.251764][79150:79152] CHIP:DMG:
    [1692344203.251806][79150:79152] CHIP:DMG: Parameters =
    [1692344203.251825][79150:79152] CHIP:DMG: {
    [1692344203.251846][79150:79152] CHIP:DMG:     pA (65) = 0479E9E9A3EB54AE63F6DCB2D6B729E0B643B08160AAB3558A916F7D37BF559DEB6C2708B1034B65BDDA64C81E487717C56BBB4CF7E8124485E1C252920F277DC5
    [1692344203.251864][79150:79152] CHIP:DMG: }
    [1692344203.251889][79150:79152] CHIP:DMG:
    [1692344203.251906][79150:79152] CHIP:DMG:
    [1692344203.252039][79150:79152] CHIP:SC: Sent spake2p msg1
    [1692344203.301907][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.239325][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.239573][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.240523][79150:79152] CHIP:DMG: << from BLE | 205208469 | [Secure Channel  (0) / Password Authenticated Session Establishment '2' (0x23) / Session = 0 / Exchange = 51300]
    [1692344205.240609][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.240656][79150:79152] CHIP:DMG: {
    [1692344205.240714][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344205.240760][79150:79152] CHIP:DMG:     {
    [1692344205.240808][79150:79152] CHIP:DMG:         DestinationNodeId = 3A8F2142DECBD059
    [1692344205.240852][79150:79152] CHIP:DMG:     }
    [1692344205.240921][79150:79152] CHIP:DMG: }
    [1692344205.240964][79150:79152] CHIP:DMG:
    [1692344205.241043][79150:79152] CHIP:DMG: Encrypted Payload (127 bytes) =
    [1692344205.241088][79150:79152] CHIP:DMG: {
    [1692344205.241131][79150:79152] CHIP:DMG:     data = 01000000953b3b0c59d0cbde42218f3a002364c8000015300141048c4eba842b0bfd664d3d4cb0bb1740dd1c0c5cf6ca98661a615ae65478b349b41ee4dafc221b6c5adf5fbfc01bb2e34fab24b31154cb17396ae17f822215db1b30022080ccdedd38c1e5258837f2a1b2eabffff8895cc26e334213fba1b7bfc5afa68e18
    [1692344205.241182][79150:79152] CHIP:DMG:     buffer_ptr = 281473299114976
    [1692344205.241223][79150:79152] CHIP:DMG: }
    [1692344205.241283][79150:79152] CHIP:DMG:
    [1692344205.241344][79150:79152] CHIP:DMG: Decrypted Payload (105 bytes) =
    [1692344205.241389][79150:79152] CHIP:DMG: {
    [1692344205.241430][79150:79152] CHIP:DMG:     data = 15300141048c4eba842b0bfd664d3d4cb0bb1740dd1c0c5cf6ca98661a615ae65478b349b41ee4dafc221b6c5adf5fbfc01bb2e34fab24b31154cb17396ae17f822215db1b30022080ccdedd38c1e5258837f2a1b2eabffff8895cc26e334213fba1b7bfc5afa68e18
    [1692344205.241476][79150:79152] CHIP:DMG: }
    [1692344205.241535][79150:79152] CHIP:DMG:
    [1692344205.241638][79150:79152] CHIP:DMG: Parameters =
    [1692344205.241685][79150:79152] CHIP:DMG: {
    [1692344205.241737][79150:79152] CHIP:DMG:     pB (65) = 048C4EBA842B0BFD664D3D4CB0BB1740DD1C0C5CF6CA98661A615AE65478B349B41EE4DAFC221B6C5ADF5FBFC01BB2E34FAB24B31154CB17396AE17F822215DB1B
    [1692344205.241789][79150:79152] CHIP:DMG:     cB (32) = 80CCDEDD38C1E5258837F2A1B2EABFFFF8895CC26E334213FBA1B7BFC5AFA68E
    [1692344205.241832][79150:79152] CHIP:DMG: }
    [1692344205.241891][79150:79152] CHIP:DMG:
    [1692344205.241935][79150:79152] CHIP:DMG:
    [1692344205.242001][79150:79152] CHIP:DMG: Additional Fields =
    [1692344205.242048][79150:79152] CHIP:DMG: {
    [1692344205.242152][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344205.242197][79150:79152] CHIP:DMG: }
    [1692344205.242238][79150:79152] CHIP:DMG:
    [1692344205.242324][79150:79152] CHIP:EM: >>> [E:51300i S:0 M:205208469] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1692344205.242383][79150:79152] CHIP:EM: Found matching exchange: 51300i, Delegate: 0xffff9c00f0d0
    [1692344205.242470][79150:79152] CHIP:SC: Received spake2p msg2
    [1692344205.245613][79150:79152] CHIP:EM: <<< [E:51300i S:0 M:131879879] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1692344205.245720][79150:79152] CHIP:IN: (U) Sending msg 131879879 to IP address 'BLE'
    [1692344205.246177][79150:79152] CHIP:DMG: >> to BLE | 131879879 | [Secure Channel  (0) / Password Authenticated Session Establishment '3' (0x24) / Session = 0 / Exchange = 51300]
    [1692344205.246259][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.246304][79150:79152] CHIP:DMG: {
    [1692344205.246364][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344205.246408][79150:79152] CHIP:DMG:     {
    [1692344205.246482][79150:79152] CHIP:DMG:         SourceNodeId = 3A8F2142DECBD059
    [1692344205.246526][79150:79152] CHIP:DMG:     }
    [1692344205.246587][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344205.246631][79150:79152] CHIP:DMG:     {
    [1692344205.246689][79150:79152] CHIP:DMG:         Initiator = true
    [1692344205.246733][79150:79152] CHIP:DMG:     }
    [1692344205.246789][79150:79152] CHIP:DMG: }
    [1692344205.246832][79150:79152] CHIP:DMG:
    [1692344205.246887][79150:79152] CHIP:DMG: Encrypted Payload (59 bytes) =
    [1692344205.246953][79150:79152] CHIP:DMG: {
    [1692344205.246995][79150:79152] CHIP:DMG:     data = 04000000c753dc0759d0cbde42218f3a012464c8000015300120b5fbacb0bab58b5dc7f03304948d48da39cfa1ce8532d47bfe93ac1116b7bfd418
    [1692344205.247041][79150:79152] CHIP:DMG:     buffer_ptr = 281473298994464
    [1692344205.247082][79150:79152] CHIP:DMG: }
    [1692344205.247122][79150:79152] CHIP:DMG:
    [1692344205.247207][79150:79152] CHIP:DMG: Decrypted Payload (37 bytes) =
    [1692344205.247252][79150:79152] CHIP:DMG: {
    [1692344205.247294][79150:79152] CHIP:DMG:     data = 15300120b5fbacb0bab58b5dc7f03304948d48da39cfa1ce8532d47bfe93ac1116b7bfd418
    [1692344205.247336][79150:79152] CHIP:DMG: }
    [1692344205.247376][79150:79152] CHIP:DMG:
    [1692344205.247472][79150:79152] CHIP:DMG: Parameters =
    [1692344205.247520][79150:79152] CHIP:DMG: {
    [1692344205.247569][79150:79152] CHIP:DMG:     cA (32) = B5FBACB0BAB58B5DC7F03304948D48DA39CFA1CE8532D47BFE93AC1116B7BFD4
    [1692344205.247612][79150:79152] CHIP:DMG: }
    [1692344205.247652][79150:79152] CHIP:DMG:
    [1692344205.247694][79150:79152] CHIP:DMG:
    [1692344205.247918][79150:79152] CHIP:SC: Sent spake2p msg3
    [1692344205.327407][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.328957][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.329186][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.330171][79150:79152] CHIP:DMG: << from BLE | 205208470 | [Secure Channel  (0) / Status Report (0x40) / Session = 0 / Exchange = 51300]
    [1692344205.330270][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.330323][79150:79152] CHIP:DMG: {
    [1692344205.330390][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344205.330444][79150:79152] CHIP:DMG:     {
    [1692344205.330498][79150:79152] CHIP:DMG:         DestinationNodeId = 3A8F2142DECBD059
    [1692344205.330549][79150:79152] CHIP:DMG:     }
    [1692344205.330630][79150:79152] CHIP:DMG: }
    [1692344205.330682][79150:79152] CHIP:DMG:
    [1692344205.330772][79150:79152] CHIP:DMG: Encrypted Payload (30 bytes) =
    [1692344205.330825][79150:79152] CHIP:DMG: {
    [1692344205.330874][79150:79152] CHIP:DMG:     data = 01000000963b3b0c59d0cbde42218f3a004064c800000000000000000000
    [1692344205.330923][79150:79152] CHIP:DMG:     buffer_ptr = 281473299114976
    [1692344205.330972][79150:79152] CHIP:DMG: }
    [1692344205.331041][79150:79152] CHIP:DMG:
    [1692344205.331112][79150:79152] CHIP:DMG: Decrypted Payload (8 bytes) =
    [1692344205.331164][79150:79152] CHIP:DMG: {
    [1692344205.331212][79150:79152] CHIP:DMG:     data = 0000000000000000
    [1692344205.331261][79150:79152] CHIP:DMG: }
    [1692344205.331332][79150:79152] CHIP:DMG:
    [1692344205.331402][79150:79152] CHIP:DMG: Parameters =
    [1692344205.331454][79150:79152] CHIP:DMG: {
    [1692344205.331502][79150:79152] CHIP:DMG:     GeneralStatusCode = 0
    [1692344205.331552][79150:79152] CHIP:DMG:     ProtocolId = 0
    [1692344205.331630][79150:79152] CHIP:DMG:     ProtocolCode = 0
    [1692344205.331681][79150:79152] CHIP:DMG: }
    [1692344205.331727][79150:79152] CHIP:DMG:
    [1692344205.331775][79150:79152] CHIP:DMG:
    [1692344205.331850][79150:79152] CHIP:DMG: Additional Fields =
    [1692344205.331908][79150:79152] CHIP:DMG: {
    [1692344205.331942][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344205.331972][79150:79152] CHIP:DMG: }
    [1692344205.331997][79150:79152] CHIP:DMG:
    [1692344205.332041][79150:79152] CHIP:EM: >>> [E:51300i S:0 M:205208470] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692344205.332099][79150:79152] CHIP:EM: Found matching exchange: 51300i, Delegate: 0xffff9c00f0d0
    [1692344205.332463][79150:79152] CHIP:SC: SecureSession[0xffff9c01cf00]: Moving from state 'kEstablishing' --> 'kActive'
    [1692344205.332510][79150:79152] CHIP:IN: SecureSession[0xffff9c01cf00]: Activated - Type:1 LSID:56692
    [1692344205.332542][79150:79152] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:56692 PSID:19067!
    [1692344205.332582][79150:79152] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1692344205.332612][79150:79152] CHIP:TOO: Pairing Success
    [1692344205.332638][79150:79152] CHIP:TOO: PASE establishment successful
    [1692344205.332671][79150:79152] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1692344205.332706][79150:79152] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1692344205.332736][79150:79152] CHIP:CTL: Sending request for commissioning information
    [1692344205.332786][79150:79152] CHIP:DMG: SendReadRequest ReadClient[0xffff9c01f3c0]: Sending Read Request
    [1692344205.333271][79150:79152] CHIP:EM: <<< [E:51301i S:56692 M:241138727] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    [1692344205.333335][79150:79152] CHIP:IN: (S) Sending msg 241138727 on secure session with LSID: 56692
    [1692344205.333652][79150:79152] CHIP:DMG: >> to BLE | 241138727 | [Interaction Model  (1) / Read Request (0x02) / Session = 19067 / Exchange = 51301]
    [1692344205.333707][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.333738][79150:79152] CHIP:DMG: {
    [1692344205.333788][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344205.333820][79150:79152] CHIP:DMG:     {
    [1692344205.333847][79150:79152] CHIP:DMG:         Initiator = true
    [1692344205.333876][79150:79152] CHIP:DMG:     }
    [1692344205.333915][79150:79152] CHIP:DMG: }
    [1692344205.333944][79150:79152] CHIP:DMG:
    [1692344205.333997][79150:79152] CHIP:DMG: Encrypted Payload (123 bytes) =
    [1692344205.334028][79150:79152] CHIP:DMG: {
    [1692344205.334058][79150:79152] CHIP:DMG:     data = 007b4a00277c5f0ed986e985934fcf204d18fcec93bc06f27b4572f810ac6e38c7c1b521a6a85121cbbb7af740353638f17ecb6feb00aac6ceae0853c3d6c760fac294c07c008a9c61d581dd6080d3fed5cb9205de90ede73433e2570d640d2ad83c7d7979d68ab0c97c8b0a056cf5106438f474abd5d91f81b0ca
    [1692344205.334118][79150:79152] CHIP:DMG:     buffer_ptr = 281473299114976
    [1692344205.334149][79150:79152] CHIP:DMG: }
    [1692344205.334191][79150:79152] CHIP:DMG:
    [1692344205.334236][79150:79152] CHIP:DMG: Decrypted Payload (93 bytes) =
    [1692344205.334267][79150:79152] CHIP:DMG: {
    [1692344205.334296][79150:79152] CHIP:DMG:     data = 153600172403312504fcff18172402002403302404001817240200240330240401181724020024033024040218172402002403302404031817240200240328240402181724020024032824040418172403312404031818280324ff0118
    [1692344205.334328][79150:79152] CHIP:DMG: }
    [1692344205.334369][79150:79152] CHIP:DMG:
    [1692344205.334461][79150:79152] CHIP:DMG: ReadRequestMessage =
    [1692344205.334498][79150:79152] CHIP:DMG: {
    [1692344205.334528][79150:79152] CHIP:DMG:      AttributePathIBs =
    [1692344205.334564][79150:79152] CHIP:DMG:      [
    [1692344205.334599][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.334653][79150:79152] CHIP:DMG:              {
    [1692344205.334693][79150:79152] CHIP:DMG:                      Cluster = 0x31,
    [1692344205.334739][79150:79152] CHIP:DMG:                      Attribute = 0x0000_FFFC,
    [1692344205.334780][79150:79152] CHIP:DMG:              }
    [1692344205.334821][79150:79152] CHIP:DMG:
    [1692344205.334872][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.334911][79150:79152] CHIP:DMG:              {
    [1692344205.334949][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.334992][79150:79152] CHIP:DMG:                      Cluster = 0x30,
    [1692344205.335047][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0000,
    [1692344205.335088][79150:79152] CHIP:DMG:              }
    [1692344205.335129][79150:79152] CHIP:DMG:
    [1692344205.335165][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.335216][79150:79152] CHIP:DMG:              {
    [1692344205.335256][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.335299][79150:79152] CHIP:DMG:                      Cluster = 0x30,
    [1692344205.335342][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0001,
    [1692344205.335394][79150:79152] CHIP:DMG:              }
    [1692344205.335437][79150:79152] CHIP:DMG:
    [1692344205.335473][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.335510][79150:79152] CHIP:DMG:              {
    [1692344205.335561][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.335603][79150:79152] CHIP:DMG:                      Cluster = 0x30,
    [1692344205.335646][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0002,
    [1692344205.335699][79150:79152] CHIP:DMG:              }
    [1692344205.335740][79150:79152] CHIP:DMG:
    [1692344205.335776][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.335813][79150:79152] CHIP:DMG:              {
    [1692344205.335864][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.335907][79150:79152] CHIP:DMG:                      Cluster = 0x30,
    [1692344205.335950][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0003,
    [1692344205.336001][79150:79152] CHIP:DMG:              }
    [1692344205.336044][79150:79152] CHIP:DMG:
    [1692344205.336080][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.336117][79150:79152] CHIP:DMG:              {
    [1692344205.336169][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.336213][79150:79152] CHIP:DMG:                      Cluster = 0x28,
    [1692344205.336256][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0002,
    [1692344205.336307][79150:79152] CHIP:DMG:              }
    [1692344205.336351][79150:79152] CHIP:DMG:
    [1692344205.336388][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.336424][79150:79152] CHIP:DMG:              {
    [1692344205.336476][79150:79152] CHIP:DMG:                      Endpoint = 0x0,
    [1692344205.336519][79150:79152] CHIP:DMG:                      Cluster = 0x28,
    [1692344205.336562][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0004,
    [1692344205.336613][79150:79152] CHIP:DMG:              }
    [1692344205.336655][79150:79152] CHIP:DMG:
    [1692344205.336693][79150:79152] CHIP:DMG:              AttributePathIB =
    [1692344205.336730][79150:79152] CHIP:DMG:              {
    [1692344205.336768][79150:79152] CHIP:DMG:                      Cluster = 0x31,
    [1692344205.336810][79150:79152] CHIP:DMG:                      Attribute = 0x0000_0003,
    [1692344205.336850][79150:79152] CHIP:DMG:              }
    [1692344205.336888][79150:79152] CHIP:DMG:
    [1692344205.336924][79150:79152] CHIP:DMG:      ],
    [1692344205.336980][79150:79152] CHIP:DMG:
    [1692344205.337018][79150:79152] CHIP:DMG:      isFabricFiltered = false,
    [1692344205.337053][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.337086][79150:79152] CHIP:DMG: },
    [1692344205.337117][79150:79152] CHIP:DMG:
    [1692344205.337278][79150:79152] CHIP:DMG: MoveToState ReadClient[0xffff9c01f3c0]: Moving to [AwaitingIn]
    [1692344205.416690][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.465515][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.465745][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.553443][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.553718][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.554963][79150:79152] CHIP:DMG: << from BLE | 244578375 | [Interaction Model  (1) / Report Data (0x05) / Session = 56692 / Exchange = 51301]
    [1692344205.555065][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.555120][79150:79152] CHIP:DMG: {
    [1692344205.555212][79150:79152] CHIP:DMG: }
    [1692344205.555265][79150:79152] CHIP:DMG:
    [1692344205.555329][79150:79152] CHIP:DMG: Encrypted Payload (257 bytes) =
    [1692344205.555382][79150:79152] CHIP:DMG: {
    [1692344205.555433][79150:79152] CHIP:DMG:     data = 0074dd0047f8930e0eda45047bf220c70bfcb732fd27f86564312de61a6fe60eae37cd45d5664407b71246fab953a3de1f393566c02e116ed051d01c28b971adf5898f44749a1c74efa85a815edd20884b89b78a07139a749495542eb25deaf91d9f7b5af05b7401ee50405209e74ce11ccf87092f29f9b62172d233c5f19c121400585ddc660c83624ce8987491aff6dcb7334dd4e5fe5c3bfd448c0e97206cb613e2c4d2dc45306b7554a0fbb863825cff69f654823b8765bc0273c4496c012d7cab3ac9aeebedeafe6f57f328a4a322bd72eddebb924a90e5e764a3b1770aee427a3135aaa3410316499375e764943dfe42aae0b721e16c3eca94665128c138
    [1692344205.555499][79150:79152] CHIP:DMG:     buffer_ptr = 281473299131584
    [1692344205.555572][79150:79152] CHIP:DMG: }
    [1692344205.555614][79150:79152] CHIP:DMG:
    [1692344205.555689][79150:79152] CHIP:DMG: Decrypted Payload (227 bytes) =
    [1692344205.555741][79150:79152] CHIP:DMG: {
    [1692344205.555791][79150:79152] CHIP:DMG:     data = 1536011535012600015d6ec4370124020024033124040318240214181815350126007155e27f370124020024032824040418240201181815350126007155e27f37012402002403282404021825025714181815350126002df3f7b9370124020024033024040318240200181815350126002df3f7b9370124020024033024040218240200181815350126002df3f7b9370124020024033024040118350224003c2501840318181815350126002df3f7b937012402002403302404001824020018181535012600015d6ec437012402002403312504fcff18240202181818290424ff0118
    [1692344205.555872][79150:79152] CHIP:DMG: }
    [1692344205.555920][79150:79152] CHIP:DMG:
    [1692344205.556209][79150:79152] CHIP:DMG:
    [1692344205.556293][79150:79152] CHIP:DMG: Additional Fields =
    [1692344205.556347][79150:79152] CHIP:DMG: {
    [1692344205.556426][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344205.556478][79150:79152] CHIP:DMG: }
    [1692344205.556525][79150:79152] CHIP:DMG:
    [1692344205.556600][79150:79152] CHIP:EM: >>> [E:51301i S:56692 M:244578375] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1692344205.556668][79150:79152] CHIP:EM: Found matching exchange: 51301i, Delegate: 0xffff9c01f3d0
    [1692344205.556899][79150:79152] CHIP:DMG: ReportDataMessage =
    [1692344205.556962][79150:79152] CHIP:DMG: {
    [1692344205.557012][79150:79152] CHIP:DMG:      AttributeReportIBs =
    [1692344205.557084][79150:79152] CHIP:DMG:      [
    [1692344205.557180][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.557260][79150:79152] CHIP:DMG:              {
    [1692344205.557320][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.557411][79150:79152] CHIP:DMG:                      {
    [1692344205.557488][79150:79152] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692344205.557561][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.557636][79150:79152] CHIP:DMG:                              {
    [1692344205.557735][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.557817][79150:79152] CHIP:DMG:                                      Cluster = 0x31,
    [1692344205.557899][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0003,
    [1692344205.558005][79150:79152] CHIP:DMG:                              }
    [1692344205.558118][79150:79152] CHIP:DMG:
    [1692344205.558199][79150:79152] CHIP:DMG:                              Data = 20,
    [1692344205.558291][79150:79152] CHIP:DMG:                      },
    [1692344205.558371][79150:79152] CHIP:DMG:
    [1692344205.558433][79150:79152] CHIP:DMG:              },
    [1692344205.558520][79150:79152] CHIP:DMG:
    [1692344205.558598][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.558675][79150:79152] CHIP:DMG:              {
    [1692344205.558735][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.558821][79150:79152] CHIP:DMG:                      {
    [1692344205.558893][79150:79152] CHIP:DMG:                              DataVersion = 0x7fe25571,
    [1692344205.558964][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.559038][79150:79152] CHIP:DMG:                              {
    [1692344205.559136][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.559217][79150:79152] CHIP:DMG:                                      Cluster = 0x28,
    [1692344205.559297][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0004,
    [1692344205.559395][79150:79152] CHIP:DMG:                              }
    [1692344205.559473][79150:79152] CHIP:DMG:
    [1692344205.559571][79150:79152] CHIP:DMG:                              Data = 1,
    [1692344205.559644][79150:79152] CHIP:DMG:                      },
    [1692344205.559721][79150:79152] CHIP:DMG:
    [1692344205.559780][79150:79152] CHIP:DMG:              },
    [1692344205.559891][79150:79152] CHIP:DMG:
    [1692344205.559949][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.560022][79150:79152] CHIP:DMG:              {
    [1692344205.560105][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.560172][79150:79152] CHIP:DMG:                      {
    [1692344205.560240][79150:79152] CHIP:DMG:                              DataVersion = 0x7fe25571,
    [1692344205.560311][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.560405][79150:79152] CHIP:DMG:                              {
    [1692344205.560479][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.560559][79150:79152] CHIP:DMG:                                      Cluster = 0x28,
    [1692344205.560660][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0002,
    [1692344205.560736][79150:79152] CHIP:DMG:                              }
    [1692344205.560813][79150:79152] CHIP:DMG:
    [1692344205.560918][79150:79152] CHIP:DMG:                              Data = 5207,
    [1692344205.560989][79150:79152] CHIP:DMG:                      },
    [1692344205.561063][79150:79152] CHIP:DMG:
    [1692344205.561144][79150:79152] CHIP:DMG:              },
    [1692344205.561230][79150:79152] CHIP:DMG:
    [1692344205.561287][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.561382][79150:79152] CHIP:DMG:              {
    [1692344205.561444][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.561509][79150:79152] CHIP:DMG:                      {
    [1692344205.561578][79150:79152] CHIP:DMG:                              DataVersion = 0xb9f7f32d,
    [1692344205.561667][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.561740][79150:79152] CHIP:DMG:                              {
    [1692344205.561816][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.561919][79150:79152] CHIP:DMG:                                      Cluster = 0x30,
    [1692344205.562001][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0003,
    [1692344205.562196][79150:79152] CHIP:DMG:                              }
    [1692344205.562282][79150:79152] CHIP:DMG:
    [1692344205.562359][79150:79152] CHIP:DMG:                              Data = 0,
    [1692344205.562451][79150:79152] CHIP:DMG:                      },
    [1692344205.562529][79150:79152] CHIP:DMG:
    [1692344205.562588][79150:79152] CHIP:DMG:              },
    [1692344205.562694][79150:79152] CHIP:DMG:
    [1692344205.562752][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.562825][79150:79152] CHIP:DMG:              {
    [1692344205.562885][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.562971][79150:79152] CHIP:DMG:                      {
    [1692344205.563042][79150:79152] CHIP:DMG:                              DataVersion = 0xb9f7f32d,
    [1692344205.563113][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.563205][79150:79152] CHIP:DMG:                              {
    [1692344205.563281][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.563361][79150:79152] CHIP:DMG:                                      Cluster = 0x30,
    [1692344205.563462][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0002,
    [1692344205.563538][79150:79152] CHIP:DMG:                              }
    [1692344205.563616][79150:79152] CHIP:DMG:
    [1692344205.563712][79150:79152] CHIP:DMG:                              Data = 0,
    [1692344205.563784][79150:79152] CHIP:DMG:                      },
    [1692344205.563860][79150:79152] CHIP:DMG:
    [1692344205.563920][79150:79152] CHIP:DMG:              },
    [1692344205.564007][79150:79152] CHIP:DMG:
    [1692344205.564063][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.564139][79150:79152] CHIP:DMG:              {
    [1692344205.564183][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.564220][79150:79152] CHIP:DMG:                      {
    [1692344205.564245][79150:79152] CHIP:DMG:                              DataVersion = 0xb9f7f32d,
    [1692344205.564270][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.564296][79150:79152] CHIP:DMG:                              {
    [1692344205.564321][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.564346][79150:79152] CHIP:DMG:                                      Cluster = 0x30,
    [1692344205.564380][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692344205.564406][79150:79152] CHIP:DMG:                              }
    [1692344205.564434][79150:79152] CHIP:DMG:
    [1692344205.564459][79150:79152] CHIP:DMG:                              Data =
    [1692344205.564485][79150:79152] CHIP:DMG:                              {
    [1692344205.564513][79150:79152] CHIP:DMG:                                      0x0 = 60,
    [1692344205.564542][79150:79152] CHIP:DMG:                                      0x1 = 900,
    [1692344205.564570][79150:79152] CHIP:DMG:                              },
    [1692344205.564595][79150:79152] CHIP:DMG:                      },
    [1692344205.564623][79150:79152] CHIP:DMG:
    [1692344205.564644][79150:79152] CHIP:DMG:              },
    [1692344205.564674][79150:79152] CHIP:DMG:
    [1692344205.564694][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.564720][79150:79152] CHIP:DMG:              {
    [1692344205.564741][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.564764][79150:79152] CHIP:DMG:                      {
    [1692344205.564788][79150:79152] CHIP:DMG:                              DataVersion = 0xb9f7f32d,
    [1692344205.564813][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.564839][79150:79152] CHIP:DMG:                              {
    [1692344205.564865][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.564893][79150:79152] CHIP:DMG:                                      Cluster = 0x30,
    [1692344205.564920][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_0000,
    [1692344205.564955][79150:79152] CHIP:DMG:                              }
    [1692344205.564991][79150:79152] CHIP:DMG:
    [1692344205.565019][79150:79152] CHIP:DMG:                              Data = 0,
    [1692344205.565043][79150:79152] CHIP:DMG:                      },
    [1692344205.565070][79150:79152] CHIP:DMG:
    [1692344205.565100][79150:79152] CHIP:DMG:              },
    [1692344205.565130][79150:79152] CHIP:DMG:
    [1692344205.565150][79150:79152] CHIP:DMG:              AttributeReportIB =
    [1692344205.565185][79150:79152] CHIP:DMG:              {
    [1692344205.565207][79150:79152] CHIP:DMG:                      AttributeDataIB =
    [1692344205.565230][79150:79152] CHIP:DMG:                      {
    [1692344205.565254][79150:79152] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692344205.565288][79150:79152] CHIP:DMG:                              AttributePathIB =
    [1692344205.565314][79150:79152] CHIP:DMG:                              {
    [1692344205.565340][79150:79152] CHIP:DMG:                                      Endpoint = 0x0,
    [1692344205.565377][79150:79152] CHIP:DMG:                                      Cluster = 0x31,
    [1692344205.565406][79150:79152] CHIP:DMG:                                      Attribute = 0x0000_FFFC,
    [1692344205.565432][79150:79152] CHIP:DMG:                              }
    [1692344205.565468][79150:79152] CHIP:DMG:
    [1692344205.565496][79150:79152] CHIP:DMG:                              Data = 2,
    [1692344205.565520][79150:79152] CHIP:DMG:                      },
    [1692344205.565556][79150:79152] CHIP:DMG:
    [1692344205.565577][79150:79152] CHIP:DMG:              },
    [1692344205.565602][79150:79152] CHIP:DMG:
    [1692344205.565629][79150:79152] CHIP:DMG:      ],
    [1692344205.565681][79150:79152] CHIP:DMG:
    [1692344205.565702][79150:79152] CHIP:DMG:      SuppressResponse = true,
    [1692344205.565732][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.565751][79150:79152] CHIP:DMG: }
    [1692344205.566463][79150:79152] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
    [1692344205.566529][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1692344205.566558][79150:79152] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1692344205.566585][79150:79152] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1692344205.566608][79150:79152] CHIP:CTL: Arming failsafe (60 seconds)
    [1692344205.566700][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344205.566739][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344205.567028][79150:79152] CHIP:EM: <<< [E:51302i S:56692 M:241138728] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344205.567071][79150:79152] CHIP:IN: (S) Sending msg 241138728 on secure session with LSID: 56692
    [1692344205.567258][79150:79152] CHIP:DMG: >> to BLE | 241138728 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51302]
    [1692344205.567290][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.567309][79150:79152] CHIP:DMG: {
    [1692344205.567339][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344205.567357][79150:79152] CHIP:DMG:     {
    [1692344205.567373][79150:79152] CHIP:DMG:         Initiator = true
    [1692344205.567391][79150:79152] CHIP:DMG:     }
    [1692344205.567414][79150:79152] CHIP:DMG: }
    [1692344205.567441][79150:79152] CHIP:DMG:
    [1692344205.567465][79150:79152] CHIP:DMG: Encrypted Payload (65 bytes) =
    [1692344205.567483][79150:79152] CHIP:DMG: {
    [1692344205.567500][79150:79152] CHIP:DMG:     data = 007b4a00287c5f0e9bf8d220604a8ce103dedf1055ecf1689ce34f87339462e03176b4daa85447b309e3609e4c3d697450f8df8bfc6967a4e99e58a895f2e0d07d
    [1692344205.567519][79150:79152] CHIP:DMG:     buffer_ptr = 281473299131584
    [1692344205.567545][79150:79152] CHIP:DMG: }
    [1692344205.567561][79150:79152] CHIP:DMG:
    [1692344205.567585][79150:79152] CHIP:DMG: Decrypted Payload (35 bytes) =
    [1692344205.567603][79150:79152] CHIP:DMG: {
    [1692344205.567620][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013024020018350124003c24010318181824ff0118
    [1692344205.567638][79150:79152] CHIP:DMG: }
    [1692344205.567664][79150:79152] CHIP:DMG:
    [1692344205.567720][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344205.567741][79150:79152] CHIP:DMG: {
    [1692344205.567760][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344205.567782][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344205.567801][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344205.567827][79150:79152] CHIP:DMG:      [
    [1692344205.567848][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344205.567872][79150:79152] CHIP:DMG:              {
    [1692344205.567893][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344205.567918][79150:79152] CHIP:DMG:                      {
    [1692344205.567944][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344205.567970][79150:79152] CHIP:DMG:                              ClusterId = 0x30,
    [1692344205.567997][79150:79152] CHIP:DMG:                              CommandId = 0x0,
    [1692344205.568022][79150:79152] CHIP:DMG:                      },
    [1692344205.568048][79150:79152] CHIP:DMG:
    [1692344205.568098][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344205.568124][79150:79152] CHIP:DMG:                      {
    [1692344205.568150][79150:79152] CHIP:DMG:                              0x0 = 60,
    [1692344205.568177][79150:79152] CHIP:DMG:                              0x1 = 3,
    [1692344205.568204][79150:79152] CHIP:DMG:                      },
    [1692344205.568227][79150:79152] CHIP:DMG:              },
    [1692344205.568252][79150:79152] CHIP:DMG:
    [1692344205.568271][79150:79152] CHIP:DMG:      ],
    [1692344205.568313][79150:79152] CHIP:DMG:
    [1692344205.568334][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.568353][79150:79152] CHIP:DMG: },
    [1692344205.568372][79150:79152] CHIP:DMG:
    [1692344205.568489][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344205.642275][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.643960][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.644171][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.645060][79150:79152] CHIP:DMG: << from BLE | 244578376 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51302]
    [1692344205.645144][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.645190][79150:79152] CHIP:DMG: {
    [1692344205.645270][79150:79152] CHIP:DMG: }
    [1692344205.645314][79150:79152] CHIP:DMG:
    [1692344205.645368][79150:79152] CHIP:DMG: Encrypted Payload (66 bytes) =
    [1692344205.645411][79150:79152] CHIP:DMG: {
    [1692344205.645454][79150:79152] CHIP:DMG:     data = 0074dd0048f8930ea43e6ff76a9a249fc2610ea6f44b70a0c8f9b240ac39423265dbcf60d646e0a9530601db8a8a6a36e317d4f43ab9274af3cfafebf783808963fd
    [1692344205.645498][79150:79152] CHIP:DMG:     buffer_ptr = 281473299138096
    [1692344205.645563][79150:79152] CHIP:DMG: }
    [1692344205.645605][79150:79152] CHIP:DMG:
    [1692344205.645666][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344205.645710][79150:79152] CHIP:DMG: {
    [1692344205.645751][79150:79152] CHIP:DMG:     data = 152800360115350037002400002401302402011835012400002c01001818181824ff0118
    [1692344205.645819][79150:79152] CHIP:DMG: }
    [1692344205.645861][79150:79152] CHIP:DMG:
    [1692344205.645965][79150:79152] CHIP:DMG:
    [1692344205.646034][79150:79152] CHIP:DMG: Additional Fields =
    [1692344205.646118][79150:79152] CHIP:DMG: {
    [1692344205.646167][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344205.646234][79150:79152] CHIP:DMG: }
    [1692344205.646275][79150:79152] CHIP:DMG:
    [1692344205.646339][79150:79152] CHIP:EM: >>> [E:51302i S:56692 M:244578376] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344205.646399][79150:79152] CHIP:EM: Found matching exchange: 51302i, Delegate: 0xffffa4005ca8
    [1692344205.646496][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344205.646578][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344205.646626][79150:79152] CHIP:DMG: {
    [1692344205.646673][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344205.646722][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344205.646804][79150:79152] CHIP:DMG:      [
    [1692344205.646854][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344205.646920][79150:79152] CHIP:DMG:              {
    [1692344205.646971][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344205.647051][79150:79152] CHIP:DMG:                      {
    [1692344205.647114][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344205.647178][79150:79152] CHIP:DMG:                              {
    [1692344205.647260][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344205.647331][79150:79152] CHIP:DMG:                                      ClusterId = 0x30,
    [1692344205.647399][79150:79152] CHIP:DMG:                                      CommandId = 0x1,
    [1692344205.647464][79150:79152] CHIP:DMG:                              },
    [1692344205.647531][79150:79152] CHIP:DMG:
    [1692344205.647607][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344205.647672][79150:79152] CHIP:DMG:                              {
    [1692344205.647739][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344205.647813][79150:79152] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692344205.647882][79150:79152] CHIP:DMG:                              },
    [1692344205.647942][79150:79152] CHIP:DMG:                      },
    [1692344205.648026][79150:79152] CHIP:DMG:
    [1692344205.648079][79150:79152] CHIP:DMG:              },
    [1692344205.648142][79150:79152] CHIP:DMG:
    [1692344205.648190][79150:79152] CHIP:DMG:      ],
    [1692344205.648253][79150:79152] CHIP:DMG:
    [1692344205.648301][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.648348][79150:79152] CHIP:DMG: },
    [1692344205.648485][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692344205.648557][79150:79152] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1692344205.648613][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1692344205.648675][79150:79152] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1692344205.648729][79150:79152] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1692344205.648771][79150:79152] CHIP:CTL: Setting Regulatory Config
    [1692344205.648812][79150:79152] CHIP:CTL: Device does not support configurable regulatory location
    [1692344205.648929][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344205.649051][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344205.649578][79150:79152] CHIP:EM: <<< [E:51303i S:56692 M:241138729] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344205.649664][79150:79152] CHIP:IN: (S) Sending msg 241138729 on secure session with LSID: 56692
    [1692344205.650065][79150:79152] CHIP:DMG: >> to BLE | 241138729 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51303]
    [1692344205.650191][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.650236][79150:79152] CHIP:DMG: {
    [1692344205.650308][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344205.650353][79150:79152] CHIP:DMG:     {
    [1692344205.650392][79150:79152] CHIP:DMG:         Initiator = true
    [1692344205.650456][79150:79152] CHIP:DMG:     }
    [1692344205.650513][79150:79152] CHIP:DMG: }
    [1692344205.650555][79150:79152] CHIP:DMG:
    [1692344205.650609][79150:79152] CHIP:DMG: Encrypted Payload (70 bytes) =
    [1692344205.650653][79150:79152] CHIP:DMG: {
    [1692344205.650717][79150:79152] CHIP:DMG:     data = 007b4a00297c5f0e654bcfd799f9cd3db770900bfbdd0dffeafe34b9b9b9bff88bfe4a5097ee22fc2c7b5671e897e1636dfdedf80f60b6bc3f76baf198db7001005f295c89a4
    [1692344205.650763][79150:79152] CHIP:DMG:     buffer_ptr = 281473299131584
    [1692344205.650805][79150:79152] CHIP:DMG: }
    [1692344205.650845][79150:79152] CHIP:DMG:
    [1692344205.650908][79150:79152] CHIP:DMG: Decrypted Payload (40 bytes) =
    [1692344205.650953][79150:79152] CHIP:DMG: {
    [1692344205.651015][79150:79152] CHIP:DMG:     data = 152800280136021537002400002401302402021835012400002c0102585824020418181824ff0118
    [1692344205.651062][79150:79152] CHIP:DMG: }
    [1692344205.651102][79150:79152] CHIP:DMG:
    [1692344205.651232][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344205.651283][79150:79152] CHIP:DMG: {
    [1692344205.651328][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344205.651380][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344205.651447][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344205.651513][79150:79152] CHIP:DMG:      [
    [1692344205.651562][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344205.651616][79150:79152] CHIP:DMG:              {
    [1692344205.651667][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344205.651744][79150:79152] CHIP:DMG:                      {
    [1692344205.651804][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344205.651884][79150:79152] CHIP:DMG:                              ClusterId = 0x30,
    [1692344205.651957][79150:79152] CHIP:DMG:                              CommandId = 0x2,
    [1692344205.652045][79150:79152] CHIP:DMG:                      },
    [1692344205.652109][79150:79152] CHIP:DMG:
    [1692344205.652162][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344205.652220][79150:79152] CHIP:DMG:                      {
    [1692344205.652299][79150:79152] CHIP:DMG:                              0x0 = 0,
    [1692344205.652376][79150:79152] CHIP:DMG:                              0x1 = "XX" (2 chars),
    [1692344205.652447][79150:79152] CHIP:DMG:                              0x2 = 4,
    [1692344205.652929][79150:79152] CHIP:DMG:                      },
    [1692344205.652978][79150:79152] CHIP:DMG:              },
    [1692344205.653010][79150:79152] CHIP:DMG:
    [1692344205.653032][79150:79152] CHIP:DMG:      ],
    [1692344205.653061][79150:79152] CHIP:DMG:
    [1692344205.653083][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.653104][79150:79152] CHIP:DMG: },
    [1692344205.653126][79150:79152] CHIP:DMG:
    [1692344205.653308][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344205.653402][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344205.777519][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.779487][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.779718][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.780565][79150:79152] CHIP:DMG: << from BLE | 244578377 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51303]
    [1692344205.780650][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.780696][79150:79152] CHIP:DMG: {
    [1692344205.780778][79150:79152] CHIP:DMG: }
    [1692344205.780822][79150:79152] CHIP:DMG:
    [1692344205.780877][79150:79152] CHIP:DMG: Encrypted Payload (66 bytes) =
    [1692344205.780920][79150:79152] CHIP:DMG: {
    [1692344205.780963][79150:79152] CHIP:DMG:     data = 0074dd0049f8930e1652eb634c8b9da04b33ce753acdbf7eba0bab440a96c9041900684be08e5fd0c910cab115451ee6698bd594d53f572473ff925d5a30162d6b5c
    [1692344205.781008][79150:79152] CHIP:DMG:     buffer_ptr = 281473299138096
    [1692344205.781049][79150:79152] CHIP:DMG: }
    [1692344205.781089][79150:79152] CHIP:DMG:
    [1692344205.781148][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344205.781193][79150:79152] CHIP:DMG: {
    [1692344205.781234][79150:79152] CHIP:DMG:     data = 152800360115350037002400002401302402031835012400002c01001818181824ff0118
    [1692344205.781276][79150:79152] CHIP:DMG: }
    [1692344205.781316][79150:79152] CHIP:DMG:
    [1692344205.781423][79150:79152] CHIP:DMG:
    [1692344205.781492][79150:79152] CHIP:DMG: Additional Fields =
    [1692344205.781539][79150:79152] CHIP:DMG: {
    [1692344205.781593][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344205.781638][79150:79152] CHIP:DMG: }
    [1692344205.781678][79150:79152] CHIP:DMG:
    [1692344205.781744][79150:79152] CHIP:EM: >>> [E:51303i S:56692 M:244578377] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344205.781804][79150:79152] CHIP:EM: Found matching exchange: 51303i, Delegate: 0xffff9c00c2d8
    [1692344205.781882][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344205.781963][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344205.782012][79150:79152] CHIP:DMG: {
    [1692344205.782059][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344205.782160][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344205.782226][79150:79152] CHIP:DMG:      [
    [1692344205.782275][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344205.782346][79150:79152] CHIP:DMG:              {
    [1692344205.782399][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344205.782459][79150:79152] CHIP:DMG:                      {
    [1692344205.782518][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344205.782582][79150:79152] CHIP:DMG:                              {
    [1692344205.782649][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344205.782719][79150:79152] CHIP:DMG:                                      ClusterId = 0x30,
    [1692344205.782788][79150:79152] CHIP:DMG:                                      CommandId = 0x3,
    [1692344205.782853][79150:79152] CHIP:DMG:                              },
    [1692344205.782921][79150:79152] CHIP:DMG:
    [1692344205.782981][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344205.783043][79150:79152] CHIP:DMG:                              {
    [1692344205.783111][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344205.783185][79150:79152] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692344205.783256][79150:79152] CHIP:DMG:                              },
    [1692344205.783317][79150:79152] CHIP:DMG:                      },
    [1692344205.783382][79150:79152] CHIP:DMG:
    [1692344205.783434][79150:79152] CHIP:DMG:              },
    [1692344205.783496][79150:79152] CHIP:DMG:
    [1692344205.783544][79150:79152] CHIP:DMG:      ],
    [1692344205.783607][79150:79152] CHIP:DMG:
    [1692344205.783655][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.783702][79150:79152] CHIP:DMG: },
    [1692344205.783824][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1692344205.783938][79150:79152] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1692344205.783997][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1692344205.784040][79150:79152] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1692344205.784093][79150:79152] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1692344205.784135][79150:79152] CHIP:CTL: Sending request for PAI certificate
    [1692344205.784174][79150:79152] CHIP:CTL: Sending Certificate Chain request to 0xffff9c00f080 device
    [1692344205.784289][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344205.784379][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344205.784849][79150:79152] CHIP:EM: <<< [E:51304i S:56692 M:241138730] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344205.784935][79150:79152] CHIP:IN: (S) Sending msg 241138730 on secure session with LSID: 56692
    [1692344205.785336][79150:79152] CHIP:DMG: >> to BLE | 241138730 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51304]
    [1692344205.785410][79150:79152] CHIP:DMG: Header Flags =
    [1692344205.785455][79150:79152] CHIP:DMG: {
    [1692344205.785526][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344205.785570][79150:79152] CHIP:DMG:     {
    [1692344205.785609][79150:79152] CHIP:DMG:         Initiator = true
    [1692344205.785651][79150:79152] CHIP:DMG:     }
    [1692344205.785707][79150:79152] CHIP:DMG: }
    [1692344205.785749][79150:79152] CHIP:DMG:
    [1692344205.785803][79150:79152] CHIP:DMG: Encrypted Payload (62 bytes) =
    [1692344205.785846][79150:79152] CHIP:DMG: {
    [1692344205.785887][79150:79152] CHIP:DMG:     data = 007b4a002a7c5f0e4118fbf6b5069530adb23d4d69fad7a94cdf4873b6620d070400031bc8464b72c9c88cd7a7103c3fadb55bb995a160ac8126bce71d7a
    [1692344205.785931][79150:79152] CHIP:DMG:     buffer_ptr = 281473299131584
    [1692344205.785972][79150:79152] CHIP:DMG: }
    [1692344205.786012][79150:79152] CHIP:DMG:
    [1692344205.786224][79150:79152] CHIP:DMG: Decrypted Payload (32 bytes) =
    [1692344205.786276][79150:79152] CHIP:DMG: {
    [1692344205.786319][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013e24020218350124000218181824ff0118
    [1692344205.786362][79150:79152] CHIP:DMG: }
    [1692344205.786402][79150:79152] CHIP:DMG:
    [1692344205.786524][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344205.786575][79150:79152] CHIP:DMG: {
    [1692344205.786620][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344205.786673][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344205.786721][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344205.786782][79150:79152] CHIP:DMG:      [
    [1692344205.786830][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344205.786884][79150:79152] CHIP:DMG:              {
    [1692344205.786936][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344205.786995][79150:79152] CHIP:DMG:                      {
    [1692344205.787056][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344205.787121][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344205.787184][79150:79152] CHIP:DMG:                              CommandId = 0x2,
    [1692344205.787244][79150:79152] CHIP:DMG:                      },
    [1692344205.787305][79150:79152] CHIP:DMG:
    [1692344205.787354][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344205.787407][79150:79152] CHIP:DMG:                      {
    [1692344205.787509][79150:79152] CHIP:DMG:                              0x0 = 2,
    [1692344205.787573][79150:79152] CHIP:DMG:                      },
    [1692344205.787629][79150:79152] CHIP:DMG:              },
    [1692344205.787690][79150:79152] CHIP:DMG:
    [1692344205.787738][79150:79152] CHIP:DMG:      ],
    [1692344205.787798][79150:79152] CHIP:DMG:
    [1692344205.787846][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344205.787893][79150:79152] CHIP:DMG: },
    [1692344205.787937][79150:79152] CHIP:DMG:
    [1692344205.788144][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344205.788264][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344205.867065][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344205.870800][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.871249][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344205.960699][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344205.961090][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.048713][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.048974][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.050374][79150:79152] CHIP:DMG: << from BLE | 244578378 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51304]
    [1692344206.050478][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.050528][79150:79152] CHIP:DMG: {
    [1692344206.050617][79150:79152] CHIP:DMG: }
    [1692344206.050669][79150:79152] CHIP:DMG:
    [1692344206.050741][79150:79152] CHIP:DMG: Encrypted Payload (560 bytes) =
    [1692344206.050796][79150:79152] CHIP:DMG: {
    [1692344206.050848][79150:79152] CHIP:DMG:     data = 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
    [1692344206.050953][79150:79152] CHIP:DMG:     buffer_ptr = 281473299138096
    [1692344206.051003][79150:79152] CHIP:DMG: }
    [1692344206.051050][79150:79152] CHIP:DMG:
    [1692344206.051125][79150:79152] CHIP:DMG: Decrypted Payload (530 bytes) =
    [1692344206.051178][79150:79152] CHIP:DMG: {
    [1692344206.051229][79150:79152] CHIP:DMG:     data = 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
    [1692344206.051338][79150:79152] CHIP:DMG: }
    [1692344206.051386][79150:79152] CHIP:DMG:
    [1692344206.051611][79150:79152] CHIP:DMG: DAC/PAI (496) =
    [1692344206.051727][79150:79152] CHIP:DMG: {
    -----BEGIN CERTIFICATE-----
    MIIB7DCCAZGgAwIBAgIINsL7m4iqFWowCgYIKoZIzj0EAwIwTjE2MDQGA1UEAwwt
    SG9vUmlpIE1hdHRlciBEZXZlbG9wbWVudCBQQUEgV2l0aCBWSUQgMHgxMzUxMRQw
    EgYKKwYBBAGConwCAQwEMTM1MTAeFw0yMDEwMTUxNDIzNDNaFw00MDEwMTUxNDIz
    NDJaMEExKTAnBgNVBAMMIEhvb1JpaSBNYXR0ZXIgRGV2ZWxvcG1lbnQgUEFJIDAx
    MRQwEgYKKwYBBAGConwCAQwEMTM1MTBZMBMGByqGSM49AgEGCCqGSM49AwEHA0IA
    BDq1+g2RHX+a7ZNGvBQ39avweiL6iYPU5c3P2O328PfT2rdE9w321RAZ0vmUFoal
    skkB8XmJY0gBrkJEaVDt7r2jZjBkMBIGA1UdEwEB/wQIMAYBAf8CAQAwDgYDVR0P
    AQH/BAQDAgEGMB0GA1UdDgQWBBTZosFMe6EHxrTYTUFY33VqNRb5fzAfBgNVHSME
    GDAWgBTQqlNTqZv8B293Kk0UZIPVsY7EbDAKBggqhkjOPQQDAgNJADBGAiEAh2DB
    QunSNdTDFQHfSiBQH+ig/oHUI4Phc3f+T04+qiQCIQD35d5slbIvqNYE94X8xYTs
    Q+oGMTjUv3xVtSg5pmMvwQ==
    -----END CERTIFICATE-----
    [1692344206.051943][79150:79152] CHIP:DMG: }
    [1692344206.051991][79150:79152] CHIP:DMG:
    [1692344206.052053][79150:79152] CHIP:DMG:
    [1692344206.052135][79150:79152] CHIP:DMG: Additional Fields =
    [1692344206.052189][79150:79152] CHIP:DMG: {
    [1692344206.052244][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344206.052296][79150:79152] CHIP:DMG: }
    [1692344206.052343][79150:79152] CHIP:DMG:
    [1692344206.052421][79150:79152] CHIP:EM: >>> [E:51304i S:56692 M:244578378] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344206.052490][79150:79152] CHIP:EM: Found matching exchange: 51304i, Delegate: 0xffffa4005ca8
    [1692344206.052586][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344206.052679][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344206.052735][79150:79152] CHIP:DMG: {
    [1692344206.052791][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.052849][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344206.052923][79150:79152] CHIP:DMG:      [
    [1692344206.052981][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344206.053059][79150:79152] CHIP:DMG:              {
    [1692344206.053121][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344206.053190][79150:79152] CHIP:DMG:                      {
    [1692344206.053254][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344206.053328][79150:79152] CHIP:DMG:                              {
    [1692344206.053406][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344206.053488][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344206.053569][79150:79152] CHIP:DMG:                                      CommandId = 0x3,
    [1692344206.053644][79150:79152] CHIP:DMG:                              },
    [1692344206.053723][79150:79152] CHIP:DMG:
    [1692344206.053791][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344206.053867][79150:79152] CHIP:DMG:                              {
    [1692344206.053944][79150:79152] CHIP:DMG:                                      0x0 = [
    [1692344206.054314][79150:79152] CHIP:DMG:                                                      0x30, 0x82, 0x01, 0xec, 0x30, 0x82, 0x01, 0x91, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x36, 0xc2, 0xfb, 0x9b, 0x88, 0xaa, 0x15, 0x6a, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x4e, 0x31, 0x36, 0x30, 0x34, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x2d, 0x48, 0x6f, 0x6f, 0x52, 0x69, 0x69, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x50, 0x41, 0x41, 0x20, 0x57, 0x69, 0x74, 0x68, 0x20, 0x56, 0x49, 0x44, 0x20, 0x30, 0x78, 0x31, 0x33, 0x35, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x35, 0x31, 0x30, 0x1e, 0x17, 0x0d, 0x32, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x17, 0x0d, 0x34, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x32, 0x5a, 0x30, 0x41, 0x31, 0x29, 0x30, 0x27, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x20, 0x48, 0x6f, 0x6f, 0x52, 0x69, 0x69, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x35, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x3a, 0xb5, 0xfa, 0x0d, 0x91, 0x1d, 0x7f, 0x9a, 0xed, 0x93, 0x46, 0xbc, 0x14, 0x37, 0xf5, 0xab, 0xf0, 0x7a, 0x22, 0xfa, 0x89, 0x83, 0xd4, 0xe5, 0xcd, 0xcf, 0xd8, 0xed, 0xf6, 0xf0, 0xf7, 0xd3, 0xda, 0xb7, 0x44, 0xf7, 0x0d, 0xf6, 0xd5, 0x10, 0x19, 0xd2, 0x
    [1692344206.054492][79150:79152] CHIP:DMG:                                      ] (496 bytes)
    [1692344206.054574][79150:79152] CHIP:DMG:                              },
    [1692344206.054644][79150:79152] CHIP:DMG:                      },
    [1692344206.054723][79150:79152] CHIP:DMG:
    [1692344206.054784][79150:79152] CHIP:DMG:              },
    [1692344206.054857][79150:79152] CHIP:DMG:
    [1692344206.054913][79150:79152] CHIP:DMG:      ],
    [1692344206.054987][79150:79152] CHIP:DMG:
    [1692344206.055042][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.055097][79150:79152] CHIP:DMG: },
    [1692344206.055240][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1692344206.055313][79150:79152] CHIP:CTL: Received certificate chain from the device
    [1692344206.055376][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1692344206.055436][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1692344206.055500][79150:79152] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1692344206.055550][79150:79152] CHIP:CTL: Sending request for DAC certificate
    [1692344206.055597][79150:79152] CHIP:CTL: Sending Certificate Chain request to 0xffff9c00f080 device
    [1692344206.055730][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344206.055802][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344206.056380][79150:79152] CHIP:EM: <<< [E:51305i S:56692 M:241138731] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344206.056498][79150:79152] CHIP:IN: (S) Sending msg 241138731 on secure session with LSID: 56692
    [1692344206.056985][79150:79152] CHIP:DMG: >> to BLE | 241138731 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51305]
    [1692344206.057074][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.057126][79150:79152] CHIP:DMG: {
    [1692344206.057207][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344206.057258][79150:79152] CHIP:DMG:     {
    [1692344206.057303][79150:79152] CHIP:DMG:         Initiator = true
    [1692344206.057352][79150:79152] CHIP:DMG:     }
    [1692344206.057416][79150:79152] CHIP:DMG: }
    [1692344206.057465][79150:79152] CHIP:DMG:
    [1692344206.057528][79150:79152] CHIP:DMG: Encrypted Payload (62 bytes) =
    [1692344206.057577][79150:79152] CHIP:DMG: {
    [1692344206.057626][79150:79152] CHIP:DMG:     data = 007b4a002b7c5f0e2008a7a29846c87306fb32cc02e3c5b6fa727fa5fd376f78bfcd3985e476f949c835d57cfc9ed077e3700f77cf0e3e44b8ab1fd7663e
    [1692344206.057678][79150:79152] CHIP:DMG:     buffer_ptr = 281473299131584
    [1692344206.057726][79150:79152] CHIP:DMG: }
    [1692344206.057772][79150:79152] CHIP:DMG:
    [1692344206.057842][79150:79152] CHIP:DMG: Decrypted Payload (32 bytes) =
    [1692344206.057893][79150:79152] CHIP:DMG: {
    [1692344206.057941][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013e24020218350124000118181824ff0118
    [1692344206.057990][79150:79152] CHIP:DMG: }
    [1692344206.058036][79150:79152] CHIP:DMG:
    [1692344206.058213][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344206.058273][79150:79152] CHIP:DMG: {
    [1692344206.058327][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.058388][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344206.058444][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344206.058515][79150:79152] CHIP:DMG:      [
    [1692344206.058571][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344206.058634][79150:79152] CHIP:DMG:              {
    [1692344206.058694][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344206.058765][79150:79152] CHIP:DMG:                      {
    [1692344206.058834][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344206.058909][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344206.058964][79150:79152] CHIP:DMG:                              CommandId = 0x2,
    [1692344206.058990][79150:79152] CHIP:DMG:                      },
    [1692344206.059018][79150:79152] CHIP:DMG:
    [1692344206.059041][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344206.059072][79150:79152] CHIP:DMG:                      {
    [1692344206.059098][79150:79152] CHIP:DMG:                              0x0 = 1,
    [1692344206.059126][79150:79152] CHIP:DMG:                      },
    [1692344206.059151][79150:79152] CHIP:DMG:              },
    [1692344206.059177][79150:79152] CHIP:DMG:
    [1692344206.059198][79150:79152] CHIP:DMG:      ],
    [1692344206.059225][79150:79152] CHIP:DMG:
    [1692344206.059246][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.059266][79150:79152] CHIP:DMG: },
    [1692344206.059286][79150:79152] CHIP:DMG:
    [1692344206.059406][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344206.059467][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344206.137383][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344206.140938][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.141180][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.230767][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.231040][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.318709][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.318966][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.320238][79150:79152] CHIP:DMG: << from BLE | 244578379 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51305]
    [1692344206.320338][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.320394][79150:79152] CHIP:DMG: {
    [1692344206.320488][79150:79152] CHIP:DMG: }
    [1692344206.320540][79150:79152] CHIP:DMG:
    [1692344206.320608][79150:79152] CHIP:DMG: Encrypted Payload (557 bytes) =
    [1692344206.320661][79150:79152] CHIP:DMG: {
    [1692344206.320711][79150:79152] CHIP:DMG:     data = 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
    [1692344206.320843][79150:79152] CHIP:DMG:     buffer_ptr = 281473299138096
    [1692344206.320893][79150:79152] CHIP:DMG: }
    [1692344206.320936][79150:79152] CHIP:DMG:
    [1692344206.321010][79150:79152] CHIP:DMG: Decrypted Payload (527 bytes) =
    [1692344206.321061][79150:79152] CHIP:DMG: {
    [1692344206.321135][79150:79152] CHIP:DMG:     data = 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
    [1692344206.321242][79150:79152] CHIP:DMG: }
    [1692344206.321291][79150:79152] CHIP:DMG:
    [1692344206.321516][79150:79152] CHIP:DMG: DAC/PAI (493) =
    [1692344206.321631][79150:79152] CHIP:DMG: {
    MIIB6TCCAZCgAwIBAgIIEgzYfqRe338wCgYIKoZIzj0EAwIwQTEpMCcGA1UEAwwg
    SG9vUmlpIE1hdHRlciBEZXZlbG9wbWVudCBQQUkgMDExFDASBgorBgEEAYKifAIB
    DAQxMzUxMCAXDTIzMDEwMTAwMDAwMFoYDzk5OTkxMjMxMjM1OTU5WjBRMSMwIQYD
    VQQDDBpIb29SaWkgV1NEX1dpbmRvd19Db3ZlcmluZzEUMBIGCisGAQQBgqJ8AgEM
    BDEzNTExFDASBgorBgEEAYKifAICDARGRkY3MFkwEwYHKoZIzj0CAQYIKoZIzj0D
    AQcDQgAEZUqUDQrI4A6blu8WpXX2j2k9+CJQvvoA+IA3gpNG7V/kwbkErzZ9fcHu
    qP+H6djqKbTmNVSAZUfklulA3Fo5M6NgMF4wDAYDVR0TAQH/BAIwADAOBgNVHQ8B
    Af8EBAMCB4AwHQYDVR0OBBYEFFjsXlhzI7eSHw5wQHgrEoOrGMCpMB8GA1UdIwQY
    MBaAFNmiwUx7oQfGtNhNQVjfdWo1Fvl/MAoGCCqGSM49BAMCA0cAMEQCICl/Ghti
    H4Dl6ReoBqhBYfkU5ZphzHfIWygYiLfhPMIYAiBWL2Svbk21k5aq46VTYfgZytDT
    fKNY0jLLLQQtOgbNjA==
    [1692344206.321844][79150:79152] CHIP:DMG: }
    [1692344206.321893][79150:79152] CHIP:DMG:
    [1692344206.321978][79150:79152] CHIP:DMG:
    [1692344206.322061][79150:79152] CHIP:DMG: Additional Fields =
    [1692344206.322194][79150:79152] CHIP:DMG: {
    [1692344206.322253][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344206.322304][79150:79152] CHIP:DMG: }
    [1692344206.322351][79150:79152] CHIP:DMG:
    [1692344206.322428][79150:79152] CHIP:EM: >>> [E:51305i S:56692 M:244578379] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344206.322498][79150:79152] CHIP:EM: Found matching exchange: 51305i, Delegate: 0xffffa40573b8
    [1692344206.322595][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344206.322688][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344206.322746][79150:79152] CHIP:DMG: {
    [1692344206.322800][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.322858][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344206.322960][79150:79152] CHIP:DMG:      [
    [1692344206.323017][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344206.323096][79150:79152] CHIP:DMG:              {
    [1692344206.323158][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344206.323229][79150:79152] CHIP:DMG:                      {
    [1692344206.323314][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344206.323392][79150:79152] CHIP:DMG:                              {
    [1692344206.323468][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344206.323549][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344206.323651][79150:79152] CHIP:DMG:                                      CommandId = 0x3,
    [1692344206.323727][79150:79152] CHIP:DMG:                              },
    [1692344206.323806][79150:79152] CHIP:DMG:
    [1692344206.323897][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344206.323972][79150:79152] CHIP:DMG:                              {
    [1692344206.324048][79150:79152] CHIP:DMG:                                      0x0 = [
    [1692344206.324425][79150:79152] CHIP:DMG:                                                      0x30, 0x82, 0x01, 0xe9, 0x30, 0x82, 0x01, 0x90, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x12, 0x0c, 0xd8, 0x7e, 0xa4, 0x5e, 0xdf, 0x7f, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x41, 0x31, 0x29, 0x30, 0x27, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x20, 0x48, 0x6f, 0x6f, 0x52, 0x69, 0x69, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x35, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x33, 0x30, 0x31, 0x30, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x51, 0x31, 0x23, 0x30, 0x21, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1a, 0x48, 0x6f, 0x6f, 0x52, 0x69, 0x69, 0x20, 0x57, 0x53, 0x44, 0x5f, 0x57, 0x69, 0x6e, 0x64, 0x6f, 0x77, 0x5f, 0x43, 0x6f, 0x76, 0x65, 0x72, 0x69, 0x6e, 0x67, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x35, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x37, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x65, 0x4a, 0x94, 0x0d, 0x0a, 0xc8, 0xe0, 0x0e, 0x9b, 0x96, 0xef, 0x16, 0xa5, 0x75, 0xf6, 0x8f, 0x69, 0x3d, 0xf8, 0x22, 0x50, 0xbe, 0xfa, 0x00, 0xf8, 0x80, 0x37, 0x82, 0x93, 0x46, 0xed, 0x5f, 0xe4, 0xc1, 0xb9, 0x04, 0xaf, 0x
    [1692344206.324600][79150:79152] CHIP:DMG:                                      ] (493 bytes)
    [1692344206.324681][79150:79152] CHIP:DMG:                              },
    [1692344206.324751][79150:79152] CHIP:DMG:                      },
    [1692344206.324850][79150:79152] CHIP:DMG:
    [1692344206.324911][79150:79152] CHIP:DMG:              },
    [1692344206.324984][79150:79152] CHIP:DMG:
    [1692344206.325040][79150:79152] CHIP:DMG:      ],
    [1692344206.325114][79150:79152] CHIP:DMG:
    [1692344206.325169][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.325224][79150:79152] CHIP:DMG: },
    [1692344206.325364][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1692344206.325438][79150:79152] CHIP:CTL: Received certificate chain from the device
    [1692344206.325501][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1692344206.325562][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1692344206.325624][79150:79152] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1692344206.325672][79150:79152] CHIP:CTL: Sending Attestation Request to the device.
    [1692344206.325720][79150:79152] CHIP:CTL: Sending Attestation request to 0xffff9c00f080 device
    [1692344206.325878][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344206.325952][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344206.326612][79150:79152] CHIP:EM: <<< [E:51306i S:56692 M:241138732] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344206.326713][79150:79152] CHIP:IN: (S) Sending msg 241138732 on secure session with LSID: 56692
    [1692344206.327188][79150:79152] CHIP:DMG: >> to BLE | 241138732 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51306]
    [1692344206.327303][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.327356][79150:79152] CHIP:DMG: {
    [1692344206.327438][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344206.327490][79150:79152] CHIP:DMG:     {
    [1692344206.327534][79150:79152] CHIP:DMG:         Initiator = true
    [1692344206.327583][79150:79152] CHIP:DMG:     }
    [1692344206.327647][79150:79152] CHIP:DMG: }
    [1692344206.327720][79150:79152] CHIP:DMG:
    [1692344206.327784][79150:79152] CHIP:DMG: Encrypted Payload (94 bytes) =
    [1692344206.327834][79150:79152] CHIP:DMG: {
    [1692344206.327884][79150:79152] CHIP:DMG:     data = 007b4a002c7c5f0eea4788e9e96dbe9a6d58c4eee239d4d7592222fd75caa293f6164841b01a7d35b518dc2233ca2d15ce4f01a2dd7cd023698ae2dce619257e121e6b580d05b123e25e002e76d4ce4d543b496cabe0d7c528919314251d
    [1692344206.327961][79150:79152] CHIP:DMG:     buffer_ptr = 281473299140384
    [1692344206.328011][79150:79152] CHIP:DMG: }
    [1692344206.328057][79150:79152] CHIP:DMG:
    [1692344206.328127][79150:79152] CHIP:DMG: Decrypted Payload (64 bytes) =
    [1692344206.328178][79150:79152] CHIP:DMG: {
    [1692344206.328248][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013e24020018350130002088284ccd01f53ebf8ea1d8ad7ea39a7de82080738e54a6f6b33b4835b320023818181824ff0118
    [1692344206.328304][79150:79152] CHIP:DMG: }
    [1692344206.328351][79150:79152] CHIP:DMG:
    [1692344206.328495][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344206.328554][79150:79152] CHIP:DMG: {
    [1692344206.328607][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.328691][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344206.328748][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344206.328821][79150:79152] CHIP:DMG:      [
    [1692344206.328878][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344206.328942][79150:79152] CHIP:DMG:              {
    [1692344206.329026][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344206.329095][79150:79152] CHIP:DMG:                      {
    [1692344206.329165][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344206.329217][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344206.329259][79150:79152] CHIP:DMG:                              CommandId = 0x0,
    [1692344206.329284][79150:79152] CHIP:DMG:                      },
    [1692344206.329310][79150:79152] CHIP:DMG:
    [1692344206.329332][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344206.329371][79150:79152] CHIP:DMG:                      {
    [1692344206.329396][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344206.329439][79150:79152] CHIP:DMG:                                              0x88, 0x28, 0x4c, 0xcd, 0x01, 0xf5, 0x3e, 0xbf, 0x8e, 0xa1, 0xd8, 0xad, 0x7e, 0xa3, 0x9a, 0x7d, 0xe8, 0x20, 0x80, 0x73, 0x8e, 0x54, 0xa6, 0xf6, 0xb3, 0x3b, 0x48, 0x35, 0xb3, 0x20, 0x02, 0x38,
    [1692344206.329472][79150:79152] CHIP:DMG:                              ] (32 bytes)
    [1692344206.329499][79150:79152] CHIP:DMG:                      },
    [1692344206.329521][79150:79152] CHIP:DMG:              },
    [1692344206.329555][79150:79152] CHIP:DMG:
    [1692344206.329574][79150:79152] CHIP:DMG:      ],
    [1692344206.329600][79150:79152] CHIP:DMG:
    [1692344206.329619][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.329639][79150:79152] CHIP:DMG: },
    [1692344206.329658][79150:79152] CHIP:DMG:
    [1692344206.329794][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344206.329833][79150:79152] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1692344206.329886][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344206.407192][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344206.410716][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.410932][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.499704][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.499890][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.500812][79150:79152] CHIP:DMG: << from BLE | 244578380 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51306]
    [1692344206.500880][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.500916][79150:79152] CHIP:DMG: {
    [1692344206.500979][79150:79152] CHIP:DMG: }
    [1692344206.501014][79150:79152] CHIP:DMG:
    [1692344206.501057][79150:79152] CHIP:DMG: Encrypted Payload (417 bytes) =
    [1692344206.501092][79150:79152] CHIP:DMG: {
    [1692344206.501125][79150:79152] CHIP:DMG:     data = 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
    [1692344206.501173][79150:79152] CHIP:DMG:     buffer_ptr = 281473299138096
    [1692344206.501226][79150:79152] CHIP:DMG: }
    [1692344206.501256][79150:79152] CHIP:DMG:
    [1692344206.501305][79150:79152] CHIP:DMG: Decrypted Payload (387 bytes) =
    [1692344206.501340][79150:79152] CHIP:DMG: {
    [1692344206.501372][79150:79152] CHIP:DMG:     data = 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
    [1692344206.501416][79150:79152] CHIP:DMG: }
    [1692344206.501464][79150:79152] CHIP:DMG:
    [1692344206.501635][79150:79152] CHIP:DMG: Attestation Elements (286 bytes) =
    [1692344206.501672][79150:79152] CHIP:DMG: {
    [1692344206.501705][79150:79152] CHIP:DMG:     Certification Declaration =
    [1692344206.501737][79150:79152] CHIP:DMG:     {
    [1692344206.503304][79150:79152] CHIP:DMG:         Format Version = 1
    [1692344206.503364][79150:79152] CHIP:DMG:         Vendor Id = 5207
    [1692344206.503401][79150:79152] CHIP:DMG:         Product Ids =
    [1692344206.503435][79150:79152] CHIP:DMG:         {
    [1692344206.503471][79150:79152] CHIP:DMG:             Product Id = 1
    [1692344206.503507][79150:79152] CHIP:DMG:         }
    [1692344206.503543][79150:79152] CHIP:DMG:         Device Type Id = 514
    [1692344206.503586][79150:79152] CHIP:DMG:         Certificate Id (19) = CSA00000MAT00000-00
    [1692344206.503625][79150:79152] CHIP:DMG:         Security Level = 0
    [1692344206.503662][79150:79152] CHIP:DMG:         Security Information = 0
    [1692344206.503699][79150:79152] CHIP:DMG:         Version Number = 1
    [1692344206.503754][79150:79152] CHIP:DMG:         Certification Type = 1
    [1692344206.503791][79150:79152] CHIP:DMG:         DAC Origin Vendor Id = 4945
    [1692344206.503828][79150:79152] CHIP:DMG:         DAC Origin Product Id = 65527
    [1692344206.503864][79150:79152] CHIP:DMG:     }
    [1692344206.503904][79150:79152] CHIP:DMG:     Attestation Nonce (32) = 88284CCD01F53EBF8EA1D8AD7EA39A7DE82080738E54A6F6B33B4835B3200238
    [1692344206.503939][79150:79152] CHIP:DMG:     Timestamp = 0
    [1692344206.503985][79150:79152] CHIP:DMG: }
    [1692344206.504017][79150:79152] CHIP:DMG:
    [1692344206.504060][79150:79152] CHIP:DMG:
    [1692344206.504130][79150:79152] CHIP:DMG: Additional Fields =
    [1692344206.504166][79150:79152] CHIP:DMG: {
    [1692344206.504219][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344206.504255][79150:79152] CHIP:DMG: }
    [1692344206.504286][79150:79152] CHIP:DMG:
    [1692344206.504345][79150:79152] CHIP:EM: >>> [E:51306i S:56692 M:244578380] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344206.504394][79150:79152] CHIP:EM: Found matching exchange: 51306i, Delegate: 0xffffa4057608
    [1692344206.504479][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344206.504545][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344206.504583][79150:79152] CHIP:DMG: {
    [1692344206.504619][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.504672][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344206.504725][79150:79152] CHIP:DMG:      [
    [1692344206.504761][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344206.504811][79150:79152] CHIP:DMG:              {
    [1692344206.504863][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344206.504916][79150:79152] CHIP:DMG:                      {
    [1692344206.504961][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344206.505025][79150:79152] CHIP:DMG:                              {
    [1692344206.505079][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344206.505134][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344206.505187][79150:79152] CHIP:DMG:                                      CommandId = 0x1,
    [1692344206.505251][79150:79152] CHIP:DMG:                              },
    [1692344206.505303][79150:79152] CHIP:DMG:
    [1692344206.505350][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344206.505413][79150:79152] CHIP:DMG:                              {
    [1692344206.505467][79150:79152] CHIP:DMG:                                      0x0 = [
    [1692344206.505694][79150:79152] CHIP:DMG:                                                      0x15, 0x30, 0x01, 0xf3, 0x30, 0x81, 0xf0, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x81, 0xe2, 0x30, 0x81, 0xdf, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x4b, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x3e, 0x04, 0x3c, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0x57, 0x14, 0x36, 0x02, 0x04, 0x01, 0x18, 0x25, 0x03, 0x02, 0x02, 0x2c, 0x04, 0x13, 0x43, 0x53, 0x41, 0x30, 0x30, 0x30, 0x30, 0x30, 0x4d, 0x41, 0x54, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2d, 0x30, 0x30, 0x24, 0x05, 0x00, 0x24, 0x06, 0x00, 0x24, 0x07, 0x01, 0x24, 0x08, 0x01, 0x25, 0x09, 0x51, 0x13, 0x25, 0x0a, 0xf7, 0xff, 0x18, 0x31, 0x7e, 0x30, 0x7c, 0x02, 0x01, 0x03, 0x80, 0x14, 0x62, 0xfa, 0x82, 0x33, 0x59, 0xac, 0xfa, 0xa9, 0x96, 0x3e, 0x1c, 0xfa, 0x14, 0x0a, 0xdd, 0xf5, 0x04, 0xf3, 0x71, 0x60, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x04, 0x48, 0x30, 0x46, 0x02, 0x21, 0x00, 0x88, 0xb5, 0xa4, 0xfa, 0x54, 0xbf, 0xad, 0xf0, 0x8d, 0xb2, 0x4f, 0x1c, 0x38, 0xef, 0x67, 0x1e, 0x3b, 0xd0, 0xd3, 0x4b, 0xc1, 0x48, 0x0c, 0x3d, 0xcb, 0xba, 0xd0, 0x5f, 0xaa, 0x5f, 0x08, 0x88, 0x02, 0x21, 0x00, 0xc5, 0xcc, 0xa7, 0x8a, 0x07, 0xb9, 0xfa, 0x9c, 0xcf, 0x46, 0x0c, 0x68, 0x81, 0x2f, 0x25, 0x98, 0x51, 0xcd, 0xc8, 0x7b, 0x4d, 0xfd, 0x96, 0x3e, 0x49, 0x17, 0x71, 0x4b, 0x0a, 0x24, 0x75, 0x09, 0x30, 0x02, 0x20, 0x88, 0x28, 0x4c, 0xcd, 0x01, 0xf5, 0x3e, 0xbf, 0x8e, 0xa1, 0xd8, 0xad, 0x7e, 0xa3, 0x9a, 0x7d, 0xe8, 0x20, 0x80, 0x73, 0x8e, 0x54, 0xa6, 0xf6, 0xb3, 0x3b, 0x48, 0x35, 0xb3, 0x20, 0x02, 0x38, 0x24, 0x
    [1692344206.505826][79150:79152] CHIP:DMG:                                      ] (286 bytes)
    [1692344206.505879][79150:79152] CHIP:DMG:                                      0x1 = [
    [1692344206.505981][79150:79152] CHIP:DMG:                                                      0xb9, 0xca, 0x21, 0x0f, 0x7b, 0xa9, 0x78, 0x9a, 0x61, 0x8c, 0x55, 0x6e, 0x9e, 0x6e, 0xfa, 0x9b, 0xed, 0x7e, 0x1b, 0x93, 0xb2, 0x11, 0xdb, 0x21, 0x8a, 0xeb, 0x80, 0x83, 0xe3, 0xe2, 0xfb, 0x51, 0x15, 0xc7, 0x78, 0x57, 0x04, 0xdc, 0xd2, 0x8c, 0x7d, 0x98, 0x90, 0xc7, 0xf7, 0x2f, 0x97, 0xf7, 0x87, 0xd4, 0x69, 0xa0, 0x42, 0x23, 0xb6, 0xb9, 0x5a, 0xce, 0xd6, 0x94, 0x31, 0xf4, 0x78, 0x69,
    [1692344206.506050][79150:79152] CHIP:DMG:                                      ] (64 bytes)
    [1692344206.506125][79150:79152] CHIP:DMG:                              },
    [1692344206.506173][79150:79152] CHIP:DMG:                      },
    [1692344206.506220][79150:79152] CHIP:DMG:
    [1692344206.506250][79150:79152] CHIP:DMG:              },
    [1692344206.506288][79150:79152] CHIP:DMG:
    [1692344206.506316][79150:79152] CHIP:DMG:      ],
    [1692344206.506352][79150:79152] CHIP:DMG:
    [1692344206.506380][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.506408][79150:79152] CHIP:DMG: },
    [1692344206.506485][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1692344206.506541][79150:79152] CHIP:CTL: Received Attestation Information from the device
    [1692344206.506577][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1692344206.506606][79150:79152] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 286/286
    [1692344206.506674][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1692344206.506715][79150:79152] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1692344206.506738][79150:79152] CHIP:CTL: Verifying attestation
    [1692344206.548306][79150:79152] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
    [1692344206.548384][79150:79152] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
    [1692344206.548405][79150:79152] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
    [1692344206.548432][79150:79152] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
    [1692344206.548452][79150:79152] CHIP:CTL: Sending CSR request to 0xffff9c00f080 device
    [1692344206.548525][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344206.548556][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344206.548872][79150:79152] CHIP:EM: <<< [E:51307i S:56692 M:241138733] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344206.548914][79150:79152] CHIP:IN: (S) Sending msg 241138733 on secure session with LSID: 56692
    [1692344206.549098][79150:79152] CHIP:DMG: >> to BLE | 241138733 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51307]
    [1692344206.549129][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.549147][79150:79152] CHIP:DMG: {
    [1692344206.549176][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344206.549193][79150:79152] CHIP:DMG:     {
    [1692344206.549209][79150:79152] CHIP:DMG:         Initiator = true
    [1692344206.549225][79150:79152] CHIP:DMG:     }
    [1692344206.549246][79150:79152] CHIP:DMG: }
    [1692344206.549273][79150:79152] CHIP:DMG:
    [1692344206.549296][79150:79152] CHIP:DMG: Encrypted Payload (94 bytes) =
    [1692344206.549313][79150:79152] CHIP:DMG: {
    [1692344206.549330][79150:79152] CHIP:DMG:     data = 007b4a002d7c5f0ecbde3d9c5f1f22307c69bc4be8eb815afaf0c57f75351b488061124578539c7b4626ab46b2d5e4c6d4a67a323d5ddd1e0d28e50b5b252c982aafcf21a7d8707d278f2f3f91b754e3115b12fe2f841016339788b38db1
    [1692344206.549348][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156880
    [1692344206.549372][79150:79152] CHIP:DMG: }
    [1692344206.549388][79150:79152] CHIP:DMG:
    [1692344206.549412][79150:79152] CHIP:DMG: Decrypted Payload (64 bytes) =
    [1692344206.549429][79150:79152] CHIP:DMG: {
    [1692344206.549445][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013e2402041835013000202716927b7e38474d8b0afb5c22c562c1d0845560879f5176da995fccf0937b0318181824ff0118
    [1692344206.549471][79150:79152] CHIP:DMG: }
    [1692344206.549487][79150:79152] CHIP:DMG:
    [1692344206.549544][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344206.549564][79150:79152] CHIP:DMG: {
    [1692344206.549582][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.549611][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344206.549631][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344206.549655][79150:79152] CHIP:DMG:      [
    [1692344206.549674][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344206.549697][79150:79152] CHIP:DMG:              {
    [1692344206.549725][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344206.549749][79150:79152] CHIP:DMG:                      {
    [1692344206.549772][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344206.549797][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344206.549831][79150:79152] CHIP:DMG:                              CommandId = 0x4,
    [1692344206.549855][79150:79152] CHIP:DMG:                      },
    [1692344206.549880][79150:79152] CHIP:DMG:
    [1692344206.549909][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344206.549933][79150:79152] CHIP:DMG:                      {
    [1692344206.549958][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344206.549998][79150:79152] CHIP:DMG:                                              0x27, 0x16, 0x92, 0x7b, 0x7e, 0x38, 0x47, 0x4d, 0x8b, 0x0a, 0xfb, 0x5c, 0x22, 0xc5, 0x62, 0xc1, 0xd0, 0x84, 0x55, 0x60, 0x87, 0x9f, 0x51, 0x76, 0xda, 0x99, 0x5f, 0xcc, 0xf0, 0x93, 0x7b, 0x03,
    [1692344206.550030][79150:79152] CHIP:DMG:                              ] (32 bytes)
    [1692344206.550055][79150:79152] CHIP:DMG:                      },
    [1692344206.550099][79150:79152] CHIP:DMG:              },
    [1692344206.550133][79150:79152] CHIP:DMG:
    [1692344206.550152][79150:79152] CHIP:DMG:      ],
    [1692344206.550177][79150:79152] CHIP:DMG:
    [1692344206.550195][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.550214][79150:79152] CHIP:DMG: },
    [1692344206.550232][79150:79152] CHIP:DMG:
    [1692344206.550370][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344206.550405][79150:79152] CHIP:CTL: Sent CSR request, waiting for the CSR
    [1692344206.550463][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344206.632238][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344206.860664][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.860932][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.949410][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344206.949661][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344206.950812][79150:79152] CHIP:DMG: << from BLE | 244578381 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51307]
    [1692344206.950900][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.950947][79150:79152] CHIP:DMG: {
    [1692344206.951027][79150:79152] CHIP:DMG: }
    [1692344206.951072][79150:79152] CHIP:DMG:
    [1692344206.951126][79150:79152] CHIP:DMG: Encrypted Payload (375 bytes) =
    [1692344206.951169][79150:79152] CHIP:DMG: {
    [1692344206.951212][79150:79152] CHIP:DMG:     data = 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
    [1692344206.951297][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156880
    [1692344206.951340][79150:79152] CHIP:DMG: }
    [1692344206.951380][79150:79152] CHIP:DMG:
    [1692344206.951440][79150:79152] CHIP:DMG: Decrypted Payload (345 bytes) =
    [1692344206.951485][79150:79152] CHIP:DMG: {
    [1692344206.951527][79150:79152] CHIP:DMG:     data = 1528003601153500370024000024013e2402051835013000f5153001cd3081ca3070020100300e310c300a060355040a0c034353523059301306072a8648ce3d020106082a8648ce3d0301070342000483f8969afcd3648c77d897be7fc00ce315b96a24e8a0dcabd2cca5045b26961d0db6ad8d92f1da0be795834c884ff487d65b26f26d0267e270f30e1a6b0a9d5fa000300c06082a8648ce3d04030205000348003045022100cd5dba89fae250d65acb2d790c49fca21fad70d801712fe82b35208b259cf7b8022042dcea4dfeafad26a2c28ece60cf7fee676548ec7286d3359a2322c2a1f940b83002202716927b7e38474d8b0afb5c22c562c1d0845560879f5176da995fccf0937b03183001407aa96abe9412b302d087f3983be4d9ac72e2b68526aaaf571b8ac42fed8d1b3ff1ca71266819e53e970277d45c64cd205e170c9a2bd12277cf040deba2cf4c281818181824ff0118
    [1692344206.951606][79150:79152] CHIP:DMG: }
    [1692344206.951646][79150:79152] CHIP:DMG:
    [1692344206.951827][79150:79152] CHIP:DMG: NOCSR Elements =
    [1692344206.951875][79150:79152] CHIP:DMG: {
    [1692344206.951938][79150:79152] CHIP:DMG:     CSR (205) = 3081CA3070020100300E310C300A060355040A0C034353523059301306072A8648CE3D020106082A8648CE3D0301070342000483F8969AFCD3648C77D897BE7FC00CE315B96A24E8A0DCABD2CCA5045B26961D0DB6AD8D92F1DA0BE795834C884FF487D65B26F26D0267E270F30E1A6B0A9D5FA000300C06082A8648CE3D04030205000348003045022100CD5DBA89FAE250D65ACB2D790C49FCA21FAD70D801712FE82B35208B259CF7B8022042DCEA4DFEAFAD26A2C28ECE60CF7FEE676548EC7286D3359A2322C2A1F940B8
    [1692344206.951996][79150:79152] CHIP:DMG:     CSRNonce (32) = 2716927B7E38474D8B0AFB5C22C562C1D0845560879F5176DA995FCCF0937B03
    [1692344206.952039][79150:79152] CHIP:DMG: }
    [1692344206.952079][79150:79152] CHIP:DMG:
    [1692344206.952120][79150:79152] CHIP:DMG: CSR (205) =
    [1692344206.952210][79150:79152] CHIP:DMG: {
    -----BEGIN CERTIFICATE REQUEST-----
    MIHKMHACAQAwDjEMMAoGA1UECgwDQ1NSMFkwEwYHKoZIzj0CAQYIKoZIzj0DAQcD
    QgAEg/iWmvzTZIx32Je+f8AM4xW5aiTooNyr0sylBFsmlh0Ntq2NkvHaC+eVg0yI
    T/SH1lsm8m0CZ+Jw8w4aawqdX6AAMAwGCCqGSM49BAMCBQADSAAwRQIhAM1duon6
    4lDWWssteQxJ/KIfrXDYAXEv6Cs1IIslnPe4AiBC3OpN/q+tJqLCjs5gz3/uZ2VI
    7HKG0zWaIyLCoflAuA==
    -----END CERTIFICATE REQUEST-----
    [1692344206.952336][79150:79152] CHIP:DMG: }
    [1692344206.952378][79150:79152] CHIP:DMG:
    [1692344206.952431][79150:79152] CHIP:DMG:
    [1692344206.952500][79150:79152] CHIP:DMG: Additional Fields =
    [1692344206.952546][79150:79152] CHIP:DMG: {
    [1692344206.952593][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344206.952637][79150:79152] CHIP:DMG: }
    [1692344206.952677][79150:79152] CHIP:DMG:
    [1692344206.952742][79150:79152] CHIP:EM: >>> [E:51307i S:56692 M:244578381] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344206.952801][79150:79152] CHIP:EM: Found matching exchange: 51307i, Delegate: 0xffffa40573b8
    [1692344206.952909][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344206.952990][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344206.953039][79150:79152] CHIP:DMG: {
    [1692344206.953086][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.953135][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344206.953200][79150:79152] CHIP:DMG:      [
    [1692344206.953267][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344206.953339][79150:79152] CHIP:DMG:              {
    [1692344206.953392][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344206.953452][79150:79152] CHIP:DMG:                      {
    [1692344206.953510][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344206.953593][79150:79152] CHIP:DMG:                              {
    [1692344206.953658][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344206.953731][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344206.953818][79150:79152] CHIP:DMG:                                      CommandId = 0x5,
    [1692344206.953880][79150:79152] CHIP:DMG:                              },
    [1692344206.953941][79150:79152] CHIP:DMG:
    [1692344206.954017][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344206.954109][79150:79152] CHIP:DMG:                              {
    [1692344206.954177][79150:79152] CHIP:DMG:                                      0x0 = [
    [1692344206.954440][79150:79152] CHIP:DMG:                                                      0x15, 0x30, 0x01, 0xcd, 0x30, 0x81, 0xca, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x83, 0xf8, 0x96, 0x9a, 0xfc, 0xd3, 0x64, 0x8c, 0x77, 0xd8, 0x97, 0xbe, 0x7f, 0xc0, 0x0c, 0xe3, 0x15, 0xb9, 0x6a, 0x24, 0xe8, 0xa0, 0xdc, 0xab, 0xd2, 0xcc, 0xa5, 0x04, 0x5b, 0x26, 0x96, 0x1d, 0x0d, 0xb6, 0xad, 0x8d, 0x92, 0xf1, 0xda, 0x0b, 0xe7, 0x95, 0x83, 0x4c, 0x88, 0x4f, 0xf4, 0x87, 0xd6, 0x5b, 0x26, 0xf2, 0x6d, 0x02, 0x67, 0xe2, 0x70, 0xf3, 0x0e, 0x1a, 0x6b, 0x0a, 0x9d, 0x5f, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x48, 0x00, 0x30, 0x45, 0x02, 0x21, 0x00, 0xcd, 0x5d, 0xba, 0x89, 0xfa, 0xe2, 0x50, 0xd6, 0x5a, 0xcb, 0x2d, 0x79, 0x0c, 0x49, 0xfc, 0xa2, 0x1f, 0xad, 0x70, 0xd8, 0x01, 0x71, 0x2f, 0xe8, 0x2b, 0x35, 0x20, 0x8b, 0x25, 0x9c, 0xf7, 0xb8, 0x02, 0x20, 0x42, 0xdc, 0xea, 0x4d, 0xfe, 0xaf, 0xad, 0x26, 0xa2, 0xc2, 0x8e, 0xce, 0x60, 0xcf, 0x7f, 0xee, 0x67, 0x65, 0x48, 0xec, 0x72, 0x86, 0xd3, 0x35, 0x9a, 0x23, 0x22, 0xc2, 0xa1, 0xf9, 0x40, 0xb8, 0x30, 0x02, 0x20, 0x27, 0x16, 0x92, 0x7b, 0x7e, 0x38, 0x47, 0x4d, 0x8b, 0x0a, 0xfb, 0x5c, 0x22, 0xc5, 0x62, 0xc1, 0xd0, 0x84, 0x55, 0x60, 0x87, 0x9f, 0x51, 0x76, 0xda, 0x99, 0x5f, 0xcc, 0xf0, 0x93, 0x7b, 0x03, 0x18,
    [1692344206.954597][79150:79152] CHIP:DMG:                                      ] (245 bytes)
    [1692344206.954666][79150:79152] CHIP:DMG:                                      0x1 = [
    [1692344206.954796][79150:79152] CHIP:DMG:                                                      0x7a, 0xa9, 0x6a, 0xbe, 0x94, 0x12, 0xb3, 0x02, 0xd0, 0x87, 0xf3, 0x98, 0x3b, 0xe4, 0xd9, 0xac, 0x72, 0xe2, 0xb6, 0x85, 0x26, 0xaa, 0xaf, 0x57, 0x1b, 0x8a, 0xc4, 0x2f, 0xed, 0x8d, 0x1b, 0x3f, 0xf1, 0xca, 0x71, 0x26, 0x68, 0x19, 0xe5, 0x3e, 0x97, 0x02, 0x77, 0xd4, 0x5c, 0x64, 0xcd, 0x20, 0x5e, 0x17, 0x0c, 0x9a, 0x2b, 0xd1, 0x22, 0x77, 0xcf, 0x04, 0x0d, 0xeb, 0xa2, 0xcf, 0x4c, 0x28,
    [1692344206.954882][79150:79152] CHIP:DMG:                                      ] (64 bytes)
    [1692344206.954956][79150:79152] CHIP:DMG:                              },
    [1692344206.955017][79150:79152] CHIP:DMG:                      },
    [1692344206.955086][79150:79152] CHIP:DMG:
    [1692344206.955137][79150:79152] CHIP:DMG:              },
    [1692344206.955202][79150:79152] CHIP:DMG:
    [1692344206.955250][79150:79152] CHIP:DMG:      ],
    [1692344206.955313][79150:79152] CHIP:DMG:
    [1692344206.955361][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.955408][79150:79152] CHIP:DMG: },
    [1692344206.955554][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
    [1692344206.955621][79150:79152] CHIP:CTL: Received certificate signing request from the device
    [1692344206.955677][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
    [1692344206.955722][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
    [1692344206.955775][79150:79152] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
    [1692344206.965296][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
    [1692344206.965355][79150:79152] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
    [1692344206.965380][79150:79152] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
    [1692344206.965401][79150:79152] CHIP:CTL: Getting certificate chain for the device from the issuer
    [1692344206.969157][79150:79152] CHIP:CTL: Verifying Certificate Signing Request
    [1692344206.971477][79150:79152] CHIP:CTL: Generating NOC
    [1692344206.971848][79150:79152] CHIP:CTL: Providing certificate chain to the commissioner
    [1692344206.971884][79150:79152] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
    [1692344206.971914][79150:79152] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
    [1692344206.972074][79150:79152] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
    [1692344206.972110][79150:79152] CHIP:CTL: Sending root certificate to the device
    [1692344206.972187][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344206.972225][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344206.972550][79150:79152] CHIP:EM: <<< [E:51308i S:56692 M:241138734] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344206.972594][79150:79152] CHIP:IN: (S) Sending msg 241138734 on secure session with LSID: 56692
    [1692344206.972853][79150:79152] CHIP:DMG: >> to BLE | 241138734 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51308]
    [1692344206.972888][79150:79152] CHIP:DMG: Header Flags =
    [1692344206.972907][79150:79152] CHIP:DMG: {
    [1692344206.972937][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344206.972956][79150:79152] CHIP:DMG:     {
    [1692344206.972972][79150:79152] CHIP:DMG:         Initiator = true
    [1692344206.972989][79150:79152] CHIP:DMG:     }
    [1692344206.973013][79150:79152] CHIP:DMG: }
    [1692344206.973041][79150:79152] CHIP:DMG:
    [1692344206.973064][79150:79152] CHIP:DMG: Encrypted Payload (293 bytes) =
    [1692344206.973082][79150:79152] CHIP:DMG: {
    [1692344206.973099][79150:79152] CHIP:DMG:     data = 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
    [1692344206.973123][79150:79152] CHIP:DMG:     buffer_ptr = 281473299174560
    [1692344206.973149][79150:79152] CHIP:DMG: }
    [1692344206.973166][79150:79152] CHIP:DMG:
    [1692344206.973191][79150:79152] CHIP:DMG: Decrypted Payload (263 bytes) =
    [1692344206.973209][79150:79152] CHIP:DMG: {
    [1692344206.973226][79150:79152] CHIP:DMG:     data = 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
    [1692344206.973248][79150:79152] CHIP:DMG: }
    [1692344206.973273][79150:79152] CHIP:DMG:
    [1692344206.973343][79150:79152] CHIP:DMG: RCACValue (231) =
    [1692344206.973375][79150:79152] CHIP:DMG: {
    FTABAQEkAgE3AyQUARgmBIAigScmBYAlTTo3BiQUARgkBwEkCAEwCUEEFFwEl5HG8AZrzFzAZejKY8Y8kmnwYjAbvll8TS52noR711H41qTaz8Uk4bIryZY3rZD1jz58YDHt1ZH22TPE6TcKNQEpARgkAmAwBBRjKfPpF96gzNLCFepPCXofLr7W1DAFFGMp8+kX3qDM0sIV6k8Jeh8uvtbUGDALQLk/+05GUhCsIZNH1/mfErouZmHU+ajVlOxQhtZzvSckhblefqh39teHfjzdqHQM0VvlmEqcuvJGBabqr4c2UZ0Y
    [1692344206.973409][79150:79152] CHIP:DMG: }
    [1692344206.973426][79150:79152] CHIP:DMG:
    [1692344206.973460][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344206.973480][79150:79152] CHIP:DMG: {
    [1692344206.973498][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344206.973520][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344206.973540][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344206.973566][79150:79152] CHIP:DMG:      [
    [1692344206.973586][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344206.973621][79150:79152] CHIP:DMG:              {
    [1692344206.973643][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344206.973669][79150:79152] CHIP:DMG:                      {
    [1692344206.973697][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344206.973724][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344206.973750][79150:79152] CHIP:DMG:                              CommandId = 0xb,
    [1692344206.973774][79150:79152] CHIP:DMG:                      },
    [1692344206.973801][79150:79152] CHIP:DMG:
    [1692344206.973822][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344206.973847][79150:79152] CHIP:DMG:                      {
    [1692344206.973900][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344206.974003][79150:79152] CHIP:DMG:                                              0x15, 0x30, 0x01, 0x01, 0x01, 0x24, 0x02, 0x01, 0x37, 0x03, 0x24, 0x14, 0x01, 0x18, 0x26, 0x04, 0x80, 0x22, 0x81, 0x27, 0x26, 0x05, 0x80, 0x25, 0x4d, 0x3a, 0x37, 0x06, 0x24, 0x14, 0x01, 0x18, 0x24, 0x07, 0x01, 0x24, 0x08, 0x01, 0x30, 0x09, 0x41, 0x04, 0x14, 0x5c, 0x04, 0x97, 0x91, 0xc6, 0xf0, 0x06, 0x6b, 0xcc, 0x5c, 0xc0, 0x65, 0xe8, 0xca, 0x63, 0xc6, 0x3c, 0x92, 0x69, 0xf0, 0x62, 0x30, 0x1b, 0xbe, 0x59, 0x7c, 0x4d, 0x2e, 0x76, 0x9e, 0x84, 0x7b, 0xd7, 0x51, 0xf8, 0xd6, 0xa4, 0xda, 0xcf, 0xc5, 0x24, 0xe1, 0xb2, 0x2b, 0xc9, 0x96, 0x37, 0xad, 0x90, 0xf5, 0x8f, 0x3e, 0x7c, 0x60, 0x31, 0xed, 0xd5, 0x91, 0xf6, 0xd9, 0x33, 0xc4, 0xe9, 0x37, 0x0a, 0x35, 0x01, 0x29, 0x01, 0x18, 0x24, 0x02, 0x60, 0x30, 0x04, 0x14, 0x63, 0x29, 0xf3, 0xe9, 0x17, 0xde, 0xa0, 0xcc, 0xd2, 0xc2, 0x15, 0xea, 0x4f, 0x09, 0x7a, 0x1f, 0x2e, 0xbe, 0xd6, 0xd4, 0x30, 0x05, 0x14, 0x63, 0x29, 0xf3, 0xe9, 0x17, 0xde, 0xa0, 0xcc, 0xd2, 0xc2, 0x15, 0xea, 0x4f, 0x09, 0x7a, 0x1f, 0x2e, 0xbe, 0xd6, 0xd4, 0x18, 0x30, 0x0b, 0x40, 0xb9, 0x3f, 0xfb, 0x4e, 0x46, 0x52, 0x10, 0xac, 0x21, 0x93, 0x47, 0xd7, 0xf9, 0x9f, 0x12, 0xba, 0x2e, 0x66, 0x61, 0xd4, 0xf9, 0xa8, 0xd5, 0x94, 0xec, 0x50, 0x86, 0xd6, 0x73, 0xbd, 0x27, 0x24, 0x85, 0xb9, 0x5e, 0x7e, 0xa8, 0x77, 0xf6, 0xd7, 0x87, 0x7e, 0x3c, 0xdd, 0xa8, 0x74, 0x0c, 0xd1, 0x5b, 0xe5, 0x98, 0x4a, 0x9c, 0xba, 0xf2, 0x46, 0x05, 0xa6, 0xea, 0xaf, 0x87, 0x36, 0x51, 0x9d, 0x18,
    [1692344206.974058][79150:79152] CHIP:DMG:                              ] (231 bytes)
    [1692344206.974104][79150:79152] CHIP:DMG:                      },
    [1692344206.974127][79150:79152] CHIP:DMG:              },
    [1692344206.974163][79150:79152] CHIP:DMG:
    [1692344206.974183][79150:79152] CHIP:DMG:      ],
    [1692344206.974209][79150:79152] CHIP:DMG:
    [1692344206.974229][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344206.974248][79150:79152] CHIP:DMG: },
    [1692344206.974267][79150:79152] CHIP:DMG:
    [1692344206.974401][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344206.974456][79150:79152] CHIP:CTL: Sent root certificate to the device
    [1692344206.974927][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344207.037544][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.127456][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.173509][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344207.173723][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344207.174716][79150:79152] CHIP:DMG: << from BLE | 244578382 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51308]
    [1692344207.174802][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.174848][79150:79152] CHIP:DMG: {
    [1692344207.174926][79150:79152] CHIP:DMG: }
    [1692344207.174971][79150:79152] CHIP:DMG:
    [1692344207.175024][79150:79152] CHIP:DMG: Encrypted Payload (63 bytes) =
    [1692344207.175067][79150:79152] CHIP:DMG: {
    [1692344207.175109][79150:79152] CHIP:DMG:     data = 0074dd004ef8930ed898ccb97edee8e2e8b36bf057b4f1f6436091ef188ea7f1df233d0d34661c6b1a120e1e28a8e1a265897aacfc242b8c52cd45d441dece
    [1692344207.175154][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156688
    [1692344207.175218][79150:79152] CHIP:DMG: }
    [1692344207.175259][79150:79152] CHIP:DMG:
    [1692344207.175320][79150:79152] CHIP:DMG: Decrypted Payload (33 bytes) =
    [1692344207.175364][79150:79152] CHIP:DMG: {
    [1692344207.175406][79150:79152] CHIP:DMG:     data = 1528003601153501370024000024013e24020b1835012400001818181824ff0118
    [1692344207.175469][79150:79152] CHIP:DMG: }
    [1692344207.175510][79150:79152] CHIP:DMG:
    [1692344207.175607][79150:79152] CHIP:DMG:
    [1692344207.175677][79150:79152] CHIP:DMG: Additional Fields =
    [1692344207.175723][79150:79152] CHIP:DMG: {
    [1692344207.175789][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344207.175834][79150:79152] CHIP:DMG: }
    [1692344207.175874][79150:79152] CHIP:DMG:
    [1692344207.175938][79150:79152] CHIP:EM: >>> [E:51308i S:56692 M:244578382] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344207.175997][79150:79152] CHIP:EM: Found matching exchange: 51308i, Delegate: 0xffffa4057608
    [1692344207.176097][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344207.176175][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344207.176224][79150:79152] CHIP:DMG: {
    [1692344207.176298][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.176350][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344207.176413][79150:79152] CHIP:DMG:      [
    [1692344207.176462][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344207.176548][79150:79152] CHIP:DMG:              {
    [1692344207.176602][79150:79152] CHIP:DMG:                      CommandStatusIB =
    [1692344207.176667][79150:79152] CHIP:DMG:                      {
    [1692344207.176723][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344207.176806][79150:79152] CHIP:DMG:                              {
    [1692344207.176871][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344207.176938][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344207.177023][79150:79152] CHIP:DMG:                                      CommandId = 0xb,
    [1692344207.177088][79150:79152] CHIP:DMG:                              },
    [1692344207.177160][79150:79152] CHIP:DMG:
    [1692344207.177235][79150:79152] CHIP:DMG:                              StatusIB =
    [1692344207.177302][79150:79152] CHIP:DMG:                              {
    [1692344207.177368][79150:79152] CHIP:DMG:                                      status = 0x00 (SUCCESS),
    [1692344207.177433][79150:79152] CHIP:DMG:                              },
    [1692344207.177514][79150:79152] CHIP:DMG:
    [1692344207.177573][79150:79152] CHIP:DMG:                      },
    [1692344207.177640][79150:79152] CHIP:DMG:
    [1692344207.177708][79150:79152] CHIP:DMG:              },
    [1692344207.177771][79150:79152] CHIP:DMG:
    [1692344207.177818][79150:79152] CHIP:DMG:      ],
    [1692344207.177878][79150:79152] CHIP:DMG:
    [1692344207.177944][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.177993][79150:79152] CHIP:DMG: },
    [1692344207.178140][79150:79152] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
    [1692344207.178215][79150:79152] CHIP:CTL: Device confirmed that it has received the root certificate
    [1692344207.178269][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
    [1692344207.178313][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
    [1692344207.178365][79150:79152] CHIP:CTL: Performing next commissioning step 'SendNOC'
    [1692344207.178514][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344207.178586][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344207.179330][79150:79152] CHIP:EM: <<< [E:51309i S:56692 M:241138735] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344207.179419][79150:79152] CHIP:IN: (S) Sending msg 241138735 on secure session with LSID: 56692
    [1692344207.179964][79150:79152] CHIP:DMG: >> to BLE | 241138735 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51309]
    [1692344207.180040][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.180086][79150:79152] CHIP:DMG: {
    [1692344207.180155][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344207.180199][79150:79152] CHIP:DMG:     {
    [1692344207.180238][79150:79152] CHIP:DMG:         Initiator = true
    [1692344207.180280][79150:79152] CHIP:DMG:     }
    [1692344207.180335][79150:79152] CHIP:DMG: }
    [1692344207.180403][79150:79152] CHIP:DMG:
    [1692344207.180462][79150:79152] CHIP:DMG: Encrypted Payload (566 bytes) =
    [1692344207.180506][79150:79152] CHIP:DMG: {
    [1692344207.180548][79150:79152] CHIP:DMG:     data = 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
    [1692344207.180656][79150:79152] CHIP:DMG:     buffer_ptr = 281473299174560
    [1692344207.180697][79150:79152] CHIP:DMG: }
    [1692344207.180737][79150:79152] CHIP:DMG:
    [1692344207.180803][79150:79152] CHIP:DMG: Decrypted Payload (536 bytes) =
    [1692344207.180847][79150:79152] CHIP:DMG: {
    [1692344207.180890][79150:79152] CHIP:DMG:     data = 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
    [1692344207.181005][79150:79152] CHIP:DMG: }
    [1692344207.181046][79150:79152] CHIP:DMG:
    [1692344207.181252][79150:79152] CHIP:DMG: NOCValue (241) =
    [1692344207.181327][79150:79152] CHIP:DMG: {
    FTABAQEkAgE3AyQTAhgmBIAigScmBYAlTTo3BiQVASQRARgkBwEkCAEwCUEEg/iWmvzTZIx32Je+f8AM4xW5aiTooNyr0sylBFsmlh0Ntq2NkvHaC+eVg0yIT/SH1lsm8m0CZ+Jw8w4aawqdXzcKNQEoARgkAgE2AwQCBAEYMAQUVKShInSYk1yEHOOA+mTGpTQnCPIwBRQHf3I7MLpxz0yurDSWP8JbupDQnhgwC0CCupXgL5IBl6jwWLoBF7G9zoCrCrHP+rARvcWZpo4dpxK4PgCJO1x/iCbLLnVkaK9ZrMTP2/XSItHCop9FUcc7GA==
    [1692344207.181409][79150:79152] CHIP:DMG: }
    [1692344207.181449][79150:79152] CHIP:DMG:
    [1692344207.181492][79150:79152] CHIP:DMG: ICACValue (231) =
    [1692344207.181552][79150:79152] CHIP:DMG: {
    FTABAQEkAgE3AyQUARgmBIAigScmBYAlTTo3BiQTAhgkBwEkCAEwCUEEEcI94xYYFlflcmpRP7Tyi8PQ9anm4ps9Wj5G1XuCKVEW8K5n9gkNI6N9KN4Kx2peouq9vbeZU3DecKZfW5TarjcKNQEpARgkAmAwBBQHf3I7MLpxz0yurDSWP8JbupDQnjAFFGMp8+kX3qDM0sIV6k8Jeh8uvtbUGDALQLa+9s0fbrcCXcWhmKPrc4OjZ1qWinlEBmtcMeR0kzsteiq9nSOtwQkcVFL4UZIwAjK1kBZkBUFf/CLcexXJ+fIY
    [1692344207.181655][79150:79152] CHIP:DMG: }
    [1692344207.181695][79150:79152] CHIP:DMG:
    [1692344207.181773][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344207.181821][79150:79152] CHIP:DMG: {
    [1692344207.181866][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.181918][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344207.181965][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344207.182032][79150:79152] CHIP:DMG:      [
    [1692344207.182114][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344207.182172][79150:79152] CHIP:DMG:              {
    [1692344207.182223][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344207.182283][79150:79152] CHIP:DMG:                      {
    [1692344207.182344][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344207.182402][79150:79152] CHIP:DMG:                              ClusterId = 0x3e,
    [1692344207.182482][79150:79152] CHIP:DMG:                              CommandId = 0x6,
    [1692344207.182543][79150:79152] CHIP:DMG:                      },
    [1692344207.182606][79150:79152] CHIP:DMG:
    [1692344207.182659][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344207.182719][79150:79152] CHIP:DMG:                      {
    [1692344207.182780][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344207.183033][79150:79152] CHIP:DMG:                                              0x15, 0x30, 0x01, 0x01, 0x01, 0x24, 0x02, 0x01, 0x37, 0x03, 0x24, 0x13, 0x02, 0x18, 0x26, 0x04, 0x80, 0x22, 0x81, 0x27, 0x26, 0x05, 0x80, 0x25, 0x4d, 0x3a, 0x37, 0x06, 0x24, 0x15, 0x01, 0x24, 0x11, 0x01, 0x18, 0x24, 0x07, 0x01, 0x24, 0x08, 0x01, 0x30, 0x09, 0x41, 0x04, 0x83, 0xf8, 0x96, 0x9a, 0xfc, 0xd3, 0x64, 0x8c, 0x77, 0xd8, 0x97, 0xbe, 0x7f, 0xc0, 0x0c, 0xe3, 0x15, 0xb9, 0x6a, 0x24, 0xe8, 0xa0, 0xdc, 0xab, 0xd2, 0xcc, 0xa5, 0x04, 0x5b, 0x26, 0x96, 0x1d, 0x0d, 0xb6, 0xad, 0x8d, 0x92, 0xf1, 0xda, 0x0b, 0xe7, 0x95, 0x83, 0x4c, 0x88, 0x4f, 0xf4, 0x87, 0xd6, 0x5b, 0x26, 0xf2, 0x6d, 0x02, 0x67, 0xe2, 0x70, 0xf3, 0x0e, 0x1a, 0x6b, 0x0a, 0x9d, 0x5f, 0x37, 0x0a, 0x35, 0x01, 0x28, 0x01, 0x18, 0x24, 0x02, 0x01, 0x36, 0x03, 0x04, 0x02, 0x04, 0x01, 0x18, 0x30, 0x04, 0x14, 0x54, 0xa4, 0xa1, 0x22, 0x74, 0x98, 0x93, 0x5c, 0x84, 0x1c, 0xe3, 0x80, 0xfa, 0x64, 0xc6, 0xa5, 0x34, 0x27, 0x08, 0xf2, 0x30, 0x05, 0x14, 0x07, 0x7f, 0x72, 0x3b, 0x30, 0xba, 0x71, 0xcf, 0x4c, 0xae, 0xac, 0x34, 0x96, 0x3f, 0xc2, 0x5b, 0xba, 0x90, 0xd0, 0x9e, 0x18, 0x30, 0x0b, 0x40, 0x82, 0xba, 0x95, 0xe0, 0x2f, 0x92, 0x01, 0x97, 0xa8, 0xf0, 0x58, 0xba, 0x01, 0x17, 0xb1, 0xbd, 0xce, 0x80, 0xab, 0x0a, 0xb1, 0xcf, 0xfa, 0xb0, 0x11, 0xbd, 0xc5, 0x99, 0xa6, 0x8e, 0x1d, 0xa7, 0x12, 0xb8, 0x3e, 0x00, 0x89, 0x3b, 0x5c, 0x7f, 0x88, 0x26, 0xcb, 0x2e, 0x75, 0x64, 0x68, 0xaf, 0x59, 0xac, 0xc4, 0xcf, 0xdb, 0xf5, 0xd2, 0x22, 0xd1, 0xc2, 0xa2, 0x9f, 0x45, 0x51, 0xc7, 0x3b, 0x18,
    [1692344207.183168][79150:79152] CHIP:DMG:                              ] (241 bytes)
    [1692344207.183231][79150:79152] CHIP:DMG:                              0x1 = [
    [1692344207.183474][79150:79152] CHIP:DMG:                                              0x15, 0x30, 0x01, 0x01, 0x01, 0x24, 0x02, 0x01, 0x37, 0x03, 0x24, 0x14, 0x01, 0x18, 0x26, 0x04, 0x80, 0x22, 0x81, 0x27, 0x26, 0x05, 0x80, 0x25, 0x4d, 0x3a, 0x37, 0x06, 0x24, 0x13, 0x02, 0x18, 0x24, 0x07, 0x01, 0x24, 0x08, 0x01, 0x30, 0x09, 0x41, 0x04, 0x11, 0xc2, 0x3d, 0xe3, 0x16, 0x18, 0x16, 0x57, 0xe5, 0x72, 0x6a, 0x51, 0x3f, 0xb4, 0xf2, 0x8b, 0xc3, 0xd0, 0xf5, 0xa9, 0xe6, 0xe2, 0x9b, 0x3d, 0x5a, 0x3e, 0x46, 0xd5, 0x7b, 0x82, 0x29, 0x51, 0x16, 0xf0, 0xae, 0x67, 0xf6, 0x09, 0x0d, 0x23, 0xa3, 0x7d, 0x28, 0xde, 0x0a, 0xc7, 0x6a, 0x5e, 0xa2, 0xea, 0xbd, 0xbd, 0xb7, 0x99, 0x53, 0x70, 0xde, 0x70, 0xa6, 0x5f, 0x5b, 0x94, 0xda, 0xae, 0x37, 0x0a, 0x35, 0x01, 0x29, 0x01, 0x18, 0x24, 0x02, 0x60, 0x30, 0x04, 0x14, 0x07, 0x7f, 0x72, 0x3b, 0x30, 0xba, 0x71, 0xcf, 0x4c, 0xae, 0xac, 0x34, 0x96, 0x3f, 0xc2, 0x5b, 0xba, 0x90, 0xd0, 0x9e, 0x30, 0x05, 0x14, 0x63, 0x29, 0xf3, 0xe9, 0x17, 0xde, 0xa0, 0xcc, 0xd2, 0xc2, 0x15, 0xea, 0x4f, 0x09, 0x7a, 0x1f, 0x2e, 0xbe, 0xd6, 0xd4, 0x18, 0x30, 0x0b, 0x40, 0xb6, 0xbe, 0xf6, 0xcd, 0x1f, 0x6e, 0xb7, 0x02, 0x5d, 0xc5, 0xa1, 0x98, 0xa3, 0xeb, 0x73, 0x83, 0xa3, 0x67, 0x5a, 0x96, 0x8a, 0x79, 0x44, 0x06, 0x6b, 0x5c, 0x31, 0xe4, 0x74, 0x93, 0x3b, 0x2d, 0x7a, 0x2a, 0xbd, 0x9d, 0x23, 0xad, 0xc1, 0x09, 0x1c, 0x54, 0x52, 0xf8, 0x51, 0x92, 0x30, 0x02, 0x32, 0xb5, 0x90, 0x16, 0x64, 0x05, 0x41, 0x5f, 0xfc, 0x22, 0xdc, 0x7b, 0x15, 0xc9, 0xf9, 0xf2, 0x18,
    [1692344207.183603][79150:79152] CHIP:DMG:                              ] (231 bytes)
    [1692344207.183666][79150:79152] CHIP:DMG:                              0x2 = [
    [1692344207.183738][79150:79152] CHIP:DMG:                                              0x74, 0x65, 0x6d, 0x70, 0x6f, 0x72, 0x61, 0x72, 0x79, 0x20, 0x69, 0x70, 0x6b, 0x20, 0x30, 0x31,
    [1692344207.183813][79150:79152] CHIP:DMG:                              ] (16 bytes)
    [1692344207.183897][79150:79152] CHIP:DMG:                              0x3 = 112233,
    [1692344207.183964][79150:79152] CHIP:DMG:                              0x4 = 65521,
    [1692344207.184028][79150:79152] CHIP:DMG:                      },
    [1692344207.184084][79150:79152] CHIP:DMG:              },
    [1692344207.184150][79150:79152] CHIP:DMG:
    [1692344207.184199][79150:79152] CHIP:DMG:      ],
    [1692344207.184266][79150:79152] CHIP:DMG:
    [1692344207.184308][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.184328][79150:79152] CHIP:DMG: },
    [1692344207.184348][79150:79152] CHIP:DMG:
    [1692344207.184490][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344207.184534][79150:79152] CHIP:CTL: Sent operational certificate to the device
    [1692344207.184580][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344207.307394][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.442527][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.531521][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.668648][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344207.668917][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344207.669936][79150:79152] CHIP:DMG: << from BLE | 244578383 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51309]
    [1692344207.670044][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.670187][79150:79152] CHIP:DMG: {
    [1692344207.670297][79150:79152] CHIP:DMG: }
    [1692344207.670358][79150:79152] CHIP:DMG:
    [1692344207.670431][79150:79152] CHIP:DMG: Encrypted Payload (66 bytes) =
    [1692344207.670491][79150:79152] CHIP:DMG: {
    [1692344207.670549][79150:79152] CHIP:DMG:     data = 0074dd004ff8930e33cde00c0d57ebfc3ef88862d0a756a6b0b471ba5a9c6c7a0da3ee24909d162403e847237d3a45feb722a17de3ba1cc3b62a1e0813003af3d049
    [1692344207.670610][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156688
    [1692344207.670664][79150:79152] CHIP:DMG: }
    [1692344207.670717][79150:79152] CHIP:DMG:
    [1692344207.670797][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344207.670858][79150:79152] CHIP:DMG: {
    [1692344207.670917][79150:79152] CHIP:DMG:     data = 1528003601153500370024000024013e2402081835012400002401011818181824ff0118
    [1692344207.670975][79150:79152] CHIP:DMG: }
    [1692344207.671029][79150:79152] CHIP:DMG:
    [1692344207.671156][79150:79152] CHIP:DMG:
    [1692344207.671248][79150:79152] CHIP:DMG: Additional Fields =
    [1692344207.671308][79150:79152] CHIP:DMG: {
    [1692344207.671369][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344207.671428][79150:79152] CHIP:DMG: }
    [1692344207.671483][79150:79152] CHIP:DMG:
    [1692344207.671598][79150:79152] CHIP:EM: >>> [E:51309i S:56692 M:244578383] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344207.671677][79150:79152] CHIP:EM: Found matching exchange: 51309i, Delegate: 0xffffa40573b8
    [1692344207.671777][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344207.671881][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344207.671947][79150:79152] CHIP:DMG: {
    [1692344207.671997][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.672050][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344207.672123][79150:79152] CHIP:DMG:      [
    [1692344207.672180][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344207.672258][79150:79152] CHIP:DMG:              {
    [1692344207.672328][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344207.672425][79150:79152] CHIP:DMG:                      {
    [1692344207.672493][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344207.672570][79150:79152] CHIP:DMG:                              {
    [1692344207.672646][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344207.672727][79150:79152] CHIP:DMG:                                      ClusterId = 0x3e,
    [1692344207.672831][79150:79152] CHIP:DMG:                                      CommandId = 0x8,
    [1692344207.672909][79150:79152] CHIP:DMG:                              },
    [1692344207.672989][79150:79152] CHIP:DMG:
    [1692344207.673058][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344207.673156][79150:79152] CHIP:DMG:                              {
    [1692344207.673234][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344207.673318][79150:79152] CHIP:DMG:                                      0x1 = 1,
    [1692344207.673419][79150:79152] CHIP:DMG:                              },
    [1692344207.673492][79150:79152] CHIP:DMG:                      },
    [1692344207.673573][79150:79152] CHIP:DMG:
    [1692344207.673654][79150:79152] CHIP:DMG:              },
    [1692344207.673713][79150:79152] CHIP:DMG:
    [1692344207.673744][79150:79152] CHIP:DMG:      ],
    [1692344207.673783][79150:79152] CHIP:DMG:
    [1692344207.673827][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.673858][79150:79152] CHIP:DMG: },
    [1692344207.673937][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
    [1692344207.673996][79150:79152] CHIP:CTL: Device returned status 0 on receiving the NOC
    [1692344207.674027][79150:79152] CHIP:CTL: Operational credentials provisioned on device 0xffff9c00f080
    [1692344207.674054][79150:79152] CHIP:TOO: Secure Pairing Success
    [1692344207.674102][79150:79152] CHIP:TOO: CASE establishment successful
    [1692344207.674150][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
    [1692344207.674182][79150:79152] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
    [1692344207.674210][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
    [1692344207.674246][79150:79152] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
    [1692344207.674357][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344207.674403][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344207.674814][79150:79152] CHIP:EM: <<< [E:51310i S:56692 M:241138736] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344207.674876][79150:79152] CHIP:IN: (S) Sending msg 241138736 on secure session with LSID: 56692
    [1692344207.675174][79150:79152] CHIP:DMG: >> to BLE | 241138736 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51310]
    [1692344207.675222][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.675251][79150:79152] CHIP:DMG: {
    [1692344207.675296][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344207.675324][79150:79152] CHIP:DMG:     {
    [1692344207.675349][79150:79152] CHIP:DMG:         Initiator = true
    [1692344207.675376][79150:79152] CHIP:DMG:     }
    [1692344207.675411][79150:79152] CHIP:DMG: }
    [1692344207.675453][79150:79152] CHIP:DMG:
    [1692344207.675489][79150:79152] CHIP:DMG: Encrypted Payload (171 bytes) =
    [1692344207.675517][79150:79152] CHIP:DMG: {
    [1692344207.675544][79150:79152] CHIP:DMG:     data = 007b4a00307c5f0e3af914692b188a459c1374300e1aec678a9c03e626e47fab04b59586fc913523a84b77c9562f553df498679bc57e4ca0090b1b9d3d716c19c4e6c3263a0778f213ca44fb7e6ca9fd4a59ae17f884839520ce0b82394fd52dcc348a17498d603fc1d25585231605cc8979365e44367894c08caa5e14282b128101192f5f03e80747bd40ecf980fae201ed525a09c507a7893d28843cd8325d1948ced8a375521a0606a9
    [1692344207.675587][79150:79152] CHIP:DMG:     buffer_ptr = 281473299174560
    [1692344207.675615][79150:79152] CHIP:DMG: }
    [1692344207.675640][79150:79152] CHIP:DMG:
    [1692344207.675678][79150:79152] CHIP:DMG: Decrypted Payload (141 bytes) =
    [1692344207.675706][79150:79152] CHIP:DMG: {
    [1692344207.675745][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013124020318350130006a0e080000000000010000000300000b35060004001fffe00208695e3bcb08b969680708fd4b099dfa29a57605102b7b7e3d9d0214478ebd7841d79fd392030f4f70656e5468726561642d31303638010210680410725655edc0397183a85837c6ca5703390c0402a0f7f824010f18181824ff0118
    [1692344207.675779][79150:79152] CHIP:DMG: }
    [1692344207.675804][79150:79152] CHIP:DMG:
    [1692344207.675896][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344207.675928][79150:79152] CHIP:DMG: {
    [1692344207.675957][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.675991][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344207.676033][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344207.676074][79150:79152] CHIP:DMG:      [
    [1692344207.676105][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344207.676140][79150:79152] CHIP:DMG:              {
    [1692344207.676172][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344207.676211][79150:79152] CHIP:DMG:                      {
    [1692344207.676262][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344207.676304][79150:79152] CHIP:DMG:                              ClusterId = 0x31,
    [1692344207.676345][79150:79152] CHIP:DMG:                              CommandId = 0x3,
    [1692344207.676384][79150:79152] CHIP:DMG:                      },
    [1692344207.676436][79150:79152] CHIP:DMG:
    [1692344207.676471][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344207.676509][79150:79152] CHIP:DMG:                      {
    [1692344207.676549][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344207.676650][79150:79152] CHIP:DMG:                                              0x0e, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x0b, 0x35, 0x06, 0x00, 0x04, 0x00, 0x1f, 0xff, 0xe0, 0x02, 0x08, 0x69, 0x5e, 0x3b, 0xcb, 0x08, 0xb9, 0x69, 0x68, 0x07, 0x08, 0xfd, 0x4b, 0x09, 0x9d, 0xfa, 0x29, 0xa5, 0x76, 0x05, 0x10, 0x2b, 0x7b, 0x7e, 0x3d, 0x9d, 0x02, 0x14, 0x47, 0x8e, 0xbd, 0x78, 0x41, 0xd7, 0x9f, 0xd3, 0x92, 0x03, 0x0f, 0x4f, 0x70, 0x65, 0x6e, 0x54, 0x68, 0x72, 0x65, 0x61, 0x64, 0x2d, 0x31, 0x30, 0x36, 0x38, 0x01, 0x02, 0x10, 0x68, 0x04, 0x10, 0x72, 0x56, 0x55, 0xed, 0xc0, 0x39, 0x71, 0x83, 0xa8, 0x58, 0x37, 0xc6, 0xca, 0x57, 0x03, 0x39, 0x0c, 0x04, 0x02, 0xa0, 0xf7, 0xf8,
    [1692344207.676718][79150:79152] CHIP:DMG:                              ] (106 bytes)
    [1692344207.676761][79150:79152] CHIP:DMG:                              0x1 = 15,
    [1692344207.676803][79150:79152] CHIP:DMG:                      },
    [1692344207.676838][79150:79152] CHIP:DMG:              },
    [1692344207.676891][79150:79152] CHIP:DMG:
    [1692344207.676922][79150:79152] CHIP:DMG:      ],
    [1692344207.676961][79150:79152] CHIP:DMG:
    [1692344207.676991][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.677021][79150:79152] CHIP:DMG: },
    [1692344207.677049][79150:79152] CHIP:DMG:
    [1692344207.677214][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344207.677297][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344207.801546][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.803206][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344207.803345][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344207.803940][79150:79152] CHIP:DMG: << from BLE | 244578384 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51310]
    [1692344207.803993][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.804019][79150:79152] CHIP:DMG: {
    [1692344207.804065][79150:79152] CHIP:DMG: }
    [1692344207.804091][79150:79152] CHIP:DMG:
    [1692344207.804123][79150:79152] CHIP:DMG: Encrypted Payload (66 bytes) =
    [1692344207.804148][79150:79152] CHIP:DMG: {
    [1692344207.804174][79150:79152] CHIP:DMG:     data = 0074dd0050f8930e7a5ba6e74924ba31c2250e58f42a585e62bad1d9d057cb4746130e4461c644afb812a76a587eb5c259f1ab901b3f2ed29ee636dd27d9dc419eb0
    [1692344207.804200][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156688
    [1692344207.804238][79150:79152] CHIP:DMG: }
    [1692344207.804263][79150:79152] CHIP:DMG:
    [1692344207.804299][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344207.804325][79150:79152] CHIP:DMG: {
    [1692344207.804349][79150:79152] CHIP:DMG:     data = 152800360115350037002400002401312402051835012400002402001818181824ff0118
    [1692344207.804385][79150:79152] CHIP:DMG: }
    [1692344207.804410][79150:79152] CHIP:DMG:
    [1692344207.804476][79150:79152] CHIP:DMG:
    [1692344207.804518][79150:79152] CHIP:DMG: Additional Fields =
    [1692344207.804545][79150:79152] CHIP:DMG: {
    [1692344207.804585][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344207.804611][79150:79152] CHIP:DMG: }
    [1692344207.804634][79150:79152] CHIP:DMG:
    [1692344207.804674][79150:79152] CHIP:EM: >>> [E:51310i S:56692 M:244578384] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344207.804710][79150:79152] CHIP:EM: Found matching exchange: 51310i, Delegate: 0xffffa4057608
    [1692344207.804771][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344207.804820][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344207.804849][79150:79152] CHIP:DMG: {
    [1692344207.804888][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.804918][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344207.804955][79150:79152] CHIP:DMG:      [
    [1692344207.804983][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344207.805035][79150:79152] CHIP:DMG:              {
    [1692344207.805066][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344207.805103][79150:79152] CHIP:DMG:                      {
    [1692344207.805148][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344207.805187][79150:79152] CHIP:DMG:                              {
    [1692344207.805225][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344207.805266][79150:79152] CHIP:DMG:                                      ClusterId = 0x31,
    [1692344207.805317][79150:79152] CHIP:DMG:                                      CommandId = 0x5,
    [1692344207.805356][79150:79152] CHIP:DMG:                              },
    [1692344207.805395][79150:79152] CHIP:DMG:
    [1692344207.805440][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344207.805477][79150:79152] CHIP:DMG:                              {
    [1692344207.805516][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344207.805568][79150:79152] CHIP:DMG:                                      0x2 = 0,
    [1692344207.805609][79150:79152] CHIP:DMG:                              },
    [1692344207.805644][79150:79152] CHIP:DMG:                      },
    [1692344207.805695][79150:79152] CHIP:DMG:
    [1692344207.805726][79150:79152] CHIP:DMG:              },
    [1692344207.805762][79150:79152] CHIP:DMG:
    [1692344207.805801][79150:79152] CHIP:DMG:      ],
    [1692344207.805839][79150:79152] CHIP:DMG:
    [1692344207.805867][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.805894][79150:79152] CHIP:DMG: },
    [1692344207.805979][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1692344207.806120][79150:79152] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
    [1692344207.806161][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
    [1692344207.806188][79150:79152] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'FailsafeBeforeThreadEnable'
    [1692344207.806222][79150:79152] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeThreadEnable'
    [1692344207.806262][79150:79152] CHIP:CTL: Arming failsafe (101 seconds)
    [1692344207.806346][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344207.806383][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344207.806739][79150:79152] CHIP:EM: <<< [E:51311i S:56692 M:241138737] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344207.806793][79150:79152] CHIP:IN: (S) Sending msg 241138737 on secure session with LSID: 56692
    [1692344207.807051][79150:79152] CHIP:DMG: >> to BLE | 241138737 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51311]
    [1692344207.807095][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.807120][79150:79152] CHIP:DMG: {
    [1692344207.807162][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344207.807188][79150:79152] CHIP:DMG:     {
    [1692344207.807210][79150:79152] CHIP:DMG:         Initiator = true
    [1692344207.807235][79150:79152] CHIP:DMG:     }
    [1692344207.807267][79150:79152] CHIP:DMG: }
    [1692344207.807306][79150:79152] CHIP:DMG:
    [1692344207.807340][79150:79152] CHIP:DMG: Encrypted Payload (65 bytes) =
    [1692344207.807365][79150:79152] CHIP:DMG: {
    [1692344207.807390][79150:79152] CHIP:DMG:     data = 007b4a00317c5f0e44c2fc98bcdae1daae54d4572e06d890536349a9b133d87378766077e3bec8fb3e1c65dea9d08c4042e3c927858b4b9341a5ba384483aceae7
    [1692344207.807430][79150:79152] CHIP:DMG:     buffer_ptr = 281473299174560
    [1692344207.807455][79150:79152] CHIP:DMG: }
    [1692344207.807478][79150:79152] CHIP:DMG:
    [1692344207.807514][79150:79152] CHIP:DMG: Decrypted Payload (35 bytes) =
    [1692344207.807539][79150:79152] CHIP:DMG: {
    [1692344207.807577][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013024020018350124006524011118181824ff0118
    [1692344207.807602][79150:79152] CHIP:DMG: }
    [1692344207.807626][79150:79152] CHIP:DMG:
    [1692344207.807696][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344207.807725][79150:79152] CHIP:DMG: {
    [1692344207.807765][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.807796][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344207.807824][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344207.807861][79150:79152] CHIP:DMG:      [
    [1692344207.807889][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344207.807922][79150:79152] CHIP:DMG:              {
    [1692344207.807952][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344207.807986][79150:79152] CHIP:DMG:                      {
    [1692344207.808019][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344207.808057][79150:79152] CHIP:DMG:                              ClusterId = 0x30,
    [1692344207.808094][79150:79152] CHIP:DMG:                              CommandId = 0x0,
    [1692344207.808129][79150:79152] CHIP:DMG:                      },
    [1692344207.808166][79150:79152] CHIP:DMG:
    [1692344207.808197][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344207.808230][79150:79152] CHIP:DMG:                      {
    [1692344207.808265][79150:79152] CHIP:DMG:                              0x0 = 101,
    [1692344207.808303][79150:79152] CHIP:DMG:                              0x1 = 17,
    [1692344207.808340][79150:79152] CHIP:DMG:                      },
    [1692344207.808371][79150:79152] CHIP:DMG:              },
    [1692344207.808407][79150:79152] CHIP:DMG:
    [1692344207.808435][79150:79152] CHIP:DMG:      ],
    [1692344207.808472][79150:79152] CHIP:DMG:
    [1692344207.808499][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.808527][79150:79152] CHIP:DMG: },
    [1692344207.808553][79150:79152] CHIP:DMG:
    [1692344207.808682][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344207.808758][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344207.892419][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344207.894048][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344207.894356][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344207.895354][79150:79152] CHIP:DMG: << from BLE | 244578385 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51311]
    [1692344207.895453][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.895506][79150:79152] CHIP:DMG: {
    [1692344207.895598][79150:79152] CHIP:DMG: }
    [1692344207.895650][79150:79152] CHIP:DMG:
    [1692344207.895714][79150:79152] CHIP:DMG: Encrypted Payload (66 bytes) =
    [1692344207.895764][79150:79152] CHIP:DMG: {
    [1692344207.895814][79150:79152] CHIP:DMG:     data = 0074dd0051f8930e4a39310a7e5f16bf28444155ec8ff50f4730222fa5acb6d76f5d609faaa744260178a6722d0318a3275deb22577a123c0916d266ae7b1da669a5
    [1692344207.895892][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156688
    [1692344207.895944][79150:79152] CHIP:DMG: }
    [1692344207.895990][79150:79152] CHIP:DMG:
    [1692344207.896060][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344207.896111][79150:79152] CHIP:DMG: {
    [1692344207.896185][79150:79152] CHIP:DMG:     data = 152800360115350037002400002401302402011835012400002c01001818181824ff0118
    [1692344207.896236][79150:79152] CHIP:DMG: }
    [1692344207.896282][79150:79152] CHIP:DMG:
    [1692344207.896401][79150:79152] CHIP:DMG:
    [1692344207.896483][79150:79152] CHIP:DMG: Additional Fields =
    [1692344207.896565][79150:79152] CHIP:DMG: {
    [1692344207.896622][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344207.896672][79150:79152] CHIP:DMG: }
    [1692344207.896719][79150:79152] CHIP:DMG:
    [1692344207.896791][79150:79152] CHIP:EM: >>> [E:51311i S:56692 M:244578385] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344207.896880][79150:79152] CHIP:EM: Found matching exchange: 51311i, Delegate: 0xffffa40573b8
    [1692344207.896967][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344207.897057][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344207.897136][79150:79152] CHIP:DMG: {
    [1692344207.897193][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.897249][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344207.897321][79150:79152] CHIP:DMG:      [
    [1692344207.897399][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344207.897478][79150:79152] CHIP:DMG:              {
    [1692344207.897539][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344207.897617][79150:79152] CHIP:DMG:                      {
    [1692344207.897706][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344207.897785][79150:79152] CHIP:DMG:                              {
    [1692344207.897861][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344207.897958][79150:79152] CHIP:DMG:                                      ClusterId = 0x30,
    [1692344207.898039][79150:79152] CHIP:DMG:                                      CommandId = 0x1,
    [1692344207.898167][79150:79152] CHIP:DMG:                              },
    [1692344207.898273][79150:79152] CHIP:DMG:
    [1692344207.898346][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344207.898421][79150:79152] CHIP:DMG:                              {
    [1692344207.898499][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344207.898608][79150:79152] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692344207.898689][79150:79152] CHIP:DMG:                              },
    [1692344207.898779][79150:79152] CHIP:DMG:                      },
    [1692344207.898860][79150:79152] CHIP:DMG:
    [1692344207.898921][79150:79152] CHIP:DMG:              },
    [1692344207.898994][79150:79152] CHIP:DMG:
    [1692344207.899069][79150:79152] CHIP:DMG:      ],
    [1692344207.899144][79150:79152] CHIP:DMG:
    [1692344207.899200][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.899255][79150:79152] CHIP:DMG: },
    [1692344207.899418][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692344207.899500][79150:79152] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1692344207.899588][79150:79152] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
    [1692344207.899642][79150:79152] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
    [1692344207.899704][79150:79152] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
    [1692344207.899871][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344207.899946][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344207.900531][79150:79152] CHIP:EM: <<< [E:51312i S:56692 M:241138738] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344207.900630][79150:79152] CHIP:IN: (S) Sending msg 241138738 on secure session with LSID: 56692
    [1692344207.901120][79150:79152] CHIP:DMG: >> to BLE | 241138738 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19067 / Exchange = 51312]
    [1692344207.901207][79150:79152] CHIP:DMG: Header Flags =
    [1692344207.901258][79150:79152] CHIP:DMG: {
    [1692344207.901341][79150:79152] CHIP:DMG:     Exchange (0x01) =
    [1692344207.901393][79150:79152] CHIP:DMG:     {
    [1692344207.901440][79150:79152] CHIP:DMG:         Initiator = true
    [1692344207.901488][79150:79152] CHIP:DMG:     }
    [1692344207.901552][79150:79152] CHIP:DMG: }
    [1692344207.901623][79150:79152] CHIP:DMG:
    [1692344207.901688][79150:79152] CHIP:DMG: Encrypted Payload (73 bytes) =
    [1692344207.901739][79150:79152] CHIP:DMG: {
    [1692344207.901787][79150:79152] CHIP:DMG:     data = 007b4a00327c5f0eb35d6615c1563a7a08d7ac40b9997c4863edf8fd0e9e8c7c92ad9264b8e5cf670b20adaff2e5a6ac96d8039809195d2cee2066512d4d2e0d95442175517ae17088
    [1692344207.901861][79150:79152] CHIP:DMG:     buffer_ptr = 281473299174560
    [1692344207.901912][79150:79152] CHIP:DMG: }
    [1692344207.901959][79150:79152] CHIP:DMG:
    [1692344207.902028][79150:79152] CHIP:DMG: Decrypted Payload (43 bytes) =
    [1692344207.902108][79150:79152] CHIP:DMG: {
    [1692344207.902160][79150:79152] CHIP:DMG:     data = 15280028013602153700240000240131240206183501300008695e3bcb08b9696824011318181824ff0118
    [1692344207.902234][79150:79152] CHIP:DMG: }
    [1692344207.902282][79150:79152] CHIP:DMG:
    [1692344207.902422][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344207.902480][79150:79152] CHIP:DMG: {
    [1692344207.902532][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344207.902618][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344207.902675][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344207.902748][79150:79152] CHIP:DMG:      [
    [1692344207.902806][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344207.902868][79150:79152] CHIP:DMG:              {
    [1692344207.902950][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344207.903023][79150:79152] CHIP:DMG:                      {
    [1692344207.903091][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344207.903186][79150:79152] CHIP:DMG:                              ClusterId = 0x31,
    [1692344207.903262][79150:79152] CHIP:DMG:                              CommandId = 0x6,
    [1692344207.903330][79150:79152] CHIP:DMG:                      },
    [1692344207.903401][79150:79152] CHIP:DMG:
    [1692344207.903486][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344207.903554][79150:79152] CHIP:DMG:                      {
    [1692344207.903624][79150:79152] CHIP:DMG:                              0x0 = [
    [1692344207.903703][79150:79152] CHIP:DMG:                                              0x69, 0x5e, 0x3b, 0xcb, 0x08, 0xb9, 0x69, 0x68,
    [1692344207.903808][79150:79152] CHIP:DMG:                              ] (8 bytes)
    [1692344207.903884][79150:79152] CHIP:DMG:                              0x1 = 19,
    [1692344207.903913][79150:79152] CHIP:DMG:                      },
    [1692344207.903938][79150:79152] CHIP:DMG:              },
    [1692344207.903965][79150:79152] CHIP:DMG:
    [1692344207.903986][79150:79152] CHIP:DMG:      ],
    [1692344207.904014][79150:79152] CHIP:DMG:
    [1692344207.904044][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344207.904065][79150:79152] CHIP:DMG: },
    [1692344207.904085][79150:79152] CHIP:DMG:
    [1692344207.904224][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344207.904303][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344207.982545][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344209.423799][79150:79151] CHIP:DL: Indication received, conn = 0xffffa4056040
    [1692344209.424077][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1692344209.425091][79150:79152] CHIP:DMG: << from BLE | 244578386 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56692 / Exchange = 51312]
    [1692344209.425190][79150:79152] CHIP:DMG: Header Flags =
    [1692344209.425244][79150:79152] CHIP:DMG: {
    [1692344209.425336][79150:79152] CHIP:DMG: }
    [1692344209.425387][79150:79152] CHIP:DMG:
    [1692344209.425449][79150:79152] CHIP:DMG: Encrypted Payload (65 bytes) =
    [1692344209.425499][79150:79152] CHIP:DMG: {
    [1692344209.425548][79150:79152] CHIP:DMG:     data = 0074dd0052f8930ebb40f551a6a02e2bacfab647e91f946489f89f58daa47059425cd079332e95330acb0ce2260717f0a0e2fe404396fe069997c11a46903bef1f
    [1692344209.425625][79150:79152] CHIP:DMG:     buffer_ptr = 281473299156688
    [1692344209.425677][79150:79152] CHIP:DMG: }
    [1692344209.425723][79150:79152] CHIP:DMG:
    [1692344209.425793][79150:79152] CHIP:DMG: Decrypted Payload (35 bytes) =
    [1692344209.425844][79150:79152] CHIP:DMG: {
    [1692344209.425915][79150:79152] CHIP:DMG:     data = 1528003601153500370024000024013124020718350124000034021818181824ff0118
    [1692344209.425966][79150:79152] CHIP:DMG: }
    [1692344209.426012][79150:79152] CHIP:DMG:
    [1692344209.426269][79150:79152] CHIP:DMG:
    [1692344209.426385][79150:79152] CHIP:DMG: Additional Fields =
    [1692344209.426442][79150:79152] CHIP:DMG: {
    [1692344209.426498][79150:79152] CHIP:DMG:     peer_address = BLE
    [1692344209.426549][79150:79152] CHIP:DMG: }
    [1692344209.426596][79150:79152] CHIP:DMG:
    [1692344209.426692][79150:79152] CHIP:EM: >>> [E:51312i S:56692 M:244578386] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344209.426761][79150:79152] CHIP:EM: Found matching exchange: 51312i, Delegate: 0xffffa4057608
    [1692344209.426849][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344209.426963][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344209.427020][79150:79152] CHIP:DMG: {
    [1692344209.427073][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344209.427129][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344209.427203][79150:79152] CHIP:DMG:      [
    [1692344209.427283][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344209.427361][79150:79152] CHIP:DMG:              {
    [1692344209.427422][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344209.427519][79150:79152] CHIP:DMG:                      {
    [1692344209.427587][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344209.427660][79150:79152] CHIP:DMG:                              {
    [1692344209.427738][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344209.427840][79150:79152] CHIP:DMG:                                      ClusterId = 0x31,
    [1692344209.427921][79150:79152] CHIP:DMG:                                      CommandId = 0x7,
    [1692344209.427997][79150:79152] CHIP:DMG:                              },
    [1692344209.428076][79150:79152] CHIP:DMG:
    [1692344209.428146][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344209.428219][79150:79152] CHIP:DMG:                              {
    [1692344209.428293][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344209.428375][79150:79152] CHIP:DMG:                                      0x2 = NULL
    [1692344209.428456][79150:79152] CHIP:DMG:                              },
    [1692344209.428526][79150:79152] CHIP:DMG:                      },
    [1692344209.428604][79150:79152] CHIP:DMG:
    [1692344209.428665][79150:79152] CHIP:DMG:              },
    [1692344209.428737][79150:79152] CHIP:DMG:
    [1692344209.428792][79150:79152] CHIP:DMG:      ],
    [1692344209.428865][79150:79152] CHIP:DMG:
    [1692344209.428920][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344209.428975][79150:79152] CHIP:DMG: },
    [1692344209.429115][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1692344209.429194][79150:79152] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
    [1692344209.429259][79150:79152] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
    [1692344209.429309][79150:79152] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
    [1692344209.429365][79150:79152] CHIP:CTL: Performing next commissioning step 'FindOperational'
    [1692344209.429438][79150:79152] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692344209.429489][79150:79152] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692344209.429562][79150:79152] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692344209.429627][79150:79152] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692344209.431149][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344209.629633][79150:79152] CHIP:DIS: Checking node lookup status after 200 ms
    [1692344209.949192][79150:79152] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
    [1692344211.662513][79150:79152] CHIP:DL: Avahi resolve found
    [1692344211.662673][79150:79152] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692344211.662741][79150:79152] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692344211.662805][79150:79152] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692344211.662858][79150:79152] CHIP:DIS:      Port: 5540
    [1692344211.662907][79150:79152] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692344211.662956][79150:79152] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692344211.663004][79150:79152] CHIP:DIS:      TCP Supported: 0
    [1692344211.664903][79150:79152] CHIP:DIS: Lookup clearing interface for non LL address
    [1692344211.665136][79150:79152] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692344211.665209][79150:79152] CHIP:DIS: Checking node lookup status after 2236 ms
    [1692344211.665281][79150:79152] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692344211.665333][79150:79152] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692344211.665540][79150:79152] CHIP:IN: SecureSession[0xffff9c024b40]: Allocated Type:2 LSID:56693
    [1692344211.665680][79150:79152] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692344211.668404][79150:79152] CHIP:EM: <<< [E:51313i S:0 M:131879880] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692344211.668556][79150:79152] CHIP:IN: (U) Sending msg 131879880 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692344211.669089][79150:79152] CHIP:DMG: >> to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 | 131879880 | [Secure Channel  (0) / Certificate Authenticated Session Establishment Sigma '1' (0x30) / Session = 0 / Exchange = 51313]
    [1692344211.669199][79150:79152] CHIP:DMG: Header Flags =
    [1692344211.669281][79150:79152] CHIP:DMG: {
    [1692344211.669351][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344211.669415][79150:79152] CHIP:DMG:     {
    [1692344211.669477][79150:79152] CHIP:DMG:         SourceNodeId = 4196781A1DC1F514
    [1692344211.669536][79150:79152] CHIP:DMG:     }
    [1692344211.669614][79150:79152] CHIP:DMG:     Exchange (0x05) =
    [1692344211.669674][79150:79152] CHIP:DMG:     {
    [1692344211.669725][79150:79152] CHIP:DMG:         Initiator = true
    [1692344211.669782][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344211.669838][79150:79152] CHIP:DMG:     }
    [1692344211.669912][79150:79152] CHIP:DMG: }
    [1692344211.669970][79150:79152] CHIP:DMG:
    [1692344211.670041][79150:79152] CHIP:DMG: Encrypted Payload (166 bytes) =
    [1692344211.670134][79150:79152] CHIP:DMG: {
    [1692344211.670195][79150:79152] CHIP:DMG:     data = 04000000c853dc0714f5c11d1a789641053071c8000015300120101d46db3459eab8caf32bfe13e30d8caa3612d6115a72fefa11b578c6512211250275dd300320e7f1716322b50a6cda25cc1370e034c831c000f6f29d303c3df4acf1bff06d0130044104b8d014959b738da13bab351113b8e6de96a42d337d76c704ad0d833d3f8ab998d6f86a11acb33ee32eb9ec7047f058f722aa5fc0ee0197f346f02652af562e6218
    [1692344211.670263][79150:79152] CHIP:DMG:     buffer_ptr = 281473299152176
    [1692344211.670319][79150:79152] CHIP:DMG: }
    [1692344211.670372][79150:79152] CHIP:DMG:
    [1692344211.670453][79150:79152] CHIP:DMG: Decrypted Payload (144 bytes) =
    [1692344211.670512][79150:79152] CHIP:DMG: {
    [1692344211.670567][79150:79152] CHIP:DMG:     data = 15300120101d46db3459eab8caf32bfe13e30d8caa3612d6115a72fefa11b578c6512211250275dd300320e7f1716322b50a6cda25cc1370e034c831c000f6f29d303c3df4acf1bff06d0130044104b8d014959b738da13bab351113b8e6de96a42d337d76c704ad0d833d3f8ab998d6f86a11acb33ee32eb9ec7047f058f722aa5fc0ee0197f346f02652af562e6218
    [1692344211.670629][79150:79152] CHIP:DMG: }
    [1692344211.670683][79150:79152] CHIP:DMG:
    [1692344211.670815][79150:79152] CHIP:DMG: Parameters =
    [1692344211.670877][79150:79152] CHIP:DMG: {
    [1692344211.670943][79150:79152] CHIP:DMG:     InitiatorRandom (32) = 101D46DB3459EAB8CAF32BFE13E30D8CAA3612D6115A72FEFA11B578C6512211
    [1692344211.671004][79150:79152] CHIP:DMG:     InitiatorSessionId = 56693
    [1692344211.671054][79150:79152] CHIP:DMG:     DestinationId (32) = E7F1716322B50A6CDA25CC1370E034C831C000F6F29D303C3DF4ACF1BFF06D01
    [1692344211.671095][79150:79152] CHIP:DMG:     InitiatorEphPubKey (65) = 04B8D014959B738DA13BAB351113B8E6DE96A42D337D76C704AD0D833D3F8AB998D6F86A11ACB33EE32EB9EC7047F058F722AA5FC0EE0197F346F02652AF562E62
    [1692344211.671123][79150:79152] CHIP:DMG: }
    [1692344211.671141][79150:79152] CHIP:DMG:
    [1692344211.671160][79150:79152] CHIP:DMG:
    [1692344211.671426][79150:79152] CHIP:SC: Sent Sigma1 msg
    [1692344211.671470][79150:79152] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692344211.968139][79150:79152] CHIP:DMG: << from UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 205208471 | [Secure Channel  (0) / Standalone Ack (0x10) / Session = 0 / Exchange = 51313]
    [1692344211.968245][79150:79152] CHIP:DMG: Header Flags =
    [1692344211.968287][79150:79152] CHIP:DMG: {
    [1692344211.968342][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344211.968390][79150:79152] CHIP:DMG:     {
    [1692344211.968438][79150:79152] CHIP:DMG:         DestinationNodeId = 4196781A1DC1F514
    [1692344211.968481][79150:79152] CHIP:DMG:     }
    [1692344211.968541][79150:79152] CHIP:DMG:     Exchange (0x02) =
    [1692344211.968586][79150:79152] CHIP:DMG:     {
    [1692344211.968632][79150:79152] CHIP:DMG:         AckMsg = 131879880
    [1692344211.968675][79150:79152] CHIP:DMG:     }
    [1692344211.968732][79150:79152] CHIP:DMG: }
    [1692344211.968775][79150:79152] CHIP:DMG:
    [1692344211.968829][79150:79152] CHIP:DMG: Encrypted Payload (26 bytes) =
    [1692344211.968873][79150:79152] CHIP:DMG: {
    [1692344211.968916][79150:79152] CHIP:DMG:     data = 01000000973b3b0c14f5c11d1a789641021071c80000c853dc07
    [1692344211.968959][79150:79152] CHIP:DMG:     buffer_ptr = 281473299016464
    [1692344211.969000][79150:79152] CHIP:DMG: }
    [1692344211.969037][79150:79152] CHIP:DMG:
    [1692344211.969114][79150:79152] CHIP:DMG: Additional Fields =
    [1692344211.969160][79150:79152] CHIP:DMG: {
    [1692344211.969207][79150:79152] CHIP:DMG:     peer_address = UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540
    [1692344211.969252][79150:79152] CHIP:DMG: }
    [1692344211.969292][79150:79152] CHIP:DMG:
    [1692344211.969357][79150:79152] CHIP:EM: >>> [E:51313i S:0 M:205208471 (Ack:131879880)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692344211.969416][79150:79152] CHIP:EM: Found matching exchange: 51313i, Delegate: 0xffff9c023ba8
    [1692344211.969494][79150:79152] CHIP:EM: Rxd Ack; Removing MessageCounter:131879880 from Retrans Table on exchange 51313i
    [1692344212.032238][79150:79152] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1692344212.247491][79150:79152] CHIP:DMG: << from UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 205208472 | [Secure Channel  (0) / Certificate Authenticated Session Establishment Sigma '2' (0x31) / Session = 0 / Exchange = 51313]
    [1692344212.247599][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.247647][79150:79152] CHIP:DMG: {
    [1692344212.247707][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344212.247752][79150:79152] CHIP:DMG:     {
    [1692344212.247800][79150:79152] CHIP:DMG:         DestinationNodeId = 4196781A1DC1F514
    [1692344212.247845][79150:79152] CHIP:DMG:     }
    [1692344212.247904][79150:79152] CHIP:DMG:     Exchange (0x06) =
    [1692344212.247948][79150:79152] CHIP:DMG:     {
    [1692344212.247993][79150:79152] CHIP:DMG:         AckMsg = 131879880
    [1692344212.248036][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344212.248078][79150:79152] CHIP:DMG:     }
    [1692344212.248135][79150:79152] CHIP:DMG: }
    [1692344212.248178][79150:79152] CHIP:DMG:
    [1692344212.248239][79150:79152] CHIP:DMG: Encrypted Payload (732 bytes) =
    [1692344212.248283][79150:79152] CHIP:DMG: {
    [1692344212.248325][79150:79152] CHIP:DMG:     data = 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
    [1692344212.248430][79150:79152] CHIP:DMG:     buffer_ptr = 281473299106816
    [1692344212.248472][79150:79152] CHIP:DMG: }
    [1692344212.248512][79150:79152] CHIP:DMG:
    [1692344212.248577][79150:79152] CHIP:DMG: Decrypted Payload (706 bytes) =
    [1692344212.248623][79150:79152] CHIP:DMG: {
    [1692344212.248665][79150:79152] CHIP:DMG:     data = 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
    [1692344212.248763][79150:79152] CHIP:DMG: }
    [1692344212.248803][79150:79152] CHIP:DMG:
    [1692344212.249022][79150:79152] CHIP:DMG: Parameters =
    [1692344212.249068][79150:79152] CHIP:DMG: {
    [1692344212.249116][79150:79152] CHIP:DMG:     ResponderRandom (32) = BD0863BDC77F3BEA2098BC205644326B2F8FD4D3BA8A6A83B3F8E451B7F069FD
    [1692344212.249160][79150:79152] CHIP:DMG:     ResponderSessionId = 19066
    [1692344212.249211][79150:79152] CHIP:DMG:     ResponderEphPubKey (65) = 0477D3F207666F312F92198C94738AB2DC2575B183AE5B9A344B0963705F0B3E6CDCE7F6BA462FFF5A1BA9F3D6208C498ABEB6630A7C3967EFF1FCD726FB33FCC3
    [1692344212.249312][79150:79152] CHIP:DMG:     Encrypted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
    [1692344212.249406][79150:79152] CHIP:DMG:     SED =
    [1692344212.249448][79150:79152] CHIP:DMG:     {
    [1692344212.249495][79150:79152] CHIP:DMG:         Idle Retransmit Timeout = 2800
    [1692344212.249543][79150:79152] CHIP:DMG:         Active Retransmit Timeout = 1000
    [1692344212.249589][79150:79152] CHIP:DMG:     }
    [1692344212.249634][79150:79152] CHIP:DMG: }
    [1692344212.249676][79150:79152] CHIP:DMG:
    [1692344212.249717][79150:79152] CHIP:DMG:
    [1692344212.249785][79150:79152] CHIP:DMG: Additional Fields =
    [1692344212.249830][79150:79152] CHIP:DMG: {
    [1692344212.249877][79150:79152] CHIP:DMG:     peer_address = UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540
    [1692344212.249922][79150:79152] CHIP:DMG: }
    [1692344212.249962][79150:79152] CHIP:DMG:
    [1692344212.250029][79150:79152] CHIP:EM: >>> [E:51313i S:0 M:205208472 (Ack:131879880)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692344212.250144][79150:79152] CHIP:EM: Found matching exchange: 51313i, Delegate: 0xffff9c023ba8
    [1692344212.250200][79150:79152] CHIP:EM: CHIP MessageCounter:131879880 not in RetransTable on exchange 51313i
    [1692344212.250292][79150:79152] CHIP:SC: Received Sigma2 msg
    [1692344212.250357][79150:79152] CHIP:SC: Peer assigned session session ID 19066
    [1692344212.259133][79150:79152] CHIP:SC: Found MRP parameters in the message
    [1692344212.259239][79150:79152] CHIP:SC: Sending Sigma3
    [1692344212.260726][79150:79152] CHIP:EM: <<< [E:51313i S:0 M:131879881 (Ack:205208472)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692344212.260889][79150:79152] CHIP:IN: (U) Sending msg 131879881 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692344212.261192][79150:79152] CHIP:DMG: >> to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 131879881 | [Secure Channel  (0) / Certificate Authenticated Session Establishment Sigma '3' (0x32) / Session = 0 / Exchange = 51313]
    [1692344212.261232][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.261252][79150:79152] CHIP:DMG: {
    [1692344212.261283][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344212.261303][79150:79152] CHIP:DMG:     {
    [1692344212.261323][79150:79152] CHIP:DMG:         SourceNodeId = 4196781A1DC1F514
    [1692344212.261341][79150:79152] CHIP:DMG:     }
    [1692344212.261366][79150:79152] CHIP:DMG:     Exchange (0x07) =
    [1692344212.261384][79150:79152] CHIP:DMG:     {
    [1692344212.261400][79150:79152] CHIP:DMG:         Initiator = true
    [1692344212.261419][79150:79152] CHIP:DMG:         AckMsg = 205208472
    [1692344212.261437][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344212.261455][79150:79152] CHIP:DMG:     }
    [1692344212.261479][79150:79152] CHIP:DMG: }
    [1692344212.261496][79150:79152] CHIP:DMG:
    [1692344212.261524][79150:79152] CHIP:DMG: Encrypted Payload (598 bytes) =
    [1692344212.261542][79150:79152] CHIP:DMG: {
    [1692344212.261560][79150:79152] CHIP:DMG:     data = 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
    [1692344212.261599][79150:79152] CHIP:DMG:     buffer_ptr = 281473299154624
    [1692344212.261617][79150:79152] CHIP:DMG: }
    [1692344212.261633][79150:79152] CHIP:DMG:
    [1692344212.261660][79150:79152] CHIP:DMG: Decrypted Payload (572 bytes) =
    [1692344212.261679][79150:79152] CHIP:DMG: {
    [1692344212.261697][79150:79152] CHIP:DMG:     data = 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
    [1692344212.261735][79150:79152] CHIP:DMG: }
    [1692344212.261751][79150:79152] CHIP:DMG:
    [1692344212.261833][79150:79152] CHIP:DMG: Parameters =
    [1692344212.261852][79150:79152] CHIP:DMG: {
    [1692344212.261894][79150:79152] CHIP:DMG:     Encrypted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
    [1692344212.261930][79150:79152] CHIP:DMG: }
    [1692344212.261946][79150:79152] CHIP:DMG:
    [1692344212.261964][79150:79152] CHIP:DMG:
    [1692344212.262234][79150:79152] CHIP:SC: Sent Sigma3 msg
    [1692344212.649620][79150:79152] CHIP:DMG: << from UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 205208473 | [Secure Channel  (0) / Standalone Ack (0x10) / Session = 0 / Exchange = 51313]
    [1692344212.649723][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.649771][79150:79152] CHIP:DMG: {
    [1692344212.649831][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344212.649876][79150:79152] CHIP:DMG:     {
    [1692344212.649924][79150:79152] CHIP:DMG:         DestinationNodeId = 4196781A1DC1F514
    [1692344212.649969][79150:79152] CHIP:DMG:     }
    [1692344212.650029][79150:79152] CHIP:DMG:     Exchange (0x02) =
    [1692344212.650149][79150:79152] CHIP:DMG:     {
    [1692344212.650202][79150:79152] CHIP:DMG:         AckMsg = 131879881
    [1692344212.650246][79150:79152] CHIP:DMG:     }
    [1692344212.650305][79150:79152] CHIP:DMG: }
    [1692344212.650349][79150:79152] CHIP:DMG:
    [1692344212.650402][79150:79152] CHIP:DMG: Encrypted Payload (26 bytes) =
    [1692344212.650445][79150:79152] CHIP:DMG: {
    [1692344212.650487][79150:79152] CHIP:DMG:     data = 01000000993b3b0c14f5c11d1a789641021071c80000c953dc07
    [1692344212.650530][79150:79152] CHIP:DMG:     buffer_ptr = 281473299016464
    [1692344212.650572][79150:79152] CHIP:DMG: }
    [1692344212.650612][79150:79152] CHIP:DMG:
    [1692344212.650689][79150:79152] CHIP:DMG: Additional Fields =
    [1692344212.650736][79150:79152] CHIP:DMG: {
    [1692344212.650784][79150:79152] CHIP:DMG:     peer_address = UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540
    [1692344212.650829][79150:79152] CHIP:DMG: }
    [1692344212.650869][79150:79152] CHIP:DMG:
    [1692344212.650934][79150:79152] CHIP:EM: >>> [E:51313i S:0 M:205208473 (Ack:131879881)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692344212.650994][79150:79152] CHIP:EM: Found matching exchange: 51313i, Delegate: 0xffff9c023ba8
    [1692344212.651073][79150:79152] CHIP:EM: Rxd Ack; Removing MessageCounter:131879881 from Retrans Table on exchange 51313i
    [1692344212.855496][79150:79152] CHIP:DMG: << from UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 205208474 | [Secure Channel  (0) / Status Report (0x40) / Session = 0 / Exchange = 51313]
    [1692344212.855616][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.855670][79150:79152] CHIP:DMG: {
    [1692344212.855751][79150:79152] CHIP:DMG:     Message (0x01) =
    [1692344212.855813][79150:79152] CHIP:DMG:     {
    [1692344212.855879][79150:79152] CHIP:DMG:         DestinationNodeId = 4196781A1DC1F514
    [1692344212.855937][79150:79152] CHIP:DMG:     }
    [1692344212.856016][79150:79152] CHIP:DMG:     Exchange (0x06) =
    [1692344212.856075][79150:79152] CHIP:DMG:     {
    [1692344212.856130][79150:79152] CHIP:DMG:         AckMsg = 131879881
    [1692344212.856182][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344212.856230][79150:79152] CHIP:DMG:     }
    [1692344212.856319][79150:79152] CHIP:DMG: }
    [1692344212.856373][79150:79152] CHIP:DMG:
    [1692344212.856440][79150:79152] CHIP:DMG: Encrypted Payload (34 bytes) =
    [1692344212.856492][79150:79152] CHIP:DMG: {
    [1692344212.856541][79150:79152] CHIP:DMG:     data = 010000009a3b3b0c14f5c11d1a789641064071c80000c953dc070000000000000000
    [1692344212.856591][79150:79152] CHIP:DMG:     buffer_ptr = 281473299182000
    [1692344212.856639][79150:79152] CHIP:DMG: }
    [1692344212.856687][79150:79152] CHIP:DMG:
    [1692344212.856758][79150:79152] CHIP:DMG: Decrypted Payload (8 bytes) =
    [1692344212.856810][79150:79152] CHIP:DMG: {
    [1692344212.856859][79150:79152] CHIP:DMG:     data = 0000000000000000
    [1692344212.856907][79150:79152] CHIP:DMG: }
    [1692344212.856953][79150:79152] CHIP:DMG:
    [1692344212.857020][79150:79152] CHIP:DMG: Parameters =
    [1692344212.857073][79150:79152] CHIP:DMG: {
    [1692344212.857123][79150:79152] CHIP:DMG:     GeneralStatusCode = 0
    [1692344212.857171][79150:79152] CHIP:DMG:     ProtocolId = 0
    [1692344212.857220][79150:79152] CHIP:DMG:     ProtocolCode = 0
    [1692344212.857268][79150:79152] CHIP:DMG: }
    [1692344212.857320][79150:79152] CHIP:DMG:
    [1692344212.857369][79150:79152] CHIP:DMG:
    [1692344212.857448][79150:79152] CHIP:DMG: Additional Fields =
    [1692344212.857502][79150:79152] CHIP:DMG: {
    [1692344212.857558][79150:79152] CHIP:DMG:     peer_address = UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540
    [1692344212.857611][79150:79152] CHIP:DMG: }
    [1692344212.857668][79150:79152] CHIP:DMG:
    [1692344212.857750][79150:79152] CHIP:EM: >>> [E:51313i S:0 M:205208474 (Ack:131879881)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692344212.857819][79150:79152] CHIP:EM: Found matching exchange: 51313i, Delegate: 0xffff9c023ba8
    [1692344212.857878][79150:79152] CHIP:EM: CHIP MessageCounter:131879881 not in RetransTable on exchange 51313i
    [1692344212.857991][79150:79152] CHIP:SC: Success status report received. Session was established
    [1692344212.866536][79150:79152] CHIP:SC: SecureSession[0xffff9c024b40]: Moving from state 'kEstablishing' --> 'kActive'
    [1692344212.866591][79150:79152] CHIP:IN: SecureSession[0xffff9c024b40]: Activated - Type:2 LSID:56693
    [1692344212.866620][79150:79152] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:56693 PSID:19066!
    [1692344212.866646][79150:79152] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692344212.866705][79150:79152] CHIP:CTL: Successfully finished commissioning step 'FindOperational'
    [1692344212.866731][79150:79152] CHIP:CTL: Commissioning stage next step: 'FindOperational' -> 'SendComplete'
    [1692344212.866763][79150:79152] CHIP:CTL: Performing next commissioning step 'SendComplete'
    [1692344212.866833][79150:79152] CHIP:DMG: ICR moving to [AddingComm]
    [1692344212.866859][79150:79152] CHIP:DMG: ICR moving to [AddedComma]
    [1692344212.867272][79150:79152] CHIP:EM: <<< [E:51314i S:56693 M:237750377] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692344212.867328][79150:79152] CHIP:IN: (S) Sending msg 237750377 on secure session with LSID: 56693
    [1692344212.867617][79150:79152] CHIP:DMG: >> to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 237750377 | [Interaction Model  (1) / InvokeCommandRequest (0x08) / Session = 19066 / Exchange = 51314]
    [1692344212.867657][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.867676][79150:79152] CHIP:DMG: {
    [1692344212.867705][79150:79152] CHIP:DMG:     Exchange (0x05) =
    [1692344212.867723][79150:79152] CHIP:DMG:     {
    [1692344212.867738][79150:79152] CHIP:DMG:         Initiator = true
    [1692344212.867755][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344212.867771][79150:79152] CHIP:DMG:     }
    [1692344212.867793][79150:79152] CHIP:DMG: }
    [1692344212.867809][79150:79152] CHIP:DMG:
    [1692344212.867833][79150:79152] CHIP:DMG: Encrypted Payload (59 bytes) =
    [1692344212.867851][79150:79152] CHIP:DMG: {
    [1692344212.867867][79150:79152] CHIP:DMG:     data = 007a4a0069c82b0e7ea8d39c21f740784746ec623230fcc35ef8308871dfc59b7f016d3d86930c9397da1185b424d3eae24830a53f80903c469707
    [1692344212.867885][79150:79152] CHIP:DMG:     buffer_ptr = 281473299185856
    [1692344212.867901][79150:79152] CHIP:DMG: }
    [1692344212.867916][79150:79152] CHIP:DMG:
    [1692344212.867941][79150:79152] CHIP:DMG: Decrypted Payload (29 bytes) =
    [1692344212.867959][79150:79152] CHIP:DMG: {
    [1692344212.867975][79150:79152] CHIP:DMG:     data = 1528002801360215370024000024013024020418350118181824ff0118
    [1692344212.867991][79150:79152] CHIP:DMG: }
    [1692344212.868007][79150:79152] CHIP:DMG:
    [1692344212.868063][79150:79152] CHIP:DMG: InvokeRequestMessage =
    [1692344212.868085][79150:79152] CHIP:DMG: {
    [1692344212.868103][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344212.868125][79150:79152] CHIP:DMG:      timedRequest = false,
    [1692344212.868144][79150:79152] CHIP:DMG:      InvokeRequests =
    [1692344212.868168][79150:79152] CHIP:DMG:      [
    [1692344212.868187][79150:79152] CHIP:DMG:              CommandDataIB =
    [1692344212.868209][79150:79152] CHIP:DMG:              {
    [1692344212.868230][79150:79152] CHIP:DMG:                      CommandPathIB =
    [1692344212.868252][79150:79152] CHIP:DMG:                      {
    [1692344212.868275][79150:79152] CHIP:DMG:                              EndpointId = 0x0,
    [1692344212.868310][79150:79152] CHIP:DMG:                              ClusterId = 0x30,
    [1692344212.868336][79150:79152] CHIP:DMG:                              CommandId = 0x4,
    [1692344212.868362][79150:79152] CHIP:DMG:                      },
    [1692344212.868387][79150:79152] CHIP:DMG:
    [1692344212.868409][79150:79152] CHIP:DMG:                      CommandFields =
    [1692344212.868431][79150:79152] CHIP:DMG:                      {
    [1692344212.868454][79150:79152] CHIP:DMG:                      },
    [1692344212.868476][79150:79152] CHIP:DMG:              },
    [1692344212.868507][79150:79152] CHIP:DMG:
    [1692344212.868526][79150:79152] CHIP:DMG:      ],
    [1692344212.868550][79150:79152] CHIP:DMG:
    [1692344212.868570][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344212.868588][79150:79152] CHIP:DMG: },
    [1692344212.868607][79150:79152] CHIP:DMG:
    [1692344212.868843][79150:79152] CHIP:DMG: ICR moving to [CommandSen]
    [1692344212.869167][79150:79152] CHIP:EM: <<< [E:51313i S:0 M:131879882 (Ack:205208474)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692344212.869300][79150:79152] CHIP:IN: (U) Sending msg 131879882 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692344212.869527][79150:79152] CHIP:DMG: >> to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 131879882 | [Secure Channel  (0) / Standalone Ack (0x10) / Session = 0 / Exchange = 51313]
    [1692344212.869559][79150:79152] CHIP:DMG: Header Flags =
    [1692344212.869577][79150:79152] CHIP:DMG: {
    [1692344212.869600][79150:79152] CHIP:DMG:     Message (0x04) =
    [1692344212.869617][79150:79152] CHIP:DMG:     {
    [1692344212.869635][79150:79152] CHIP:DMG:         SourceNodeId = 4196781A1DC1F514
    [1692344212.869652][79150:79152] CHIP:DMG:     }
    [1692344212.869706][79150:79152] CHIP:DMG:     Exchange (0x03) =
    [1692344212.869724][79150:79152] CHIP:DMG:     {
    [1692344212.869739][79150:79152] CHIP:DMG:         Initiator = true
    [1692344212.869757][79150:79152] CHIP:DMG:         AckMsg = 205208474
    [1692344212.869774][79150:79152] CHIP:DMG:     }
    [1692344212.869796][79150:79152] CHIP:DMG: }
    [1692344212.869813][79150:79152] CHIP:DMG:
    [1692344212.869836][79150:79152] CHIP:DMG: Encrypted Payload (26 bytes) =
    [1692344212.869858][79150:79152] CHIP:DMG: {
    [1692344212.869878][79150:79152] CHIP:DMG:     data = 04000000ca53dc0714f5c11d1a789641031071c800009a3b3b0c
    [1692344212.869898][79150:79152] CHIP:DMG:     buffer_ptr = 281473299182080
    [1692344212.869916][79150:79152] CHIP:DMG: }
    [1692344212.869934][79150:79152] CHIP:DMG:
    [1692344212.870130][79150:79152] CHIP:EM: Flushed pending ack for MessageCounter:205208474 on exchange 51313i
    [1692344213.132353][79150:79152] CHIP:DMG: << from UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 121077570 | [Interaction Model  (1) / InvokeCommandResponse (0x09) / Session = 56693 / Exchange = 51314]
    [1692344213.132433][79150:79152] CHIP:DMG: Header Flags =
    [1692344213.132466][79150:79152] CHIP:DMG: {
    [1692344213.132514][79150:79152] CHIP:DMG:     Exchange (0x06) =
    [1692344213.132548][79150:79152] CHIP:DMG:     {
    [1692344213.132581][79150:79152] CHIP:DMG:         AckMsg = 237750377
    [1692344213.132612][79150:79152] CHIP:DMG:         NeedsAck = true
    [1692344213.132643][79150:79152] CHIP:DMG:     }
    [1692344213.132684][79150:79152] CHIP:DMG: }
    [1692344213.132714][79150:79152] CHIP:DMG:
    [1692344213.132754][79150:79152] CHIP:DMG: Encrypted Payload (70 bytes) =
    [1692344213.132784][79150:79152] CHIP:DMG: {
    [1692344213.132813][79150:79152] CHIP:DMG:     data = 0075dd00427f37071fe065570a3c5bb8fd98da12140709a7b63647c660e9f2ff302f3e849df944f8a262d2aad26cc807fd7a155d4175a5d4a4080de885f5479382ee39faabf5
    [1692344213.132845][79150:79152] CHIP:DMG:     buffer_ptr = 281473299181152
    [1692344213.132875][79150:79152] CHIP:DMG: }
    [1692344213.132903][79150:79152] CHIP:DMG:
    [1692344213.132945][79150:79152] CHIP:DMG: Decrypted Payload (36 bytes) =
    [1692344213.132976][79150:79152] CHIP:DMG: {
    [1692344213.133006][79150:79152] CHIP:DMG:     data = 152800360115350037002400002401302402051835012400002c01001818181824ff0118
    [1692344213.133036][79150:79152] CHIP:DMG: }
    [1692344213.133063][79150:79152] CHIP:DMG:
    [1692344213.133141][79150:79152] CHIP:DMG:
    [1692344213.133196][79150:79152] CHIP:DMG: Additional Fields =
    [1692344213.133229][79150:79152] CHIP:DMG: {
    [1692344213.133263][79150:79152] CHIP:DMG:     peer_address = UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540
    [1692344213.133296][79150:79152] CHIP:DMG: }
    [1692344213.133324][79150:79152] CHIP:DMG:
    [1692344213.133378][79150:79152] CHIP:EM: >>> [E:51314i S:56693 M:121077570 (Ack:237750377)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692344213.133422][79150:79152] CHIP:EM: Found matching exchange: 51314i, Delegate: 0xffffa4057258
    [1692344213.133483][79150:79152] CHIP:EM: Rxd Ack; Removing MessageCounter:237750377 from Retrans Table on exchange 51314i
    [1692344213.133541][79150:79152] CHIP:DMG: ICR moving to [ResponseRe]
    [1692344213.133604][79150:79152] CHIP:DMG: InvokeResponseMessage =
    [1692344213.133641][79150:79152] CHIP:DMG: {
    [1692344213.133674][79150:79152] CHIP:DMG:      suppressResponse = false,
    [1692344213.133708][79150:79152] CHIP:DMG:      InvokeResponseIBs =
    [1692344213.133753][79150:79152] CHIP:DMG:      [
    [1692344213.133788][79150:79152] CHIP:DMG:              InvokeResponseIB =
    [1692344213.133836][79150:79152] CHIP:DMG:              {
    [1692344213.133873][79150:79152] CHIP:DMG:                      CommandDataIB =
    [1692344213.133930][79150:79152] CHIP:DMG:                      {
    [1692344213.133970][79150:79152] CHIP:DMG:                              CommandPathIB =
    [1692344213.134014][79150:79152] CHIP:DMG:                              {
    [1692344213.134059][79150:79152] CHIP:DMG:                                      EndpointId = 0x0,
    [1692344213.134156][79150:79152] CHIP:DMG:                                      ClusterId = 0x30,
    [1692344213.134203][79150:79152] CHIP:DMG:                                      CommandId = 0x5,
    [1692344213.134247][79150:79152] CHIP:DMG:                              },
    [1692344213.134292][79150:79152] CHIP:DMG:
    [1692344213.134333][79150:79152] CHIP:DMG:                              CommandFields =
    [1692344213.134376][79150:79152] CHIP:DMG:                              {
    [1692344213.134418][79150:79152] CHIP:DMG:                                      0x0 = 0,
    [1692344213.134471][79150:79152] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692344213.134519][79150:79152] CHIP:DMG:                              },
    [1692344213.134560][79150:79152] CHIP:DMG:                      },
    [1692344213.134605][79150:79152] CHIP:DMG:
    [1692344213.134633][79150:79152] CHIP:DMG:              },
    [1692344213.134662][79150:79152] CHIP:DMG:
    [1692344213.134681][79150:79152] CHIP:DMG:      ],
    [1692344213.134706][79150:79152] CHIP:DMG:
    [1692344213.134726][79150:79152] CHIP:DMG:      InteractionModelRevision = 1
    [1692344213.134744][79150:79152] CHIP:DMG: },
    [1692344213.134811][79150:79152] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0005
    [1692344213.134847][79150:79152] CHIP:CTL: Received CommissioningComplete response, errorCode=0
    [1692344213.134874][79150:79152] CHIP:CTL: Successfully finished commissioning step 'SendComplete'
    [1692344213.134892][79150:79152] CHIP:CTL: Commissioning stage next step: 'SendComplete' -> 'Cleanup'
    [1692344213.134923][79150:79152] CHIP:CTL: Performing next commissioning step 'Cleanup'
    [1692344213.134943][79150:79152] CHIP:DIS: Closing all BLE connections
    [1692344213.134964][79150:79152] CHIP:IN: Clearing BLE pending packets.
    [1692344213.135028][79150:79152] CHIP:BLE: Auto-closing end point's BLE connection.
    [1692344213.135054][79150:79152] CHIP:DL: Closing BLE GATT connection (con 0xffffa4056040)
    [1692344213.135085][79150:79152] CHIP:IN: SecureSession[0xffff9c01cf00]: MarkForEviction Type:1 LSID:56692
    [1692344213.135104][79150:79152] CHIP:SC: SecureSession[0xffff9c01cf00]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692344213.135158][79150:79152] CHIP:IN: SecureSession[0xffff9c01cf00]: Released - Type:1 LSID:56692
    [1692344213.135191][79150:79152] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
    [1692344213.135218][79150:79152] CHIP:TOO: Device commissioning completed with success
    [1692344213.135283][79150:79152] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692344213.135323][79150:79151] CHIP:DL: BluezDisconnect peer=FD:6C:6B:84:BB:37
    [1692344213.135584][79150:79152] CHIP:EM: <<< [E:51314i S:56693 M:237750378 (Ack:121077570)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692344213.135641][79150:79152] CHIP:IN: (S) Sending msg 237750378 on secure session with LSID: 56693
    [1692344213.135993][79150:79152] CHIP:DMG: >> to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540 | 237750378 | [Secure Channel  (0) / Standalone Ack (0x10) / Session = 19066 / Exchange = 51314]
    [1692344213.136036][79150:79152] CHIP:DMG: Header Flags =
    [1692344213.136054][79150:79152] CHIP:DMG: {
    [1692344213.136084][79150:79152] CHIP:DMG:     Exchange (0x03) =
    [1692344213.136101][79150:79152] CHIP:DMG:     {
    [1692344213.136117][79150:79152] CHIP:DMG:         Initiator = true
    [1692344213.136135][79150:79152] CHIP:DMG:         AckMsg = 121077570
    [1692344213.136152][79150:79152] CHIP:DMG:     }
    [1692344213.136174][79150:79152] CHIP:DMG: }
    [1692344213.136191][79150:79152] CHIP:DMG:
    [1692344213.136219][79150:79152] CHIP:DMG: Encrypted Payload (34 bytes) =
    [1692344213.136240][79150:79152] CHIP:DMG: {
    [1692344213.136260][79150:79152] CHIP:DMG:     data = 007a4a006ac82b0ed8a17bf86af74f16f46b057c2930c7bd2158e6f2857692b508ee
    [1692344213.136279][79150:79152] CHIP:DMG:     buffer_ptr = 281473299137712
    [1692344213.136298][79150:79152] CHIP:DMG: }
    [1692344213.136315][79150:79152] CHIP:DMG:
    [1692344213.136504][79150:79152] CHIP:EM: Flushed pending ack for MessageCounter:121077570 on exchange 51314i
    [1692344213.136871][79150:79150] CHIP:CTL: Shutting down the commissioner
    [1692344213.136903][79150:79150] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692344213.136928][79150:79150] CHIP:CTL: Shutting down the controller
    [1692344213.136950][79150:79150] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692344213.136969][79150:79150] CHIP:IN: SecureSession[0xffff9c024b40]: MarkForEviction Type:2 LSID:56693
    [1692344213.136989][79150:79150] CHIP:SC: SecureSession[0xffff9c024b40]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692344213.137010][79150:79150] CHIP:IN: SecureSession[0xffff9c024b40]: Released - Type:2 LSID:56693
    [1692344213.137037][79150:79150] CHIP:FP: Forgetting fabric 0x1
    [1692344213.137068][79150:79150] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692344213.137278][79150:79150] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692344213.137308][79150:79150] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692344213.137353][79150:79150] CHIP:CTL: Shutting down the commissioner
    [1692344213.137373][79150:79150] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692344213.137393][79150:79150] CHIP:CTL: Shutting down the controller
    [1692344213.137409][79150:79150] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692344213.138528][79150:79150] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692344213.138630][79150:79150] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692344213.138687][79150:79150] CHIP:FP: Shutting down FabricTable
    [1692344213.138719][79150:79150] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692344213.138952][79150:79150] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692344213.138977][79150:79150] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692344213.139212][79150:79150] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-3eW9W1)
    [1692344213.139871][79150:79150] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692344213.139934][79150:79150] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692344213.139956][79150:79150] CHIP:DL: Inet Layer shutdown
    [1692344213.139974][79150:79150] CHIP:DL: BLE shutdown
    [1692344213.141075][79150:79150] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$  ./chip-tool generalcommissioning arm-fail-safe 900 1 1 0
    [1692345070.203289][79200:79200] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345070.208731][79200:79200] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345070.208991][79200:79200] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345070.209119][79200:79200] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345070.209496][79200:79200] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-SRLxrF)
    [1692345070.210120][79200:79200] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345070.210175][79200:79200] CHIP:DL: NVS set: chip-counters/reboot-count = 17 (0x11)
    [1692345070.211078][79200:79200] CHIP:DL: Got Ethernet interface: eth0
    [1692345070.211683][79200:79200] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345070.212283][79200:79200] CHIP:DL: Got WiFi interface: wlan0
    [1692345070.212349][79200:79200] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345070.212402][79200:79200] CHIP:IN: UDP::Init bind&listen port=0
    [1692345070.212518][79200:79200] CHIP:IN: UDP::Init bound to port=36054
    [1692345070.212539][79200:79200] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345070.212556][79200:79200] CHIP:IN: TransportMgr initialized
    [1692345070.212589][79200:79200] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345070.212793][79200:79200] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345070.214400][79200:79200] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345070.214900][79200:79200] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345070.220190][79200:79200] CHIP:ZCL: Using ZAP configuration...
    [1692345070.223704][79200:79200] CHIP:DL: Avahi client registered
    [1692345070.224773][79200:79200] CHIP:CTL: System State Initialized...
    [1692345070.224889][79200:79200] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345070.224942][79200:79200] CHIP:CTL: Setting attestation nonce to random value
    [1692345070.224975][79200:79200] CHIP:CTL: Setting CSR nonce to random value
    [1692345070.225308][79200:79202] CHIP:DL: CHIP task running
    [1692345070.225505][79200:79202] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345070.225780][79200:79202] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345070.225822][79200:79202] CHIP:CTL: Setting attestation nonce to random value
    [1692345070.225971][79200:79202] CHIP:CTL: Setting CSR nonce to random value
    [1692345070.226806][79200:79202] CHIP:CTL: Generating NOC
    [1692345070.227755][79200:79202] CHIP:FP: Validating NOC chain
    [1692345070.229969][79200:79202] CHIP:FP: NOC chain validation successful
    [1692345070.230232][79200:79202] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345070.230281][79200:79202] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345070.230311][79200:79202] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345070.230338][79200:79202] CHIP:TS: Retaining current Last Known Good Time
    [1692345070.239898][79200:79202] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345070.242175][79200:79202] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345070.244325][79200:79202] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345070.263555][79200:79202] CHIP:TOO: Sending command to node 0x1
    [1692345070.263980][79200:79202] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345070.264015][79200:79202] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345070.264050][79200:79202] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345070.264080][79200:79202] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345070.265788][79200:79202] CHIP:DL: Avahi resolve found
    [1692345070.265860][79200:79202] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345070.265884][79200:79202] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345070.265909][79200:79202] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345070.265931][79200:79202] CHIP:DIS:      Port: 5540
    [1692345070.265951][79200:79202] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345070.265971][79200:79202] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345070.265990][79200:79202] CHIP:DIS:      TCP Supported: 0
    [1692345070.266802][79200:79202] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345070.266913][79200:79202] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345070.266938][79200:79202] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345070.266958][79200:79202] CHIP:DIS: Keeping DNSSD lookup active
    [1692345070.465375][79200:79202] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345070.465505][79200:79202] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345070.465564][79200:79202] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345070.465792][79200:79202] CHIP:IN: SecureSession[0xffffa000d360]: Allocated Type:2 LSID:22658
    [1692345070.465887][79200:79202] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345070.468057][79200:79202] CHIP:EM: <<< [E:25867i S:0 M:253758719] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345070.468197][79200:79202] CHIP:IN: (U) Sending msg 253758719 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345070.468538][79200:79202] CHIP:SC: Sent Sigma1 msg
    [1692345070.468610][79200:79202] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345071.922711][79200:79202] CHIP:EM: >>> [E:25867i S:0 M:205208475 (Ack:253758719)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345071.922802][79200:79202] CHIP:EM: Found matching exchange: 25867i, Delegate: 0xffffa000f408
    [1692345071.922874][79200:79202] CHIP:EM: Rxd Ack; Removing MessageCounter:253758719 from Retrans Table on exchange 25867i
    [1692345072.201489][79200:79202] CHIP:EM: >>> [E:25867i S:0 M:205208476 (Ack:253758719)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345072.201579][79200:79202] CHIP:EM: Found matching exchange: 25867i, Delegate: 0xffffa000f408
    [1692345072.201634][79200:79202] CHIP:EM: CHIP MessageCounter:253758719 not in RetransTable on exchange 25867i
    [1692345072.201721][79200:79202] CHIP:SC: Received Sigma2 msg
    [1692345072.201793][79200:79202] CHIP:SC: Peer assigned session session ID 19068
    [1692345072.209775][79200:79202] CHIP:SC: Found MRP parameters in the message
    [1692345072.209878][79200:79202] CHIP:SC: Sending Sigma3
    [1692345072.211035][79200:79202] CHIP:EM: <<< [E:25867i S:0 M:253758720 (Ack:205208476)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345072.211308][79200:79202] CHIP:IN: (U) Sending msg 253758720 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345072.211621][79200:79202] CHIP:SC: Sent Sigma3 msg
    [1692345072.447567][79200:79202] CHIP:EM: >>> [E:25867i S:0 M:205208477 (Ack:253758720)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345072.447654][79200:79202] CHIP:EM: Found matching exchange: 25867i, Delegate: 0xffffa000f408
    [1692345072.447727][79200:79202] CHIP:EM: Rxd Ack; Removing MessageCounter:253758720 from Retrans Table on exchange 25867i
    [1692345072.635116][79200:79202] CHIP:EM: >>> [E:25867i S:0 M:205208478 (Ack:253758720)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345072.635222][79200:79202] CHIP:EM: Found matching exchange: 25867i, Delegate: 0xffffa000f408
    [1692345072.635286][79200:79202] CHIP:EM: CHIP MessageCounter:253758720 not in RetransTable on exchange 25867i
    [1692345072.635389][79200:79202] CHIP:SC: Success status report received. Session was established
    [1692345072.645049][79200:79202] CHIP:SC: SecureSession[0xffffa000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345072.645154][79200:79202] CHIP:IN: SecureSession[0xffffa000d360]: Activated - Type:2 LSID:22658
    [1692345072.645206][79200:79202] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:22658 PSID:19068!
    [1692345072.645271][79200:79202] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345072.645379][79200:79202] CHIP:TOO: Sending cluster (0x00000030) command (0x00000000) on endpoint 0
    [1692345072.645543][79200:79202] CHIP:DMG: ICR moving to [AddingComm]
    [1692345072.645666][79200:79202] CHIP:DMG: ICR moving to [AddedComma]
    [1692345072.645911][79200:79202] CHIP:EM: <<< [E:25868i S:22658 M:135587082] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345072.646007][79200:79202] CHIP:IN: (S) Sending msg 135587082 on secure session with LSID: 22658
    [1692345072.646411][79200:79202] CHIP:DMG: ICR moving to [CommandSen]
    [1692345072.646570][79200:79202] CHIP:EM: <<< [E:25867i S:0 M:253758721 (Ack:205208478)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345072.646946][79200:79202] CHIP:IN: (U) Sending msg 253758721 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345072.647128][79200:79202] CHIP:EM: Flushed pending ack for MessageCounter:205208478 on exchange 25867i
    [1692345072.863827][79200:79202] CHIP:EM: >>> [E:25868i S:22658 M:7418169 (Ack:135587082)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345072.863917][79200:79202] CHIP:EM: Found matching exchange: 25868i, Delegate: 0xffffa000a4f8
    [1692345072.863990][79200:79202] CHIP:EM: Rxd Ack; Removing MessageCounter:135587082 from Retrans Table on exchange 25868i
    [1692345072.864061][79200:79202] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345072.864152][79200:79202] CHIP:DMG: InvokeResponseMessage =
    [1692345072.864202][79200:79202] CHIP:DMG: {
    [1692345072.864248][79200:79202] CHIP:DMG:      suppressResponse = false,
    [1692345072.864297][79200:79202] CHIP:DMG:      InvokeResponseIBs =
    [1692345072.864362][79200:79202] CHIP:DMG:      [
    [1692345072.864411][79200:79202] CHIP:DMG:              InvokeResponseIB =
    [1692345072.864478][79200:79202] CHIP:DMG:              {
    [1692345072.864531][79200:79202] CHIP:DMG:                      CommandDataIB =
    [1692345072.864589][79200:79202] CHIP:DMG:                      {
    [1692345072.864645][79200:79202] CHIP:DMG:                              CommandPathIB =
    [1692345072.864717][79200:79202] CHIP:DMG:                              {
    [1692345072.864784][79200:79202] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345072.864853][79200:79202] CHIP:DMG:                                      ClusterId = 0x30,
    [1692345072.864922][79200:79202] CHIP:DMG:                                      CommandId = 0x1,
    [1692345072.864987][79200:79202] CHIP:DMG:                              },
    [1692345072.865054][79200:79202] CHIP:DMG:
    [1692345072.865113][79200:79202] CHIP:DMG:                              CommandFields =
    [1692345072.865177][79200:79202] CHIP:DMG:                              {
    [1692345072.865287][79200:79202] CHIP:DMG:                                      0x0 = 0,
    [1692345072.865362][79200:79202] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692345072.865432][79200:79202] CHIP:DMG:                              },
    [1692345072.865494][79200:79202] CHIP:DMG:                      },
    [1692345072.865560][79200:79202] CHIP:DMG:
    [1692345072.865611][79200:79202] CHIP:DMG:              },
    [1692345072.865672][79200:79202] CHIP:DMG:
    [1692345072.865720][79200:79202] CHIP:DMG:      ],
    [1692345072.865781][79200:79202] CHIP:DMG:
    [1692345072.865828][79200:79202] CHIP:DMG:      InteractionModelRevision = 1
    [1692345072.865875][79200:79202] CHIP:DMG: },
    [1692345072.865998][79200:79202] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692345072.866135][79200:79202] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Command 0x0000_0001
    [1692345072.871423][79200:79202] CHIP:TOO:   ArmFailSafeResponse: {
    [1692345072.871531][79200:79202] CHIP:TOO:     errorCode: 0
    [1692345072.871583][79200:79202] CHIP:TOO:     debugText:
    [1692345072.871628][79200:79202] CHIP:TOO:    }
    [1692345072.871714][79200:79202] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345072.871934][79200:79202] CHIP:EM: <<< [E:25868i S:22658 M:135587083 (Ack:7418169)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345072.872019][79200:79202] CHIP:IN: (S) Sending msg 135587083 on secure session with LSID: 22658
    [1692345072.872281][79200:79202] CHIP:EM: Flushed pending ack for MessageCounter:7418169 on exchange 25868i
    [1692345072.872733][79200:79200] CHIP:CTL: Shutting down the commissioner
    [1692345072.872800][79200:79200] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345072.872847][79200:79200] CHIP:CTL: Shutting down the controller
    [1692345072.872895][79200:79200] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345072.872939][79200:79200] CHIP:IN: SecureSession[0xffffa000d360]: MarkForEviction Type:2 LSID:22658
    [1692345072.872984][79200:79200] CHIP:SC: SecureSession[0xffffa000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345072.873029][79200:79200] CHIP:IN: SecureSession[0xffffa000d360]: Released - Type:2 LSID:22658
    [1692345072.873080][79200:79200] CHIP:FP: Forgetting fabric 0x1
    [1692345072.873139][79200:79200] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345072.873576][79200:79200] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345072.873635][79200:79200] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345072.873724][79200:79200] CHIP:CTL: Shutting down the commissioner
    [1692345072.873773][79200:79200] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345072.873819][79200:79200] CHIP:CTL: Shutting down the controller
    [1692345072.873859][79200:79200] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345072.875260][79200:79200] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345072.875395][79200:79200] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345072.875472][79200:79200] CHIP:FP: Shutting down FabricTable
    [1692345072.875517][79200:79200] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345072.875749][79200:79200] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345072.875803][79200:79200] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345072.876125][79200:79200] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-BEbw9w)
    [1692345072.877021][79200:79200] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345072.877117][79200:79200] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345072.877154][79200:79200] CHIP:DL: Inet Layer shutdown
    [1692345072.877183][79200:79200] CHIP:DL: BLE shutdown
    [1692345072.877214][79200:79200] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning read networks 1 0
    [1692345089.059867][79204:79204] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345089.065296][79204:79204] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345089.065583][79204:79204] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345089.065716][79204:79204] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345089.066123][79204:79204] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-3TxD5e)
    [1692345089.066719][79204:79204] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345089.066777][79204:79204] CHIP:DL: NVS set: chip-counters/reboot-count = 18 (0x12)
    [1692345089.067679][79204:79204] CHIP:DL: Got Ethernet interface: eth0
    [1692345089.068267][79204:79204] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345089.068859][79204:79204] CHIP:DL: Got WiFi interface: wlan0
    [1692345089.068922][79204:79204] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345089.068973][79204:79204] CHIP:IN: UDP::Init bind&listen port=0
    [1692345089.069090][79204:79204] CHIP:IN: UDP::Init bound to port=42141
    [1692345089.069121][79204:79204] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345089.069138][79204:79204] CHIP:IN: TransportMgr initialized
    [1692345089.069171][79204:79204] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345089.069357][79204:79204] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345089.070897][79204:79204] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345089.071357][79204:79204] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345089.073814][79204:79204] CHIP:ZCL: Using ZAP configuration...
    [1692345089.077361][79204:79204] CHIP:DL: Avahi client registered
    [1692345089.078498][79204:79204] CHIP:CTL: System State Initialized...
    [1692345089.078615][79204:79204] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345089.078667][79204:79204] CHIP:CTL: Setting attestation nonce to random value
    [1692345089.078757][79204:79204] CHIP:CTL: Setting CSR nonce to random value
    [1692345089.079041][79204:79206] CHIP:DL: CHIP task running
    [1692345089.079224][79204:79206] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345089.079493][79204:79206] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345089.079533][79204:79206] CHIP:CTL: Setting attestation nonce to random value
    [1692345089.079685][79204:79206] CHIP:CTL: Setting CSR nonce to random value
    [1692345089.080474][79204:79206] CHIP:CTL: Generating NOC
    [1692345089.081414][79204:79206] CHIP:FP: Validating NOC chain
    [1692345089.083078][79204:79206] CHIP:FP: NOC chain validation successful
    [1692345089.083283][79204:79206] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345089.083323][79204:79206] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345089.083350][79204:79206] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345089.083375][79204:79206] CHIP:TS: Retaining current Last Known Good Time
    [1692345089.091248][79204:79206] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345089.095204][79204:79206] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345089.098552][79204:79206] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345089.119552][79204:79206] CHIP:TOO: Sending command to node 0x1
    [1692345089.119976][79204:79206] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345089.120009][79204:79206] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345089.120044][79204:79206] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345089.120074][79204:79206] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345089.121858][79204:79206] CHIP:DL: Avahi resolve found
    [1692345089.121928][79204:79206] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345089.121951][79204:79206] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345089.121976][79204:79206] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345089.121997][79204:79206] CHIP:DIS:      Port: 5540
    [1692345089.122017][79204:79206] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345089.122037][79204:79206] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345089.122057][79204:79206] CHIP:DIS:      TCP Supported: 0
    [1692345089.122873][79204:79206] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345089.122980][79204:79206] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345089.123004][79204:79206] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345089.123023][79204:79206] CHIP:DIS: Keeping DNSSD lookup active
    [1692345089.320603][79204:79206] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345089.320734][79204:79206] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345089.320794][79204:79206] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345089.321024][79204:79206] CHIP:IN: SecureSession[0xffff8000d360]: Allocated Type:2 LSID:11329
    [1692345089.321119][79204:79206] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345089.323278][79204:79206] CHIP:EM: <<< [E:12046i S:0 M:239808595] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345089.323419][79204:79206] CHIP:IN: (U) Sending msg 239808595 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345089.323801][79204:79206] CHIP:SC: Sent Sigma1 msg
    [1692345089.323899][79204:79206] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345091.088162][79204:79206] CHIP:EM: >>> [E:12046i S:0 M:205208479 (Ack:239808595)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345091.088254][79204:79206] CHIP:EM: Found matching exchange: 12046i, Delegate: 0xffff8000f408
    [1692345091.088328][79204:79206] CHIP:EM: Rxd Ack; Removing MessageCounter:239808595 from Retrans Table on exchange 12046i
    [1692345091.371340][79204:79206] CHIP:EM: >>> [E:12046i S:0 M:205208480 (Ack:239808595)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345091.371432][79204:79206] CHIP:EM: Found matching exchange: 12046i, Delegate: 0xffff8000f408
    [1692345091.371488][79204:79206] CHIP:EM: CHIP MessageCounter:239808595 not in RetransTable on exchange 12046i
    [1692345091.371577][79204:79206] CHIP:SC: Received Sigma2 msg
    [1692345091.371651][79204:79206] CHIP:SC: Peer assigned session session ID 19069
    [1692345091.380292][79204:79206] CHIP:SC: Found MRP parameters in the message
    [1692345091.380400][79204:79206] CHIP:SC: Sending Sigma3
    [1692345091.381622][79204:79206] CHIP:EM: <<< [E:12046i S:0 M:239808596 (Ack:205208480)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345091.381914][79204:79206] CHIP:IN: (U) Sending msg 239808596 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345091.382423][79204:79206] CHIP:SC: Sent Sigma3 msg
    [1692345091.611092][79204:79206] CHIP:EM: >>> [E:12046i S:0 M:205208481 (Ack:239808596)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345091.611180][79204:79206] CHIP:EM: Found matching exchange: 12046i, Delegate: 0xffff8000f408
    [1692345091.611253][79204:79206] CHIP:EM: Rxd Ack; Removing MessageCounter:239808596 from Retrans Table on exchange 12046i
    [1692345091.799753][79204:79206] CHIP:EM: >>> [E:12046i S:0 M:205208482 (Ack:239808596)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345091.799853][79204:79206] CHIP:EM: Found matching exchange: 12046i, Delegate: 0xffff8000f408
    [1692345091.799916][79204:79206] CHIP:EM: CHIP MessageCounter:239808596 not in RetransTable on exchange 12046i
    [1692345091.800019][79204:79206] CHIP:SC: Success status report received. Session was established
    [1692345091.810734][79204:79206] CHIP:SC: SecureSession[0xffff8000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345091.810844][79204:79206] CHIP:IN: SecureSession[0xffff8000d360]: Activated - Type:2 LSID:11329
    [1692345091.810892][79204:79206] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:11329 PSID:19069!
    [1692345091.810952][79204:79206] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345091.815976][79204:79206] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0001, endpoint 0
    [1692345091.816035][79204:79206] CHIP:TOO: Sending ReadAttribute to:
    [1692345091.816076][79204:79206] CHIP:DMG: SendReadRequest ReadClient[0xffff80011fb0]: Sending Read Request
    [1692345091.816267][79204:79206] CHIP:EM: <<< [E:12047i S:11329 M:238718649] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345091.816318][79204:79206] CHIP:IN: (S) Sending msg 238718649 on secure session with LSID: 11329
    [1692345091.816529][79204:79206] CHIP:DMG: MoveToState ReadClient[0xffff80011fb0]: Moving to [AwaitingIn]
    [1692345091.816645][79204:79206] CHIP:EM: <<< [E:12046i S:0 M:239808597 (Ack:205208482)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345091.816808][79204:79206] CHIP:IN: (U) Sending msg 239808597 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345091.816938][79204:79206] CHIP:EM: Flushed pending ack for MessageCounter:205208482 on exchange 12046i
    [1692345092.030133][79204:79206] CHIP:EM: >>> [E:12047i S:11329 M:189636292 (Ack:238718649)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345092.030221][79204:79206] CHIP:EM: Found matching exchange: 12047i, Delegate: 0xffff80011fc0
    [1692345092.030296][79204:79206] CHIP:EM: Rxd Ack; Removing MessageCounter:238718649 from Retrans Table on exchange 12047i
    [1692345092.030426][79204:79206] CHIP:DMG: ReportDataMessage =
    [1692345092.030482][79204:79206] CHIP:DMG: {
    [1692345092.030526][79204:79206] CHIP:DMG:      AttributeReportIBs =
    [1692345092.030592][79204:79206] CHIP:DMG:      [
    [1692345092.030642][79204:79206] CHIP:DMG:              AttributeReportIB =
    [1692345092.030711][79204:79206] CHIP:DMG:              {
    [1692345092.030764][79204:79206] CHIP:DMG:                      AttributeDataIB =
    [1692345092.030827][79204:79206] CHIP:DMG:                      {
    [1692345092.030888][79204:79206] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345092.030949][79204:79206] CHIP:DMG:                              AttributePathIB =
    [1692345092.031014][79204:79206] CHIP:DMG:                              {
    [1692345092.031080][79204:79206] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345092.031151][79204:79206] CHIP:DMG:                                      Cluster = 0x31,
    [1692345092.031220][79204:79206] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345092.031285][79204:79206] CHIP:DMG:                              }
    [1692345092.031352][79204:79206] CHIP:DMG:
    [1692345092.031415][79204:79206] CHIP:DMG:                              Data = [
    [1692345092.031477][79204:79206] CHIP:DMG:
    [1692345092.031546][79204:79206] CHIP:DMG:                              ],
    [1692345092.031607][79204:79206] CHIP:DMG:                      },
    [1692345092.031673][79204:79206] CHIP:DMG:
    [1692345092.031725][79204:79206] CHIP:DMG:              },
    [1692345092.031803][79204:79206] CHIP:DMG:
    [1692345092.031852][79204:79206] CHIP:DMG:              AttributeReportIB =
    [1692345092.031921][79204:79206] CHIP:DMG:              {
    [1692345092.031973][79204:79206] CHIP:DMG:                      AttributeDataIB =
    [1692345092.032032][79204:79206] CHIP:DMG:                      {
    [1692345092.032093][79204:79206] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345092.032155][79204:79206] CHIP:DMG:                              AttributePathIB =
    [1692345092.032218][79204:79206] CHIP:DMG:                              {
    [1692345092.032282][79204:79206] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345092.032351][79204:79206] CHIP:DMG:                                      Cluster = 0x31,
    [1692345092.032420][79204:79206] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345092.032487][79204:79206] CHIP:DMG:                                      ListIndex = Null,
    [1692345092.032552][79204:79206] CHIP:DMG:                              }
    [1692345092.032620][79204:79206] CHIP:DMG:
    [1692345092.032682][79204:79206] CHIP:DMG:                              Data =
    [1692345092.032745][79204:79206] CHIP:DMG:                              {
    [1692345092.032855][79204:79206] CHIP:DMG:                                      0x0 = [
    [1692345092.032926][79204:79206] CHIP:DMG:                                                      0x69, 0x5e, 0x3b, 0xcb, 0x08, 0xb9, 0x69, 0x68,
    [1692345092.033003][79204:79206] CHIP:DMG:                                      ] (8 bytes)
    [1692345092.033071][79204:79206] CHIP:DMG:                                      0x1 = true,
    [1692345092.033139][79204:79206] CHIP:DMG:                              },
    [1692345092.033198][79204:79206] CHIP:DMG:                      },
    [1692345092.033266][79204:79206] CHIP:DMG:
    [1692345092.033317][79204:79206] CHIP:DMG:              },
    [1692345092.033381][79204:79206] CHIP:DMG:
    [1692345092.033430][79204:79206] CHIP:DMG:      ],
    [1692345092.033501][79204:79206] CHIP:DMG:
    [1692345092.033550][79204:79206] CHIP:DMG:      SuppressResponse = true,
    [1692345092.033600][79204:79206] CHIP:DMG:      InteractionModelRevision = 1
    [1692345092.033647][79204:79206] CHIP:DMG: }
    [1692345092.034175][79204:79206] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0001 DataVersion: 3295567105
    [1692345092.038469][79204:79206] CHIP:TOO:   Networks: 1 entries
    [1692345092.038541][79204:79206] CHIP:TOO:     [1]: {
    [1692345092.038580][79204:79206] CHIP:TOO:       NetworkID: 695E3BCB08B96968
    [1692345092.038611][79204:79206] CHIP:TOO:       Connected: TRUE
    [1692345092.038639][79204:79206] CHIP:TOO:      }
    [1692345092.039321][79204:79206] CHIP:EM: <<< [E:12047i S:11329 M:238718650 (Ack:189636292)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345092.039388][79204:79206] CHIP:IN: (S) Sending msg 238718650 on secure session with LSID: 11329
    [1692345092.039585][79204:79206] CHIP:EM: Flushed pending ack for MessageCounter:189636292 on exchange 12047i
    [1692345092.039909][79204:79204] CHIP:CTL: Shutting down the commissioner
    [1692345092.039957][79204:79204] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345092.039990][79204:79204] CHIP:CTL: Shutting down the controller
    [1692345092.040022][79204:79204] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345092.040053][79204:79204] CHIP:IN: SecureSession[0xffff8000d360]: MarkForEviction Type:2 LSID:11329
    [1692345092.040081][79204:79204] CHIP:SC: SecureSession[0xffff8000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345092.040108][79204:79204] CHIP:IN: SecureSession[0xffff8000d360]: Released - Type:2 LSID:11329
    [1692345092.040142][79204:79204] CHIP:FP: Forgetting fabric 0x1
    [1692345092.040183][79204:79204] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345092.040505][79204:79204] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345092.040542][79204:79204] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345092.040597][79204:79204] CHIP:CTL: Shutting down the commissioner
    [1692345092.040628][79204:79204] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345092.040658][79204:79204] CHIP:CTL: Shutting down the controller
    [1692345092.040685][79204:79204] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345092.041973][79204:79204] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345092.042134][79204:79204] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345092.042212][79204:79204] CHIP:FP: Shutting down FabricTable
    [1692345092.042255][79204:79204] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345092.042489][79204:79204] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345092.042537][79204:79204] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345092.042839][79204:79204] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-4A0f9Z)
    [1692345092.043690][79204:79204] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345092.043778][79204:79204] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345092.043812][79204:79204] CHIP:DL: Inet Layer shutdown
    [1692345092.043839][79204:79204] CHIP:DL: BLE shutdown
    [1692345092.043868][79204:79204] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$  ./chip-tool networkcommissioning  remove-network hex:695E3BCB08B96968 1 0
    [1692345140.378472][79209:79209] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345140.383851][79209:79209] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345140.384109][79209:79209] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345140.384217][79209:79209] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345140.384554][79209:79209] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-bdFzdj)
    [1692345140.385137][79209:79209] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345140.385189][79209:79209] CHIP:DL: NVS set: chip-counters/reboot-count = 19 (0x13)
    [1692345140.386066][79209:79209] CHIP:DL: Got Ethernet interface: eth0
    [1692345140.386670][79209:79209] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345140.387252][79209:79209] CHIP:DL: Got WiFi interface: wlan0
    [1692345140.387323][79209:79209] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345140.387374][79209:79209] CHIP:IN: UDP::Init bind&listen port=0
    [1692345140.387478][79209:79209] CHIP:IN: UDP::Init bound to port=42453
    [1692345140.387498][79209:79209] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345140.387516][79209:79209] CHIP:IN: TransportMgr initialized
    [1692345140.387547][79209:79209] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345140.387843][79209:79209] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345140.389369][79209:79209] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345140.389845][79209:79209] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345140.392445][79209:79209] CHIP:ZCL: Using ZAP configuration...
    [1692345140.395904][79209:79209] CHIP:DL: Avahi client registered
    [1692345140.396912][79209:79209] CHIP:CTL: System State Initialized...
    [1692345140.397026][79209:79209] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345140.397078][79209:79209] CHIP:CTL: Setting attestation nonce to random value
    [1692345140.397111][79209:79209] CHIP:CTL: Setting CSR nonce to random value
    [1692345140.397412][79209:79211] CHIP:DL: CHIP task running
    [1692345140.397592][79209:79211] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345140.397930][79209:79211] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345140.397973][79209:79211] CHIP:CTL: Setting attestation nonce to random value
    [1692345140.398154][79209:79211] CHIP:CTL: Setting CSR nonce to random value
    [1692345140.399054][79209:79211] CHIP:CTL: Generating NOC
    [1692345140.399993][79209:79211] CHIP:FP: Validating NOC chain
    [1692345140.401593][79209:79211] CHIP:FP: NOC chain validation successful
    [1692345140.401793][79209:79211] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345140.401834][79209:79211] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345140.401862][79209:79211] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345140.401886][79209:79211] CHIP:TS: Retaining current Last Known Good Time
    [1692345140.411056][79209:79211] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345140.413556][79209:79211] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345140.415610][79209:79211] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345140.435437][79209:79211] CHIP:TOO: Sending command to node 0x1
    [1692345140.435830][79209:79211] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345140.435860][79209:79211] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345140.435892][79209:79211] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345140.435922][79209:79211] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345140.437601][79209:79211] CHIP:DL: Avahi resolve found
    [1692345140.437673][79209:79211] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345140.437693][79209:79211] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345140.437717][79209:79211] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345140.437737][79209:79211] CHIP:DIS:      Port: 5540
    [1692345140.437754][79209:79211] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345140.437772][79209:79211] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345140.437790][79209:79211] CHIP:DIS:      TCP Supported: 0
    [1692345140.438566][79209:79211] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345140.438666][79209:79211] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345140.438688][79209:79211] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345140.438705][79209:79211] CHIP:DIS: Keeping DNSSD lookup active
    [1692345140.635969][79209:79211] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345140.636088][79209:79211] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345140.636138][79209:79211] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345140.636343][79209:79211] CHIP:IN: SecureSession[0xffffac00d360]: Allocated Type:2 LSID:11462
    [1692345140.636427][79209:79211] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345140.638421][79209:79211] CHIP:EM: <<< [E:58728i S:0 M:62171861] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345140.638541][79209:79211] CHIP:IN: (U) Sending msg 62171861 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345140.638847][79209:79211] CHIP:SC: Sent Sigma1 msg
    [1692345140.638915][79209:79211] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345142.434883][79209:79211] CHIP:EM: >>> [E:58728i S:0 M:205208483 (Ack:62171861)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345142.434972][79209:79211] CHIP:EM: Found matching exchange: 58728i, Delegate: 0xffffac00f408
    [1692345142.435044][79209:79211] CHIP:EM: Rxd Ack; Removing MessageCounter:62171861 from Retrans Table on exchange 58728i
    [1692345142.711963][79209:79211] CHIP:EM: >>> [E:58728i S:0 M:205208484 (Ack:62171861)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345142.712054][79209:79211] CHIP:EM: Found matching exchange: 58728i, Delegate: 0xffffac00f408
    [1692345142.712108][79209:79211] CHIP:EM: CHIP MessageCounter:62171861 not in RetransTable on exchange 58728i
    [1692345142.712196][79209:79211] CHIP:SC: Received Sigma2 msg
    [1692345142.712267][79209:79211] CHIP:SC: Peer assigned session session ID 19070
    [1692345142.720498][79209:79211] CHIP:SC: Found MRP parameters in the message
    [1692345142.720569][79209:79211] CHIP:SC: Sending Sigma3
    [1692345142.721356][79209:79211] CHIP:EM: <<< [E:58728i S:0 M:62171862 (Ack:205208484)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345142.721569][79209:79211] CHIP:IN: (U) Sending msg 62171862 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345142.721795][79209:79211] CHIP:SC: Sent Sigma3 msg
    [1692345142.960298][79209:79211] CHIP:EM: >>> [E:58728i S:0 M:205208485 (Ack:62171862)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345142.960387][79209:79211] CHIP:EM: Found matching exchange: 58728i, Delegate: 0xffffac00f408
    [1692345142.960460][79209:79211] CHIP:EM: Rxd Ack; Removing MessageCounter:62171862 from Retrans Table on exchange 58728i
    [1692345143.153035][79209:79211] CHIP:EM: >>> [E:58728i S:0 M:205208486 (Ack:62171862)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345143.153136][79209:79211] CHIP:EM: Found matching exchange: 58728i, Delegate: 0xffffac00f408
    [1692345143.153199][79209:79211] CHIP:EM: CHIP MessageCounter:62171862 not in RetransTable on exchange 58728i
    [1692345143.153301][79209:79211] CHIP:SC: Success status report received. Session was established
    [1692345143.161285][79209:79211] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345143.161348][79209:79211] CHIP:IN: SecureSession[0xffffac00d360]: Activated - Type:2 LSID:11462
    [1692345143.161375][79209:79211] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:11462 PSID:19070!
    [1692345143.161410][79209:79211] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345143.161473][79209:79211] CHIP:TOO: Sending cluster (0x00000031) command (0x00000004) on endpoint 0
    [1692345143.161575][79209:79211] CHIP:DMG: ICR moving to [AddingComm]
    [1692345143.161644][79209:79211] CHIP:DMG: ICR moving to [AddedComma]
    [1692345143.161802][79209:79211] CHIP:EM: <<< [E:58729i S:11462 M:129031340] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345143.161856][79209:79211] CHIP:IN: (S) Sending msg 129031340 on secure session with LSID: 11462
    [1692345143.162110][79209:79211] CHIP:DMG: ICR moving to [CommandSen]
    [1692345143.162208][79209:79211] CHIP:EM: <<< [E:58728i S:0 M:62171863 (Ack:205208486)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345143.162374][79209:79211] CHIP:IN: (U) Sending msg 62171863 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345143.162509][79209:79211] CHIP:EM: Flushed pending ack for MessageCounter:205208486 on exchange 58728i
    [1692345143.382980][79209:79211] CHIP:EM: >>> [E:58729i S:11462 M:168859616 (Ack:129031340)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345143.383070][79209:79211] CHIP:EM: Found matching exchange: 58729i, Delegate: 0xffffac00a4f8
    [1692345143.383142][79209:79211] CHIP:EM: Rxd Ack; Removing MessageCounter:129031340 from Retrans Table on exchange 58729i
    [1692345143.383212][79209:79211] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345143.383304][79209:79211] CHIP:DMG: InvokeResponseMessage =
    [1692345143.383354][79209:79211] CHIP:DMG: {
    [1692345143.383402][79209:79211] CHIP:DMG:      suppressResponse = false,
    [1692345143.383451][79209:79211] CHIP:DMG:      InvokeResponseIBs =
    [1692345143.383517][79209:79211] CHIP:DMG:      [
    [1692345143.383566][79209:79211] CHIP:DMG:              InvokeResponseIB =
    [1692345143.383633][79209:79211] CHIP:DMG:              {
    [1692345143.383686][79209:79211] CHIP:DMG:                      CommandDataIB =
    [1692345143.383748][79209:79211] CHIP:DMG:                      {
    [1692345143.383804][79209:79211] CHIP:DMG:                              CommandPathIB =
    [1692345143.383869][79209:79211] CHIP:DMG:                              {
    [1692345143.383936][79209:79211] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345143.384007][79209:79211] CHIP:DMG:                                      ClusterId = 0x31,
    [1692345143.384077][79209:79211] CHIP:DMG:                                      CommandId = 0x5,
    [1692345143.384143][79209:79211] CHIP:DMG:                              },
    [1692345143.384211][79209:79211] CHIP:DMG:
    [1692345143.384270][79209:79211] CHIP:DMG:                              CommandFields =
    [1692345143.384336][79209:79211] CHIP:DMG:                              {
    [1692345143.384450][79209:79211] CHIP:DMG:                                      0x0 = 0,
    [1692345143.384523][79209:79211] CHIP:DMG:                                      0x2 = 0,
    [1692345143.384594][79209:79211] CHIP:DMG:                              },
    [1692345143.384655][79209:79211] CHIP:DMG:                      },
    [1692345143.384724][79209:79211] CHIP:DMG:
    [1692345143.384776][79209:79211] CHIP:DMG:              },
    [1692345143.384839][79209:79211] CHIP:DMG:
    [1692345143.384887][79209:79211] CHIP:DMG:      ],
    [1692345143.384950][79209:79211] CHIP:DMG:
    [1692345143.384998][79209:79211] CHIP:DMG:      InteractionModelRevision = 1
    [1692345143.385046][79209:79211] CHIP:DMG: },
    [1692345143.385177][79209:79211] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1692345143.385266][79209:79211] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Command 0x0000_0005
    [1692345143.385409][79209:79211] CHIP:TOO:   NetworkConfigResponse: {
    [1692345143.385474][79209:79211] CHIP:TOO:     networkingStatus: 0
    [1692345143.385525][79209:79211] CHIP:TOO:     networkIndex: 0
    [1692345143.385571][79209:79211] CHIP:TOO:    }
    [1692345143.385649][79209:79211] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345143.385842][79209:79211] CHIP:EM: <<< [E:58729i S:11462 M:129031341 (Ack:168859616)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345143.385921][79209:79211] CHIP:IN: (S) Sending msg 129031341 on secure session with LSID: 11462
    [1692345143.386278][79209:79211] CHIP:EM: Flushed pending ack for MessageCounter:168859616 on exchange 58729i
    [1692345143.386642][79209:79209] CHIP:CTL: Shutting down the commissioner
    [1692345143.386708][79209:79209] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345143.386756][79209:79209] CHIP:CTL: Shutting down the controller
    [1692345143.386804][79209:79209] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345143.386848][79209:79209] CHIP:IN: SecureSession[0xffffac00d360]: MarkForEviction Type:2 LSID:11462
    [1692345143.386996][79209:79209] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345143.387050][79209:79209] CHIP:IN: SecureSession[0xffffac00d360]: Released - Type:2 LSID:11462
    [1692345143.387103][79209:79209] CHIP:FP: Forgetting fabric 0x1
    [1692345143.387165][79209:79209] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345143.387554][79209:79209] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345143.387625][79209:79209] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345143.387709][79209:79209] CHIP:CTL: Shutting down the commissioner
    [1692345143.387764][79209:79209] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345143.387806][79209:79209] CHIP:CTL: Shutting down the controller
    [1692345143.387844][79209:79209] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345143.389655][79209:79209] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345143.389824][79209:79209] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345143.389920][79209:79209] CHIP:FP: Shutting down FabricTable
    [1692345143.389981][79209:79209] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345143.390480][79209:79209] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345143.390536][79209:79209] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345143.390928][79209:79209] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-4WngLH)
    [1692345143.392077][79209:79209] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345143.392198][79209:79209] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345143.392250][79209:79209] CHIP:DL: Inet Layer shutdown
    [1692345143.392292][79209:79209] CHIP:DL: BLE shutdown
    [1692345143.392335][79209:79209] CHIP:DL: System Layer shutdown
    [1692345160.083341][79212:79212] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345160.088773][79212:79212] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345160.089036][79212:79212] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345160.089139][79212:79212] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345160.089473][79212:79212] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-3fnSoU)
    [1692345160.090061][79212:79212] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345160.090148][79212:79212] CHIP:DL: NVS set: chip-counters/reboot-count = 20 (0x14)
    [1692345160.091023][79212:79212] CHIP:DL: Got Ethernet interface: eth0
    [1692345160.091586][79212:79212] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345160.092164][79212:79212] CHIP:DL: Got WiFi interface: wlan0
    [1692345160.092225][79212:79212] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345160.092275][79212:79212] CHIP:IN: UDP::Init bind&listen port=0
    [1692345160.092380][79212:79212] CHIP:IN: UDP::Init bound to port=53595
    [1692345160.092400][79212:79212] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345160.092418][79212:79212] CHIP:IN: TransportMgr initialized
    [1692345160.092553][79212:79212] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345160.092744][79212:79212] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345160.094300][79212:79212] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345160.094747][79212:79212] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345160.097261][79212:79212] CHIP:ZCL: Using ZAP configuration...
    [1692345160.100794][79212:79212] CHIP:DL: Avahi client registered
    [1692345160.101875][79212:79212] CHIP:CTL: System State Initialized...
    [1692345160.101992][79212:79212] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345160.102045][79212:79212] CHIP:CTL: Setting attestation nonce to random value
    [1692345160.102099][79212:79212] CHIP:CTL: Setting CSR nonce to random value
    [1692345160.102427][79212:79214] CHIP:DL: CHIP task running
    [1692345160.102612][79212:79214] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345160.102879][79212:79214] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345160.102921][79212:79214] CHIP:CTL: Setting attestation nonce to random value
    [1692345160.103068][79212:79214] CHIP:CTL: Setting CSR nonce to random value
    [1692345160.103846][79212:79214] CHIP:CTL: Generating NOC
    [1692345160.104771][79212:79214] CHIP:FP: Validating NOC chain
    [1692345160.106358][79212:79214] CHIP:FP: NOC chain validation successful
    [1692345160.106502][79212:79214] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345160.106530][79212:79214] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345160.106549][79212:79214] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345160.106565][79212:79214] CHIP:TS: Retaining current Last Known Good Time
    [1692345160.114715][79212:79214] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345160.117631][79212:79214] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345160.120289][79212:79214] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345160.140865][79212:79214] CHIP:TOO: Sending command to node 0x1
    [1692345160.141284][79212:79214] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345160.141317][79212:79214] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345160.141353][79212:79214] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345160.141383][79212:79214] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345160.143031][79212:79214] CHIP:DL: Avahi resolve found
    [1692345160.143102][79212:79214] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345160.143122][79212:79214] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345160.143144][79212:79214] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345160.143164][79212:79214] CHIP:DIS:      Port: 5540
    [1692345160.143181][79212:79214] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345160.143200][79212:79214] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345160.143218][79212:79214] CHIP:DIS:      TCP Supported: 0
    [1692345160.143931][79212:79214] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345160.144030][79212:79214] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345160.144053][79212:79214] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345160.144069][79212:79214] CHIP:DIS: Keeping DNSSD lookup active
    [1692345160.342350][79212:79214] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345160.342441][79212:79214] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345160.342475][79212:79214] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345160.342632][79212:79214] CHIP:IN: SecureSession[0xffffac00d360]: Allocated Type:2 LSID:8708
    [1692345160.342696][79212:79214] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345160.343975][79212:79214] CHIP:EM: <<< [E:30182i S:0 M:236714649] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345160.344064][79212:79214] CHIP:IN: (U) Sending msg 236714649 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345160.344282][79212:79214] CHIP:SC: Sent Sigma1 msg
    [1692345160.344315][79212:79214] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345161.605395][79212:79214] CHIP:EM: >>> [E:30182i S:0 M:205208487 (Ack:236714649)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345161.605483][79212:79214] CHIP:EM: Found matching exchange: 30182i, Delegate: 0xffffac00f408
    [1692345161.605555][79212:79214] CHIP:EM: Rxd Ack; Removing MessageCounter:236714649 from Retrans Table on exchange 30182i
    [1692345161.882792][79212:79214] CHIP:EM: >>> [E:30182i S:0 M:205208488 (Ack:236714649)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345161.882891][79212:79214] CHIP:EM: Found matching exchange: 30182i, Delegate: 0xffffac00f408
    [1692345161.882952][79212:79214] CHIP:EM: CHIP MessageCounter:236714649 not in RetransTable on exchange 30182i
    [1692345161.883052][79212:79214] CHIP:SC: Received Sigma2 msg
    [1692345161.883135][79212:79214] CHIP:SC: Peer assigned session session ID 19071
    [1692345161.893098][79212:79214] CHIP:SC: Found MRP parameters in the message
    [1692345161.893218][79212:79214] CHIP:SC: Sending Sigma3
    [1692345161.894646][79212:79214] CHIP:EM: <<< [E:30182i S:0 M:236714650 (Ack:205208488)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345161.894974][79212:79214] CHIP:IN: (U) Sending msg 236714650 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345161.895338][79212:79214] CHIP:SC: Sent Sigma3 msg
    [1692345162.130013][79212:79214] CHIP:EM: >>> [E:30182i S:0 M:205208489 (Ack:236714650)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345162.130163][79212:79214] CHIP:EM: Found matching exchange: 30182i, Delegate: 0xffffac00f408
    [1692345162.130249][79212:79214] CHIP:EM: Rxd Ack; Removing MessageCounter:236714650 from Retrans Table on exchange 30182i
    [1692345162.322656][79212:79214] CHIP:EM: >>> [E:30182i S:0 M:205208490 (Ack:236714650)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345162.322758][79212:79214] CHIP:EM: Found matching exchange: 30182i, Delegate: 0xffffac00f408
    [1692345162.322815][79212:79214] CHIP:EM: CHIP MessageCounter:236714650 not in RetransTable on exchange 30182i
    [1692345162.322922][79212:79214] CHIP:SC: Success status report received. Session was established
    [1692345162.331824][79212:79214] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345162.331906][79212:79214] CHIP:IN: SecureSession[0xffffac00d360]: Activated - Type:2 LSID:8708
    [1692345162.331946][79212:79214] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:8708 PSID:19071!
    [1692345162.331996][79212:79214] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345162.332170][79212:79214] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0001, endpoint 0
    [1692345162.332235][79212:79214] CHIP:TOO: Sending ReadAttribute to:
    [1692345162.332290][79212:79214] CHIP:DMG: SendReadRequest ReadClient[0xffffac011fb0]: Sending Read Request
    [1692345162.332532][79212:79214] CHIP:EM: <<< [E:30183i S:8708 M:117783877] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345162.332610][79212:79214] CHIP:IN: (S) Sending msg 117783877 on secure session with LSID: 8708
    [1692345162.332901][79212:79214] CHIP:DMG: MoveToState ReadClient[0xffffac011fb0]: Moving to [AwaitingIn]
    [1692345162.333036][79212:79214] CHIP:EM: <<< [E:30182i S:0 M:236714651 (Ack:205208490)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345162.333262][79212:79214] CHIP:IN: (U) Sending msg 236714651 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345162.333444][79212:79214] CHIP:EM: Flushed pending ack for MessageCounter:205208490 on exchange 30182i
    [1692345162.538229][79212:79214] CHIP:EM: >>> [E:30183i S:8708 M:254236362 (Ack:117783877)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345162.538304][79212:79214] CHIP:EM: Found matching exchange: 30183i, Delegate: 0xffffac011fc0
    [1692345162.538363][79212:79214] CHIP:EM: Rxd Ack; Removing MessageCounter:117783877 from Retrans Table on exchange 30183i
    [1692345162.538457][79212:79214] CHIP:DMG: ReportDataMessage =
    [1692345162.538500][79212:79214] CHIP:DMG: {
    [1692345162.538534][79212:79214] CHIP:DMG:      AttributeReportIBs =
    [1692345162.538586][79212:79214] CHIP:DMG:      [
    [1692345162.538625][79212:79214] CHIP:DMG:              AttributeReportIB =
    [1692345162.538678][79212:79214] CHIP:DMG:              {
    [1692345162.538719][79212:79214] CHIP:DMG:                      AttributeDataIB =
    [1692345162.538773][79212:79214] CHIP:DMG:                      {
    [1692345162.538821][79212:79214] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345162.538898][79212:79214] CHIP:DMG:                              AttributePathIB =
    [1692345162.538949][79212:79214] CHIP:DMG:                              {
    [1692345162.539001][79212:79214] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345162.539055][79212:79214] CHIP:DMG:                                      Cluster = 0x31,
    [1692345162.539124][79212:79214] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345162.539176][79212:79214] CHIP:DMG:                              }
    [1692345162.539229][79212:79214] CHIP:DMG:
    [1692345162.539278][79212:79214] CHIP:DMG:                              Data = [
    [1692345162.539343][79212:79214] CHIP:DMG:
    [1692345162.539397][79212:79214] CHIP:DMG:                              ],
    [1692345162.539444][79212:79214] CHIP:DMG:                      },
    [1692345162.539496][79212:79214] CHIP:DMG:
    [1692345162.539557][79212:79214] CHIP:DMG:              },
    [1692345162.539606][79212:79214] CHIP:DMG:
    [1692345162.539643][79212:79214] CHIP:DMG:      ],
    [1692345162.539691][79212:79214] CHIP:DMG:
    [1692345162.539744][79212:79214] CHIP:DMG:      SuppressResponse = true,
    [1692345162.539785][79212:79214] CHIP:DMG:      InteractionModelRevision = 1
    [1692345162.539821][79212:79214] CHIP:DMG: }
    [1692345162.540102][79212:79214] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0001 DataVersion: 3295567105
    [1692345162.540212][79212:79214] CHIP:TOO:   Networks: 0 entries
    [1692345162.540450][79212:79214] CHIP:EM: <<< [E:30183i S:8708 M:117783878 (Ack:254236362)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345162.540515][79212:79214] CHIP:IN: (S) Sending msg 117783878 on secure session with LSID: 8708
    [1692345162.540730][79212:79214] CHIP:EM: Flushed pending ack for MessageCounter:254236362 on exchange 30183i
    [1692345162.541044][79212:79212] CHIP:CTL: Shutting down the commissioner
    [1692345162.541151][79212:79212] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345162.541194][79212:79212] CHIP:CTL: Shutting down the controller
    [1692345162.541232][79212:79212] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345162.541267][79212:79212] CHIP:IN: SecureSession[0xffffac00d360]: MarkForEviction Type:2 LSID:8708
    [1692345162.541303][79212:79212] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345162.541338][79212:79212] CHIP:IN: SecureSession[0xffffac00d360]: Released - Type:2 LSID:8708
    [1692345162.541377][79212:79212] CHIP:FP: Forgetting fabric 0x1
    [1692345162.541426][79212:79212] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345162.541727][79212:79212] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345162.541766][79212:79212] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345162.541824][79212:79212] CHIP:CTL: Shutting down the commissioner
    [1692345162.541857][79212:79212] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345162.541890][79212:79212] CHIP:CTL: Shutting down the controller
    [1692345162.541919][79212:79212] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345162.543324][79212:79212] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345162.543455][79212:79212] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345162.543709][79212:79212] CHIP:FP: Shutting down FabricTable
    [1692345162.543830][79212:79212] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345162.544118][79212:79212] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345162.544163][79212:79212] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345162.544474][79212:79212] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-gX7vcf)
    [1692345162.545408][79212:79212] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345162.545496][79212:79212] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345162.545533][79212:79212] CHIP:DL: Inet Layer shutdown
    [1692345162.545564][79212:79212] CHIP:DL: BLE shutdown
    [1692345162.545596][79212:79212] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning read last-networking-status 1 0
    [1692345178.235032][79215:79215] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345178.240478][79215:79215] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345178.240743][79215:79215] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345178.240872][79215:79215] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345178.241243][79215:79215] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-vWND1y)
    [1692345178.241843][79215:79215] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345178.241897][79215:79215] CHIP:DL: NVS set: chip-counters/reboot-count = 21 (0x15)
    [1692345178.242837][79215:79215] CHIP:DL: Got Ethernet interface: eth0
    [1692345178.243441][79215:79215] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345178.244047][79215:79215] CHIP:DL: Got WiFi interface: wlan0
    [1692345178.244110][79215:79215] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345178.244162][79215:79215] CHIP:IN: UDP::Init bind&listen port=0
    [1692345178.244279][79215:79215] CHIP:IN: UDP::Init bound to port=51746
    [1692345178.244300][79215:79215] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345178.244326][79215:79215] CHIP:IN: TransportMgr initialized
    [1692345178.244358][79215:79215] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345178.244549][79215:79215] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345178.246106][79215:79215] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345178.246589][79215:79215] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345178.249116][79215:79215] CHIP:ZCL: Using ZAP configuration...
    [1692345178.252637][79215:79215] CHIP:DL: Avahi client registered
    [1692345178.253628][79215:79215] CHIP:CTL: System State Initialized...
    [1692345178.253741][79215:79215] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345178.253796][79215:79215] CHIP:CTL: Setting attestation nonce to random value
    [1692345178.253831][79215:79215] CHIP:CTL: Setting CSR nonce to random value
    [1692345178.254162][79215:79217] CHIP:DL: CHIP task running
    [1692345178.254357][79215:79217] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345178.254627][79215:79217] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345178.254668][79215:79217] CHIP:CTL: Setting attestation nonce to random value
    [1692345178.254820][79215:79217] CHIP:CTL: Setting CSR nonce to random value
    [1692345178.255600][79215:79217] CHIP:CTL: Generating NOC
    [1692345178.256525][79215:79217] CHIP:FP: Validating NOC chain
    [1692345178.258139][79215:79217] CHIP:FP: NOC chain validation successful
    [1692345178.258284][79215:79217] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345178.258313][79215:79217] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345178.258331][79215:79217] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345178.258349][79215:79217] CHIP:TS: Retaining current Last Known Good Time
    [1692345178.268534][79215:79217] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345178.271300][79215:79217] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345178.273841][79215:79217] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345178.294534][79215:79217] CHIP:TOO: Sending command to node 0x1
    [1692345178.294965][79215:79217] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345178.294999][79215:79217] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345178.295034][79215:79217] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345178.295065][79215:79217] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345178.296776][79215:79217] CHIP:DL: Avahi resolve found
    [1692345178.296849][79215:79217] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345178.296871][79215:79217] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345178.296897][79215:79217] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345178.296920][79215:79217] CHIP:DIS:      Port: 5540
    [1692345178.296940][79215:79217] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345178.296960][79215:79217] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345178.296980][79215:79217] CHIP:DIS:      TCP Supported: 0
    [1692345178.297770][79215:79217] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345178.297968][79215:79217] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345178.297995][79215:79217] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345178.298014][79215:79217] CHIP:DIS: Keeping DNSSD lookup active
    [1692345178.494495][79215:79217] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345178.494625][79215:79217] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345178.494686][79215:79217] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345178.494916][79215:79217] CHIP:IN: SecureSession[0xffff9000d360]: Allocated Type:2 LSID:22332
    [1692345178.495010][79215:79217] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345178.497118][79215:79217] CHIP:EM: <<< [E:30366i S:0 M:267130384] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345178.497255][79215:79217] CHIP:IN: (U) Sending msg 267130384 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345178.497609][79215:79217] CHIP:SC: Sent Sigma1 msg
    [1692345178.497682][79215:79217] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345178.767704][79215:79217] CHIP:EM: >>> [E:30366i S:0 M:205208491 (Ack:267130384)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345178.767795][79215:79217] CHIP:EM: Found matching exchange: 30366i, Delegate: 0xffff9000f408
    [1692345178.767869][79215:79217] CHIP:EM: Rxd Ack; Removing MessageCounter:267130384 from Retrans Table on exchange 30366i
    [1692345179.049718][79215:79217] CHIP:EM: >>> [E:30366i S:0 M:205208492 (Ack:267130384)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345179.049808][79215:79217] CHIP:EM: Found matching exchange: 30366i, Delegate: 0xffff9000f408
    [1692345179.049861][79215:79217] CHIP:EM: CHIP MessageCounter:267130384 not in RetransTable on exchange 30366i
    [1692345179.049948][79215:79217] CHIP:SC: Received Sigma2 msg
    [1692345179.050020][79215:79217] CHIP:SC: Peer assigned session session ID 19072
    [1692345179.057837][79215:79217] CHIP:SC: Found MRP parameters in the message
    [1692345179.057920][79215:79217] CHIP:SC: Sending Sigma3
    [1692345179.058786][79215:79217] CHIP:EM: <<< [E:30366i S:0 M:267130385 (Ack:205208492)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345179.059007][79215:79217] CHIP:IN: (U) Sending msg 267130385 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345179.059243][79215:79217] CHIP:SC: Sent Sigma3 msg
    [1692345179.291020][79215:79217] CHIP:EM: >>> [E:30366i S:0 M:205208493 (Ack:267130385)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345179.291111][79215:79217] CHIP:EM: Found matching exchange: 30366i, Delegate: 0xffff9000f408
    [1692345179.291183][79215:79217] CHIP:EM: Rxd Ack; Removing MessageCounter:267130385 from Retrans Table on exchange 30366i
    [1692345179.483593][79215:79217] CHIP:EM: >>> [E:30366i S:0 M:205208494 (Ack:267130385)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345179.483695][79215:79217] CHIP:EM: Found matching exchange: 30366i, Delegate: 0xffff9000f408
    [1692345179.483757][79215:79217] CHIP:EM: CHIP MessageCounter:267130385 not in RetransTable on exchange 30366i
    [1692345179.483860][79215:79217] CHIP:SC: Success status report received. Session was established
    [1692345179.492362][79215:79217] CHIP:SC: SecureSession[0xffff9000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345179.492423][79215:79217] CHIP:IN: SecureSession[0xffff9000d360]: Activated - Type:2 LSID:22332
    [1692345179.492451][79215:79217] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:22332 PSID:19072!
    [1692345179.492486][79215:79217] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345179.492620][79215:79217] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0005, endpoint 0
    [1692345179.492660][79215:79217] CHIP:TOO: Sending ReadAttribute to:
    [1692345179.492697][79215:79217] CHIP:DMG: SendReadRequest ReadClient[0xffff90011fb0]: Sending Read Request
    [1692345179.492940][79215:79217] CHIP:EM: <<< [E:30367i S:22332 M:166277378] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345179.492998][79215:79217] CHIP:IN: (S) Sending msg 166277378 on secure session with LSID: 22332
    [1692345179.493227][79215:79217] CHIP:DMG: MoveToState ReadClient[0xffff90011fb0]: Moving to [AwaitingIn]
    [1692345179.493350][79215:79217] CHIP:EM: <<< [E:30366i S:0 M:267130386 (Ack:205208494)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345179.493520][79215:79217] CHIP:IN: (U) Sending msg 267130386 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345179.493662][79215:79217] CHIP:EM: Flushed pending ack for MessageCounter:205208494 on exchange 30366i
    [1692345179.706884][79215:79217] CHIP:EM: >>> [E:30367i S:22332 M:250869000 (Ack:166277378)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345179.706967][79215:79217] CHIP:EM: Found matching exchange: 30367i, Delegate: 0xffff90011fc0
    [1692345179.707038][79215:79217] CHIP:EM: Rxd Ack; Removing MessageCounter:166277378 from Retrans Table on exchange 30367i
    [1692345179.707168][79215:79217] CHIP:DMG: ReportDataMessage =
    [1692345179.707234][79215:79217] CHIP:DMG: {
    [1692345179.707282][79215:79217] CHIP:DMG:      AttributeReportIBs =
    [1692345179.707347][79215:79217] CHIP:DMG:      [
    [1692345179.707397][79215:79217] CHIP:DMG:              AttributeReportIB =
    [1692345179.707463][79215:79217] CHIP:DMG:              {
    [1692345179.707516][79215:79217] CHIP:DMG:                      AttributeDataIB =
    [1692345179.707582][79215:79217] CHIP:DMG:                      {
    [1692345179.707648][79215:79217] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345179.707711][79215:79217] CHIP:DMG:                              AttributePathIB =
    [1692345179.707775][79215:79217] CHIP:DMG:                              {
    [1692345179.707841][79215:79217] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345179.707914][79215:79217] CHIP:DMG:                                      Cluster = 0x31,
    [1692345179.707984][79215:79217] CHIP:DMG:                                      Attribute = 0x0000_0005,
    [1692345179.708050][79215:79217] CHIP:DMG:                              }
    [1692345179.708117][79215:79217] CHIP:DMG:
    [1692345179.708186][79215:79217] CHIP:DMG:                              Data = 0,
    [1692345179.708247][79215:79217] CHIP:DMG:                      },
    [1692345179.708313][79215:79217] CHIP:DMG:
    [1692345179.708365][79215:79217] CHIP:DMG:              },
    [1692345179.708428][79215:79217] CHIP:DMG:
    [1692345179.708476][79215:79217] CHIP:DMG:      ],
    [1692345179.708536][79215:79217] CHIP:DMG:
    [1692345179.708586][79215:79217] CHIP:DMG:      SuppressResponse = true,
    [1692345179.708637][79215:79217] CHIP:DMG:      InteractionModelRevision = 1
    [1692345179.708685][79215:79217] CHIP:DMG: }
    [1692345179.708957][79215:79217] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0005 DataVersion: 3295567105
    [1692345179.717469][79215:79217] CHIP:TOO:   LastNetworkingStatus: 0
    [1692345179.717740][79215:79217] CHIP:EM: <<< [E:30367i S:22332 M:166277379 (Ack:250869000)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345179.717807][79215:79217] CHIP:IN: (S) Sending msg 166277379 on secure session with LSID: 22332
    [1692345179.718001][79215:79217] CHIP:EM: Flushed pending ack for MessageCounter:250869000 on exchange 30367i
    [1692345179.718331][79215:79215] CHIP:CTL: Shutting down the commissioner
    [1692345179.718385][79215:79215] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345179.718420][79215:79215] CHIP:CTL: Shutting down the controller
    [1692345179.718455][79215:79215] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345179.718485][79215:79215] CHIP:IN: SecureSession[0xffff9000d360]: MarkForEviction Type:2 LSID:22332
    [1692345179.718517][79215:79215] CHIP:SC: SecureSession[0xffff9000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345179.718550][79215:79215] CHIP:IN: SecureSession[0xffff9000d360]: Released - Type:2 LSID:22332
    [1692345179.718591][79215:79215] CHIP:FP: Forgetting fabric 0x1
    [1692345179.718637][79215:79215] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345179.718922][79215:79215] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345179.718963][79215:79215] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345179.719023][79215:79215] CHIP:CTL: Shutting down the commissioner
    [1692345179.719058][79215:79215] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345179.719091][79215:79215] CHIP:CTL: Shutting down the controller
    [1692345179.719119][79215:79215] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345179.720549][79215:79215] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345179.720684][79215:79215] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345179.720762][79215:79215] CHIP:FP: Shutting down FabricTable
    [1692345179.720808][79215:79215] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345179.721149][79215:79215] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345179.721200][79215:79215] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345179.721559][79215:79215] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-Py6YPH)
    [1692345179.722495][79215:79215] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345179.722587][79215:79215] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345179.722624][79215:79215] CHIP:DL: Inet Layer shutdown
    [1692345179.722653][79215:79215] CHIP:DL: BLE shutdown
    [1692345179.722685][79215:79215] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning read last-network-id 1 0
    [1692345190.164749][79219:79219] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345190.170239][79219:79219] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345190.170507][79219:79219] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345190.170614][79219:79219] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345190.170963][79219:79219] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-O0t3Ml)
    [1692345190.171545][79219:79219] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345190.171598][79219:79219] CHIP:DL: NVS set: chip-counters/reboot-count = 22 (0x16)
    [1692345190.172483][79219:79219] CHIP:DL: Got Ethernet interface: eth0
    [1692345190.173041][79219:79219] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345190.173614][79219:79219] CHIP:DL: Got WiFi interface: wlan0
    [1692345190.173674][79219:79219] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345190.173724][79219:79219] CHIP:IN: UDP::Init bind&listen port=0
    [1692345190.173830][79219:79219] CHIP:IN: UDP::Init bound to port=55708
    [1692345190.173849][79219:79219] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345190.173867][79219:79219] CHIP:IN: TransportMgr initialized
    [1692345190.173899][79219:79219] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345190.174117][79219:79219] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345190.175640][79219:79219] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345190.176095][79219:79219] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345190.178546][79219:79219] CHIP:ZCL: Using ZAP configuration...
    [1692345190.181969][79219:79219] CHIP:DL: Avahi client registered
    [1692345190.183054][79219:79219] CHIP:CTL: System State Initialized...
    [1692345190.183167][79219:79219] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345190.183219][79219:79219] CHIP:CTL: Setting attestation nonce to random value
    [1692345190.183252][79219:79219] CHIP:CTL: Setting CSR nonce to random value
    [1692345190.183545][79219:79221] CHIP:DL: CHIP task running
    [1692345190.183722][79219:79221] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345190.184000][79219:79221] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345190.184043][79219:79221] CHIP:CTL: Setting attestation nonce to random value
    [1692345190.184191][79219:79221] CHIP:CTL: Setting CSR nonce to random value
    [1692345190.184986][79219:79221] CHIP:CTL: Generating NOC
    [1692345190.185910][79219:79221] CHIP:FP: Validating NOC chain
    [1692345190.187591][79219:79221] CHIP:FP: NOC chain validation successful
    [1692345190.187772][79219:79221] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345190.187808][79219:79221] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345190.187831][79219:79221] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345190.187853][79219:79221] CHIP:TS: Retaining current Last Known Good Time
    [1692345190.196100][79219:79221] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345190.198788][79219:79221] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345190.200929][79219:79221] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345190.220573][79219:79221] CHIP:TOO: Sending command to node 0x1
    [1692345190.220960][79219:79221] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345190.220990][79219:79221] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345190.221023][79219:79221] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345190.221051][79219:79221] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345190.222668][79219:79221] CHIP:DL: Avahi resolve found
    [1692345190.222740][79219:79221] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345190.222761][79219:79221] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345190.222785][79219:79221] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345190.222805][79219:79221] CHIP:DIS:      Port: 5540
    [1692345190.222823][79219:79221] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345190.222841][79219:79221] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345190.222858][79219:79221] CHIP:DIS:      TCP Supported: 0
    [1692345190.223587][79219:79221] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345190.223682][79219:79221] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345190.223704][79219:79221] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345190.223721][79219:79221] CHIP:DIS: Keeping DNSSD lookup active
    [1692345190.420978][79219:79221] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345190.421104][79219:79221] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345190.421162][79219:79221] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345190.421386][79219:79221] CHIP:IN: SecureSession[0xffff8000d360]: Allocated Type:2 LSID:42364
    [1692345190.421480][79219:79221] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345190.423655][79219:79221] CHIP:EM: <<< [E:32138i S:0 M:249833333] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345190.423793][79219:79221] CHIP:IN: (U) Sending msg 249833333 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345190.424138][79219:79221] CHIP:SC: Sent Sigma1 msg
    [1692345190.424212][79219:79221] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345191.929333][79219:79221] CHIP:EM: >>> [E:32138i S:0 M:205208495 (Ack:249833333)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345191.929381][79219:79221] CHIP:EM: Found matching exchange: 32138i, Delegate: 0xffff8000f408
    [1692345191.929417][79219:79221] CHIP:EM: Rxd Ack; Removing MessageCounter:249833333 from Retrans Table on exchange 32138i
    [1692345192.208102][79219:79221] CHIP:EM: >>> [E:32138i S:0 M:205208496 (Ack:249833333)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345192.208194][79219:79221] CHIP:EM: Found matching exchange: 32138i, Delegate: 0xffff8000f408
    [1692345192.208248][79219:79221] CHIP:EM: CHIP MessageCounter:249833333 not in RetransTable on exchange 32138i
    [1692345192.208336][79219:79221] CHIP:SC: Received Sigma2 msg
    [1692345192.208408][79219:79221] CHIP:SC: Peer assigned session session ID 19073
    [1692345192.216700][79219:79221] CHIP:SC: Found MRP parameters in the message
    [1692345192.216775][79219:79221] CHIP:SC: Sending Sigma3
    [1692345192.217566][79219:79221] CHIP:EM: <<< [E:32138i S:0 M:249833334 (Ack:205208496)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345192.217772][79219:79221] CHIP:IN: (U) Sending msg 249833334 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345192.217999][79219:79221] CHIP:SC: Sent Sigma3 msg
    [1692345192.455671][79219:79221] CHIP:EM: >>> [E:32138i S:0 M:205208497 (Ack:249833334)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345192.455726][79219:79221] CHIP:EM: Found matching exchange: 32138i, Delegate: 0xffff8000f408
    [1692345192.455766][79219:79221] CHIP:EM: Rxd Ack; Removing MessageCounter:249833334 from Retrans Table on exchange 32138i
    [1692345192.644873][79219:79221] CHIP:EM: >>> [E:32138i S:0 M:205208498 (Ack:249833334)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345192.644963][79219:79221] CHIP:EM: Found matching exchange: 32138i, Delegate: 0xffff8000f408
    [1692345192.645017][79219:79221] CHIP:EM: CHIP MessageCounter:249833334 not in RetransTable on exchange 32138i
    [1692345192.645111][79219:79221] CHIP:SC: Success status report received. Session was established
    [1692345192.654836][79219:79221] CHIP:SC: SecureSession[0xffff8000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345192.654927][79219:79221] CHIP:IN: SecureSession[0xffff8000d360]: Activated - Type:2 LSID:42364
    [1692345192.654976][79219:79221] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:42364 PSID:19073!
    [1692345192.655033][79219:79221] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345192.655223][79219:79221] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0006, endpoint 0
    [1692345192.655288][79219:79221] CHIP:TOO: Sending ReadAttribute to:
    [1692345192.655350][79219:79221] CHIP:DMG: SendReadRequest ReadClient[0xffff80011fb0]: Sending Read Request
    [1692345192.655633][79219:79221] CHIP:EM: <<< [E:32139i S:42364 M:91490633] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345192.655776][79219:79221] CHIP:IN: (S) Sending msg 91490633 on secure session with LSID: 42364
    [1692345192.656011][79219:79221] CHIP:DMG: MoveToState ReadClient[0xffff80011fb0]: Moving to [AwaitingIn]
    [1692345192.656122][79219:79221] CHIP:EM: <<< [E:32138i S:0 M:249833335 (Ack:205208498)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345192.656281][79219:79221] CHIP:IN: (U) Sending msg 249833335 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345192.656408][79219:79221] CHIP:EM: Flushed pending ack for MessageCounter:205208498 on exchange 32138i
    [1692345192.870451][79219:79221] CHIP:EM: >>> [E:32139i S:42364 M:39170767 (Ack:91490633)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345192.870532][79219:79221] CHIP:EM: Found matching exchange: 32139i, Delegate: 0xffff80011fc0
    [1692345192.870599][79219:79221] CHIP:EM: Rxd Ack; Removing MessageCounter:91490633 from Retrans Table on exchange 32139i
    [1692345192.870703][79219:79221] CHIP:DMG: ReportDataMessage =
    [1692345192.870753][79219:79221] CHIP:DMG: {
    [1692345192.870792][79219:79221] CHIP:DMG:      AttributeReportIBs =
    [1692345192.870849][79219:79221] CHIP:DMG:      [
    [1692345192.870901][79219:79221] CHIP:DMG:              AttributeReportIB =
    [1692345192.870969][79219:79221] CHIP:DMG:              {
    [1692345192.871022][79219:79221] CHIP:DMG:                      AttributeDataIB =
    [1692345192.871077][79219:79221] CHIP:DMG:                      {
    [1692345192.871139][79219:79221] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345192.871213][79219:79221] CHIP:DMG:                              AttributePathIB =
    [1692345192.871279][79219:79221] CHIP:DMG:                              {
    [1692345192.871344][79219:79221] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345192.871415][79219:79221] CHIP:DMG:                                      Cluster = 0x31,
    [1692345192.871487][79219:79221] CHIP:DMG:                                      Attribute = 0x0000_0006,
    [1692345192.871553][79219:79221] CHIP:DMG:                              }
    [1692345192.871622][79219:79221] CHIP:DMG:
    [1692345192.871688][79219:79221] CHIP:DMG:                              Data = [
    [1692345192.871756][79219:79221] CHIP:DMG:                                              0x69, 0x5e, 0x3b, 0xcb, 0x08, 0xb9, 0x69, 0x68,
    [1692345192.871830][79219:79221] CHIP:DMG:                              ] (8 bytes)
    [1692345192.871892][79219:79221] CHIP:DMG:                      },
    [1692345192.871958][79219:79221] CHIP:DMG:
    [1692345192.872010][79219:79221] CHIP:DMG:              },
    [1692345192.872071][79219:79221] CHIP:DMG:
    [1692345192.872119][79219:79221] CHIP:DMG:      ],
    [1692345192.872179][79219:79221] CHIP:DMG:
    [1692345192.872229][79219:79221] CHIP:DMG:      SuppressResponse = true,
    [1692345192.872279][79219:79221] CHIP:DMG:      InteractionModelRevision = 1
    [1692345192.872327][79219:79221] CHIP:DMG: }
    [1692345192.872600][79219:79221] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0006 DataVersion: 3295567105
    [1692345192.872741][79219:79221] CHIP:TOO:   LastNetworkID: 695E3BCB08B96968
    [1692345192.872982][79219:79221] CHIP:EM: <<< [E:32139i S:42364 M:91490634 (Ack:39170767)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345192.873062][79219:79221] CHIP:IN: (S) Sending msg 91490634 on secure session with LSID: 42364
    [1692345192.873300][79219:79221] CHIP:EM: Flushed pending ack for MessageCounter:39170767 on exchange 32139i
    [1692345192.873657][79219:79219] CHIP:CTL: Shutting down the commissioner
    [1692345192.873730][79219:79219] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345192.873779][79219:79219] CHIP:CTL: Shutting down the controller
    [1692345192.873826][79219:79219] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345192.873872][79219:79219] CHIP:IN: SecureSession[0xffff8000d360]: MarkForEviction Type:2 LSID:42364
    [1692345192.873918][79219:79219] CHIP:SC: SecureSession[0xffff8000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345192.873963][79219:79219] CHIP:IN: SecureSession[0xffff8000d360]: Released - Type:2 LSID:42364
    [1692345192.874016][79219:79219] CHIP:FP: Forgetting fabric 0x1
    [1692345192.874116][79219:79219] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345192.874519][79219:79219] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345192.874576][79219:79219] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345192.874671][79219:79219] CHIP:CTL: Shutting down the commissioner
    [1692345192.874716][79219:79219] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345192.874759][79219:79219] CHIP:CTL: Shutting down the controller
    [1692345192.874796][79219:79219] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345192.876551][79219:79219] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345192.876723][79219:79219] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345192.876820][79219:79219] CHIP:FP: Shutting down FabricTable
    [1692345192.876881][79219:79219] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345192.877196][79219:79219] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345192.877263][79219:79219] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345192.877652][79219:79219] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-HBAf07)
    [1692345192.878882][79219:79219] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345192.879016][79219:79219] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345192.879071][79219:79219] CHIP:DL: Inet Layer shutdown
    [1692345192.879114][79219:79219] CHIP:DL: BLE shutdown
    [1692345192.879159][79219:79219] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool generalcommissioning read breadcrumb 1 0
    [1692345204.567035][79222:79222] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345204.572507][79222:79222] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345204.572776][79222:79222] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345204.572883][79222:79222] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345204.573234][79222:79222] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-gJwANu)
    [1692345204.573822][79222:79222] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345204.573877][79222:79222] CHIP:DL: NVS set: chip-counters/reboot-count = 23 (0x17)
    [1692345204.574792][79222:79222] CHIP:DL: Got Ethernet interface: eth0
    [1692345204.575505][79222:79222] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345204.576104][79222:79222] CHIP:DL: Got WiFi interface: wlan0
    [1692345204.576169][79222:79222] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345204.576221][79222:79222] CHIP:IN: UDP::Init bind&listen port=0
    [1692345204.576325][79222:79222] CHIP:IN: UDP::Init bound to port=37775
    [1692345204.576346][79222:79222] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345204.576364][79222:79222] CHIP:IN: TransportMgr initialized
    [1692345204.576397][79222:79222] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345204.576589][79222:79222] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345204.578251][79222:79222] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345204.578738][79222:79222] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345204.581231][79222:79222] CHIP:ZCL: Using ZAP configuration...
    [1692345204.584700][79222:79222] CHIP:DL: Avahi client registered
    [1692345204.585791][79222:79222] CHIP:CTL: System State Initialized...
    [1692345204.585905][79222:79222] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345204.585957][79222:79222] CHIP:CTL: Setting attestation nonce to random value
    [1692345204.585991][79222:79222] CHIP:CTL: Setting CSR nonce to random value
    [1692345204.586308][79222:79224] CHIP:DL: CHIP task running
    [1692345204.586503][79222:79224] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345204.586804][79222:79224] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345204.586847][79222:79224] CHIP:CTL: Setting attestation nonce to random value
    [1692345204.587009][79222:79224] CHIP:CTL: Setting CSR nonce to random value
    [1692345204.587819][79222:79224] CHIP:CTL: Generating NOC
    [1692345204.588775][79222:79224] CHIP:FP: Validating NOC chain
    [1692345204.590393][79222:79224] CHIP:FP: NOC chain validation successful
    [1692345204.590542][79222:79224] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345204.590571][79222:79224] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345204.590589][79222:79224] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345204.590606][79222:79224] CHIP:TS: Retaining current Last Known Good Time
    [1692345204.598584][79222:79224] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345204.601088][79222:79224] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345204.605631][79222:79224] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345204.623438][79222:79224] CHIP:TOO: Sending command to node 0x1
    [1692345204.623909][79222:79224] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345204.623944][79222:79224] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345204.623980][79222:79224] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345204.624010][79222:79224] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345204.625717][79222:79224] CHIP:DL: Avahi resolve found
    [1692345204.625785][79222:79224] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345204.625806][79222:79224] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345204.625829][79222:79224] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345204.625849][79222:79224] CHIP:DIS:      Port: 5540
    [1692345204.625866][79222:79224] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345204.625884][79222:79224] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345204.625902][79222:79224] CHIP:DIS:      TCP Supported: 0
    [1692345204.626657][79222:79224] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345204.626757][79222:79224] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345204.626780][79222:79224] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345204.626797][79222:79224] CHIP:DIS: Keeping DNSSD lookup active
    [1692345204.824036][79222:79224] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345204.824119][79222:79224] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345204.824150][79222:79224] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345204.824296][79222:79224] CHIP:IN: SecureSession[0xffffa000d360]: Allocated Type:2 LSID:45895
    [1692345204.824350][79222:79224] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345204.825578][79222:79224] CHIP:EM: <<< [E:8419i S:0 M:191731272] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345204.825666][79222:79224] CHIP:IN: (U) Sending msg 191731272 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345204.825880][79222:79224] CHIP:SC: Sent Sigma1 msg
    [1692345204.825918][79222:79224] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345205.094431][79222:79224] CHIP:EM: >>> [E:8419i S:0 M:205208499 (Ack:191731272)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345205.094520][79222:79224] CHIP:EM: Found matching exchange: 8419i, Delegate: 0xffffa000f408
    [1692345205.094596][79222:79224] CHIP:EM: Rxd Ack; Removing MessageCounter:191731272 from Retrans Table on exchange 8419i
    [1692345205.379173][79222:79224] CHIP:EM: >>> [E:8419i S:0 M:205208500 (Ack:191731272)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345205.379272][79222:79224] CHIP:EM: Found matching exchange: 8419i, Delegate: 0xffffa000f408
    [1692345205.379335][79222:79224] CHIP:EM: CHIP MessageCounter:191731272 not in RetransTable on exchange 8419i
    [1692345205.379436][79222:79224] CHIP:SC: Received Sigma2 msg
    [1692345205.379520][79222:79224] CHIP:SC: Peer assigned session session ID 19074
    [1692345205.387223][79222:79224] CHIP:SC: Found MRP parameters in the message
    [1692345205.387314][79222:79224] CHIP:SC: Sending Sigma3
    [1692345205.388332][79222:79224] CHIP:EM: <<< [E:8419i S:0 M:191731273 (Ack:205208500)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345205.388578][79222:79224] CHIP:IN: (U) Sending msg 191731273 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345205.388876][79222:79224] CHIP:SC: Sent Sigma3 msg
    [1692345205.618996][79222:79224] CHIP:EM: >>> [E:8419i S:0 M:205208501 (Ack:191731273)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345205.619096][79222:79224] CHIP:EM: Found matching exchange: 8419i, Delegate: 0xffffa000f408
    [1692345205.619181][79222:79224] CHIP:EM: Rxd Ack; Removing MessageCounter:191731273 from Retrans Table on exchange 8419i
    [1692345205.810211][79222:79224] CHIP:EM: >>> [E:8419i S:0 M:205208502 (Ack:191731273)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345205.810300][79222:79224] CHIP:EM: Found matching exchange: 8419i, Delegate: 0xffffa000f408
    [1692345205.810353][79222:79224] CHIP:EM: CHIP MessageCounter:191731273 not in RetransTable on exchange 8419i
    [1692345205.810442][79222:79224] CHIP:SC: Success status report received. Session was established
    [1692345205.820217][79222:79224] CHIP:SC: SecureSession[0xffffa000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345205.820284][79222:79224] CHIP:IN: SecureSession[0xffffa000d360]: Activated - Type:2 LSID:45895
    [1692345205.820315][79222:79224] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:45895 PSID:19074!
    [1692345205.820353][79222:79224] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345205.820493][79222:79224] CHIP:TOO:      cluster 0x0000_0030, attribute: 0x0000_0000, endpoint 0
    [1692345205.820536][79222:79224] CHIP:TOO: Sending ReadAttribute to:
    [1692345205.820575][79222:79224] CHIP:DMG: SendReadRequest ReadClient[0xffffa0011fb0]: Sending Read Request
    [1692345205.820807][79222:79224] CHIP:EM: <<< [E:8420i S:45895 M:112399123] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345205.820880][79222:79224] CHIP:IN: (S) Sending msg 112399123 on secure session with LSID: 45895
    [1692345205.821137][79222:79224] CHIP:DMG: MoveToState ReadClient[0xffffa0011fb0]: Moving to [AwaitingIn]
    [1692345205.821269][79222:79224] CHIP:EM: <<< [E:8419i S:0 M:191731274 (Ack:205208502)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345205.821473][79222:79224] CHIP:IN: (U) Sending msg 191731274 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345205.821628][79222:79224] CHIP:EM: Flushed pending ack for MessageCounter:205208502 on exchange 8419i
    [1692345206.029753][79222:79224] CHIP:EM: >>> [E:8420i S:45895 M:182258801 (Ack:112399123)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345206.029829][79222:79224] CHIP:EM: Found matching exchange: 8420i, Delegate: 0xffffa0011fc0
    [1692345206.029889][79222:79224] CHIP:EM: Rxd Ack; Removing MessageCounter:112399123 from Retrans Table on exchange 8420i
    [1692345206.029982][79222:79224] CHIP:DMG: ReportDataMessage =
    [1692345206.030026][79222:79224] CHIP:DMG: {
    [1692345206.030061][79222:79224] CHIP:DMG:      AttributeReportIBs =
    [1692345206.030148][79222:79224] CHIP:DMG:      [
    [1692345206.030189][79222:79224] CHIP:DMG:              AttributeReportIB =
    [1692345206.030241][79222:79224] CHIP:DMG:              {
    [1692345206.030292][79222:79224] CHIP:DMG:                      AttributeDataIB =
    [1692345206.030359][79222:79224] CHIP:DMG:                      {
    [1692345206.030423][79222:79224] CHIP:DMG:                              DataVersion = 0xb9f7f334,
    [1692345206.030483][79222:79224] CHIP:DMG:                              AttributePathIB =
    [1692345206.030548][79222:79224] CHIP:DMG:                              {
    [1692345206.030614][79222:79224] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345206.030685][79222:79224] CHIP:DMG:                                      Cluster = 0x30,
    [1692345206.030755][79222:79224] CHIP:DMG:                                      Attribute = 0x0000_0000,
    [1692345206.030821][79222:79224] CHIP:DMG:                              }
    [1692345206.030891][79222:79224] CHIP:DMG:
    [1692345206.030959][79222:79224] CHIP:DMG:                              Data = 1,
    [1692345206.031021][79222:79224] CHIP:DMG:                      },
    [1692345206.031086][79222:79224] CHIP:DMG:
    [1692345206.031140][79222:79224] CHIP:DMG:              },
    [1692345206.031202][79222:79224] CHIP:DMG:
    [1692345206.031250][79222:79224] CHIP:DMG:      ],
    [1692345206.031310][79222:79224] CHIP:DMG:
    [1692345206.031360][79222:79224] CHIP:DMG:      SuppressResponse = true,
    [1692345206.031410][79222:79224] CHIP:DMG:      InteractionModelRevision = 1
    [1692345206.031457][79222:79224] CHIP:DMG: }
    [1692345206.031726][79222:79224] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Attribute 0x0000_0000 DataVersion: 3120034612
    [1692345206.031866][79222:79224] CHIP:TOO:   Breadcrumb: 1
    [1692345206.032104][79222:79224] CHIP:EM: <<< [E:8420i S:45895 M:112399124 (Ack:182258801)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345206.032186][79222:79224] CHIP:IN: (S) Sending msg 112399124 on secure session with LSID: 45895
    [1692345206.032423][79222:79224] CHIP:EM: Flushed pending ack for MessageCounter:182258801 on exchange 8420i
    [1692345206.032823][79222:79222] CHIP:CTL: Shutting down the commissioner
    [1692345206.032892][79222:79222] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345206.032940][79222:79222] CHIP:CTL: Shutting down the controller
    [1692345206.032989][79222:79222] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345206.033034][79222:79222] CHIP:IN: SecureSession[0xffffa000d360]: MarkForEviction Type:2 LSID:45895
    [1692345206.033079][79222:79222] CHIP:SC: SecureSession[0xffffa000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345206.033125][79222:79222] CHIP:IN: SecureSession[0xffffa000d360]: Released - Type:2 LSID:45895
    [1692345206.033176][79222:79222] CHIP:FP: Forgetting fabric 0x1
    [1692345206.033235][79222:79222] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345206.033702][79222:79222] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345206.033771][79222:79222] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345206.033854][79222:79222] CHIP:CTL: Shutting down the commissioner
    [1692345206.033910][79222:79222] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345206.033963][79222:79222] CHIP:CTL: Shutting down the controller
    [1692345206.034006][79222:79222] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345206.035830][79222:79222] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345206.035999][79222:79222] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345206.036096][79222:79222] CHIP:FP: Shutting down FabricTable
    [1692345206.036157][79222:79222] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345206.036481][79222:79222] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345206.036531][79222:79222] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345206.036926][79222:79222] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-yEGFhK)
    [1692345206.038053][79222:79222] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345206.038229][79222:79222] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345206.038283][79222:79222] CHIP:DL: Inet Layer shutdown
    [1692345206.038325][79222:79222] CHIP:DL: BLE shutdown
    [1692345206.038368][79222:79222] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning connect-network hex:695E3BCB08B96968 1 0 --Breadcrumb 2
    [1692345232.995118][79225:79225] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345233.000477][79225:79225] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345233.000754][79225:79225] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345233.000859][79225:79225] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345233.001205][79225:79225] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-lmAYhR)
    [1692345233.001784][79225:79225] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345233.001839][79225:79225] CHIP:DL: NVS set: chip-counters/reboot-count = 24 (0x18)
    [1692345233.002863][79225:79225] CHIP:DL: Got Ethernet interface: eth0
    [1692345233.003484][79225:79225] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345233.004066][79225:79225] CHIP:DL: Got WiFi interface: wlan0
    [1692345233.004136][79225:79225] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345233.004186][79225:79225] CHIP:IN: UDP::Init bind&listen port=0
    [1692345233.004293][79225:79225] CHIP:IN: UDP::Init bound to port=42360
    [1692345233.004315][79225:79225] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345233.004330][79225:79225] CHIP:IN: TransportMgr initialized
    [1692345233.004362][79225:79225] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345233.004549][79225:79225] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345233.006218][79225:79225] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345233.006724][79225:79225] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345233.009187][79225:79225] CHIP:ZCL: Using ZAP configuration...
    [1692345233.012793][79225:79225] CHIP:DL: Avahi client registered
    [1692345233.013933][79225:79225] CHIP:CTL: System State Initialized...
    [1692345233.014056][79225:79225] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345233.014141][79225:79225] CHIP:CTL: Setting attestation nonce to random value
    [1692345233.014179][79225:79225] CHIP:CTL: Setting CSR nonce to random value
    [1692345233.014469][79225:79227] CHIP:DL: CHIP task running
    [1692345233.014660][79225:79227] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345233.014936][79225:79227] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345233.014978][79225:79227] CHIP:CTL: Setting attestation nonce to random value
    [1692345233.015130][79225:79227] CHIP:CTL: Setting CSR nonce to random value
    [1692345233.015963][79225:79227] CHIP:CTL: Generating NOC
    [1692345233.016944][79225:79227] CHIP:FP: Validating NOC chain
    [1692345233.018730][79225:79227] CHIP:FP: NOC chain validation successful
    [1692345233.018902][79225:79227] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345233.018933][79225:79227] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345233.018953][79225:79227] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345233.018971][79225:79227] CHIP:TS: Retaining current Last Known Good Time
    [1692345233.027079][79225:79227] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345233.029773][79225:79227] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345233.034456][79225:79227] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345233.053817][79225:79227] CHIP:TOO: Sending command to node 0x1
    [1692345233.054233][79225:79227] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345233.054264][79225:79227] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345233.054298][79225:79227] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345233.054327][79225:79227] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345233.055878][79225:79227] CHIP:DL: Avahi resolve found
    [1692345233.055945][79225:79227] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345233.055965][79225:79227] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345233.055988][79225:79227] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345233.056007][79225:79227] CHIP:DIS:      Port: 5540
    [1692345233.056025][79225:79227] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345233.056043][79225:79227] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345233.056060][79225:79227] CHIP:DIS:      TCP Supported: 0
    [1692345233.056773][79225:79227] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345233.056870][79225:79227] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345233.056893][79225:79227] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345233.056910][79225:79227] CHIP:DIS: Keeping DNSSD lookup active
    [1692345233.255255][79225:79227] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345233.255388][79225:79227] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345233.255447][79225:79227] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345233.255673][79225:79227] CHIP:IN: SecureSession[0xffff9800d360]: Allocated Type:2 LSID:50742
    [1692345233.255768][79225:79227] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345233.257884][79225:79227] CHIP:EM: <<< [E:25637i S:0 M:209142347] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345233.258024][79225:79227] CHIP:IN: (U) Sending msg 209142347 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345233.258438][79225:79227] CHIP:SC: Sent Sigma1 msg
    [1692345233.258515][79225:79227] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345234.267560][79225:79227] CHIP:EM: >>> [E:25637i S:0 M:205208503 (Ack:209142347)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345234.267649][79225:79227] CHIP:EM: Found matching exchange: 25637i, Delegate: 0xffff9800f408
    [1692345234.267724][79225:79227] CHIP:EM: Rxd Ack; Removing MessageCounter:209142347 from Retrans Table on exchange 25637i
    [1692345234.544668][79225:79227] CHIP:EM: >>> [E:25637i S:0 M:205208504 (Ack:209142347)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345234.544760][79225:79227] CHIP:EM: Found matching exchange: 25637i, Delegate: 0xffff9800f408
    [1692345234.544814][79225:79227] CHIP:EM: CHIP MessageCounter:209142347 not in RetransTable on exchange 25637i
    [1692345234.544902][79225:79227] CHIP:SC: Received Sigma2 msg
    [1692345234.544976][79225:79227] CHIP:SC: Peer assigned session session ID 19075
    [1692345234.552808][79225:79227] CHIP:SC: Found MRP parameters in the message
    [1692345234.552904][79225:79227] CHIP:SC: Sending Sigma3
    [1692345234.553983][79225:79227] CHIP:EM: <<< [E:25637i S:0 M:209142348 (Ack:205208504)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345234.554350][79225:79227] CHIP:IN: (U) Sending msg 209142348 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345234.554645][79225:79227] CHIP:SC: Sent Sigma3 msg
    [1692345234.791695][79225:79227] CHIP:EM: >>> [E:25637i S:0 M:205208505 (Ack:209142348)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345234.791784][79225:79227] CHIP:EM: Found matching exchange: 25637i, Delegate: 0xffff9800f408
    [1692345234.791859][79225:79227] CHIP:EM: Rxd Ack; Removing MessageCounter:209142348 from Retrans Table on exchange 25637i
    [1692345235.070019][79225:79227] CHIP:EM: >>> [E:25637i S:0 M:205208506 (Ack:209142348)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345235.070112][79225:79227] CHIP:EM: Found matching exchange: 25637i, Delegate: 0xffff9800f408
    [1692345235.070148][79225:79227] CHIP:EM: CHIP MessageCounter:209142348 not in RetransTable on exchange 25637i
    [1692345235.070210][79225:79227] CHIP:SC: Success status report received. Session was established
    [1692345235.081421][79225:79227] CHIP:SC: SecureSession[0xffff9800d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345235.081513][79225:79227] CHIP:IN: SecureSession[0xffff9800d360]: Activated - Type:2 LSID:50742
    [1692345235.081558][79225:79227] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:50742 PSID:19075!
    [1692345235.081613][79225:79227] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345235.081708][79225:79227] CHIP:TOO: Sending cluster (0x00000031) command (0x00000006) on endpoint 0
    [1692345235.081858][79225:79227] CHIP:DMG: ICR moving to [AddingComm]
    [1692345235.081966][79225:79227] CHIP:DMG: ICR moving to [AddedComma]
    [1692345235.082244][79225:79227] CHIP:EM: <<< [E:25638i S:50742 M:227937139] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345235.082314][79225:79227] CHIP:IN: (S) Sending msg 227937139 on secure session with LSID: 50742
    [1692345235.082600][79225:79227] CHIP:DMG: ICR moving to [CommandSen]
    [1692345235.082697][79225:79227] CHIP:EM: <<< [E:25637i S:0 M:209142349 (Ack:205208506)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345235.082848][79225:79227] CHIP:IN: (U) Sending msg 209142349 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345235.082969][79225:79227] CHIP:EM: Flushed pending ack for MessageCounter:205208506 on exchange 25637i
    [1692345235.291892][79225:79227] CHIP:EM: >>> [E:25638i S:50742 M:159196827 (Ack:227937139)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345235.291960][79225:79227] CHIP:EM: Found matching exchange: 25638i, Delegate: 0xffff9800a4f8
    [1692345235.292015][79225:79227] CHIP:EM: Rxd Ack; Removing MessageCounter:227937139 from Retrans Table on exchange 25638i
    [1692345235.292066][79225:79227] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345235.292132][79225:79227] CHIP:DMG: InvokeResponseMessage =
    [1692345235.292171][79225:79227] CHIP:DMG: {
    [1692345235.292201][79225:79227] CHIP:DMG:      suppressResponse = false,
    [1692345235.292230][79225:79227] CHIP:DMG:      InvokeResponseIBs =
    [1692345235.292269][79225:79227] CHIP:DMG:      [
    [1692345235.292298][79225:79227] CHIP:DMG:              InvokeResponseIB =
    [1692345235.292339][79225:79227] CHIP:DMG:              {
    [1692345235.292370][79225:79227] CHIP:DMG:                      CommandDataIB =
    [1692345235.292405][79225:79227] CHIP:DMG:                      {
    [1692345235.292438][79225:79227] CHIP:DMG:                              CommandPathIB =
    [1692345235.292487][79225:79227] CHIP:DMG:                              {
    [1692345235.292530][79225:79227] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345235.292584][79225:79227] CHIP:DMG:                                      ClusterId = 0x31,
    [1692345235.292628][79225:79227] CHIP:DMG:                                      CommandId = 0x7,
    [1692345235.292668][79225:79227] CHIP:DMG:                              },
    [1692345235.292710][79225:79227] CHIP:DMG:
    [1692345235.292747][79225:79227] CHIP:DMG:                              CommandFields =
    [1692345235.292787][79225:79227] CHIP:DMG:                              {
    [1692345235.292865][79225:79227] CHIP:DMG:                                      0x0 = 3,
    [1692345235.292910][79225:79227] CHIP:DMG:                                      0x2 = 0,
    [1692345235.292953][79225:79227] CHIP:DMG:                              },
    [1692345235.292990][79225:79227] CHIP:DMG:                      },
    [1692345235.293032][79225:79227] CHIP:DMG:
    [1692345235.293065][79225:79227] CHIP:DMG:              },
    [1692345235.293104][79225:79227] CHIP:DMG:
    [1692345235.293135][79225:79227] CHIP:DMG:      ],
    [1692345235.293175][79225:79227] CHIP:DMG:
    [1692345235.293206][79225:79227] CHIP:DMG:      InteractionModelRevision = 1
    [1692345235.293237][79225:79227] CHIP:DMG: },
    [1692345235.293320][79225:79227] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1692345235.293386][79225:79227] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Command 0x0000_0007
    [1692345235.293487][79225:79227] CHIP:TOO:   ConnectNetworkResponse: {
    [1692345235.293534][79225:79227] CHIP:TOO:     networkingStatus: 3
    [1692345235.293567][79225:79227] CHIP:TOO:     errorValue: 0
    [1692345235.293596][79225:79227] CHIP:TOO:    }
    [1692345235.293646][79225:79227] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345235.293815][79225:79227] CHIP:EM: <<< [E:25638i S:50742 M:227937140 (Ack:159196827)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345235.293875][79225:79227] CHIP:IN: (S) Sending msg 227937140 on secure session with LSID: 50742
    [1692345235.294055][79225:79227] CHIP:EM: Flushed pending ack for MessageCounter:159196827 on exchange 25638i
    [1692345235.294534][79225:79225] CHIP:CTL: Shutting down the commissioner
    [1692345235.294577][79225:79225] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345235.294598][79225:79225] CHIP:CTL: Shutting down the controller
    [1692345235.294620][79225:79225] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345235.294639][79225:79225] CHIP:IN: SecureSession[0xffff9800d360]: MarkForEviction Type:2 LSID:50742
    [1692345235.294659][79225:79225] CHIP:SC: SecureSession[0xffff9800d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345235.294678][79225:79225] CHIP:IN: SecureSession[0xffff9800d360]: Released - Type:2 LSID:50742
    [1692345235.294700][79225:79225] CHIP:FP: Forgetting fabric 0x1
    [1692345235.294730][79225:79225] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345235.294924][79225:79225] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345235.294948][79225:79225] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345235.294987][79225:79225] CHIP:CTL: Shutting down the commissioner
    [1692345235.295005][79225:79225] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345235.295023][79225:79225] CHIP:CTL: Shutting down the controller
    [1692345235.295039][79225:79225] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345235.295957][79225:79225] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345235.296051][79225:79225] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345235.296097][79225:79225] CHIP:FP: Shutting down FabricTable
    [1692345235.296132][79225:79225] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345235.296308][79225:79225] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345235.296343][79225:79225] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345235.296627][79225:79225] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-BBgHKR)
    [1692345235.297213][79225:79225] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345235.297274][79225:79225] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345235.297297][79225:79225] CHIP:DL: Inet Layer shutdown
    [1692345235.297314][79225:79225] CHIP:DL: BLE shutdown
    [1692345235.297334][79225:79225] CHIP:DL: System Layer shutdown
    [1692345252.877942][79230:79230] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345252.883446][79230:79230] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345252.883708][79230:79230] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345252.883835][79230:79230] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345252.884195][79230:79230] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-dAlBDc)
    [1692345252.884795][79230:79230] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345252.884848][79230:79230] CHIP:DL: NVS set: chip-counters/reboot-count = 25 (0x19)
    [1692345252.885737][79230:79230] CHIP:DL: Got Ethernet interface: eth0
    [1692345252.886363][79230:79230] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345252.886960][79230:79230] CHIP:DL: Got WiFi interface: wlan0
    [1692345252.887023][79230:79230] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345252.887074][79230:79230] CHIP:IN: UDP::Init bind&listen port=0
    [1692345252.887191][79230:79230] CHIP:IN: UDP::Init bound to port=34839
    [1692345252.887221][79230:79230] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345252.887239][79230:79230] CHIP:IN: TransportMgr initialized
    [1692345252.887271][79230:79230] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345252.887450][79230:79230] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345252.888960][79230:79230] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345252.889420][79230:79230] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345252.891901][79230:79230] CHIP:ZCL: Using ZAP configuration...
    [1692345252.895423][79230:79230] CHIP:DL: Avahi client registered
    [1692345252.896416][79230:79230] CHIP:CTL: System State Initialized...
    [1692345252.896526][79230:79230] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345252.896577][79230:79230] CHIP:CTL: Setting attestation nonce to random value
    [1692345252.896609][79230:79230] CHIP:CTL: Setting CSR nonce to random value
    [1692345252.896949][79230:79232] CHIP:DL: CHIP task running
    [1692345252.897131][79230:79232] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345252.897404][79230:79232] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345252.897443][79230:79232] CHIP:CTL: Setting attestation nonce to random value
    [1692345252.897591][79230:79232] CHIP:CTL: Setting CSR nonce to random value
    [1692345252.898499][79230:79232] CHIP:CTL: Generating NOC
    [1692345252.899517][79230:79232] CHIP:FP: Validating NOC chain
    [1692345252.901216][79230:79232] CHIP:FP: NOC chain validation successful
    [1692345252.901378][79230:79232] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345252.901407][79230:79232] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345252.901426][79230:79232] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345252.901442][79230:79232] CHIP:TS: Retaining current Last Known Good Time
    [1692345252.909100][79230:79232] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345252.914110][79230:79232] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345252.916822][79230:79232] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345252.939174][79230:79232] CHIP:TOO: Sending command to node 0x1
    [1692345252.939569][79230:79232] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345252.939600][79230:79232] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345252.939633][79230:79232] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345252.939661][79230:79232] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345252.941236][79230:79232] CHIP:DL: Avahi resolve found
    [1692345252.941309][79230:79232] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345252.941330][79230:79232] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345252.941355][79230:79232] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345252.941374][79230:79232] CHIP:DIS:      Port: 5540
    [1692345252.941392][79230:79232] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345252.941409][79230:79232] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345252.941427][79230:79232] CHIP:DIS:      TCP Supported: 0
    [1692345252.942208][79230:79232] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345252.942309][79230:79232] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345252.942332][79230:79232] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345252.942349][79230:79232] CHIP:DIS: Keeping DNSSD lookup active
    [1692345253.139649][79230:79232] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345253.139766][79230:79232] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345253.139816][79230:79232] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345253.140018][79230:79232] CHIP:IN: SecureSession[0xffff8c00d360]: Allocated Type:2 LSID:13077
    [1692345253.140098][79230:79232] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345253.142008][79230:79232] CHIP:EM: <<< [E:57596i S:0 M:193313224] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345253.142202][79230:79232] CHIP:IN: (U) Sending msg 193313224 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345253.142523][79230:79232] CHIP:SC: Sent Sigma1 msg
    [1692345253.142588][79230:79232] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345253.517875][79230:79232] CHIP:EM: >>> [E:57596i S:0 M:205208507 (Ack:193313224)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345253.517949][79230:79232] CHIP:EM: Found matching exchange: 57596i, Delegate: 0xffff8c00f408
    [1692345253.518007][79230:79232] CHIP:EM: Rxd Ack; Removing MessageCounter:193313224 from Retrans Table on exchange 57596i
    [1692345253.802912][79230:79232] CHIP:EM: >>> [E:57596i S:0 M:205208508 (Ack:193313224)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345253.802992][79230:79232] CHIP:EM: Found matching exchange: 57596i, Delegate: 0xffff8c00f408
    [1692345253.803041][79230:79232] CHIP:EM: CHIP MessageCounter:193313224 not in RetransTable on exchange 57596i
    [1692345253.803121][79230:79232] CHIP:SC: Received Sigma2 msg
    [1692345253.803186][79230:79232] CHIP:SC: Peer assigned session session ID 19076
    [1692345253.810929][79230:79232] CHIP:SC: Found MRP parameters in the message
    [1692345253.811030][79230:79232] CHIP:SC: Sending Sigma3
    [1692345253.812041][79230:79232] CHIP:EM: <<< [E:57596i S:0 M:193313225 (Ack:205208508)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345253.812237][79230:79232] CHIP:IN: (U) Sending msg 193313225 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345253.812459][79230:79232] CHIP:SC: Sent Sigma3 msg
    [1692345254.043262][79230:79232] CHIP:EM: >>> [E:57596i S:0 M:205208509 (Ack:193313225)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345254.043342][79230:79232] CHIP:EM: Found matching exchange: 57596i, Delegate: 0xffff8c00f408
    [1692345254.043408][79230:79232] CHIP:EM: Rxd Ack; Removing MessageCounter:193313225 from Retrans Table on exchange 57596i
    [1692345254.233747][79230:79232] CHIP:EM: >>> [E:57596i S:0 M:205208510 (Ack:193313225)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345254.233848][79230:79232] CHIP:EM: Found matching exchange: 57596i, Delegate: 0xffff8c00f408
    [1692345254.233910][79230:79232] CHIP:EM: CHIP MessageCounter:193313225 not in RetransTable on exchange 57596i
    [1692345254.234013][79230:79232] CHIP:SC: Success status report received. Session was established
    [1692345254.242799][79230:79232] CHIP:SC: SecureSession[0xffff8c00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345254.242889][79230:79232] CHIP:IN: SecureSession[0xffff8c00d360]: Activated - Type:2 LSID:13077
    [1692345254.242931][79230:79232] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:13077 PSID:19076!
    [1692345254.242983][79230:79232] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345254.243168][79230:79232] CHIP:TOO:      cluster 0x0000_0030, attribute: 0x0000_0000, endpoint 0
    [1692345254.243236][79230:79232] CHIP:TOO: Sending ReadAttribute to:
    [1692345254.243297][79230:79232] CHIP:DMG: SendReadRequest ReadClient[0xffff8c011fb0]: Sending Read Request
    [1692345254.243562][79230:79232] CHIP:EM: <<< [E:57597i S:13077 M:258885148] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345254.243649][79230:79232] CHIP:IN: (S) Sending msg 258885148 on secure session with LSID: 13077
    [1692345254.243964][79230:79232] CHIP:DMG: MoveToState ReadClient[0xffff8c011fb0]: Moving to [AwaitingIn]
    [1692345254.244117][79230:79232] CHIP:EM: <<< [E:57596i S:0 M:193313226 (Ack:205208510)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345254.244366][79230:79232] CHIP:IN: (U) Sending msg 193313226 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345254.244558][79230:79232] CHIP:EM: Flushed pending ack for MessageCounter:205208510 on exchange 57596i
    [1692345254.458898][79230:79232] CHIP:EM: >>> [E:57597i S:13077 M:163826439 (Ack:258885148)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345254.458989][79230:79232] CHIP:EM: Found matching exchange: 57597i, Delegate: 0xffff8c011fc0
    [1692345254.459060][79230:79232] CHIP:EM: Rxd Ack; Removing MessageCounter:258885148 from Retrans Table on exchange 57597i
    [1692345254.459172][79230:79232] CHIP:DMG: ReportDataMessage =
    [1692345254.459226][79230:79232] CHIP:DMG: {
    [1692345254.459270][79230:79232] CHIP:DMG:      AttributeReportIBs =
    [1692345254.459334][79230:79232] CHIP:DMG:      [
    [1692345254.459383][79230:79232] CHIP:DMG:              AttributeReportIB =
    [1692345254.459450][79230:79232] CHIP:DMG:              {
    [1692345254.459502][79230:79232] CHIP:DMG:                      AttributeDataIB =
    [1692345254.459572][79230:79232] CHIP:DMG:                      {
    [1692345254.459636][79230:79232] CHIP:DMG:                              DataVersion = 0xb9f7f334,
    [1692345254.459705][79230:79232] CHIP:DMG:                              AttributePathIB =
    [1692345254.459771][79230:79232] CHIP:DMG:                              {
    [1692345254.459838][79230:79232] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345254.459908][79230:79232] CHIP:DMG:                                      Cluster = 0x30,
    [1692345254.459978][79230:79232] CHIP:DMG:                                      Attribute = 0x0000_0000,
    [1692345254.460044][79230:79232] CHIP:DMG:                              }
    [1692345254.460111][79230:79232] CHIP:DMG:
    [1692345254.460178][79230:79232] CHIP:DMG:                              Data = 1,
    [1692345254.460238][79230:79232] CHIP:DMG:                      },
    [1692345254.460305][79230:79232] CHIP:DMG:
    [1692345254.460356][79230:79232] CHIP:DMG:              },
    [1692345254.460416][79230:79232] CHIP:DMG:
    [1692345254.460464][79230:79232] CHIP:DMG:      ],
    [1692345254.460524][79230:79232] CHIP:DMG:
    [1692345254.460573][79230:79232] CHIP:DMG:      SuppressResponse = true,
    [1692345254.460624][79230:79232] CHIP:DMG:      InteractionModelRevision = 1
    [1692345254.460671][79230:79232] CHIP:DMG: }
    [1692345254.460937][79230:79232] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Attribute 0x0000_0000 DataVersion: 3120034612
    [1692345254.461183][79230:79232] CHIP:TOO:   Breadcrumb: 1
    [1692345254.461434][79230:79232] CHIP:EM: <<< [E:57597i S:13077 M:258885149 (Ack:163826439)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345254.461514][79230:79232] CHIP:IN: (S) Sending msg 258885149 on secure session with LSID: 13077
    [1692345254.461747][79230:79232] CHIP:EM: Flushed pending ack for MessageCounter:163826439 on exchange 57597i
    [1692345254.462136][79230:79230] CHIP:CTL: Shutting down the commissioner
    [1692345254.462207][79230:79230] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345254.462257][79230:79230] CHIP:CTL: Shutting down the controller
    [1692345254.462306][79230:79230] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345254.462349][79230:79230] CHIP:IN: SecureSession[0xffff8c00d360]: MarkForEviction Type:2 LSID:13077
    [1692345254.462394][79230:79230] CHIP:SC: SecureSession[0xffff8c00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345254.462465][79230:79230] CHIP:IN: SecureSession[0xffff8c00d360]: Released - Type:2 LSID:13077
    [1692345254.462521][79230:79230] CHIP:FP: Forgetting fabric 0x1
    [1692345254.462580][79230:79230] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345254.462987][79230:79230] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345254.463080][79230:79230] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345254.463167][79230:79230] CHIP:CTL: Shutting down the commissioner
    [1692345254.463226][79230:79230] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345254.463279][79230:79230] CHIP:CTL: Shutting down the controller
    [1692345254.463321][79230:79230] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345254.465102][79230:79230] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345254.465267][79230:79230] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345254.465362][79230:79230] CHIP:FP: Shutting down FabricTable
    [1692345254.465424][79230:79230] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345254.465768][79230:79230] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345254.465839][79230:79230] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345254.466327][79230:79230] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-p5lCP5)
    [1692345254.467514][79230:79230] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345254.467635][79230:79230] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345254.467687][79230:79230] CHIP:DL: Inet Layer shutdown
    [1692345254.467729][79230:79230] CHIP:DL: BLE shutdown
    [1692345254.467773][79230:79230] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$  ./chip-tool generalcommissioning arm-fail-safe 0 0 1 0
    [1692345271.225096][79248:79248] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345271.230503][79248:79248] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345271.230760][79248:79248] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345271.230862][79248:79248] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345271.231210][79248:79248] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CjbPjO)
    [1692345271.231795][79248:79248] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345271.231849][79248:79248] CHIP:DL: NVS set: chip-counters/reboot-count = 26 (0x1A)
    [1692345271.232726][79248:79248] CHIP:DL: Got Ethernet interface: eth0
    [1692345271.233308][79248:79248] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345271.233888][79248:79248] CHIP:DL: Got WiFi interface: wlan0
    [1692345271.233953][79248:79248] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345271.234003][79248:79248] CHIP:IN: UDP::Init bind&listen port=0
    [1692345271.234137][79248:79248] CHIP:IN: UDP::Init bound to port=50539
    [1692345271.234159][79248:79248] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345271.234177][79248:79248] CHIP:IN: TransportMgr initialized
    [1692345271.234209][79248:79248] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345271.234502][79248:79248] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345271.236017][79248:79248] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345271.236492][79248:79248] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345271.239059][79248:79248] CHIP:ZCL: Using ZAP configuration...
    [1692345271.242578][79248:79248] CHIP:DL: Avahi client registered
    [1692345271.243708][79248:79248] CHIP:CTL: System State Initialized...
    [1692345271.243900][79248:79248] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345271.243955][79248:79248] CHIP:CTL: Setting attestation nonce to random value
    [1692345271.243991][79248:79248] CHIP:CTL: Setting CSR nonce to random value
    [1692345271.244297][79248:79250] CHIP:DL: CHIP task running
    [1692345271.244489][79248:79250] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345271.244786][79248:79250] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345271.244831][79248:79250] CHIP:CTL: Setting attestation nonce to random value
    [1692345271.245001][79248:79250] CHIP:CTL: Setting CSR nonce to random value
    [1692345271.245954][79248:79250] CHIP:CTL: Generating NOC
    [1692345271.247079][79248:79250] CHIP:FP: Validating NOC chain
    [1692345271.248934][79248:79250] CHIP:FP: NOC chain validation successful
    [1692345271.249100][79248:79250] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345271.249133][79248:79250] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345271.249155][79248:79250] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345271.249175][79248:79250] CHIP:TS: Retaining current Last Known Good Time
    [1692345271.257186][79248:79250] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345271.262427][79248:79250] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345271.264895][79248:79250] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345271.285306][79248:79250] CHIP:TOO: Sending command to node 0x1
    [1692345271.285697][79248:79250] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345271.285726][79248:79250] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345271.285760][79248:79250] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345271.285789][79248:79250] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345271.287645][79248:79250] CHIP:DL: Avahi resolve found
    [1692345271.287719][79248:79250] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345271.287743][79248:79250] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345271.287768][79248:79250] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345271.287790][79248:79250] CHIP:DIS:      Port: 5540
    [1692345271.287810][79248:79250] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345271.287830][79248:79250] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345271.287850][79248:79250] CHIP:DIS:      TCP Supported: 0
    [1692345271.288631][79248:79250] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345271.288739][79248:79250] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345271.288764][79248:79250] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345271.288783][79248:79250] CHIP:DIS: Keeping DNSSD lookup active
    [1692345271.486176][79248:79250] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345271.486311][79248:79250] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345271.486381][79248:79250] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345271.486622][79248:79250] CHIP:IN: SecureSession[0xffffa400d360]: Allocated Type:2 LSID:34038
    [1692345271.486734][79248:79250] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345271.489022][79248:79250] CHIP:EM: <<< [E:9365i S:0 M:203565691] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345271.489166][79248:79250] CHIP:IN: (U) Sending msg 203565691 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345271.489505][79248:79250] CHIP:SC: Sent Sigma1 msg
    [1692345271.489577][79248:79250] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345272.637199][79248:79250] CHIP:EM: >>> [E:9365i S:0 M:205208511 (Ack:203565691)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345272.637300][79248:79250] CHIP:EM: Found matching exchange: 9365i, Delegate: 0xffffa400f408
    [1692345272.637389][79248:79250] CHIP:EM: Rxd Ack; Removing MessageCounter:203565691 from Retrans Table on exchange 9365i
    [1692345272.950288][79248:79250] CHIP:EM: >>> [E:9365i S:0 M:205208512 (Ack:203565691)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345272.950381][79248:79250] CHIP:EM: Found matching exchange: 9365i, Delegate: 0xffffa400f408
    [1692345272.950434][79248:79250] CHIP:EM: CHIP MessageCounter:203565691 not in RetransTable on exchange 9365i
    [1692345272.950523][79248:79250] CHIP:SC: Received Sigma2 msg
    [1692345272.950595][79248:79250] CHIP:SC: Peer assigned session session ID 19077
    [1692345272.959236][79248:79250] CHIP:SC: Found MRP parameters in the message
    [1692345272.959342][79248:79250] CHIP:SC: Sending Sigma3
    [1692345272.960604][79248:79250] CHIP:EM: <<< [E:9365i S:0 M:203565692 (Ack:205208512)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345272.960902][79248:79250] CHIP:IN: (U) Sending msg 203565692 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345272.961257][79248:79250] CHIP:SC: Sent Sigma3 msg
    [1692345273.278841][79248:79250] CHIP:EM: >>> [E:9365i S:0 M:205208513 (Ack:203565692)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345273.278908][79248:79250] CHIP:EM: Found matching exchange: 9365i, Delegate: 0xffffa400f408
    [1692345273.278962][79248:79250] CHIP:EM: Rxd Ack; Removing MessageCounter:203565692 from Retrans Table on exchange 9365i
    [1692345273.470878][79248:79250] CHIP:EM: >>> [E:9365i S:0 M:205208514 (Ack:203565692)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345273.470936][79248:79250] CHIP:EM: Found matching exchange: 9365i, Delegate: 0xffffa400f408
    [1692345273.470968][79248:79250] CHIP:EM: CHIP MessageCounter:203565692 not in RetransTable on exchange 9365i
    [1692345273.471024][79248:79250] CHIP:SC: Success status report received. Session was established
    [1692345273.477223][79248:79250] CHIP:SC: SecureSession[0xffffa400d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345273.477291][79248:79250] CHIP:IN: SecureSession[0xffffa400d360]: Activated - Type:2 LSID:34038
    [1692345273.477324][79248:79250] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:34038 PSID:19077!
    [1692345273.477365][79248:79250] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345273.477439][79248:79250] CHIP:TOO: Sending cluster (0x00000030) command (0x00000000) on endpoint 0
    [1692345273.477550][79248:79250] CHIP:DMG: ICR moving to [AddingComm]
    [1692345273.477626][79248:79250] CHIP:DMG: ICR moving to [AddedComma]
    [1692345273.477829][79248:79250] CHIP:EM: <<< [E:9366i S:34038 M:39077388] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345273.477909][79248:79250] CHIP:IN: (S) Sending msg 39077388 on secure session with LSID: 34038
    [1692345273.478253][79248:79250] CHIP:DMG: ICR moving to [CommandSen]
    [1692345273.478372][79248:79250] CHIP:EM: <<< [E:9365i S:0 M:203565693 (Ack:205208514)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345273.478566][79248:79250] CHIP:IN: (U) Sending msg 203565693 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345273.478743][79248:79250] CHIP:EM: Flushed pending ack for MessageCounter:205208514 on exchange 9365i
    [1692345274.713401][79248:79250] CHIP:EM: Retransmitting MessageCounter:39077388 on exchange 9366i Send Cnt 1
    [1692345274.713603][79248:79250] CHIP:IN: (S) Sending msg 39077388 on secure session with LSID: 34038
    [1692345276.077464][79248:79250] CHIP:EM: Retransmitting MessageCounter:39077388 on exchange 9366i Send Cnt 2
    [1692345276.077630][79248:79250] CHIP:IN: (S) Sending msg 39077388 on secure session with LSID: 34038
    [1692345277.900935][79248:79250] CHIP:EM: Retransmitting MessageCounter:39077388 on exchange 9366i Send Cnt 3
    [1692345277.901132][79248:79250] CHIP:IN: (S) Sending msg 39077388 on secure session with LSID: 34038
    [1692345287.708456][79248:79250] CHIP:EM: Retransmitting MessageCounter:39077388 on exchange 9366i Send Cnt 4
    [1692345287.708649][79248:79250] CHIP:IN: (S) Sending msg 39077388 on secure session with LSID: 34038
    [1692345287.739012][79248:79250] CHIP:EM: >>> [E:9366i S:34038 M:259093607 (Ack:39077388)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345287.739104][79248:79250] CHIP:EM: Found matching exchange: 9366i, Delegate: 0xffffa400a4f8
    [1692345287.739179][79248:79250] CHIP:EM: Rxd Ack; Removing MessageCounter:39077388 from Retrans Table on exchange 9366i
    [1692345291.244837][79248:79248] CHIP:CTL: Shutting down the commissioner
    [1692345291.244917][79248:79248] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345291.244967][79248:79248] CHIP:CTL: Shutting down the controller
    [1692345291.245016][79248:79248] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345291.245061][79248:79248] CHIP:IN: SecureSession[0xffffa400d360]: MarkForEviction Type:2 LSID:34038
    [1692345291.245107][79248:79248] CHIP:SC: SecureSession[0xffffa400d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345291.245193][79248:79248] CHIP:DMG: Time out! failed to receive invoke command response from Exchange: 9366i
    [1692345291.245258][79248:79248] CHIP:TOO: Error: src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout
    [1692345291.245300][79248:79248] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345291.245369][79248:79248] CHIP:IN: SecureSession[0xffffa400d360]: Released - Type:2 LSID:34038
    [1692345291.245422][79248:79248] CHIP:FP: Forgetting fabric 0x1
    [1692345291.245479][79248:79248] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345291.245867][79248:79248] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345291.245922][79248:79248] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345291.246011][79248:79248] CHIP:CTL: Shutting down the commissioner
    [1692345291.246065][79248:79248] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345291.246174][79248:79248] CHIP:CTL: Shutting down the controller
    [1692345291.246229][79248:79248] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345291.248257][79248:79248] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345291.248452][79248:79248] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345291.248546][79248:79248] CHIP:FP: Shutting down FabricTable
    [1692345291.248616][79248:79248] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345291.248963][79248:79248] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345291.249180][79248:79248] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345291.249770][79248:79248] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-IMrtRY)
    [1692345291.251237][79248:79248] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345291.251373][79248:79248] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345291.251433][79248:79248] CHIP:DL: Inet Layer shutdown
    [1692345291.251481][79248:79248] CHIP:DL: BLE shutdown
    [1692345291.251531][79248:79248] CHIP:DL: System Layer shutdown
    [1692345291.252058][79248:79248] CHIP:TOO: Run command failure: examples/chip-tool/commands/common/CHIPCommand.cpp:524: CHIP Error 0x00000032: Timeout
    [1692345328.918233][79253:79253] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345328.923661][79253:79253] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345328.923918][79253:79253] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345328.924052][79253:79253] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345328.924427][79253:79253] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-fRXP4y)
    [1692345328.925030][79253:79253] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345328.925084][79253:79253] CHIP:DL: NVS set: chip-counters/reboot-count = 27 (0x1B)
    [1692345328.925977][79253:79253] CHIP:DL: Got Ethernet interface: eth0
    [1692345328.926602][79253:79253] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345328.927193][79253:79253] CHIP:DL: Got WiFi interface: wlan0
    [1692345328.927258][79253:79253] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345328.927309][79253:79253] CHIP:IN: UDP::Init bind&listen port=0
    [1692345328.927426][79253:79253] CHIP:IN: UDP::Init bound to port=40567
    [1692345328.927447][79253:79253] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345328.927465][79253:79253] CHIP:IN: TransportMgr initialized
    [1692345328.927497][79253:79253] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345328.927693][79253:79253] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345328.929192][79253:79253] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345328.929629][79253:79253] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345328.932122][79253:79253] CHIP:ZCL: Using ZAP configuration...
    [1692345328.935689][79253:79253] CHIP:DL: Avahi client registered
    [1692345328.936803][79253:79253] CHIP:CTL: System State Initialized...
    [1692345328.936925][79253:79253] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345328.936981][79253:79253] CHIP:CTL: Setting attestation nonce to random value
    [1692345328.937018][79253:79253] CHIP:CTL: Setting CSR nonce to random value
    [1692345328.937317][79253:79255] CHIP:DL: CHIP task running
    [1692345328.937508][79253:79255] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345328.937821][79253:79255] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345328.937865][79253:79255] CHIP:CTL: Setting attestation nonce to random value
    [1692345328.938041][79253:79255] CHIP:CTL: Setting CSR nonce to random value
    [1692345328.938952][79253:79255] CHIP:CTL: Generating NOC
    [1692345328.939993][79253:79255] CHIP:FP: Validating NOC chain
    [1692345328.941749][79253:79255] CHIP:FP: NOC chain validation successful
    [1692345328.941906][79253:79255] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345328.941937][79253:79255] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345328.941958][79253:79255] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345328.941990][79253:79255] CHIP:TS: Retaining current Last Known Good Time
    [1692345328.949410][79253:79255] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345328.951679][79253:79255] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345328.954459][79253:79255] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345328.981490][79253:79255] CHIP:TOO: Sending command to node 0x1
    [1692345328.981899][79253:79255] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345328.981928][79253:79255] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345328.981962][79253:79255] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345328.981990][79253:79255] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345328.983621][79253:79255] CHIP:DL: Avahi resolve found
    [1692345328.983691][79253:79255] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345328.983712][79253:79255] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345328.983735][79253:79255] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345328.983755][79253:79255] CHIP:DIS:      Port: 5540
    [1692345328.983773][79253:79255] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345328.983791][79253:79255] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345328.983809][79253:79255] CHIP:DIS:      TCP Supported: 0
    [1692345328.984533][79253:79255] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345328.984629][79253:79255] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345328.984651][79253:79255] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345328.984669][79253:79255] CHIP:DIS: Keeping DNSSD lookup active
    [1692345329.181849][79253:79255] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345329.181925][79253:79255] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345329.181949][79253:79255] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345329.182092][79253:79255] CHIP:IN: SecureSession[0xffff7400d360]: Allocated Type:2 LSID:7665
    [1692345329.182137][79253:79255] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345329.183158][79253:79255] CHIP:EM: <<< [E:28821i S:0 M:239167336] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345329.183229][79253:79255] CHIP:IN: (U) Sending msg 239167336 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345329.183418][79253:79255] CHIP:SC: Sent Sigma1 msg
    [1692345329.183455][79253:79255] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345329.778210][79253:79255] CHIP:EM: >>> [E:28821i S:0 M:205208515 (Ack:239167336)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345329.778298][79253:79255] CHIP:EM: Found matching exchange: 28821i, Delegate: 0xffff7400f408
    [1692345329.778372][79253:79255] CHIP:EM: Rxd Ack; Removing MessageCounter:239167336 from Retrans Table on exchange 28821i
    [1692345330.061764][79253:79255] CHIP:EM: >>> [E:28821i S:0 M:205208516 (Ack:239167336)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345330.061852][79253:79255] CHIP:EM: Found matching exchange: 28821i, Delegate: 0xffff7400f408
    [1692345330.061906][79253:79255] CHIP:EM: CHIP MessageCounter:239167336 not in RetransTable on exchange 28821i
    [1692345330.061995][79253:79255] CHIP:SC: Received Sigma2 msg
    [1692345330.062067][79253:79255] CHIP:SC: Peer assigned session session ID 19078
    [1692345330.069823][79253:79255] CHIP:SC: Found MRP parameters in the message
    [1692345330.069904][79253:79255] CHIP:SC: Sending Sigma3
    [1692345330.070768][79253:79255] CHIP:EM: <<< [E:28821i S:0 M:239167337 (Ack:205208516)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345330.070988][79253:79255] CHIP:IN: (U) Sending msg 239167337 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345330.071236][79253:79255] CHIP:SC: Sent Sigma3 msg
    [1692345330.302021][79253:79255] CHIP:EM: >>> [E:28821i S:0 M:205208517 (Ack:239167337)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345330.302148][79253:79255] CHIP:EM: Found matching exchange: 28821i, Delegate: 0xffff7400f408
    [1692345330.302227][79253:79255] CHIP:EM: Rxd Ack; Removing MessageCounter:239167337 from Retrans Table on exchange 28821i
    [1692345330.494601][79253:79255] CHIP:EM: >>> [E:28821i S:0 M:205208518 (Ack:239167337)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345330.494698][79253:79255] CHIP:EM: Found matching exchange: 28821i, Delegate: 0xffff7400f408
    [1692345330.494760][79253:79255] CHIP:EM: CHIP MessageCounter:239167337 not in RetransTable on exchange 28821i
    [1692345330.494864][79253:79255] CHIP:SC: Success status report received. Session was established
    [1692345330.506758][79253:79255] CHIP:SC: SecureSession[0xffff7400d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345330.506844][79253:79255] CHIP:IN: SecureSession[0xffff7400d360]: Activated - Type:2 LSID:7665
    [1692345330.506885][79253:79255] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:7665 PSID:19078!
    [1692345330.506936][79253:79255] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345330.507108][79253:79255] CHIP:TOO:      cluster 0x0000_0030, attribute: 0x0000_0000, endpoint 0
    [1692345330.507178][79253:79255] CHIP:TOO: Sending ReadAttribute to:
    [1692345330.507233][79253:79255] CHIP:DMG: SendReadRequest ReadClient[0xffff74011fb0]: Sending Read Request
    [1692345330.507508][79253:79255] CHIP:EM: <<< [E:28822i S:7665 M:163059778] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345330.507608][79253:79255] CHIP:IN: (S) Sending msg 163059778 on secure session with LSID: 7665
    [1692345330.507924][79253:79255] CHIP:DMG: MoveToState ReadClient[0xffff74011fb0]: Moving to [AwaitingIn]
    [1692345330.508092][79253:79255] CHIP:EM: <<< [E:28821i S:0 M:239167338 (Ack:205208518)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345330.508312][79253:79255] CHIP:IN: (U) Sending msg 239167338 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345330.508443][79253:79255] CHIP:EM: Flushed pending ack for MessageCounter:205208518 on exchange 28821i
    [1692345330.716041][79253:79255] CHIP:EM: >>> [E:28822i S:7665 M:54107022 (Ack:163059778)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345330.716135][79253:79255] CHIP:EM: Found matching exchange: 28822i, Delegate: 0xffff74011fc0
    [1692345330.716208][79253:79255] CHIP:EM: Rxd Ack; Removing MessageCounter:163059778 from Retrans Table on exchange 28822i
    [1692345330.716323][79253:79255] CHIP:DMG: ReportDataMessage =
    [1692345330.716378][79253:79255] CHIP:DMG: {
    [1692345330.716423][79253:79255] CHIP:DMG:      AttributeReportIBs =
    [1692345330.716487][79253:79255] CHIP:DMG:      [
    [1692345330.716536][79253:79255] CHIP:DMG:              AttributeReportIB =
    [1692345330.716603][79253:79255] CHIP:DMG:              {
    [1692345330.716656][79253:79255] CHIP:DMG:                      AttributeDataIB =
    [1692345330.716723][79253:79255] CHIP:DMG:                      {
    [1692345330.716822][79253:79255] CHIP:DMG:                              DataVersion = 0xb9f7f335,
    [1692345330.716887][79253:79255] CHIP:DMG:                              AttributePathIB =
    [1692345330.716952][79253:79255] CHIP:DMG:                              {
    [1692345330.717019][79253:79255] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345330.717108][79253:79255] CHIP:DMG:                                      Cluster = 0x30,
    [1692345330.717178][79253:79255] CHIP:DMG:                                      Attribute = 0x0000_0000,
    [1692345330.717244][79253:79255] CHIP:DMG:                              }
    [1692345330.717330][79253:79255] CHIP:DMG:
    [1692345330.717400][79253:79255] CHIP:DMG:                              Data = 0,
    [1692345330.717461][79253:79255] CHIP:DMG:                      },
    [1692345330.717529][79253:79255] CHIP:DMG:
    [1692345330.717599][79253:79255] CHIP:DMG:              },
    [1692345330.717662][79253:79255] CHIP:DMG:
    [1692345330.717710][79253:79255] CHIP:DMG:      ],
    [1692345330.717771][79253:79255] CHIP:DMG:
    [1692345330.717840][79253:79255] CHIP:DMG:      SuppressResponse = true,
    [1692345330.717891][79253:79255] CHIP:DMG:      InteractionModelRevision = 1
    [1692345330.717938][79253:79255] CHIP:DMG: }
    [1692345330.718281][79253:79255] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Attribute 0x0000_0000 DataVersion: 3120034613
    [1692345330.718428][79253:79255] CHIP:TOO:   Breadcrumb: 0
    [1692345330.718718][79253:79255] CHIP:EM: <<< [E:28822i S:7665 M:163059779 (Ack:54107022)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345330.718798][79253:79255] CHIP:IN: (S) Sending msg 163059779 on secure session with LSID: 7665
    [1692345330.719052][79253:79255] CHIP:EM: Flushed pending ack for MessageCounter:54107022 on exchange 28822i
    [1692345330.719416][79253:79253] CHIP:CTL: Shutting down the commissioner
    [1692345330.719484][79253:79253] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345330.719533][79253:79253] CHIP:CTL: Shutting down the controller
    [1692345330.719586][79253:79253] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345330.719630][79253:79253] CHIP:IN: SecureSession[0xffff7400d360]: MarkForEviction Type:2 LSID:7665
    [1692345330.719677][79253:79253] CHIP:SC: SecureSession[0xffff7400d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345330.719721][79253:79253] CHIP:IN: SecureSession[0xffff7400d360]: Released - Type:2 LSID:7665
    [1692345330.719774][79253:79253] CHIP:FP: Forgetting fabric 0x1
    [1692345330.719835][79253:79253] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345330.720218][79253:79253] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345330.720274][79253:79253] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345330.720356][79253:79253] CHIP:CTL: Shutting down the commissioner
    [1692345330.720402][79253:79253] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345330.720447][79253:79253] CHIP:CTL: Shutting down the controller
    [1692345330.720487][79253:79253] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345330.722313][79253:79253] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345330.722486][79253:79253] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345330.722583][79253:79253] CHIP:FP: Shutting down FabricTable
    [1692345330.722647][79253:79253] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345330.722953][79253:79253] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345330.723020][79253:79253] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345330.723415][79253:79253] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-HJKhWU)
    [1692345330.724576][79253:79253] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345330.724699][79253:79253] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345330.724752][79253:79253] CHIP:DL: Inet Layer shutdown
    [1692345330.724794][79253:79253] CHIP:DL: BLE shutdown
    [1692345330.724838][79253:79253] CHIP:DL: System Layer shutdown
    [1692345334.942354][79257:79257] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345334.947820][79257:79257] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345334.948071][79257:79257] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345334.948179][79257:79257] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345334.948533][79257:79257] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-Dz04b3)
    [1692345334.949136][79257:79257] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345334.949192][79257:79257] CHIP:DL: NVS set: chip-counters/reboot-count = 28 (0x1C)
    [1692345334.950103][79257:79257] CHIP:DL: Got Ethernet interface: eth0
    [1692345334.950691][79257:79257] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345334.951274][79257:79257] CHIP:DL: Got WiFi interface: wlan0
    [1692345334.951337][79257:79257] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345334.951388][79257:79257] CHIP:IN: UDP::Init bind&listen port=0
    [1692345334.951495][79257:79257] CHIP:IN: UDP::Init bound to port=50401
    [1692345334.951515][79257:79257] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345334.951533][79257:79257] CHIP:IN: TransportMgr initialized
    [1692345334.951563][79257:79257] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345334.951857][79257:79257] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345334.953365][79257:79257] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345334.953832][79257:79257] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345334.956457][79257:79257] CHIP:ZCL: Using ZAP configuration...
    [1692345334.960081][79257:79257] CHIP:DL: Avahi client registered
    [1692345334.961136][79257:79257] CHIP:CTL: System State Initialized...
    [1692345334.961252][79257:79257] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345334.961305][79257:79257] CHIP:CTL: Setting attestation nonce to random value
    [1692345334.961337][79257:79257] CHIP:CTL: Setting CSR nonce to random value
    [1692345334.961615][79257:79259] CHIP:DL: CHIP task running
    [1692345334.961797][79257:79259] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345334.962063][79257:79259] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345334.962128][79257:79259] CHIP:CTL: Setting attestation nonce to random value
    [1692345334.962279][79257:79259] CHIP:CTL: Setting CSR nonce to random value
    [1692345334.963071][79257:79259] CHIP:CTL: Generating NOC
    [1692345334.964086][79257:79259] CHIP:FP: Validating NOC chain
    [1692345334.965665][79257:79259] CHIP:FP: NOC chain validation successful
    [1692345334.965806][79257:79259] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345334.965835][79257:79259] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345334.965853][79257:79259] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345334.965870][79257:79259] CHIP:TS: Retaining current Last Known Good Time
    [1692345334.973625][79257:79259] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345334.976107][79257:79259] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345334.978594][79257:79259] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345334.998260][79257:79259] CHIP:TOO: Sending command to node 0x1
    [1692345334.998716][79257:79259] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345334.998749][79257:79259] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345334.998784][79257:79259] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345334.998812][79257:79259] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345335.000516][79257:79259] CHIP:DL: Avahi resolve found
    [1692345335.000590][79257:79259] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345335.000612][79257:79259] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345335.000637][79257:79259] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345335.000659][79257:79259] CHIP:DIS:      Port: 5540
    [1692345335.000679][79257:79259] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345335.000699][79257:79259] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345335.000719][79257:79259] CHIP:DIS:      TCP Supported: 0
    [1692345335.001470][79257:79259] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345335.001574][79257:79259] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345335.001596][79257:79259] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345335.001614][79257:79259] CHIP:DIS: Keeping DNSSD lookup active
    [1692345335.198937][79257:79259] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345335.199066][79257:79259] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345335.199126][79257:79259] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345335.199352][79257:79259] CHIP:IN: SecureSession[0xffff7c00d360]: Allocated Type:2 LSID:47821
    [1692345335.199444][79257:79259] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345335.201678][79257:79259] CHIP:EM: <<< [E:33586i S:0 M:172437555] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345335.201816][79257:79259] CHIP:IN: (U) Sending msg 172437555 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345335.202224][79257:79259] CHIP:SC: Sent Sigma1 msg
    [1692345335.202299][79257:79259] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345336.935658][79257:79259] CHIP:EM: >>> [E:33586i S:0 M:205208519 (Ack:172437555)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345336.935707][79257:79259] CHIP:EM: Found matching exchange: 33586i, Delegate: 0xffff7c00fbe8
    [1692345336.935743][79257:79259] CHIP:EM: Rxd Ack; Removing MessageCounter:172437555 from Retrans Table on exchange 33586i
    [1692345337.215937][79257:79259] CHIP:EM: >>> [E:33586i S:0 M:205208520 (Ack:172437555)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345337.216038][79257:79259] CHIP:EM: Found matching exchange: 33586i, Delegate: 0xffff7c00fbe8
    [1692345337.216101][79257:79259] CHIP:EM: CHIP MessageCounter:172437555 not in RetransTable on exchange 33586i
    [1692345337.216200][79257:79259] CHIP:SC: Received Sigma2 msg
    [1692345337.216282][79257:79259] CHIP:SC: Peer assigned session session ID 19079
    [1692345337.225185][79257:79259] CHIP:SC: Found MRP parameters in the message
    [1692345337.225259][79257:79259] CHIP:SC: Sending Sigma3
    [1692345337.225992][79257:79259] CHIP:EM: <<< [E:33586i S:0 M:172437556 (Ack:205208520)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345337.226209][79257:79259] CHIP:IN: (U) Sending msg 172437556 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345337.226435][79257:79259] CHIP:SC: Sent Sigma3 msg
    [1692345337.460379][79257:79259] CHIP:EM: >>> [E:33586i S:0 M:205208521 (Ack:172437556)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345337.460426][79257:79259] CHIP:EM: Found matching exchange: 33586i, Delegate: 0xffff7c00fbe8
    [1692345337.460462][79257:79259] CHIP:EM: Rxd Ack; Removing MessageCounter:172437556 from Retrans Table on exchange 33586i
    [1692345337.648439][79257:79259] CHIP:EM: >>> [E:33586i S:0 M:205208522 (Ack:172437556)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345337.648522][79257:79259] CHIP:EM: Found matching exchange: 33586i, Delegate: 0xffff7c00fbe8
    [1692345337.648574][79257:79259] CHIP:EM: CHIP MessageCounter:172437556 not in RetransTable on exchange 33586i
    [1692345337.648665][79257:79259] CHIP:SC: Success status report received. Session was established
    [1692345337.655540][79257:79259] CHIP:SC: SecureSession[0xffff7c00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345337.655595][79257:79259] CHIP:IN: SecureSession[0xffff7c00d360]: Activated - Type:2 LSID:47821
    [1692345337.655617][79257:79259] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:47821 PSID:19079!
    [1692345337.655646][79257:79259] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345337.655702][79257:79259] CHIP:TOO: Sending cluster (0x00000030) command (0x00000000) on endpoint 0
    [1692345337.655793][79257:79259] CHIP:DMG: ICR moving to [AddingComm]
    [1692345337.655848][79257:79259] CHIP:DMG: ICR moving to [AddedComma]
    [1692345337.655989][79257:79259] CHIP:EM: <<< [E:33587i S:47821 M:90948749] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345337.656034][79257:79259] CHIP:IN: (S) Sending msg 90948749 on secure session with LSID: 47821
    [1692345337.656243][79257:79259] CHIP:DMG: ICR moving to [CommandSen]
    [1692345337.656331][79257:79259] CHIP:EM: <<< [E:33586i S:0 M:172437557 (Ack:205208522)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345337.656477][79257:79259] CHIP:IN: (U) Sending msg 172437557 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345337.656595][79257:79259] CHIP:EM: Flushed pending ack for MessageCounter:205208522 on exchange 33586i
    [1692345337.877067][79257:79259] CHIP:EM: >>> [E:33587i S:47821 M:183393643 (Ack:90948749)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345337.877160][79257:79259] CHIP:EM: Found matching exchange: 33587i, Delegate: 0xffff7c00a4f8
    [1692345337.877236][79257:79259] CHIP:EM: Rxd Ack; Removing MessageCounter:90948749 from Retrans Table on exchange 33587i
    [1692345337.877310][79257:79259] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345337.877404][79257:79259] CHIP:DMG: InvokeResponseMessage =
    [1692345337.877455][79257:79259] CHIP:DMG: {
    [1692345337.877502][79257:79259] CHIP:DMG:      suppressResponse = false,
    [1692345337.877551][79257:79259] CHIP:DMG:      InvokeResponseIBs =
    [1692345337.877617][79257:79259] CHIP:DMG:      [
    [1692345337.877665][79257:79259] CHIP:DMG:              InvokeResponseIB =
    [1692345337.877733][79257:79259] CHIP:DMG:              {
    [1692345337.877786][79257:79259] CHIP:DMG:                      CommandDataIB =
    [1692345337.877881][79257:79259] CHIP:DMG:                      {
    [1692345337.877934][79257:79259] CHIP:DMG:                              CommandPathIB =
    [1692345337.877995][79257:79259] CHIP:DMG:                              {
    [1692345337.878130][79257:79259] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345337.878228][79257:79259] CHIP:DMG:                                      ClusterId = 0x30,
    [1692345337.878300][79257:79259] CHIP:DMG:                                      CommandId = 0x1,
    [1692345337.878364][79257:79259] CHIP:DMG:                              },
    [1692345337.878432][79257:79259] CHIP:DMG:
    [1692345337.878509][79257:79259] CHIP:DMG:                              CommandFields =
    [1692345337.878575][79257:79259] CHIP:DMG:                              {
    [1692345337.878686][79257:79259] CHIP:DMG:                                      0x0 = 0,
    [1692345337.878777][79257:79259] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692345337.878848][79257:79259] CHIP:DMG:                              },
    [1692345337.878909][79257:79259] CHIP:DMG:                      },
    [1692345337.878995][79257:79259] CHIP:DMG:
    [1692345337.879048][79257:79259] CHIP:DMG:              },
    [1692345337.879110][79257:79259] CHIP:DMG:
    [1692345337.879158][79257:79259] CHIP:DMG:      ],
    [1692345337.879237][79257:79259] CHIP:DMG:
    [1692345337.879288][79257:79259] CHIP:DMG:      InteractionModelRevision = 1
    [1692345337.879334][79257:79259] CHIP:DMG: },
    [1692345337.879462][79257:79259] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692345337.879544][79257:79259] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Command 0x0000_0001
    [1692345337.879670][79257:79259] CHIP:TOO:   ArmFailSafeResponse: {
    [1692345337.879748][79257:79259] CHIP:TOO:     errorCode: 0
    [1692345337.879791][79257:79259] CHIP:TOO:     debugText:
    [1692345337.879830][79257:79259] CHIP:TOO:    }
    [1692345337.879914][79257:79259] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345337.880123][79257:79259] CHIP:EM: <<< [E:33587i S:47821 M:90948750 (Ack:183393643)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345337.880195][79257:79259] CHIP:IN: (S) Sending msg 90948750 on secure session with LSID: 47821
    [1692345337.880427][79257:79259] CHIP:EM: Flushed pending ack for MessageCounter:183393643 on exchange 33587i
    [1692345337.880789][79257:79257] CHIP:CTL: Shutting down the commissioner
    [1692345337.880851][79257:79257] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345337.880894][79257:79257] CHIP:CTL: Shutting down the controller
    [1692345337.880937][79257:79257] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345337.880977][79257:79257] CHIP:IN: SecureSession[0xffff7c00d360]: MarkForEviction Type:2 LSID:47821
    [1692345337.881016][79257:79257] CHIP:SC: SecureSession[0xffff7c00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345337.881057][79257:79257] CHIP:IN: SecureSession[0xffff7c00d360]: Released - Type:2 LSID:47821
    [1692345337.881104][79257:79257] CHIP:FP: Forgetting fabric 0x1
    [1692345337.881156][79257:79257] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345337.881575][79257:79257] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345337.881674][79257:79257] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345337.881749][79257:79257] CHIP:CTL: Shutting down the commissioner
    [1692345337.881789][79257:79257] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345337.881830][79257:79257] CHIP:CTL: Shutting down the controller
    [1692345337.881866][79257:79257] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345337.883523][79257:79257] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345337.883682][79257:79257] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345337.883771][79257:79257] CHIP:FP: Shutting down FabricTable
    [1692345337.883837][79257:79257] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345337.884113][79257:79257] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345337.884158][79257:79257] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345337.884502][79257:79257] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-YY4CGR)
    [1692345337.885638][79257:79257] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345337.885747][79257:79257] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345337.885793][79257:79257] CHIP:DL: Inet Layer shutdown
    [1692345337.885830][79257:79257] CHIP:DL: BLE shutdown
    [1692345337.885869][79257:79257] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning read networks 1 0
    [1692345356.982396][79261:79261] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345356.987821][79261:79261] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345356.988078][79261:79261] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345356.988183][79261:79261] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345356.988536][79261:79261] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-2jYSUt)
    [1692345356.989107][79261:79261] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345356.989160][79261:79261] CHIP:DL: NVS set: chip-counters/reboot-count = 29 (0x1D)
    [1692345356.990144][79261:79261] CHIP:DL: Got Ethernet interface: eth0
    [1692345356.990815][79261:79261] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345356.991396][79261:79261] CHIP:DL: Got WiFi interface: wlan0
    [1692345356.991460][79261:79261] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345356.991511][79261:79261] CHIP:IN: UDP::Init bind&listen port=0
    [1692345356.991620][79261:79261] CHIP:IN: UDP::Init bound to port=42776
    [1692345356.991646][79261:79261] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345356.991662][79261:79261] CHIP:IN: TransportMgr initialized
    [1692345356.991696][79261:79261] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345356.991884][79261:79261] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345356.993461][79261:79261] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345356.994016][79261:79261] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345356.996674][79261:79261] CHIP:ZCL: Using ZAP configuration...
    [1692345357.000692][79261:79261] CHIP:DL: Avahi client registered
    [1692345357.001923][79261:79261] CHIP:CTL: System State Initialized...
    [1692345357.002052][79261:79261] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345357.002144][79261:79261] CHIP:CTL: Setting attestation nonce to random value
    [1692345357.002190][79261:79261] CHIP:CTL: Setting CSR nonce to random value
    [1692345357.002491][79261:79263] CHIP:DL: CHIP task running
    [1692345357.002692][79261:79263] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345357.002967][79261:79263] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345357.003014][79261:79263] CHIP:CTL: Setting attestation nonce to random value
    [1692345357.003175][79261:79263] CHIP:CTL: Setting CSR nonce to random value
    [1692345357.004045][79261:79263] CHIP:CTL: Generating NOC
    [1692345357.005117][79261:79263] CHIP:FP: Validating NOC chain
    [1692345357.006931][79261:79263] CHIP:FP: NOC chain validation successful
    [1692345357.007089][79261:79263] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345357.007119][79261:79263] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345357.007138][79261:79263] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345357.007156][79261:79263] CHIP:TS: Retaining current Last Known Good Time
    [1692345357.014734][79261:79263] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345357.017141][79261:79263] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345357.021693][79261:79263] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345357.040118][79261:79263] CHIP:TOO: Sending command to node 0x1
    [1692345357.040525][79261:79263] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345357.040558][79261:79263] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345357.040590][79261:79263] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345357.040618][79261:79263] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345357.042328][79261:79263] CHIP:DL: Avahi resolve found
    [1692345357.042398][79261:79263] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345357.042419][79261:79263] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345357.042443][79261:79263] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345357.042463][79261:79263] CHIP:DIS:      Port: 5540
    [1692345357.042480][79261:79263] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345357.042498][79261:79263] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345357.042516][79261:79263] CHIP:DIS:      TCP Supported: 0
    [1692345357.043259][79261:79263] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345357.043358][79261:79263] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345357.043381][79261:79263] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345357.043398][79261:79263] CHIP:DIS: Keeping DNSSD lookup active
    [1692345357.240822][79261:79263] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345357.240953][79261:79263] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345357.241012][79261:79263] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345357.241241][79261:79263] CHIP:IN: SecureSession[0xffffac00d350]: Allocated Type:2 LSID:24778
    [1692345357.241333][79261:79263] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345357.243561][79261:79263] CHIP:EM: <<< [E:5984i S:0 M:218057846] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345357.243702][79261:79263] CHIP:IN: (U) Sending msg 218057846 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345357.244050][79261:79263] CHIP:SC: Sent Sigma1 msg
    [1692345357.244124][79261:79263] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345358.106451][79261:79263] CHIP:EM: >>> [E:5984i S:0 M:205208523 (Ack:218057846)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345358.106542][79261:79263] CHIP:EM: Found matching exchange: 5984i, Delegate: 0xffffac00fd98
    [1692345358.106613][79261:79263] CHIP:EM: Rxd Ack; Removing MessageCounter:218057846 from Retrans Table on exchange 5984i
    [1692345358.389732][79261:79263] CHIP:EM: >>> [E:5984i S:0 M:205208524 (Ack:218057846)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345358.389824][79261:79263] CHIP:EM: Found matching exchange: 5984i, Delegate: 0xffffac00fd98
    [1692345358.389878][79261:79263] CHIP:EM: CHIP MessageCounter:218057846 not in RetransTable on exchange 5984i
    [1692345358.389967][79261:79263] CHIP:SC: Received Sigma2 msg
    [1692345358.390040][79261:79263] CHIP:SC: Peer assigned session session ID 19080
    [1692345358.398706][79261:79263] CHIP:SC: Found MRP parameters in the message
    [1692345358.398812][79261:79263] CHIP:SC: Sending Sigma3
    [1692345358.400078][79261:79263] CHIP:EM: <<< [E:5984i S:0 M:218057847 (Ack:205208524)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345358.400365][79261:79263] CHIP:IN: (U) Sending msg 218057847 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345358.400725][79261:79263] CHIP:SC: Sent Sigma3 msg
    [1692345358.631299][79261:79263] CHIP:EM: >>> [E:5984i S:0 M:205208525 (Ack:218057847)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345358.631389][79261:79263] CHIP:EM: Found matching exchange: 5984i, Delegate: 0xffffac00fd98
    [1692345358.631461][79261:79263] CHIP:EM: Rxd Ack; Removing MessageCounter:218057847 from Retrans Table on exchange 5984i
    [1692345358.823687][79261:79263] CHIP:EM: >>> [E:5984i S:0 M:205208526 (Ack:218057847)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345358.823775][79261:79263] CHIP:EM: Found matching exchange: 5984i, Delegate: 0xffffac00fd98
    [1692345358.823829][79261:79263] CHIP:EM: CHIP MessageCounter:218057847 not in RetransTable on exchange 5984i
    [1692345358.823919][79261:79263] CHIP:SC: Success status report received. Session was established
    [1692345358.832917][79261:79263] CHIP:SC: SecureSession[0xffffac00d350]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345358.832973][79261:79263] CHIP:IN: SecureSession[0xffffac00d350]: Activated - Type:2 LSID:24778
    [1692345358.832996][79261:79263] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:24778 PSID:19080!
    [1692345358.833027][79261:79263] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345358.833148][79261:79263] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0001, endpoint 0
    [1692345358.833182][79261:79263] CHIP:TOO: Sending ReadAttribute to:
    [1692345358.833216][79261:79263] CHIP:DMG: SendReadRequest ReadClient[0xffffac00f480]: Sending Read Request
    [1692345358.833391][79261:79263] CHIP:EM: <<< [E:5985i S:24778 M:95330642] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345358.833440][79261:79263] CHIP:IN: (S) Sending msg 95330642 on secure session with LSID: 24778
    [1692345358.833648][79261:79263] CHIP:DMG: MoveToState ReadClient[0xffffac00f480]: Moving to [AwaitingIn]
    [1692345358.833744][79261:79263] CHIP:EM: <<< [E:5984i S:0 M:218057848 (Ack:205208526)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345358.833974][79261:79263] CHIP:IN: (U) Sending msg 218057848 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345358.834143][79261:79263] CHIP:EM: Flushed pending ack for MessageCounter:205208526 on exchange 5984i
    [1692345359.045324][79261:79263] CHIP:EM: >>> [E:5985i S:24778 M:174421328 (Ack:95330642)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345359.045407][79261:79263] CHIP:EM: Found matching exchange: 5985i, Delegate: 0xffffac00f490
    [1692345359.045476][79261:79263] CHIP:EM: Rxd Ack; Removing MessageCounter:95330642 from Retrans Table on exchange 5985i
    [1692345359.045590][79261:79263] CHIP:DMG: ReportDataMessage =
    [1692345359.045641][79261:79263] CHIP:DMG: {
    [1692345359.045680][79261:79263] CHIP:DMG:      AttributeReportIBs =
    [1692345359.045737][79261:79263] CHIP:DMG:      [
    [1692345359.045781][79261:79263] CHIP:DMG:              AttributeReportIB =
    [1692345359.045840][79261:79263] CHIP:DMG:              {
    [1692345359.045896][79261:79263] CHIP:DMG:                      AttributeDataIB =
    [1692345359.045969][79261:79263] CHIP:DMG:                      {
    [1692345359.046042][79261:79263] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345359.046157][79261:79263] CHIP:DMG:                              AttributePathIB =
    [1692345359.046239][79261:79263] CHIP:DMG:                              {
    [1692345359.046335][79261:79263] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345359.046415][79261:79263] CHIP:DMG:                                      Cluster = 0x31,
    [1692345359.046497][79261:79263] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345359.046574][79261:79263] CHIP:DMG:                              }
    [1692345359.046656][79261:79263] CHIP:DMG:
    [1692345359.046731][79261:79263] CHIP:DMG:                              Data = [
    [1692345359.046805][79261:79263] CHIP:DMG:
    [1692345359.046886][79261:79263] CHIP:DMG:                              ],
    [1692345359.046958][79261:79263] CHIP:DMG:                      },
    [1692345359.047038][79261:79263] CHIP:DMG:
    [1692345359.047099][79261:79263] CHIP:DMG:              },
    [1692345359.047192][79261:79263] CHIP:DMG:
    [1692345359.047251][79261:79263] CHIP:DMG:              AttributeReportIB =
    [1692345359.047331][79261:79263] CHIP:DMG:              {
    [1692345359.047393][79261:79263] CHIP:DMG:                      AttributeDataIB =
    [1692345359.047462][79261:79263] CHIP:DMG:                      {
    [1692345359.047536][79261:79263] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345359.047609][79261:79263] CHIP:DMG:                              AttributePathIB =
    [1692345359.047684][79261:79263] CHIP:DMG:                              {
    [1692345359.047761][79261:79263] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345359.047843][79261:79263] CHIP:DMG:                                      Cluster = 0x31,
    [1692345359.047926][79261:79263] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345359.048005][79261:79263] CHIP:DMG:                                      ListIndex = Null,
    [1692345359.048082][79261:79263] CHIP:DMG:                              }
    [1692345359.048163][79261:79263] CHIP:DMG:
    [1692345359.048236][79261:79263] CHIP:DMG:                              Data =
    [1692345359.048310][79261:79263] CHIP:DMG:                              {
    [1692345359.048441][79261:79263] CHIP:DMG:                                      0x0 = [
    [1692345359.048524][79261:79263] CHIP:DMG:                                                      0x69, 0x5e, 0x3b, 0xcb, 0x08, 0xb9, 0x69, 0x68,
    [1692345359.048618][79261:79263] CHIP:DMG:                                      ] (8 bytes)
    [1692345359.048701][79261:79263] CHIP:DMG:                                      0x1 = true,
    [1692345359.048781][79261:79263] CHIP:DMG:                              },
    [1692345359.048852][79261:79263] CHIP:DMG:                      },
    [1692345359.048932][79261:79263] CHIP:DMG:
    [1692345359.048993][79261:79263] CHIP:DMG:              },
    [1692345359.049069][79261:79263] CHIP:DMG:
    [1692345359.049126][79261:79263] CHIP:DMG:      ],
    [1692345359.049212][79261:79263] CHIP:DMG:
    [1692345359.049271][79261:79263] CHIP:DMG:      SuppressResponse = true,
    [1692345359.049331][79261:79263] CHIP:DMG:      InteractionModelRevision = 1
    [1692345359.049387][79261:79263] CHIP:DMG: }
    [1692345359.049947][79261:79263] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0001 DataVersion: 3295567105
    [1692345359.050141][79261:79263] CHIP:TOO:   Networks: 1 entries
    [1692345359.050250][79261:79263] CHIP:TOO:     [1]: {
    [1692345359.050318][79261:79263] CHIP:TOO:       NetworkID: 695E3BCB08B96968
    [1692345359.050373][79261:79263] CHIP:TOO:       Connected: TRUE
    [1692345359.050425][79261:79263] CHIP:TOO:      }
    [1692345359.050736][79261:79263] CHIP:EM: <<< [E:5985i S:24778 M:95330643 (Ack:174421328)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345359.050829][79261:79263] CHIP:IN: (S) Sending msg 95330643 on secure session with LSID: 24778
    [1692345359.051098][79261:79263] CHIP:EM: Flushed pending ack for MessageCounter:174421328 on exchange 5985i
    [1692345359.051503][79261:79261] CHIP:CTL: Shutting down the commissioner
    [1692345359.051583][79261:79261] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345359.051642][79261:79261] CHIP:CTL: Shutting down the controller
    [1692345359.051709][79261:79261] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345359.051765][79261:79261] CHIP:IN: SecureSession[0xffffac00d350]: MarkForEviction Type:2 LSID:24778
    [1692345359.051818][79261:79261] CHIP:SC: SecureSession[0xffffac00d350]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345359.051871][79261:79261] CHIP:IN: SecureSession[0xffffac00d350]: Released - Type:2 LSID:24778
    [1692345359.051933][79261:79261] CHIP:FP: Forgetting fabric 0x1
    [1692345359.052090][79261:79261] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345359.052561][79261:79261] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345359.052697][79261:79261] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345359.052813][79261:79261] CHIP:CTL: Shutting down the commissioner
    [1692345359.052867][79261:79261] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345359.052916][79261:79261] CHIP:CTL: Shutting down the controller
    [1692345359.052960][79261:79261] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345359.055553][79261:79261] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345359.055773][79261:79261] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345359.055880][79261:79261] CHIP:FP: Shutting down FabricTable
    [1692345359.055944][79261:79261] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345359.056289][79261:79261] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345359.056365][79261:79261] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345359.056818][79261:79261] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-dM7Wx9)
    [1692345359.057599][79261:79261] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345359.057665][79261:79261] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345359.057689][79261:79261] CHIP:DL: Inet Layer shutdown
    [1692345359.057707][79261:79261] CHIP:DL: BLE shutdown
    [1692345359.057728][79261:79261] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$  ./chip-tool generalcommissioning arm-fail-safe 90 0 1 0
    [1692345368.492153][79264:79264] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345368.497606][79264:79264] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345368.497859][79264:79264] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345368.497976][79264:79264] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345368.498374][79264:79264] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-Zs52SG)
    [1692345368.498995][79264:79264] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345368.499063][79264:79264] CHIP:DL: NVS set: chip-counters/reboot-count = 30 (0x1E)
    [1692345368.499956][79264:79264] CHIP:DL: Got Ethernet interface: eth0
    [1692345368.500542][79264:79264] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345368.501157][79264:79264] CHIP:DL: Got WiFi interface: wlan0
    [1692345368.501229][79264:79264] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345368.501283][79264:79264] CHIP:IN: UDP::Init bind&listen port=0
    [1692345368.501390][79264:79264] CHIP:IN: UDP::Init bound to port=49232
    [1692345368.501411][79264:79264] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345368.501429][79264:79264] CHIP:IN: TransportMgr initialized
    [1692345368.501462][79264:79264] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345368.501656][79264:79264] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345368.503208][79264:79264] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345368.503691][79264:79264] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345368.508877][79264:79264] CHIP:ZCL: Using ZAP configuration...
    [1692345368.512712][79264:79264] CHIP:DL: Avahi client registered
    [1692345368.514015][79264:79264] CHIP:CTL: System State Initialized...
    [1692345368.514183][79264:79264] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345368.514248][79264:79264] CHIP:CTL: Setting attestation nonce to random value
    [1692345368.514293][79264:79264] CHIP:CTL: Setting CSR nonce to random value
    [1692345368.514608][79264:79266] CHIP:DL: CHIP task running
    [1692345368.514816][79264:79266] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345368.515132][79264:79266] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345368.515180][79264:79266] CHIP:CTL: Setting attestation nonce to random value
    [1692345368.515362][79264:79266] CHIP:CTL: Setting CSR nonce to random value
    [1692345368.516329][79264:79266] CHIP:CTL: Generating NOC
    [1692345368.517472][79264:79266] CHIP:FP: Validating NOC chain
    [1692345368.519499][79264:79266] CHIP:FP: NOC chain validation successful
    [1692345368.519681][79264:79266] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345368.519718][79264:79266] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345368.519741][79264:79266] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345368.519763][79264:79266] CHIP:TS: Retaining current Last Known Good Time
    [1692345368.527971][79264:79266] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345368.530505][79264:79266] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345368.532996][79264:79266] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345368.555827][79264:79266] CHIP:TOO: Sending command to node 0x1
    [1692345368.556213][79264:79266] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345368.556244][79264:79266] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345368.556276][79264:79266] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345368.556304][79264:79266] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345368.557931][79264:79266] CHIP:DL: Avahi resolve found
    [1692345368.557998][79264:79266] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345368.558018][79264:79266] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345368.558042][79264:79266] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345368.558061][79264:79266] CHIP:DIS:      Port: 5540
    [1692345368.558210][79264:79266] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345368.558230][79264:79266] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345368.558248][79264:79266] CHIP:DIS:      TCP Supported: 0
    [1692345368.558959][79264:79266] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345368.559055][79264:79266] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345368.559077][79264:79266] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345368.559094][79264:79266] CHIP:DIS: Keeping DNSSD lookup active
    [1692345368.757342][79264:79266] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345368.757470][79264:79266] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345368.757528][79264:79266] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345368.757756][79264:79266] CHIP:IN: SecureSession[0xffff9400d360]: Allocated Type:2 LSID:677
    [1692345368.757850][79264:79266] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345368.760049][79264:79266] CHIP:EM: <<< [E:39710i S:0 M:164046488] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345368.760198][79264:79266] CHIP:IN: (U) Sending msg 164046488 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345368.760550][79264:79266] CHIP:SC: Sent Sigma1 msg
    [1692345368.760639][79264:79266] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345369.269068][79264:79266] CHIP:EM: >>> [E:39710i S:0 M:205208527 (Ack:164046488)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345369.269143][79264:79266] CHIP:EM: Found matching exchange: 39710i, Delegate: 0xffff9400f408
    [1692345369.269201][79264:79266] CHIP:EM: Rxd Ack; Removing MessageCounter:164046488 from Retrans Table on exchange 39710i
    [1692345369.543569][79264:79266] CHIP:EM: >>> [E:39710i S:0 M:205208528 (Ack:164046488)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345369.543658][79264:79266] CHIP:EM: Found matching exchange: 39710i, Delegate: 0xffff9400f408
    [1692345369.543713][79264:79266] CHIP:EM: CHIP MessageCounter:164046488 not in RetransTable on exchange 39710i
    [1692345369.543801][79264:79266] CHIP:SC: Received Sigma2 msg
    [1692345369.543872][79264:79266] CHIP:SC: Peer assigned session session ID 19081
    [1692345369.552479][79264:79266] CHIP:SC: Found MRP parameters in the message
    [1692345369.552587][79264:79266] CHIP:SC: Sending Sigma3
    [1692345369.553809][79264:79266] CHIP:EM: <<< [E:39710i S:0 M:164046489 (Ack:205208528)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345369.554136][79264:79266] CHIP:IN: (U) Sending msg 164046489 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345369.554459][79264:79266] CHIP:SC: Sent Sigma3 msg
    [1692345369.792545][79264:79266] CHIP:EM: >>> [E:39710i S:0 M:205208529 (Ack:164046489)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345369.792634][79264:79266] CHIP:EM: Found matching exchange: 39710i, Delegate: 0xffff9400f408
    [1692345369.792707][79264:79266] CHIP:EM: Rxd Ack; Removing MessageCounter:164046489 from Retrans Table on exchange 39710i
    [1692345369.984881][79264:79266] CHIP:EM: >>> [E:39710i S:0 M:205208530 (Ack:164046489)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345369.984972][79264:79266] CHIP:EM: Found matching exchange: 39710i, Delegate: 0xffff9400f408
    [1692345369.985026][79264:79266] CHIP:EM: CHIP MessageCounter:164046489 not in RetransTable on exchange 39710i
    [1692345369.985117][79264:79266] CHIP:SC: Success status report received. Session was established
    [1692345369.992748][79264:79266] CHIP:SC: SecureSession[0xffff9400d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345369.992810][79264:79266] CHIP:IN: SecureSession[0xffff9400d360]: Activated - Type:2 LSID:677
    [1692345369.992837][79264:79266] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:677 PSID:19081!
    [1692345369.992872][79264:79266] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345369.992936][79264:79266] CHIP:TOO: Sending cluster (0x00000030) command (0x00000000) on endpoint 0
    [1692345369.993035][79264:79266] CHIP:DMG: ICR moving to [AddingComm]
    [1692345369.993100][79264:79266] CHIP:DMG: ICR moving to [AddedComma]
    [1692345369.993255][79264:79266] CHIP:EM: <<< [E:39711i S:677 M:207207823] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345369.993311][79264:79266] CHIP:IN: (S) Sending msg 207207823 on secure session with LSID: 677
    [1692345369.993546][79264:79266] CHIP:DMG: ICR moving to [CommandSen]
    [1692345369.993652][79264:79266] CHIP:EM: <<< [E:39710i S:0 M:164046490 (Ack:205208530)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345369.993824][79264:79266] CHIP:IN: (U) Sending msg 164046490 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345369.993958][79264:79266] CHIP:EM: Flushed pending ack for MessageCounter:205208530 on exchange 39710i
    [1692345370.205623][79264:79266] CHIP:EM: >>> [E:39711i S:677 M:7516762 (Ack:207207823)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345370.205698][79264:79266] CHIP:EM: Found matching exchange: 39711i, Delegate: 0xffff9400a4f8
    [1692345370.205758][79264:79266] CHIP:EM: Rxd Ack; Removing MessageCounter:207207823 from Retrans Table on exchange 39711i
    [1692345370.205815][79264:79266] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345370.205889][79264:79266] CHIP:DMG: InvokeResponseMessage =
    [1692345370.205927][79264:79266] CHIP:DMG: {
    [1692345370.205964][79264:79266] CHIP:DMG:      suppressResponse = false,
    [1692345370.206002][79264:79266] CHIP:DMG:      InvokeResponseIBs =
    [1692345370.206053][79264:79266] CHIP:DMG:      [
    [1692345370.206120][79264:79266] CHIP:DMG:              InvokeResponseIB =
    [1692345370.206181][79264:79266] CHIP:DMG:              {
    [1692345370.206235][79264:79266] CHIP:DMG:                      CommandDataIB =
    [1692345370.206324][79264:79266] CHIP:DMG:                      {
    [1692345370.206396][79264:79266] CHIP:DMG:                              CommandPathIB =
    [1692345370.206460][79264:79266] CHIP:DMG:                              {
    [1692345370.206527][79264:79266] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345370.206598][79264:79266] CHIP:DMG:                                      ClusterId = 0x30,
    [1692345370.206685][79264:79266] CHIP:DMG:                                      CommandId = 0x1,
    [1692345370.206752][79264:79266] CHIP:DMG:                              },
    [1692345370.206820][79264:79266] CHIP:DMG:
    [1692345370.206879][79264:79266] CHIP:DMG:                              CommandFields =
    [1692345370.206962][79264:79266] CHIP:DMG:                              {
    [1692345370.207079][79264:79266] CHIP:DMG:                                      0x0 = 0,
    [1692345370.207175][79264:79266] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692345370.207247][79264:79266] CHIP:DMG:                              },
    [1692345370.207308][79264:79266] CHIP:DMG:                      },
    [1692345370.207377][79264:79266] CHIP:DMG:
    [1692345370.207447][79264:79266] CHIP:DMG:              },
    [1692345370.207511][79264:79266] CHIP:DMG:
    [1692345370.207559][79264:79266] CHIP:DMG:      ],
    [1692345370.207623][79264:79266] CHIP:DMG:
    [1692345370.207692][79264:79266] CHIP:DMG:      InteractionModelRevision = 1
    [1692345370.207740][79264:79266] CHIP:DMG: },
    [1692345370.207882][79264:79266] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692345370.207975][79264:79266] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Command 0x0000_0001
    [1692345370.208115][79264:79266] CHIP:TOO:   ArmFailSafeResponse: {
    [1692345370.208202][79264:79266] CHIP:TOO:     errorCode: 0
    [1692345370.208248][79264:79266] CHIP:TOO:     debugText:
    [1692345370.208292][79264:79266] CHIP:TOO:    }
    [1692345370.208369][79264:79266] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345370.208589][79264:79266] CHIP:EM: <<< [E:39711i S:677 M:207207824 (Ack:7516762)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345370.208671][79264:79266] CHIP:IN: (S) Sending msg 207207824 on secure session with LSID: 677
    [1692345370.208925][79264:79266] CHIP:EM: Flushed pending ack for MessageCounter:7516762 on exchange 39711i
    [1692345370.209375][79264:79264] CHIP:CTL: Shutting down the commissioner
    [1692345370.209448][79264:79264] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345370.209498][79264:79264] CHIP:CTL: Shutting down the controller
    [1692345370.209547][79264:79264] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345370.209591][79264:79264] CHIP:IN: SecureSession[0xffff9400d360]: MarkForEviction Type:2 LSID:677
    [1692345370.209636][79264:79264] CHIP:SC: SecureSession[0xffff9400d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345370.209683][79264:79264] CHIP:IN: SecureSession[0xffff9400d360]: Released - Type:2 LSID:677
    [1692345370.209737][79264:79264] CHIP:FP: Forgetting fabric 0x1
    [1692345370.209797][79264:79264] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345370.210321][79264:79264] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345370.210395][79264:79264] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345370.210487][79264:79264] CHIP:CTL: Shutting down the commissioner
    [1692345370.210542][79264:79264] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345370.210594][79264:79264] CHIP:CTL: Shutting down the controller
    [1692345370.210640][79264:79264] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345370.212363][79264:79264] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345370.212527][79264:79264] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345370.212626][79264:79264] CHIP:FP: Shutting down FabricTable
    [1692345370.212687][79264:79264] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345370.212999][79264:79264] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345370.213068][79264:79264] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345370.213445][79264:79264] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-oa5JHh)
    [1692345370.214644][79264:79264] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345370.214767][79264:79264] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345370.214820][79264:79264] CHIP:DL: Inet Layer shutdown
    [1692345370.214861][79264:79264] CHIP:DL: BLE shutdown
    [1692345370.214904][79264:79264] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning  remove-network hex:695E3BCB08B96968 1 0 --Breadcrumb 1
    [1692345407.502477][79269:79269] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345407.507863][79269:79269] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345407.508133][79269:79269] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345407.508239][79269:79269] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345407.508585][79269:79269] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-VdM1kr)
    [1692345407.509162][79269:79269] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345407.509217][79269:79269] CHIP:DL: NVS set: chip-counters/reboot-count = 31 (0x1F)
    [1692345407.510137][79269:79269] CHIP:DL: Got Ethernet interface: eth0
    [1692345407.510739][79269:79269] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345407.511318][79269:79269] CHIP:DL: Got WiFi interface: wlan0
    [1692345407.511382][79269:79269] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345407.511434][79269:79269] CHIP:IN: UDP::Init bind&listen port=0
    [1692345407.511539][79269:79269] CHIP:IN: UDP::Init bound to port=57038
    [1692345407.511560][79269:79269] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345407.511577][79269:79269] CHIP:IN: TransportMgr initialized
    [1692345407.511608][79269:79269] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345407.511794][79269:79269] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345407.513313][79269:79269] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345407.513787][79269:79269] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345407.518696][79269:79269] CHIP:ZCL: Using ZAP configuration...
    [1692345407.522182][79269:79269] CHIP:DL: Avahi client registered
    [1692345407.523214][79269:79269] CHIP:CTL: System State Initialized...
    [1692345407.523323][79269:79269] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345407.523376][79269:79269] CHIP:CTL: Setting attestation nonce to random value
    [1692345407.523409][79269:79269] CHIP:CTL: Setting CSR nonce to random value
    [1692345407.523739][79269:79271] CHIP:DL: CHIP task running
    [1692345407.523933][79269:79271] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345407.524206][79269:79271] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345407.524247][79269:79271] CHIP:CTL: Setting attestation nonce to random value
    [1692345407.524397][79269:79271] CHIP:CTL: Setting CSR nonce to random value
    [1692345407.525176][79269:79271] CHIP:CTL: Generating NOC
    [1692345407.526219][79269:79271] CHIP:FP: Validating NOC chain
    [1692345407.527924][79269:79271] CHIP:FP: NOC chain validation successful
    [1692345407.528129][79269:79271] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345407.528170][79269:79271] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345407.528197][79269:79271] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345407.528222][79269:79271] CHIP:TS: Retaining current Last Known Good Time
    [1692345407.537517][79269:79271] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345407.540296][79269:79271] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345407.542497][79269:79271] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345407.562769][79269:79271] CHIP:TOO: Sending command to node 0x1
    [1692345407.563155][79269:79271] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345407.563186][79269:79271] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345407.563218][79269:79271] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345407.563247][79269:79271] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345407.564864][79269:79271] CHIP:DL: Avahi resolve found
    [1692345407.564931][79269:79271] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345407.564951][79269:79271] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345407.564973][79269:79271] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345407.564992][79269:79271] CHIP:DIS:      Port: 5540
    [1692345407.565009][79269:79271] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345407.565027][79269:79271] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345407.565044][79269:79271] CHIP:DIS:      TCP Supported: 0
    [1692345407.565760][79269:79271] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345407.565860][79269:79271] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345407.565881][79269:79271] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345407.565898][79269:79271] CHIP:DIS: Keeping DNSSD lookup active
    [1692345407.764291][79269:79271] CHIP:DIS: Checking node lookup status after 201 ms
    [1692345407.764410][79269:79271] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345407.764461][79269:79271] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345407.764666][79269:79271] CHIP:IN: SecureSession[0xffffac00d360]: Allocated Type:2 LSID:26238
    [1692345407.764751][79269:79271] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345407.766967][79269:79271] CHIP:EM: <<< [E:38601i S:0 M:114295771] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345407.767108][79269:79271] CHIP:IN: (U) Sending msg 114295771 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345407.767551][79269:79271] CHIP:SC: Sent Sigma1 msg
    [1692345407.767628][79269:79271] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345408.445915][79269:79271] CHIP:EM: >>> [E:38601i S:0 M:205208531 (Ack:114295771)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345408.446007][79269:79271] CHIP:EM: Found matching exchange: 38601i, Delegate: 0xffffac00f408
    [1692345408.446107][79269:79271] CHIP:EM: Rxd Ack; Removing MessageCounter:114295771 from Retrans Table on exchange 38601i
    [1692345408.730854][79269:79271] CHIP:EM: >>> [E:38601i S:0 M:205208532 (Ack:114295771)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345408.730943][79269:79271] CHIP:EM: Found matching exchange: 38601i, Delegate: 0xffffac00f408
    [1692345408.730998][79269:79271] CHIP:EM: CHIP MessageCounter:114295771 not in RetransTable on exchange 38601i
    [1692345408.731086][79269:79271] CHIP:SC: Received Sigma2 msg
    [1692345408.731159][79269:79271] CHIP:SC: Peer assigned session session ID 19082
    [1692345408.738769][79269:79271] CHIP:SC: Found MRP parameters in the message
    [1692345408.738855][79269:79271] CHIP:SC: Sending Sigma3
    [1692345408.739790][79269:79271] CHIP:EM: <<< [E:38601i S:0 M:114295772 (Ack:205208532)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345408.740013][79269:79271] CHIP:IN: (U) Sending msg 114295772 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345408.740284][79269:79271] CHIP:SC: Sent Sigma3 msg
    [1692345408.972153][79269:79271] CHIP:EM: >>> [E:38601i S:0 M:205208533 (Ack:114295772)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345408.972242][79269:79271] CHIP:EM: Found matching exchange: 38601i, Delegate: 0xffffac00f408
    [1692345408.972314][79269:79271] CHIP:EM: Rxd Ack; Removing MessageCounter:114295772 from Retrans Table on exchange 38601i
    [1692345409.164515][79269:79271] CHIP:EM: >>> [E:38601i S:0 M:205208534 (Ack:114295772)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345409.164604][79269:79271] CHIP:EM: Found matching exchange: 38601i, Delegate: 0xffffac00f408
    [1692345409.164661][79269:79271] CHIP:EM: CHIP MessageCounter:114295772 not in RetransTable on exchange 38601i
    [1692345409.164753][79269:79271] CHIP:SC: Success status report received. Session was established
    [1692345409.172687][79269:79271] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345409.172770][79269:79271] CHIP:IN: SecureSession[0xffffac00d360]: Activated - Type:2 LSID:26238
    [1692345409.172811][79269:79271] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:26238 PSID:19082!
    [1692345409.172860][79269:79271] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345409.172948][79269:79271] CHIP:TOO: Sending cluster (0x00000031) command (0x00000004) on endpoint 0
    [1692345409.173083][79269:79271] CHIP:DMG: ICR moving to [AddingComm]
    [1692345409.173178][79269:79271] CHIP:DMG: ICR moving to [AddedComma]
    [1692345409.173380][79269:79271] CHIP:EM: <<< [E:38602i S:26238 M:42085121] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345409.173455][79269:79271] CHIP:IN: (S) Sending msg 42085121 on secure session with LSID: 26238
    [1692345409.173742][79269:79271] CHIP:DMG: ICR moving to [CommandSen]
    [1692345409.173872][79269:79271] CHIP:EM: <<< [E:38601i S:0 M:114295773 (Ack:205208534)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345409.174140][79269:79271] CHIP:IN: (U) Sending msg 114295773 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345409.174329][79269:79271] CHIP:EM: Flushed pending ack for MessageCounter:205208534 on exchange 38601i
    [1692345409.393416][79269:79271] CHIP:EM: >>> [E:38602i S:26238 M:235959110 (Ack:42085121)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345409.393506][79269:79271] CHIP:EM: Found matching exchange: 38602i, Delegate: 0xffffac00a4f8
    [1692345409.393577][79269:79271] CHIP:EM: Rxd Ack; Removing MessageCounter:42085121 from Retrans Table on exchange 38602i
    [1692345409.393647][79269:79271] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345409.393740][79269:79271] CHIP:DMG: InvokeResponseMessage =
    [1692345409.393789][79269:79271] CHIP:DMG: {
    [1692345409.393836][79269:79271] CHIP:DMG:      suppressResponse = false,
    [1692345409.393886][79269:79271] CHIP:DMG:      InvokeResponseIBs =
    [1692345409.393950][79269:79271] CHIP:DMG:      [
    [1692345409.393999][79269:79271] CHIP:DMG:              InvokeResponseIB =
    [1692345409.394066][79269:79271] CHIP:DMG:              {
    [1692345409.394168][79269:79271] CHIP:DMG:                      CommandDataIB =
    [1692345409.394236][79269:79271] CHIP:DMG:                      {
    [1692345409.394293][79269:79271] CHIP:DMG:                              CommandPathIB =
    [1692345409.394357][79269:79271] CHIP:DMG:                              {
    [1692345409.394423][79269:79271] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345409.394494][79269:79271] CHIP:DMG:                                      ClusterId = 0x31,
    [1692345409.394563][79269:79271] CHIP:DMG:                                      CommandId = 0x5,
    [1692345409.394629][79269:79271] CHIP:DMG:                              },
    [1692345409.394696][79269:79271] CHIP:DMG:
    [1692345409.394755][79269:79271] CHIP:DMG:                              CommandFields =
    [1692345409.394819][79269:79271] CHIP:DMG:                              {
    [1692345409.394932][79269:79271] CHIP:DMG:                                      0x0 = 0,
    [1692345409.395003][79269:79271] CHIP:DMG:                                      0x2 = 0,
    [1692345409.395072][79269:79271] CHIP:DMG:                              },
    [1692345409.395132][79269:79271] CHIP:DMG:                      },
    [1692345409.395200][79269:79271] CHIP:DMG:
    [1692345409.395251][79269:79271] CHIP:DMG:              },
    [1692345409.395314][79269:79271] CHIP:DMG:
    [1692345409.395361][79269:79271] CHIP:DMG:      ],
    [1692345409.395423][79269:79271] CHIP:DMG:
    [1692345409.395471][79269:79271] CHIP:DMG:      InteractionModelRevision = 1
    [1692345409.395519][79269:79271] CHIP:DMG: },
    [1692345409.395640][79269:79271] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1692345409.395729][79269:79271] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Command 0x0000_0005
    [1692345409.395864][79269:79271] CHIP:TOO:   NetworkConfigResponse: {
    [1692345409.395931][79269:79271] CHIP:TOO:     networkingStatus: 0
    [1692345409.395979][79269:79271] CHIP:TOO:     networkIndex: 0
    [1692345409.396020][79269:79271] CHIP:TOO:    }
    [1692345409.396099][79269:79271] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345409.396303][79269:79271] CHIP:EM: <<< [E:38602i S:26238 M:42085122 (Ack:235959110)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345409.396383][79269:79271] CHIP:IN: (S) Sending msg 42085122 on secure session with LSID: 26238
    [1692345409.396617][79269:79271] CHIP:EM: Flushed pending ack for MessageCounter:235959110 on exchange 38602i
    [1692345409.396975][79269:79269] CHIP:CTL: Shutting down the commissioner
    [1692345409.397045][79269:79269] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345409.397096][79269:79269] CHIP:CTL: Shutting down the controller
    [1692345409.397143][79269:79269] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345409.397186][79269:79269] CHIP:IN: SecureSession[0xffffac00d360]: MarkForEviction Type:2 LSID:26238
    [1692345409.397231][79269:79269] CHIP:SC: SecureSession[0xffffac00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345409.397278][79269:79269] CHIP:IN: SecureSession[0xffffac00d360]: Released - Type:2 LSID:26238
    [1692345409.397329][79269:79269] CHIP:FP: Forgetting fabric 0x1
    [1692345409.397388][79269:79269] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345409.397769][79269:79269] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345409.397825][79269:79269] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345409.397905][79269:79269] CHIP:CTL: Shutting down the commissioner
    [1692345409.397953][79269:79269] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345409.398000][79269:79269] CHIP:CTL: Shutting down the controller
    [1692345409.398040][79269:79269] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345409.400088][79269:79269] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345409.400268][79269:79269] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345409.400373][79269:79269] CHIP:FP: Shutting down FabricTable
    [1692345409.400445][79269:79269] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345409.400753][79269:79269] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345409.400802][79269:79269] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345409.401196][79269:79269] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-bl48nV)
    [1692345409.402220][79269:79269] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345409.402386][79269:79269] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345409.402422][79269:79269] CHIP:DL: Inet Layer shutdown
    [1692345409.402447][79269:79269] CHIP:DL: BLE shutdown
    [1692345409.402474][79269:79269] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool generalcommissioning commissioning-complete 1 0
    [1692345422.247741][79272:79272] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345422.253123][79272:79272] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345422.253386][79272:79272] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345422.253490][79272:79272] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345422.253822][79272:79272] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-WETqej)
    [1692345422.254455][79272:79272] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345422.254510][79272:79272] CHIP:DL: NVS set: chip-counters/reboot-count = 32 (0x20)
    [1692345422.255402][79272:79272] CHIP:DL: Got Ethernet interface: eth0
    [1692345422.255984][79272:79272] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345422.256560][79272:79272] CHIP:DL: Got WiFi interface: wlan0
    [1692345422.256623][79272:79272] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345422.256674][79272:79272] CHIP:IN: UDP::Init bind&listen port=0
    [1692345422.256780][79272:79272] CHIP:IN: UDP::Init bound to port=33929
    [1692345422.256800][79272:79272] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345422.256817][79272:79272] CHIP:IN: TransportMgr initialized
    [1692345422.256848][79272:79272] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345422.257143][79272:79272] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345422.258708][79272:79272] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345422.259181][79272:79272] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345422.261799][79272:79272] CHIP:ZCL: Using ZAP configuration...
    [1692345422.265322][79272:79272] CHIP:DL: Avahi client registered
    [1692345422.266415][79272:79272] CHIP:CTL: System State Initialized...
    [1692345422.266530][79272:79272] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345422.266582][79272:79272] CHIP:CTL: Setting attestation nonce to random value
    [1692345422.266614][79272:79272] CHIP:CTL: Setting CSR nonce to random value
    [1692345422.266895][79272:79274] CHIP:DL: CHIP task running
    [1692345422.267079][79272:79274] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345422.267372][79272:79274] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345422.267414][79272:79274] CHIP:CTL: Setting attestation nonce to random value
    [1692345422.267575][79272:79274] CHIP:CTL: Setting CSR nonce to random value
    [1692345422.268425][79272:79274] CHIP:CTL: Generating NOC
    [1692345422.269587][79272:79274] CHIP:FP: Validating NOC chain
    [1692345422.271560][79272:79274] CHIP:FP: NOC chain validation successful
    [1692345422.271735][79272:79274] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345422.271769][79272:79274] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345422.271791][79272:79274] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345422.271824][79272:79274] CHIP:TS: Retaining current Last Known Good Time
    [1692345422.286440][79272:79274] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345422.289047][79272:79274] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345422.291429][79272:79274] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345422.310659][79272:79274] CHIP:TOO: Sending command to node 0x1
    [1692345422.311116][79272:79274] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345422.311150][79272:79274] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345422.311186][79272:79274] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345422.311216][79272:79274] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345422.312934][79272:79274] CHIP:DL: Avahi resolve found
    [1692345422.313010][79272:79274] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345422.313032][79272:79274] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345422.313058][79272:79274] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345422.313080][79272:79274] CHIP:DIS:      Port: 5540
    [1692345422.313100][79272:79274] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345422.313120][79272:79274] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345422.313140][79272:79274] CHIP:DIS:      TCP Supported: 0
    [1692345422.313921][79272:79274] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345422.314023][79272:79274] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345422.314047][79272:79274] CHIP:DIS: Checking node lookup status after 2 ms
    [1692345422.314066][79272:79274] CHIP:DIS: Keeping DNSSD lookup active
    [1692345422.511478][79272:79274] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345422.511606][79272:79274] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345422.511664][79272:79274] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345422.511892][79272:79274] CHIP:IN: SecureSession[0xffff8c00d360]: Allocated Type:2 LSID:55098
    [1692345422.511987][79272:79274] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345422.514176][79272:79274] CHIP:EM: <<< [E:34700i S:0 M:140992240] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345422.514309][79272:79274] CHIP:IN: (U) Sending msg 140992240 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345422.514649][79272:79274] CHIP:SC: Sent Sigma1 msg
    [1692345422.514729][79272:79274] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345423.610663][79272:79274] CHIP:EM: >>> [E:34700i S:0 M:205208535 (Ack:140992240)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345423.610746][79272:79274] CHIP:EM: Found matching exchange: 34700i, Delegate: 0xffff8c00f408
    [1692345423.610812][79272:79274] CHIP:EM: Rxd Ack; Removing MessageCounter:140992240 from Retrans Table on exchange 34700i
    [1692345423.887429][79272:79274] CHIP:EM: >>> [E:34700i S:0 M:205208536 (Ack:140992240)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345423.887525][79272:79274] CHIP:EM: Found matching exchange: 34700i, Delegate: 0xffff8c00f408
    [1692345423.887580][79272:79274] CHIP:EM: CHIP MessageCounter:140992240 not in RetransTable on exchange 34700i
    [1692345423.887670][79272:79274] CHIP:SC: Received Sigma2 msg
    [1692345423.887754][79272:79274] CHIP:SC: Peer assigned session session ID 19083
    [1692345423.892176][79272:79274] CHIP:SC: Found MRP parameters in the message
    [1692345423.892248][79272:79274] CHIP:SC: Sending Sigma3
    [1692345423.892950][79272:79274] CHIP:EM: <<< [E:34700i S:0 M:140992241 (Ack:205208536)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345423.893130][79272:79274] CHIP:IN: (U) Sending msg 140992241 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345423.893352][79272:79274] CHIP:SC: Sent Sigma3 msg
    [1692345424.344338][79272:79274] CHIP:EM: >>> [E:34700i S:0 M:205208537 (Ack:140992241)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345424.344427][79272:79274] CHIP:EM: Found matching exchange: 34700i, Delegate: 0xffff8c00f408
    [1692345424.344500][79272:79274] CHIP:EM: Rxd Ack; Removing MessageCounter:140992241 from Retrans Table on exchange 34700i
    [1692345424.537747][79272:79274] CHIP:EM: >>> [E:34700i S:0 M:205208538 (Ack:140992241)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345424.537849][79272:79274] CHIP:EM: Found matching exchange: 34700i, Delegate: 0xffff8c00f408
    [1692345424.537911][79272:79274] CHIP:EM: CHIP MessageCounter:140992241 not in RetransTable on exchange 34700i
    [1692345424.538015][79272:79274] CHIP:SC: Success status report received. Session was established
    [1692345424.547009][79272:79274] CHIP:SC: SecureSession[0xffff8c00d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345424.547093][79272:79274] CHIP:IN: SecureSession[0xffff8c00d360]: Activated - Type:2 LSID:55098
    [1692345424.547132][79272:79274] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:55098 PSID:19083!
    [1692345424.547181][79272:79274] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345424.547271][79272:79274] CHIP:TOO: Sending cluster (0x00000030) command (0x00000004) on endpoint 0
    [1692345424.547405][79272:79274] CHIP:DMG: ICR moving to [AddingComm]
    [1692345424.547477][79272:79274] CHIP:DMG: ICR moving to [AddedComma]
    [1692345424.547677][79272:79274] CHIP:EM: <<< [E:34701i S:55098 M:172674412] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345424.547756][79272:79274] CHIP:IN: (S) Sending msg 172674412 on secure session with LSID: 55098
    [1692345424.548053][79272:79274] CHIP:DMG: ICR moving to [CommandSen]
    [1692345424.548188][79272:79274] CHIP:EM: <<< [E:34700i S:0 M:140992242 (Ack:205208538)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345424.548417][79272:79274] CHIP:IN: (U) Sending msg 140992242 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345424.548597][79272:79274] CHIP:EM: Flushed pending ack for MessageCounter:205208538 on exchange 34700i
    [1692345424.767122][79272:79274] CHIP:EM: >>> [E:34701i S:55098 M:100724986 (Ack:172674412)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345424.767203][79272:79274] CHIP:EM: Found matching exchange: 34701i, Delegate: 0xffff8c00a4f8
    [1692345424.767267][79272:79274] CHIP:EM: Rxd Ack; Removing MessageCounter:172674412 from Retrans Table on exchange 34701i
    [1692345424.767329][79272:79274] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345424.767411][79272:79274] CHIP:DMG: InvokeResponseMessage =
    [1692345424.767454][79272:79274] CHIP:DMG: {
    [1692345424.767495][79272:79274] CHIP:DMG:      suppressResponse = false,
    [1692345424.767539][79272:79274] CHIP:DMG:      InvokeResponseIBs =
    [1692345424.767595][79272:79274] CHIP:DMG:      [
    [1692345424.767638][79272:79274] CHIP:DMG:              InvokeResponseIB =
    [1692345424.767696][79272:79274] CHIP:DMG:              {
    [1692345424.767742][79272:79274] CHIP:DMG:                      CommandDataIB =
    [1692345424.767796][79272:79274] CHIP:DMG:                      {
    [1692345424.767845][79272:79274] CHIP:DMG:                              CommandPathIB =
    [1692345424.767901][79272:79274] CHIP:DMG:                              {
    [1692345424.767959][79272:79274] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345424.768021][79272:79274] CHIP:DMG:                                      ClusterId = 0x30,
    [1692345424.768081][79272:79274] CHIP:DMG:                                      CommandId = 0x5,
    [1692345424.768138][79272:79274] CHIP:DMG:                              },
    [1692345424.768198][79272:79274] CHIP:DMG:
    [1692345424.768249][79272:79274] CHIP:DMG:                              CommandFields =
    [1692345424.768305][79272:79274] CHIP:DMG:                              {
    [1692345424.768402][79272:79274] CHIP:DMG:                                      0x0 = 0,
    [1692345424.768468][79272:79274] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692345424.768529][79272:79274] CHIP:DMG:                              },
    [1692345424.768583][79272:79274] CHIP:DMG:                      },
    [1692345424.768642][79272:79274] CHIP:DMG:
    [1692345424.768688][79272:79274] CHIP:DMG:              },
    [1692345424.768743][79272:79274] CHIP:DMG:
    [1692345424.768785][79272:79274] CHIP:DMG:      ],
    [1692345424.768840][79272:79274] CHIP:DMG:
    [1692345424.768881][79272:79274] CHIP:DMG:      InteractionModelRevision = 1
    [1692345424.768922][79272:79274] CHIP:DMG: },
    [1692345424.769030][79272:79274] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0005
    [1692345424.769112][79272:79274] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Command 0x0000_0005
    [1692345424.769239][79272:79274] CHIP:TOO:   CommissioningCompleteResponse: {
    [1692345424.769315][79272:79274] CHIP:TOO:     errorCode: 0
    [1692345424.769358][79272:79274] CHIP:TOO:     debugText:
    [1692345424.769397][79272:79274] CHIP:TOO:    }
    [1692345424.769467][79272:79274] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345424.769639][79272:79274] CHIP:EM: <<< [E:34701i S:55098 M:172674413 (Ack:100724986)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345424.769711][79272:79274] CHIP:IN: (S) Sending msg 172674413 on secure session with LSID: 55098
    [1692345424.769922][79272:79274] CHIP:EM: Flushed pending ack for MessageCounter:100724986 on exchange 34701i
    [1692345424.770294][79272:79272] CHIP:CTL: Shutting down the commissioner
    [1692345424.770357][79272:79272] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345424.770397][79272:79272] CHIP:CTL: Shutting down the controller
    [1692345424.770440][79272:79272] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345424.770478][79272:79272] CHIP:IN: SecureSession[0xffff8c00d360]: MarkForEviction Type:2 LSID:55098
    [1692345424.770518][79272:79272] CHIP:SC: SecureSession[0xffff8c00d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345424.770558][79272:79272] CHIP:IN: SecureSession[0xffff8c00d360]: Released - Type:2 LSID:55098
    [1692345424.770605][79272:79272] CHIP:FP: Forgetting fabric 0x1
    [1692345424.770659][79272:79272] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345424.771005][79272:79272] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345424.771053][79272:79272] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345424.771126][79272:79272] CHIP:CTL: Shutting down the commissioner
    [1692345424.771168][79272:79272] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345424.771367][79272:79272] CHIP:CTL: Shutting down the controller
    [1692345424.771412][79272:79272] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345424.773088][79272:79272] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345424.773297][79272:79272] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345424.773395][79272:79272] CHIP:FP: Shutting down FabricTable
    [1692345424.773461][79272:79272] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345424.773739][79272:79272] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345424.773799][79272:79272] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345424.774224][79272:79272] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-xUvxo1)
    [1692345424.775273][79272:79272] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345424.775380][79272:79272] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345424.775425][79272:79272] CHIP:DL: Inet Layer shutdown
    [1692345424.775463][79272:79272] CHIP:DL: BLE shutdown
    [1692345424.775502][79272:79272] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$  ./chip-tool generalcommissioning arm-fail-safe 0 0 1 0
    [1692345437.925568][79277:79277] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345437.930950][79277:79277] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345437.931205][79277:79277] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345437.931310][79277:79277] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345437.931653][79277:79277] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-IBfUkX)
    [1692345437.932244][79277:79277] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345437.932299][79277:79277] CHIP:DL: NVS set: chip-counters/reboot-count = 33 (0x21)
    [1692345437.933188][79277:79277] CHIP:DL: Got Ethernet interface: eth0
    [1692345437.933762][79277:79277] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345437.934378][79277:79277] CHIP:DL: Got WiFi interface: wlan0
    [1692345437.934444][79277:79277] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345437.934496][79277:79277] CHIP:IN: UDP::Init bind&listen port=0
    [1692345437.934600][79277:79277] CHIP:IN: UDP::Init bound to port=47858
    [1692345437.934620][79277:79277] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345437.934637][79277:79277] CHIP:IN: TransportMgr initialized
    [1692345437.934669][79277:79277] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345437.934851][79277:79277] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345437.936375][79277:79277] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345437.936845][79277:79277] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345437.939401][79277:79277] CHIP:ZCL: Using ZAP configuration...
    [1692345437.943039][79277:79277] CHIP:DL: Avahi client registered
    [1692345437.944086][79277:79277] CHIP:CTL: System State Initialized...
    [1692345437.944207][79277:79277] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345437.944263][79277:79277] CHIP:CTL: Setting attestation nonce to random value
    [1692345437.944300][79277:79277] CHIP:CTL: Setting CSR nonce to random value
    [1692345437.944590][79277:79279] CHIP:DL: CHIP task running
    [1692345437.944846][79277:79279] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345437.945138][79277:79279] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345437.945182][79277:79279] CHIP:CTL: Setting attestation nonce to random value
    [1692345437.945342][79277:79279] CHIP:CTL: Setting CSR nonce to random value
    [1692345437.946239][79277:79279] CHIP:CTL: Generating NOC
    [1692345437.947267][79277:79279] CHIP:FP: Validating NOC chain
    [1692345437.949005][79277:79279] CHIP:FP: NOC chain validation successful
    [1692345437.949157][79277:79279] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345437.949187][79277:79279] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345437.949208][79277:79279] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345437.949227][79277:79279] CHIP:TS: Retaining current Last Known Good Time
    [1692345437.957772][79277:79279] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345437.962483][79277:79279] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345437.964823][79277:79279] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345437.984935][79277:79279] CHIP:TOO: Sending command to node 0x1
    [1692345437.985321][79277:79279] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345437.985353][79277:79279] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345437.985388][79277:79279] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345437.985417][79277:79279] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345437.987084][79277:79279] CHIP:DL: Avahi resolve found
    [1692345437.987157][79277:79279] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345437.987180][79277:79279] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345437.987207][79277:79279] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345437.987229][79277:79279] CHIP:DIS:      Port: 5540
    [1692345437.987249][79277:79279] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345437.987269][79277:79279] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345437.987289][79277:79279] CHIP:DIS:      TCP Supported: 0
    [1692345437.988106][79277:79279] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345437.988211][79277:79279] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345437.988236][79277:79279] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345437.988255][79277:79279] CHIP:DIS: Keeping DNSSD lookup active
    [1692345438.185715][79277:79279] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345438.185827][79277:79279] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345438.185878][79277:79279] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345438.186121][79277:79279] CHIP:IN: SecureSession[0xffffb000d360]: Allocated Type:2 LSID:523
    [1692345438.186205][79277:79279] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345438.188450][79277:79279] CHIP:EM: <<< [E:64310i S:0 M:169183880] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345438.188587][79277:79279] CHIP:IN: (U) Sending msg 169183880 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345438.188931][79277:79279] CHIP:SC: Sent Sigma1 msg
    [1692345438.189008][79277:79279] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345438.978172][79277:79279] CHIP:EM: >>> [E:64310i S:0 M:205208539 (Ack:169183880)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345438.978260][79277:79279] CHIP:EM: Found matching exchange: 64310i, Delegate: 0xffffb000f408
    [1692345438.978334][79277:79279] CHIP:EM: Rxd Ack; Removing MessageCounter:169183880 from Retrans Table on exchange 64310i
    [1692345439.262170][79277:79279] CHIP:EM: >>> [E:64310i S:0 M:205208540 (Ack:169183880)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345439.262257][79277:79279] CHIP:EM: Found matching exchange: 64310i, Delegate: 0xffffb000f408
    [1692345439.262310][79277:79279] CHIP:EM: CHIP MessageCounter:169183880 not in RetransTable on exchange 64310i
    [1692345439.262396][79277:79279] CHIP:SC: Received Sigma2 msg
    [1692345439.262467][79277:79279] CHIP:SC: Peer assigned session session ID 19084
    [1692345439.270442][79277:79279] CHIP:SC: Found MRP parameters in the message
    [1692345439.270550][79277:79279] CHIP:SC: Sending Sigma3
    [1692345439.271715][79277:79279] CHIP:EM: <<< [E:64310i S:0 M:169183881 (Ack:205208540)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345439.271981][79277:79279] CHIP:IN: (U) Sending msg 169183881 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345439.272302][79277:79279] CHIP:SC: Sent Sigma3 msg
    [1692345439.503637][79277:79279] CHIP:EM: >>> [E:64310i S:0 M:205208541 (Ack:169183881)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345439.503726][79277:79279] CHIP:EM: Found matching exchange: 64310i, Delegate: 0xffffb000f408
    [1692345439.503799][79277:79279] CHIP:EM: Rxd Ack; Removing MessageCounter:169183881 from Retrans Table on exchange 64310i
    [1692345439.693811][79277:79279] CHIP:EM: >>> [E:64310i S:0 M:205208542 (Ack:169183881)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345439.693879][79277:79279] CHIP:EM: Found matching exchange: 64310i, Delegate: 0xffffb000f408
    [1692345439.693916][79277:79279] CHIP:EM: CHIP MessageCounter:169183881 not in RetransTable on exchange 64310i
    [1692345439.693982][79277:79279] CHIP:SC: Success status report received. Session was established
    [1692345439.700749][79277:79279] CHIP:SC: SecureSession[0xffffb000d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345439.700800][79277:79279] CHIP:IN: SecureSession[0xffffb000d360]: Activated - Type:2 LSID:523
    [1692345439.700819][79277:79279] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:523 PSID:19084!
    [1692345439.700845][79277:79279] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345439.700895][79277:79279] CHIP:TOO: Sending cluster (0x00000030) command (0x00000000) on endpoint 0
    [1692345439.700980][79277:79279] CHIP:DMG: ICR moving to [AddingComm]
    [1692345439.701026][79277:79279] CHIP:DMG: ICR moving to [AddedComma]
    [1692345439.701157][79277:79279] CHIP:EM: <<< [E:64311i S:523 M:147765005] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1692345439.701196][79277:79279] CHIP:IN: (S) Sending msg 147765005 on secure session with LSID: 523
    [1692345439.701373][79277:79279] CHIP:DMG: ICR moving to [CommandSen]
    [1692345439.701446][79277:79279] CHIP:EM: <<< [E:64310i S:0 M:169183882 (Ack:205208542)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345439.701582][79277:79279] CHIP:IN: (U) Sending msg 169183882 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345439.701687][79277:79279] CHIP:EM: Flushed pending ack for MessageCounter:205208542 on exchange 64310i
    [1692345439.916205][79277:79279] CHIP:EM: >>> [E:64311i S:523 M:267004005 (Ack:147765005)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1692345439.916284][79277:79279] CHIP:EM: Found matching exchange: 64311i, Delegate: 0xffffb000a4f8
    [1692345439.916349][79277:79279] CHIP:EM: Rxd Ack; Removing MessageCounter:147765005 from Retrans Table on exchange 64311i
    [1692345439.916409][79277:79279] CHIP:DMG: ICR moving to [ResponseRe]
    [1692345439.916490][79277:79279] CHIP:DMG: InvokeResponseMessage =
    [1692345439.916533][79277:79279] CHIP:DMG: {
    [1692345439.916574][79277:79279] CHIP:DMG:      suppressResponse = false,
    [1692345439.916617][79277:79279] CHIP:DMG:      InvokeResponseIBs =
    [1692345439.916674][79277:79279] CHIP:DMG:      [
    [1692345439.916725][79277:79279] CHIP:DMG:              InvokeResponseIB =
    [1692345439.916803][79277:79279] CHIP:DMG:              {
    [1692345439.916856][79277:79279] CHIP:DMG:                      CommandDataIB =
    [1692345439.916916][79277:79279] CHIP:DMG:                      {
    [1692345439.916973][79277:79279] CHIP:DMG:                              CommandPathIB =
    [1692345439.917037][79277:79279] CHIP:DMG:                              {
    [1692345439.917103][79277:79279] CHIP:DMG:                                      EndpointId = 0x0,
    [1692345439.917173][79277:79279] CHIP:DMG:                                      ClusterId = 0x30,
    [1692345439.917242][79277:79279] CHIP:DMG:                                      CommandId = 0x1,
    [1692345439.917307][79277:79279] CHIP:DMG:                              },
    [1692345439.917375][79277:79279] CHIP:DMG:
    [1692345439.917434][79277:79279] CHIP:DMG:                              CommandFields =
    [1692345439.917498][79277:79279] CHIP:DMG:                              {
    [1692345439.917609][79277:79279] CHIP:DMG:                                      0x0 = 0,
    [1692345439.917684][79277:79279] CHIP:DMG:                                      0x1 = "" (0 chars),
    [1692345439.917754][79277:79279] CHIP:DMG:                              },
    [1692345439.917815][79277:79279] CHIP:DMG:                      },
    [1692345439.917883][79277:79279] CHIP:DMG:
    [1692345439.917934][79277:79279] CHIP:DMG:              },
    [1692345439.917997][79277:79279] CHIP:DMG:
    [1692345439.918045][79277:79279] CHIP:DMG:      ],
    [1692345439.918154][79277:79279] CHIP:DMG:
    [1692345439.918201][79277:79279] CHIP:DMG:      InteractionModelRevision = 1
    [1692345439.918249][79277:79279] CHIP:DMG: },
    [1692345439.918373][79277:79279] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1692345439.918464][79277:79279] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0030 Command 0x0000_0001
    [1692345439.918586][79277:79279] CHIP:TOO:   ArmFailSafeResponse: {
    [1692345439.918671][79277:79279] CHIP:TOO:     errorCode: 0
    [1692345439.918720][79277:79279] CHIP:TOO:     debugText:
    [1692345439.918765][79277:79279] CHIP:TOO:    }
    [1692345439.918844][79277:79279] CHIP:DMG: ICR moving to [AwaitingDe]
    [1692345439.919036][79277:79279] CHIP:EM: <<< [E:64311i S:523 M:147765006 (Ack:267004005)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345439.919116][79277:79279] CHIP:IN: (S) Sending msg 147765006 on secure session with LSID: 523
    [1692345439.919345][79277:79279] CHIP:EM: Flushed pending ack for MessageCounter:267004005 on exchange 64311i
    [1692345439.919692][79277:79277] CHIP:CTL: Shutting down the commissioner
    [1692345439.919761][79277:79277] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345439.919810][79277:79277] CHIP:CTL: Shutting down the controller
    [1692345439.919858][79277:79277] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345439.919901][79277:79277] CHIP:IN: SecureSession[0xffffb000d360]: MarkForEviction Type:2 LSID:523
    [1692345439.920042][79277:79277] CHIP:SC: SecureSession[0xffffb000d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345439.920093][79277:79277] CHIP:IN: SecureSession[0xffffb000d360]: Released - Type:2 LSID:523
    [1692345439.920144][79277:79277] CHIP:FP: Forgetting fabric 0x1
    [1692345439.920205][79277:79277] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345439.920657][79277:79277] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345439.920730][79277:79277] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345439.920863][79277:79277] CHIP:CTL: Shutting down the commissioner
    [1692345439.920912][79277:79277] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345439.920955][79277:79277] CHIP:CTL: Shutting down the controller
    [1692345439.920990][79277:79277] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345439.922779][79277:79277] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345439.923016][79277:79277] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345439.923116][79277:79277] CHIP:FP: Shutting down FabricTable
    [1692345439.923186][79277:79277] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345439.923501][79277:79277] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345439.923550][79277:79277] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345439.923941][79277:79277] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-YO68pK)
    [1692345439.925091][79277:79277] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345439.925210][79277:79277] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345439.925262][79277:79277] CHIP:DL: Inet Layer shutdown
    [1692345439.925304][79277:79277] CHIP:DL: BLE shutdown
    [1692345439.925348][79277:79277] CHIP:DL: System Layer shutdown
    ubuntu@ubuntu:~/apps$ ./chip-tool networkcommissioning read networks 1 0
    [1692345449.598740][79280:79280] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1692345449.604198][79280:79280] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1692345449.604451][79280:79280] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1692345449.604554][79280:79280] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1692345449.604891][79280:79280] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-S8YaVD)
    [1692345449.605476][79280:79280] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345449.605529][79280:79280] CHIP:DL: NVS set: chip-counters/reboot-count = 34 (0x22)
    [1692345449.606431][79280:79280] CHIP:DL: Got Ethernet interface: eth0
    [1692345449.607007][79280:79280] CHIP:DL: Found the primary Ethernet interface:eth0
    [1692345449.607594][79280:79280] CHIP:DL: Got WiFi interface: wlan0
    [1692345449.607672][79280:79280] CHIP:DL: Failed to reset WiFi statistic counts
    [1692345449.607725][79280:79280] CHIP:IN: UDP::Init bind&listen port=0
    [1692345449.607832][79280:79280] CHIP:IN: UDP::Init bound to port=48421
    [1692345449.607853][79280:79280] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1692345449.607870][79280:79280] CHIP:IN: TransportMgr initialized
    [1692345449.607902][79280:79280] CHIP:FP: Initializing FabricTable from persistent storage
    [1692345449.608086][79280:79280] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345449.609714][79280:79280] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x93DDC5FC5A52D558, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345449.610249][79280:79280] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x631E91F3A5E6CF02, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1692345449.615397][79280:79280] CHIP:ZCL: Using ZAP configuration...
    [1692345449.619246][79280:79280] CHIP:DL: Avahi client registered
    [1692345449.620256][79280:79280] CHIP:CTL: System State Initialized...
    [1692345449.620370][79280:79280] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345449.620422][79280:79280] CHIP:CTL: Setting attestation nonce to random value
    [1692345449.620455][79280:79280] CHIP:CTL: Setting CSR nonce to random value
    [1692345449.620732][79280:79282] CHIP:DL: CHIP task running
    [1692345449.620913][79280:79282] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1692345449.621182][79280:79282] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345449.621222][79280:79282] CHIP:CTL: Setting attestation nonce to random value
    [1692345449.621369][79280:79282] CHIP:CTL: Setting CSR nonce to random value
    [1692345449.622204][79280:79282] CHIP:CTL: Generating NOC
    [1692345449.623165][79280:79282] CHIP:FP: Validating NOC chain
    [1692345449.624779][79280:79282] CHIP:FP: NOC chain validation successful
    [1692345449.624999][79280:79282] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1692345449.625042][79280:79282] CHIP:TS: Last Known Good Time: 2023-04-11T06:55:26
    [1692345449.625073][79280:79282] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1692345449.625100][79280:79282] CHIP:TS: Retaining current Last Known Good Time
    [1692345449.634730][79280:79282] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1692345449.637502][79280:79282] CHIP:TS: Committing Last Known Good Time to storage: 2023-04-11T06:55:26
    [1692345449.640180][79280:79282] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 93DDC5FC5A52D558)
    [1692345449.659735][79280:79282] CHIP:TOO: Sending command to node 0x1
    [1692345449.660160][79280:79282] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1692345449.660193][79280:79282] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1692345449.660229][79280:79282] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1692345449.660259][79280:79282] CHIP:DIS: Resolving 93DDC5FC5A52D558:0000000000000001 ...
    [1692345449.661994][79280:79282] CHIP:DL: Avahi resolve found
    [1692345449.662065][79280:79282] CHIP:DIS: Node ID resolved for 93DDC5FC5A52D558:0000000000000001
    [1692345449.662121][79280:79282] CHIP:DIS:      Hostname: 865AF54F084C0AC7
    [1692345449.662147][79280:79282] CHIP:DIS:      IP Address #1: fd00:96e4:31b:1:cda4:f921:7ab1:9e4a
    [1692345449.662169][79280:79282] CHIP:DIS:      Port: 5540
    [1692345449.662188][79280:79282] CHIP:DIS:      Mrp Interval idle: 2800 ms
    [1692345449.662208][79280:79282] CHIP:DIS:      Mrp Interval active: 1000 ms
    [1692345449.662228][79280:79282] CHIP:DIS:      TCP Supported: 0
    [1692345449.663061][79280:79282] CHIP:DIS: Lookup clearing interface for non LL address
    [1692345449.663165][79280:79282] CHIP:DIS: UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%eth0]:5540: new best score: 6
    [1692345449.663189][79280:79282] CHIP:DIS: Checking node lookup status after 3 ms
    [1692345449.663208][79280:79282] CHIP:DIS: Keeping DNSSD lookup active
    [1692345449.860543][79280:79282] CHIP:DIS: Checking node lookup status after 200 ms
    [1692345449.860609][79280:79282] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540 while in state 2
    [1692345449.860629][79280:79282] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1692345449.860751][79280:79282] CHIP:IN: SecureSession[0xffff7400d360]: Allocated Type:2 LSID:22389
    [1692345449.860792][79280:79282] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1692345449.861687][79280:79282] CHIP:EM: <<< [E:56989i S:0 M:45259468] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1692345449.861752][79280:79282] CHIP:IN: (U) Sending msg 45259468 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a]:5540'
    [1692345449.861933][79280:79282] CHIP:SC: Sent Sigma1 msg
    [1692345449.861968][79280:79282] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1692345450.140949][79280:79282] CHIP:EM: >>> [E:56989i S:0 M:205208543 (Ack:45259468)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345450.141007][79280:79282] CHIP:EM: Found matching exchange: 56989i, Delegate: 0xffff7400f408
    [1692345450.141052][79280:79282] CHIP:EM: Rxd Ack; Removing MessageCounter:45259468 from Retrans Table on exchange 56989i
    [1692345450.416386][79280:79282] CHIP:EM: >>> [E:56989i S:0 M:205208544 (Ack:45259468)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1692345450.416489][79280:79282] CHIP:EM: Found matching exchange: 56989i, Delegate: 0xffff7400f408
    [1692345450.416551][79280:79282] CHIP:EM: CHIP MessageCounter:45259468 not in RetransTable on exchange 56989i
    [1692345450.416650][79280:79282] CHIP:SC: Received Sigma2 msg
    [1692345450.416732][79280:79282] CHIP:SC: Peer assigned session session ID 19085
    [1692345450.427170][79280:79282] CHIP:SC: Found MRP parameters in the message
    [1692345450.427299][79280:79282] CHIP:SC: Sending Sigma3
    [1692345450.428416][79280:79282] CHIP:EM: <<< [E:56989i S:0 M:45259469 (Ack:205208544)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1692345450.428598][79280:79282] CHIP:IN: (U) Sending msg 45259469 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345450.428816][79280:79282] CHIP:SC: Sent Sigma3 msg
    [1692345450.665553][79280:79282] CHIP:EM: >>> [E:56989i S:0 M:205208545 (Ack:45259469)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345450.665601][79280:79282] CHIP:EM: Found matching exchange: 56989i, Delegate: 0xffff7400f408
    [1692345450.665636][79280:79282] CHIP:EM: Rxd Ack; Removing MessageCounter:45259469 from Retrans Table on exchange 56989i
    [1692345450.859399][79280:79282] CHIP:EM: >>> [E:56989i S:0 M:205208546 (Ack:45259469)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1692345450.859486][79280:79282] CHIP:EM: Found matching exchange: 56989i, Delegate: 0xffff7400f408
    [1692345450.859539][79280:79282] CHIP:EM: CHIP MessageCounter:45259469 not in RetransTable on exchange 56989i
    [1692345450.859630][79280:79282] CHIP:SC: Success status report received. Session was established
    [1692345450.869898][79280:79282] CHIP:SC: SecureSession[0xffff7400d360]: Moving from state 'kEstablishing' --> 'kActive'
    [1692345450.869969][79280:79282] CHIP:IN: SecureSession[0xffff7400d360]: Activated - Type:2 LSID:22389
    [1692345450.870001][79280:79282] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:22389 PSID:19085!
    [1692345450.870042][79280:79282] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1692345450.870231][79280:79282] CHIP:TOO:      cluster 0x0000_0031, attribute: 0x0000_0001, endpoint 0
    [1692345450.870280][79280:79282] CHIP:TOO: Sending ReadAttribute to:
    [1692345450.870324][79280:79282] CHIP:DMG: SendReadRequest ReadClient[0xffff74011fb0]: Sending Read Request
    [1692345450.870534][79280:79282] CHIP:EM: <<< [E:56990i S:22389 M:163824312] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0001:02 (IM:ReadRequest)
    [1692345450.870596][79280:79282] CHIP:IN: (S) Sending msg 163824312 on secure session with LSID: 22389
    [1692345450.870851][79280:79282] CHIP:DMG: MoveToState ReadClient[0xffff74011fb0]: Moving to [AwaitingIn]
    [1692345450.870975][79280:79282] CHIP:EM: <<< [E:56989i S:0 M:45259470 (Ack:205208546)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345450.871171][79280:79282] CHIP:IN: (U) Sending msg 45259470 to IP address 'UDP:[fd00:96e4:31b:1:cda4:f921:7ab1:9e4a%wpan0]:5540'
    [1692345450.871325][79280:79282] CHIP:EM: Flushed pending ack for MessageCounter:205208546 on exchange 56989i
    [1692345451.078959][79280:79282] CHIP:EM: >>> [E:56990i S:22389 M:95661761 (Ack:163824312)] (S) Msg RX from 1:0000000000000001 [D558] --- Type 0001:05 (IM:ReportData)
    [1692345451.079054][79280:79282] CHIP:EM: Found matching exchange: 56990i, Delegate: 0xffff74011fc0
    [1692345451.079140][79280:79282] CHIP:EM: Rxd Ack; Removing MessageCounter:163824312 from Retrans Table on exchange 56990i
    [1692345451.079257][79280:79282] CHIP:DMG: ReportDataMessage =
    [1692345451.079315][79280:79282] CHIP:DMG: {
    [1692345451.079360][79280:79282] CHIP:DMG:      AttributeReportIBs =
    [1692345451.079427][79280:79282] CHIP:DMG:      [
    [1692345451.079477][79280:79282] CHIP:DMG:              AttributeReportIB =
    [1692345451.079546][79280:79282] CHIP:DMG:              {
    [1692345451.079600][79280:79282] CHIP:DMG:                      AttributeDataIB =
    [1692345451.079668][79280:79282] CHIP:DMG:                      {
    [1692345451.079729][79280:79282] CHIP:DMG:                              DataVersion = 0xc46e5d01,
    [1692345451.079791][79280:79282] CHIP:DMG:                              AttributePathIB =
    [1692345451.079866][79280:79282] CHIP:DMG:                              {
    [1692345451.079940][79280:79282] CHIP:DMG:                                      Endpoint = 0x0,
    [1692345451.080026][79280:79282] CHIP:DMG:                                      Cluster = 0x31,
    [1692345451.080111][79280:79282] CHIP:DMG:                                      Attribute = 0x0000_0001,
    [1692345451.080191][79280:79282] CHIP:DMG:                              }
    [1692345451.080263][79280:79282] CHIP:DMG:
    [1692345451.080327][79280:79282] CHIP:DMG:                              Data = [
    [1692345451.080392][79280:79282] CHIP:DMG:
    [1692345451.080461][79280:79282] CHIP:DMG:                              ],
    [1692345451.080523][79280:79282] CHIP:DMG:                      },
    [1692345451.080591][79280:79282] CHIP:DMG:
    [1692345451.080643][79280:79282] CHIP:DMG:              },
    [1692345451.080705][79280:79282] CHIP:DMG:
    [1692345451.080753][79280:79282] CHIP:DMG:      ],
    [1692345451.080815][79280:79282] CHIP:DMG:
    [1692345451.080865][79280:79282] CHIP:DMG:      SuppressResponse = true,
    [1692345451.080917][79280:79282] CHIP:DMG:      InteractionModelRevision = 1
    [1692345451.080965][79280:79282] CHIP:DMG: }
    [1692345451.081279][79280:79282] CHIP:TOO: Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0001 DataVersion: 3295567105
    [1692345451.081420][79280:79282] CHIP:TOO:   Networks: 0 entries
    [1692345451.081695][79280:79282] CHIP:EM: <<< [E:56990i S:22389 M:163824313 (Ack:95661761)] (S) Msg TX to 1:0000000000000001 [D558] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1692345451.081778][79280:79282] CHIP:IN: (S) Sending msg 163824313 on secure session with LSID: 22389
    [1692345451.082011][79280:79282] CHIP:EM: Flushed pending ack for MessageCounter:95661761 on exchange 56990i
    [1692345451.082490][79280:79280] CHIP:CTL: Shutting down the commissioner
    [1692345451.082560][79280:79280] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345451.082610][79280:79280] CHIP:CTL: Shutting down the controller
    [1692345451.082658][79280:79280] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1692345451.082702][79280:79280] CHIP:IN: SecureSession[0xffff7400d360]: MarkForEviction Type:2 LSID:22389
    [1692345451.082749][79280:79280] CHIP:SC: SecureSession[0xffff7400d360]: Moving from state 'kActive' --> 'kPendingEviction'
    [1692345451.082794][79280:79280] CHIP:IN: SecureSession[0xffff7400d360]: Released - Type:2 LSID:22389
    [1692345451.082845][79280:79280] CHIP:FP: Forgetting fabric 0x1
    [1692345451.082904][79280:79280] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345451.083346][79280:79280] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345451.083495][79280:79280] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345451.083631][79280:79280] CHIP:CTL: Shutting down the commissioner
    [1692345451.083685][79280:79280] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1692345451.083734][79280:79280] CHIP:CTL: Shutting down the controller
    [1692345451.083776][79280:79280] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1692345451.085468][79280:79280] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1692345451.085641][79280:79280] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1692345451.085741][79280:79280] CHIP:FP: Shutting down FabricTable
    [1692345451.085801][79280:79280] CHIP:TS: Pending Last Known Good Time: 2023-04-11T06:55:26
    [1692345451.086340][79280:79280] CHIP:TS: Previous Last Known Good Time: 2023-04-11T06:55:26
    [1692345451.086403][79280:79280] CHIP:TS: Reverted Last Known Good Time to previous value
    [1692345451.086781][79280:79280] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-dvhdA8)
    [1692345451.087912][79280:79280] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1692345451.088026][79280:79280] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1692345451.088079][79280:79280] CHIP:DL: Inet Layer shutdown
    [1692345451.088122][79280:79280] CHIP:DL: BLE shutdown
    [1692345451.088167][79280:79280] CHIP:DL: System Layer shutdown
  • Additional explanation:
    If I enable CONFIG_LOG, the test item will pass once instead of requiring two times. If I disable it, the situation described above will occur.
  • Hi Jerry,
    Thanks for reporting this issue.
    I will try to repeat it and feedback to you later.
    Charlie
  • Thanks! By the way ,my CHIP version used tag:SVE_23_03/rc2,and my device type is windowcovering.
  • Hi Jerry,
    What is the version of the NCS sample you are using?
    Matter Window covering sample acts as  SSED Thread device. If you see the issue of communication with SSED and use the latest version of NCS, I recommend you try to update to the corresponding newer OTBR which will better work with the SSED. Here you can find it:
    Please execute the same test using the recommended version of OTBR (based on a specific NCS version your sample is based on).
    Charlie
