I am using the mesh SDK 2.1.1 and have one node that uses the serial API. That node sends mesh packets to the network via the PacketSend serial opcode. This command uses an indirect address via an address handle that I must 1st have to register via the AddPublicationAdd command.
In my scenario I may have to potentially have to send to packets to any address < 0x7FF as well as the group address. What is the reason for using handles to an address? In my use case I potentially have to add and remove address handles quite often as the buffer to store the handles is finite.
I plan on adding a new serial command to take an address directly to work around the current interface but was curious if there was another way I could directly specify the address without having to modify the stack. I have been trying to minimize patches to the mesh stack to make upgrades to future version easier.
