Shared
Enabling Crypto Hardware backend feature on nRF52840
I am using nRF52840, SDK_16.0.0, S140 SoftDevice and Segger 4.16 for flashing the image. I am using ‘ble_app_blinky’.
I have queries on enabling HW crpto accelerator and back end mode.
1) If I want to enable HW crypto accelerator then do I need to enable NRF_CRYPTO_BACKEND_CC310_ENABLED or already taken care by NRF_CRYPTO_BACKEND_CC310_BL_ENABLED ?
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Flib_crypto_config.html
2) If I enable NRF_CRYPTO_BACKEND_CC310_ENABLED, whether there is no need of micro-ecc and can I disable NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED ?
a) Even whether there is no need to compile and include micro_ecc_lib_nrf52.a if HW crypto accelerator is enabled.
Whether my above assumptions are correct ?
3) If I want to enable backend crypto, then whether do I need to disable NRF_CRYPTO_ENABLED.
a) As per below statement for frontend still needs backend functionality. But if I want backend functionality, still do I need front end by enabling NRF_CRYPTO_ENABLED.
“Keep in mind that at least one of the nrf_crypto backends is required to use the API functions”
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Flib_crypto_config.html&anchor=lib_crypto_config_automatic_defines_usage
4) Whether all above macros changes to be enabled only in "Secure BLE bootloader" or even at application (Ex: ble_app_blinky).
5) What is the difference between “pca10056_s140_ble_debug” and “pca10056_s140_ble” (With and without _debug).
6) What is the difference between cryptography library with backend and frontend
a) (Is backend mean crypto runs in hardware and frontend mean crypto runs is in software. Then in that case what is “software backend” and “hardware backend”. Bit confusion about the terminology.
Thanks & Regards
Vishnu Beema
