keep Settings Data and existing bonds during OTA update - nRF Connect SDK
SoC: nrf52840
Environment: nRF Connect SDK v2.4.1
When performing OTA app upgrade all settings and bonds are gone.
Settings subsystem seems to be working fine. Settings are corrently loaded at startup and data is preserved during MCU reboot. Data is also preserved when flashing app via SWD.
Is there any configuration that I am missing, which can preserve at least Settings during OTA?
prj.conf:
# Settings
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
#MCUMGR
CONFIG_MCUMGR=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_SECURE_BOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
code:
settings_subsys_init();
settings_load();
Simon
    Please provide the partitions.yml in the build folder or the pm_static.yml if you are using static partitions. Please provide the file for both the old project and the new project that you are updating to.
    I suspect that the partition was changed and somehow overlapping the setting partition.
    Do you change anything that may change the partition allocation ?
    How do you receive the image ? Did you use the smp_svr ?
    here is partitions.yml content. I don't use static one. Content of the partitions.yml is the same between the builds. There is basically no difference between the "old" and the "new" project as I am testing update proces just between the builds.
    EMPTY_0:
      address: 0x15200
      end_address: 0x16000
      placement:
        before:
        - s1_pad
      region: flash_primary
    EMPTY_1:
      address: 0x22200
      end_address: 0x23000
      placement:
        before:
        - mcuboot_pad
    EMPTY_2:
      address: 0xfd000
      end_address: 0xfe000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0x23200
      end_address: 0x90000
    app_image:
      address: 0x23200
      orig_span: &id001
      - app
      span: *id001
    b0:
      address: 0x0
      end_address: 0x8000
      placement:
        after:
        - start
    b0_container:
      address: 0x0
      end_address: 0x9000
      orig_span: &id002
      - b0
      - provision
      span: *id002
    mcuboot:
      address: 0x9200
      end_address: 0x15200
      placement:
        before:
        - mcuboot_primary
      sharers: 0x1
    mcuboot_pad:
      address: 0x23000
      end_address: 0x23200
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
      sharers: 0x2
    mcuboot_primary:
      address: 0x23000
      orig_span: &id003
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id003
    mcuboot_primary_app:
      address: 0x23200
      orig_span: &id004
      - app
      span: *id004
    mcuboot_secondary:
      address: 0x90000
      end_address: 0xfd000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
      share_size:
      - mcuboot_primary
    provision:
      address: 0x8000
      end_address: 0x9000
      placement:
        after:
        - b0
        align:
          start: 0x1000
    s0:
      address: 0x9000
      orig_span: &id005
      - s0_pad
      - mcuboot
      span: *id005
    s0_image:
      address: 0x9200
      orig_span: &id006
      - mcuboot
      span: *id006
    s0_pad:
      address: 0x9000
      end_address: 0x9200
      placement:
        after:
        - b0_container
        align:
          start: 0x1000
      share_size:
      - mcuboot_pad
    s1:
      address: 0x16000
      end_address: 0x22200
      orig_span: &id007
      - s1_pad
      - s1_image
      span: *id007
    s1_image:
      address: 0x16200
      placement:
        after:
        - s1_pad
        - s0
      share_size:
      - mcuboot
    s1_pad:
      address: 0x16000
      end_address: 0x16200
      placement:
        after:
        - s0
        align:
          start: 0x1000
      share_size:
      - mcuboot_pad
    settings_storage:
      address: 0xfe000
      end_address: 0x100000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    This is hard to answer. I might changed something unintentionaly.
    Image is generated with default build task, generated by nRF Connect vscode plugin.
    For OTA update I used "app_update.bin" file from build/zephyr/ directory.
    I am using mcumgr SMP:
    #include <zephyr/mgmt/mcumgr/transport/smp_bt.h>
        smp_bt_register();
    # sleep/shutdown
    smp_bt_unregister();
    Maybe it's worth mentioning that I also tried to enable Direct XIP without success. I get similar issue as described here:
    https://devzone.nordicsemi.com/f/nordic-q-a/102186/partition-manager-error-w-direct-xip-and-mcuboot-enabled
  • Hi Simon,
    If you have an identical partitions.yml then the partition may not be the culprit here.
    I suspect that there could be change in the setting module that may change the layout of the setting data. Causing the data mismatch.
    Have you tried to read the setting flash area out before the settings_subsys_init() is called in the new firmware (maybe putting an infinite loop there, then read flash using nrfjprog.exe --memrd or nrfjprog --readcode). You would need to read flash at address 0xfe000.
    You may want to compare the flash before and after DFU update to see if the setting area is overwritten or not. If the content doesn't change, then it must be something changed in the settings layout causing it not able to read the bond information.
    I saved settings area before upgrade and then added hardcoded asm breakpoint instruction at the beggining of int main(void). With this image I made DFU update and read the same settings area after the update. It seems that DFU erased "settings_storage" section completely.
  • Hi Simon,
    I think I know why that happens.
    Are you using nRF Device Manager for updating ?
    There is an option which is enabled by default that erase the application settings:
    If you click on the small arrow button in Firmware Upgrade , you will find the option to not to Erase application settings.
    In nRF Connect app this setting is hidden in Settings/Mcu Manager options/Erase application settings
    Could you please disable it and try again?
