Hi everybody,
I'm developing an product with :
NRF52840, V0.9.0, SDK15
In the DK I connected LIS3DH (accelerometer by TWI)
all works.I configuration of HZ and temperature.
even I can read the sensor. (the twi_handler works fine)
but I included a code of NFC wake up (power on, sleep)
and when the NFC wake up the MCU, I what to read again the accelerometer.
in this moment the TWI RX or TX doesnt call the twi_handler. and the program stuck in while (m_xfer_done == false);
I have tested disable Twi before to WFE, and enable it when wake up,... but it doesnt work..
Could you give me some ideas about what happen?
thanks
Ricardo
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
m_xfer_done = true;
static void read_sensor_Vibrometer() // *********************** LECTURA DE SENSOR VIBRACION *********************
ret_code_t err_code;
m_xfer_done = false;
// ****** send a request accelerometer values ****
uint8_t reg[1] = {LIS3DH_GET_ACC};
err_code = nrf_drv_twi_tx(&m_twi, LIS3DH_WRITE, reg, sizeof(reg), false);
// ****** read the values ****
err_code = nrf_drv_twi_rx(&m_twi, LIS3DH_READ, recepcion, 6); // ret_code_t err_code;
