Current consumption in nrf52833, sdk version 2.9.0 , not able to use : pm_state_force(0u, &(struct pm_state_info){PM_STATE_SUSPEND_TO_IDLE, 0, 0});
I am getting an error of  "undefined reference to `pm_state_force" .
Also, the output files, config file is not showing the command :  CONFIG_PM=y
prj.conf file has :
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
    Can you try these configs
    CONFIG_PM_DEVICE=y
    CONFIG_GPIO=y
    CONFIG_CRC=y
    CONFIG_POWEROFF=y
    CONFIG_HWINFO=y
    in your pr.con file?
  • Hello Kazi,
    I tried these configs. But Im getting the same error. Also, some reference to this case showed me that the function -pm_state_force(0, &(struct pm_state_info){.state = PM_STATE_SOFT_OFF,.substate_id = 0});      is not supported in versions after v2.5.0. If so, then how must I achieve a normal sleep and a deep sleep condition in nrf52833 ?
    ''I tried these configs. But Im getting the same error. Also, some reference to this case showed me that the function -pm_state_force(0, &(struct pm_state_info){.state = PM_STATE_SOFT_OFF,.substate_id = 0});  You are correct. pm_state_force() fucntion and CONFIG_PM are not supported on latest NCS version after v2.5.0. The error "undefined reference to pm_state_force" and the inability to set CONFIG_PM=y are due to changes in Zephyr and NCS.
    For system On idle, you do not need to call any special function for the CPU to enter sleep; simply using k_msleep() is sufficient for normal low-power operation in System ON mode. The system will wake up on any interrupt (timer, GPIO, etc.)
    For example:
    #include <zephyr/kernel.h>
    #define SLEEP_TIME_MS	1
    #define SW0_NODE DT_ALIAS(sw0)
    static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET(SW0_NODE, gpios);
    static struct gpio_callback button_cb_data;
    void button_pressed(const struct device *dev, struct gpio_callback *cb, uint32_t pins)
        printk("Button pressed! System woke up from sleep.\n");
    void main(void)
        int ret;
        if (!gpio_is_ready_dt(&button)) {
            return;
        ret = gpio_pin_configure_dt(&button, GPIO_INPUT | GPIO_PULL_UP);
        if (ret < 0) {
            return;
        ret = gpio_pin_interrupt_configure_dt(&button, GPIO_INT_EDGE_TO_ACTIVE);
        if (ret < 0) {
            return;
    /*/*These lines are used to register a callback function (button_pressed) that will be called
    	 when a GPIO interrupt occurs on the specified pin. This means that when the button is
    	 pressed (or released, depending on your interrupt configuration),
    	 the button_pressed function will be executed*/
        gpio_init_callback(&button_cb_data, button_pressed, BIT(button.pin));
        gpio_add_callback(button.port, &button_cb_data);
        printk("System will sleep. Press the button to wake up.\n");
        while (1) {
            k_msleep(1000); // System will enter idle if nothing else is running
    • For system off, you need to use sys_poweroff() function to enter System OFF mode (deepest sleep).
      • Before calling sys_poweroff(), configure your wakeup sources (e.g., set up a GPIO pin with sense for wakeup).
      • After entering System OFF, the device can only be woken up by a reset or a configured wakeup source.
      // Configure wakeup pin (example for a button)
      nrf_gpio_cfg_input(WAKEUP_PIN, NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_sense_set(WAKEUP_PIN, NRF_GPIO_PIN_SENSE_LOW);
      // Enter System OFF
      sys_poweroff();
    Thankyou very much, I also wanted to know about how to use RTC for sys_poweroff(); , as our custom board does not have a gpio switch for interrupt. We will have to move forward with RTC generated wakeup.
    So, I went through the system_off sample code, where i tried to use the function :
    z_nrf_grtc_wakeup_prepare(DEEP_SLEEP_TIME_S * USEC_PER_SEC);
    But , I Got the error of undefined reference.
    After reading through several forums, I got an information that this function is not supported in nrf52 modules, it is supported in nrf54 modules . Is this so?
    If Yes, what functions or configurations should I use to get an RTC based deep sleep integration?
  • Hello Kazi,
    Is there any update on the sys_poweroff() function usability with RTC.
