commissioning issues with light bulb sample (nrfconnect V3.3.0)
With nrfconnect SDK V3.3.0 seeing commissioning issues with light bulb sample with nrf52840dk and google home. The logs are given below. Please help with resolution
Mahesh
uart:~$ *** Booting My Application v3.3.0-ba167d9f3db4 ***
*** Using nRF Connect SDK v3.3.0-ba167d9f3db4 ***
*** Using Zephyr OS v4.3.99-fd9204a02d52 ***
I: 64 [DL]BLE address: F7:1A:9D:CD:46:F8
I: 74 [DL]CHIP task running
I: Init CHIP stack
I: 79 [DL]OpenThread started: OK
I: 82 [DL]Setting OpenThread device type to ROUTER
I: 87 [DL]Found DAC Private Key in factory data set. Copying to secure storage...
D: Registered new test event: 0xffffffff00000000
D: Registered new test event: 0xffffffff10000000
I: 118 [SVR]Initializing subscription resumption storage...
I: 134 [SVR]Server initializing...
I: 137 [TS]Last Known Good Time: [unknown]
I: 141 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48
I: 160 [DMG]AccessControl: initializing
I: 164 [DMG]Examples::AccessControlDelegate::Init
I: 168 [DMG]AccessControl: setting
I: 171 [DMG]DefaultAclStorage: initializing
I: 175 [DMG]DefaultAclStorage: 0 entries loaded
D: 179 [IN]UDP::Init bind&listen port=5540
D: 183 [IN]UDP::Init bound to port=5540
D: 187 [IN]BLEBase::Init - setting/overriding transport
D: 192 [IN]TransportMgr initialized
D: 217 [DL]Using Thread extended MAC for hostname.
I: 234 [ZCL]Using ZAP configuration...
D: 239 [DL]Boot reason: 6
I: 243 [ZCL]Endpoint 1 On/off already set to new value
I: 251 [DMG]AccessControlCluster: initializing
D: 256 [IN]SecureSession[0x20013468]: Allocated Type:1 LSID:21078
D: 262 [DL]CHIPoBLE advertising set to on
I: 266 [DIS]Updating services using commissioning mode 1
E: 271 [DIS]Failed to remove advertised services: 3
D: 275 [DL]Using Thread extended MAC for hostname.
D: 280 [DIS]DNS-SD Pairing Instruction not set
I: 284 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 cp=0 jf=0
E: 294 [DIS]Failed to advertise commissionable node: 3
E: 299 [DIS]Failed to finalize service update: 3
I: 303 [DIS]Updating services using commissioning mode 1
E: 308 [DIS]Failed to remove advertised services: 3
D: 313 [DL]Using Thread extended MAC for hostname.
D: 317 [DIS]DNS-SD Pairing Instruction not set
I: 321 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 cp=0 jf=0
E: 331 [DIS]Failed to advertise commissionable node: 3
E: 336 [DIS]Failed to finalize service update: 3
I: 340 [IN]CASE Server enabling CASE session setups
D: 345 [IN]SecureSession[0x20013540]: Allocated Type:2 LSID:21079
I: 351 [SVR]Server Listening...
I: 354 [DL]Device Configuration:
I: 357 [DL] Serial Number: 11223344556677889900
I: 361 [DL] Vendor Id: 65521 (0xFFF1)
I: 365 [DL] Product Id: 32773 (0x8005)
I: 368 [DL] Product Name: Matter Light Bulb
I: 372 [DL] Hardware Version: 0
I: 375 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 380 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 387 [DL] Manufacturing Date: 2022-01-01
I: 391 [DL] Device Type: 65535 (0xFFFF)
I: 394 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 399 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 405 [SVR]project-chip.github.io/.../qrcode.html
I: 414 [SVR]Manual pairing code: [34970112332]
E: 418 [DL]Long dispatch time: 342 ms, for event type 2
I: 425 [DL]CHIPoBLE advertising started
I: 429 [DL]NFC Tag emulation started
I: 30428 [DL]CHIPoBLE advertising mode changed to slow
I: 30435 [DL]CHIPoBLE advertising started
I: 90825 [DL]Current number of connections: 1/1
I: 90830 [DL]BLE connection established (ConnId: 0x00)
I: 90835 [DL]CHIPoBLE advertising stopped
I: 90838 [DL]NFC Tag emulation stopped
D: 91689 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 91696 [BLE]local and remote recv window sizes = 5
I: 91701 [BLE]selected BTP version 4
I: 91705 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 91712 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 91716 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 91724 [IN]BLE EndPoint 0x2001dd14 Connection Complete
I: 91729 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 91794 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 91885 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 91892 [EM]>>> [E:15021r S:0 M:204189502] (U) Msg RX from 0:42448B12FFF0778C [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
I: 91907 [EM]<<< [E:15021r S:0 M:199243272] (U) Msg TX from 0000000000000000 to 0:42448B12FFF0778C [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
D: 91923 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 159)
I: 91931 [SVR]Commissioning session establishment step started
D: 91974 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 91982 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 91990 [EM]>>> [E:15021r S:0 M:204189503] (U) Msg RX from 0:42448B12FFF0778C [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
I: 92132 [EM]<<< [E:15021r S:0 M:199243273] (U) Msg TX from 0000000000000000 to 0:42448B12FFF0778C [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
D: 92147 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
E: 92155 [DL]Long dispatch time: 173 ms, for event type 16388
D: 92244 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92252 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92260 [EM]>>> [E:15021r S:0 M:204189504] (U) Msg RX from 0:42448B12FFF0778C [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
I: 92274 [EM]<<< [E:15021r S:0 M:199243274] (U) Msg TX from 0000000000000000 to 0:42448B12FFF0778C [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
D: 92289 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 92298 [SC]SecureSession[0x20013468, LSID:21078]: State change 'kEstablishing' --> 'kActive'
D: 92306 [IN]SecureSession[0x20013468]: Activated - Type:1 LSID:21078
D: 92313 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:21078 PSID:64765!
I: 92321 [SVR]Commissioning completed session establishment step
I: 92327 [DIS]Updating services using commissioning mode 0
E: 92332 [DIS]Failed to remove advertised services: 3
E: 92337 [DIS]Failed to finalize service update: 3
D: 92342 [DL]CHIPoBLE advertising set to off
I: 92346 [SVR]Device completed Rendezvous process
D: 92379 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92387 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92395 [EM]>>> [E:15022r S:21078 M:250416044] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 92408 [IM]Received Read request
I: 92416 [EM]<<< [E:15022r S:21078 M:83365295] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:94)
D: 92429 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 99)
D: 92514 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92522 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92530 [EM]>>> [E:15023r S:21078 M:250416045] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
D: 92543 [IM]Received Read request
I: 92550 [EM]<<< [E:15023r S:21078 M:83365296] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 92564 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 92649 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92657 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92665 [EM]>>> [E:15024r S:21078 M:250416046] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 92678 [IM]Received Read request
I: 92685 [EM]<<< [E:15024r S:21078 M:83365297] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 92699 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 92784 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92792 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92800 [EM]>>> [E:15025r S:21078 M:250416047] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 92813 [IM]Received Read request
I: 92820 [EM]<<< [E:15025r S:21078 M:83365298] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 92834 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 92919 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 92927 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 92935 [EM]>>> [E:15026r S:21078 M:250416048] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 92948 [IM]Received Read request
I: 92955 [EM]<<< [E:15026r S:21078 M:83365299] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 92969 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 93054 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93062 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 93070 [EM]>>> [E:15027r S:21078 M:250416049] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 93083 [IM]Received Read request
I: 93090 [EM]<<< [E:15027r S:21078 M:83365300] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 93104 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 93189 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93197 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 93205 [EM]>>> [E:15028r S:21078 M:250416050] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 93218 [IM]Received Read request
I: 93225 [EM]<<< [E:15028r S:21078 M:83365301] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 93239 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 93324 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93332 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 93340 [EM]>>> [E:15029r S:21078 M:250416051] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 93355 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 93364 [EM]<<< [E:15029r S:21078 M:83365302] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:556)
D: 93379 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 93504 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93512 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 93594 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93602 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77)
D: 93684 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93692 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 93700 [EM]>>> [E:15030r S:21078 M:250416052] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 93713 [IM]Received Read request
I: 93721 [EM]<<< [E:15030r S:21078 M:83365303] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:94)
D: 93734 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 99)
D: 93819 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 93827 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 93835 [EM]>>> [E:15031r S:21078 M:250416053] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
D: 93848 [IM]Received Read request
I: 93855 [EM]<<< [E:15031r S:21078 M:83365304] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 93869 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 93954 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 96474 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 98981 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 99039 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 101559 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 104066 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 104124 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 106644 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 109151 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 109209 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 111729 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 114236 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 114293 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116814 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 119064 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119072 [EM]>>> [E:15032r S:21078 M:250416054] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 119086 [EM]<<< [E:15032r S:21078 M:83365305] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 119100 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 119153 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119162 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119170 [EM]>>> [E:15032r S:21078 M:250416055] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 119185 [FS]GeneralCommissioning: Received ArmFailSafe (120s)
I: 119192 [EM]<<< [E:15032r S:21078 M:83365306] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 119207 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 119288 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119297 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119305 [EM]>>> [E:15033r S:21078 M:250416056] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 119318 [IM]Received Read request
I: 119325 [EM]<<< [E:15033r S:21078 M:83365307] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 119338 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 119423 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119432 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119440 [EM]>>> [E:15034r S:21078 M:250416057] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 119454 [EM]<<< [E:15034r S:21078 M:83365308] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 119468 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 119558 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119567 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119575 [EM]>>> [E:15034r S:21078 M:250416058] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
I: 119623 [EM]<<< [E:15034r S:21078 M:83365309] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 119638 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 119693 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119702 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119710 [EM]>>> [E:15035r S:21078 M:250416059] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 119725 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 119734 [EM]<<< [E:15035r S:21078 M:83365310] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
D: 119749 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 119828 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119836 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 119918 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119926 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 120008 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 120055 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 120063 [EM]>>> [E:15036r S:21078 M:250416060] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
I: 120078 [ZCL]OpCreds: Received an AttestationRequest command
I: 120115 [ZCL]OpCreds: AttestationRequest successful.
I: 120123 [EM]<<< [E:15036r S:21078 M:83365311] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:716)
D: 120138 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 120233 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 120241 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 120323 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 120331 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 237)
D: 120413 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 120422 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 120430 [EM]>>> [E:15037r S:21078 M:250416061] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:96)
I: 120445 [ZCL]OpCreds: Received a CSRRequest command
I: 120506 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 120542 [ZCL]OpCreds: CSRRequest successful.
I: 120549 [EM]<<< [E:15037r S:21078 M:83365312] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:393)
D: 120564 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
E: 120572 [DL]Long dispatch time: 150 ms, for event type 16388
D: 120683 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 120691 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 156)
D: 120773 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 121811 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 121900 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 121909 [EM]>>> [E:15038r S:21078 M:250416062] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:367)
I: 121924 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 121989 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 121995 [EM]<<< [E:15038r S:21078 M:83365313] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:63)
D: 122010 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
E: 122018 [DL]Long dispatch time: 118 ms, for event type 16388
D: 122078 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122087 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 122171 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 122261 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 122349 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 122356 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
I: 122367 [EM]>>> [E:15039r S:21078 M:250416063] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:727)
I: 122382 [ZCL]OpCreds: Received an AddNOC command
I: 122389 [FP]Validating NOC chain
I: 122510 [FP]NOC chain validation successful
I: 122514 [FP]Added new fabric at index: 0x1
I: 122518 [FP]Assigned compressed fabric ID: 0x2DB644C9709A0F68, node ID: 0x00000000C5B85182
I: 122526 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 122531 [TS]New proposed Last Known Good Time: 2026-05-03T13:02:52
I: 122538 [TS]Updating pending Last Known Good Time to 2026-05-03T13:02:52
I: 122608 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD00010001
D: 122617 [DL]Using Thread extended MAC for hostname.
I: 122622 [DIS]Advertise operational node 2DB644C9709A0F68-00000000C5B85182
E: 122629 [SVR]Operational advertising failed: 3
I: 122633 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 122641 [EM]<<< [E:15039r S:21078 M:83365314] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [0F68] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
E: 122655 [DL]Long dispatch time: 306 ms, for event type 16388
D: 122661 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122669 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 122753 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122762 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 122771 [EM]>>> [E:15040r S:21078 M:250416064] (S) Msg RX from 1:FFFFFFFB00000000 [0F68] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:169)
I: 122809 [EM]<<< [E:15040r S:21078 M:83365315] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [0F68] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 122824 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 122933 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122942 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 122950 [EM]>>> [E:15041r S:21078 M:250416065] (S) Msg RX from 1:FFFFFFFB00000000 [0F68] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 122963 [IM]Received Read request
I: 122970 [EM]<<< [E:15041r S:21078 M:83365316] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [0F68] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 122984 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 123068 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 123077 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 123085 [EM]>>> [E:15042r S:21078 M:250416066] (S) Msg RX from 1:FFFFFFFB00000000 [0F68] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73)
E: 123189 [DL]Long dispatch time: 112 ms, for event type 16388
D: 123195 [DL]OpenThread State Changed (Flags: 0x101fc110)
D: 123200 [DL] Network Name: NEST-PAN-F1DB
D: 123205 [DL] PAN Id: 0xF1DB
D: 123207 [DL] Extended PAN Id: 0x10DDC2F5E438C68A
D: 123212 [DL] Channel: 23
D: 123215 [DL] Mesh Prefix: fd77:6ab4:f0a8:0:0:0:0:0/64
D: 123221 [DL]OpenThread State Changed (Flags: 0x1100100d)
D: 123227 [DL] Device Role: DETACHED
D: 123230 [DL] Thread Unicast Addresses:
D: 123234 [DL] fd77:6ab4:f0a8:0:70f9:5eb4:669f:3ae0/64 valid preferred
D: 123241 [DL] fe80:0:0:0:38a3:9895:1471:8a47/64 valid preferred
D: 125584 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 125678 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 128199 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 130238 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
D: 130245 [DL]OpenThread State Changed (Flags: 0x100012a5)
D: 130250 [DL] Device Role: LEADER
D: 130253 [DL] Partition Id: 0x2FEAB95A
D: 130257 [DL] Thread Unicast Addresses:
D: 130261 [DL] fd77:6ab4:f0a8:0:0:ff:fe00:fc00/64 valid preferred
D: 130268 [DL] fd77:6ab4:f0a8:0:0:ff:fe00:2800/64 valid preferred rloc
D: 130275 [DL] fd77:6ab4:f0a8:0:70f9:5eb4:669f:3ae0/64 valid preferred
D: 130282 [DL] fe80:0:0:0:38a3:9895:1471:8a47/64 valid preferred
D: 130289 [DL]Thread Attached updating Multicast address
I: 130294 [SVR]Joining Multicast groups
I: 130299 [EM]<<< [E:15042r S:21078 M:83365317] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [0F68] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65)
D: 130314 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 130322 [DL]Using Thread extended MAC for hostname.
I: 130327 [DIS]Advertise operational node 2DB644C9709A0F68-00000000C5B85182
E: 130334 [SVR]Operational advertising failed: 3
D: 130403 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
I: 131438 [DL]Current number of connections: 0/1
I: 131443 [DL]BLE GAP connection terminated (reason 0x13)
E: 145322 [BLE]ack recv timeout, closing ep 0x2001dd14
D: 145327 [IN]Clearing BLE pending packets.
I: 145331 [BLE]Releasing end point's BLE connection back to application.
I: 145338 [DL]Closing BLE GATT connection (ConnId 00)
    Could you do the following
    • Factory reset the light (Matter factory reset / wipe fabrics as per sample docs).
    • In Google Home, remove the failed device entry if it exists, then pair again.
    And make sure that the boarder router/Hub are on the same Thread network before retrying.
    Let me know if this changes anything.
    Andreas
