How to set Transmit Power of my Advertisement Packet in nRF Connect SDK 2.5.1
I want to set the transmitting power of the advertising packet. How can I set the TX power?
I am using nRF Connect SDK 2.5.1 in Visual Studio Code.
Sri
  • Hi
    You can change the TX power with the following Kconfigs  CONFIG_BT_CTLR_TX_PWR_xx or  CONFIG_BT_CTLR_TX_PWR_ANTENNA.
    Regards
    Runar
  • Hi, I have used the CONFIG_BT_CTLR_TX_PWR_xx for power setting. I have done a current consumption test to confirm the change in output power. I found a peculiar result for negative power settings, there are multiple current consumption peaks. For each advertisement taking different current.
    My Observations:
    Tx Power Tx - Peak Tx - Avg Idle
    8dBm 28.62mA 15.65mA 776uA
    4dBm 19.59mA 12.38mA 774uA
    0dBm 13.71mA 8.2mA 774uA
    -4dBm 14.61mA 6.91mA 774uA 8.48mA 6.55mA Multiple amplitude peaks - unknown reason
    -8dBm 14.47mA 6.53mA 774uA 8.36mA 6mA Multiple amplitude peaks - unknown reason
    -12dBm
    Skipped
    -16dBm
    -20dBm 14.75mA 5.48mA 774uA 9.31mA 4.92mA Multiple amplitude peaks - unknown reason
    So is this the expected behavior or is there a issue?
    I want to reduce my Tx Current consumption. I  read that if I enable DC/DC it will reduce the current. How do I enable it?
    I also want to put my device to sleep after stopping advertisement and in between advertisement to save power. How do it do that?
    TIA
    Sri
  • Hi Sri
    You can see here what I expect in terms of current draw when using the radio. Overall the idle current is way to high so i expect you don't have things down when not transmitting.
    Have you followed the setup from here when you measured your power? Could you also post your application?
    Regards
    Runar
  • I have custom board. So cant follow the setup from the reference but followed the setup given in PPK user guide. I want to change the Power from LDO to DCDC mode. Can you help me with that? How should I configure the code?
    I am using the below code from nRF Academy
     * Copyright (c) 2023 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    /* STEP 3 - Include the header file of the Bluetooth LE stack */
    #include <zephyr/bluetooth/gap.h>
    #include <dk_buttons_and_leds.h>
    LOG_MODULE_REGISTER(Lesson2_Exercise1, LOG_LEVEL_INF);
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
    #define RUN_STATUS_LED DK_LED1
    #define RUN_LED_BLINK_INTERVAL 1000
    /* STEP 4.1.1 - Declare the advertising packet */
    static const struct bt_data ad[] = {
    	/* STEP 4.1.2 - Set the advertising flags */
    	BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
    	/* STEP 4.1.3 - Set the advertising packet data  */
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    /* STEP 4.2.2 - Declare the URL data to include in the scan response */
    static unsigned char url_data[] = { 0x17, '/', '/', 'a', 'c', 'a', 'd', 'e', 'm',
    				    'y',  '.', 'n', 'o', 'r', 'd', 'i', 'c', 's',
    				    'e',  'm', 'i', '.', 'c', 'o', 'm' };
    /* STEP 4.2.1 - Declare the scan response packet */
    static const struct bt_data sd[] = {
    	/* 4.2.3 Include the URL data in the scan response packet */
    	BT_DATA(BT_DATA_URI, url_data, sizeof(url_data)),
    	int blink_status = 0;
    	int err;
    	LOG_INF("Starting Lesson 2 - Exercise 1 \n");
    	err = dk_leds_init();
    	if (err) {
    		LOG_ERR("LEDs init failed (err %d)\n", err);
    		return -1;
    	/* STEP 5 - Enable the Bluetooth LE stack */
    	err = bt_enable(NULL);
    	if (err) {
    		LOG_ERR("Bluetooth init failed (err %d)\n", err);
    		return -1;
    	LOG_INF("Bluetooth initialized\n");
    	/* STEP 6 - Start advertising */
    	err = bt_le_adv_start(BT_LE_ADV_NCONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)\n", err);
    		return -1;
    	LOG_INF("Advertising successfully started\n");
    	for (;;) {
    		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    How can I put my nRF52833 in "ION_RAMOFF_EVENT" or "ION_RAMOFF_RTC". I need it to sleep for 5 mins and wake up
  • Using the DCDC should be as easy as using the Kconfig option CONFIG_SOC_DCDC_NRF52X=y
    What is the usecase for your application? I would recommend reading Einars reply https://devzone.nordicsemi.com/f/nordic-q-a/99280/sleep-modes-system-on-example-for-nrf52833-with-nrf-connect-sdk-2-3-0?ReplySortBy=CreatedDate&ReplySortOrder=Ascending regarding power modes
    Regards
    Runar
