Hi. I have the following code, I am attempting to read AIN0 on pin 4 (P0.02).
I am watching the result whilst debugging the application on DK52, and it is a random value fluctuating at about 0x336c even when I GND pin 4, i.e. reading should be 0x0000.
How do I set pin 4 as an analog input?? It must be setup incorrectly at the moment so is always floating.
The adc_measure is being called every second within an LED event handler.
Thanks
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0); uint32_t seconds = 0; int16_t result = 0; void adc_measure(void) { // Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy NRF_CLOCK->TASKS_HFCLKSTART = 1; while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0); NRF_CLOCK->EVENTS_HFCLKSTARTED = 0; // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain. NRF_SAADC->CH[0].CONFIG = (SAADC_CH_PSELN_PSELN_AnalogInput0 << SAADC_CH_CONFIG_BURST_Pos) | (SAADC_CH_CONFIG_GAIN_Gain1_6 << SAADC_CH_CONFIG_GAIN_Pos) | (SAADC_CH_CONFIG_MODE_SE << SAADC_CH_CONFIG_MODE_Pos) | (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) | (SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos) | (SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos) | (SAADC_CH_CONFIG_TACQ_3us << SAADC_CH_CONFIG_TACQ_Pos); // Configure the SAADC channel with VDD as positive input, no negative input(single ended). NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos; NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos; // Configure the SAADC resolution. NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos; // Configure result to be put in RAM at the location of "result" variable. NRF_SAADC->RESULT.MAXCNT = 1; NRF_SAADC->RESULT.PTR = (uint32_t)&result; // No automatic sampling, will trigger with TASKS_SAMPLE. NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos; // Enable SAADC (would capture analog pins if they were used in CH[0].PSELP) NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos; // Calibrate the SAADC (only needs to be done once in a while) NRF_SAADC->TASKS_CALIBRATEOFFSET = 1; while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0); NRF_SAADC->EVENTS_CALIBRATEDONE = 0; while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos)); // Start the SAADC and wait for the started event. NRF_SAADC->TASKS_START = 1; while (NRF_SAADC->EVENTS_STARTED == 0); NRF_SAADC->EVENTS_STARTED = 0; // Do a SAADC sample, will put the result in the configured RAM buffer. NRF_SAADC->TASKS_SAMPLE = 1; while (NRF_SAADC->EVENTS_END == 0); NRF_SAADC->EVENTS_END = 0; // Stop the SAADC, since it's not used anymore. NRF_SAADC->TASKS_STOP = 1; while (NRF_SAADC->EVENTS_STOPPED == 0); NRF_SAADC->EVENTS_STOPPED = 0; } /** * @brief Handler for timer events. */ void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context) { nrf_gpio_pin_toggle(17); seconds++; if(seconds == 60) seconds = 0; if(seconds == 0) nrf_gpio_pin_clear(18); else nrf_gpio_pin_set(18); // nrf_gpio_cfg_sense_input( //nrf_gpio_pin_set(4); adc_measure(); // bsp_board_led_invert(1); // static uint32_t i; // uint32_t led_to_invert = ((i++) % LEDS_NUMBER); // switch (event_type) // { // case NRF_TIMER_EVENT_COMPARE0: // bsp_board_led_invert(led_to_invert); // break; // default: //Do nothing. // break; // } }
