Matter over Thread Commissioning failed
I want to test Matter over Thread, with 'light bulb' example and Border Router and controller In the same device.
To do this I need to configure CHIP, but the configuration failed.
Environment:
- PCA10056 with light bulb
- PCA10059 with radio co-proccesor
- Linux virtual machine (using VirtualBox Oracle) in a Windows 11 PC, to run Docker and CHIP.
Test steps:
  1. Run light bulb in PCA10056 and radio co-processor In PCA10059
  2. Running OTBR using Docker, following: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/protocols/thread/tools.html#id10
  3. Build Matter, https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/matter/BUILDING.html
    git clone --recurse-submodules [email protected]:project-chip/connectedhomeip.git
    git submodule update --init
    sudo apt-get install git gcc g++ pkg-config libssl-dev libdbus-1-dev \
    libglib2.0-dev libavahi-client-dev ninja-build python3-venv python3-dev \
    python3-pip unzip libgirepository1.0-dev libcairo2-dev libreadline-dev
    sudo apt-get install libsdl2-dev
    source scripts/activate.sh
    gn gen out/hostninja -C out/host
    ninja -C out/host check
    ./scripts/examples/gn_build_example.sh examples/chip-tool BUILD_PATH./chip-tool
  4.   Using CHIP Tool for Matter device testing, following the steps in https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/matter/chip_tool_guide.html
./chip-tool pairing ble-thread 1 hex: <HEX GENERATED> 20202021 3840
/chip-tool onoff toggle 1 1
But the commissioning failed:
[1685017302.407046][7164:7164] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1685017302.408518][7164:7164] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1685017302.408608][7164:7164] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1685017302.408621][7164:7164] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1685017302.408734][7164:7164] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-wC3EQR)
[1685017302.408958][7164:7164] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1685017302.408976][7164:7164] CHIP:DL: NVS set: chip-counters/reboot-count = 10 (0xA)
[1685017302.409574][7164:7164] CHIP:DL: Got Ethernet interface: enp0s8
[1685017302.409830][7164:7164] CHIP:DL: Found the primary Ethernet interface:enp0s8
[1685017302.410741][7164:7164] CHIP:DL: Failed to get WiFi interface
[1685017302.410749][7164:7164] CHIP:DL: Failed to reset WiFi statistic counts
[1685017302.410773][7164:7164] CHIP:IN: UDP::Init bind&listen port=0
[1685017302.410789][7164:7164] CHIP:IN: UDP::Init bound to port=54312
[1685017302.410793][7164:7164] CHIP:IN: UDP::Init bind&listen port=0
[1685017302.410803][7164:7164] CHIP:IN: UDP::Init bound to port=58876
[1685017302.410807][7164:7164] CHIP:IN: BLEBase::Init - setting/overriding transport
[1685017302.410811][7164:7164] CHIP:IN: TransportMgr initialized
[1685017302.410834][7164:7164] CHIP:FP: Initializing FabricTable from persistent storage
[1685017302.410877][7164:7164] CHIP:TS: Last Known Good Time: 2023-05-25T11:03:16
[1685017302.411231][7164:7164] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x466BD5809740C9A4, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1685017302.418134][7164:7164] CHIP:ZCL: Using ZAP configuration...
[1685017302.420776][7164:7164] CHIP:CTL: System State Initialized...
[1685017302.420855][7164:7164] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1685017302.420902][7164:7164] CHIP:CTL: Setting attestation nonce to random value
[1685017302.420935][7164:7164] CHIP:CTL: Setting CSR nonce to random value
[1685017302.420960][7164:7164] CHIP:IN: UDP::Init bind&listen port=5550
[1685017302.420984][7164:7164] CHIP:IN: UDP::Init bound to port=5550
[1685017302.420999][7164:7164] CHIP:IN: UDP::Init bind&listen port=5550
[1685017302.421021][7164:7164] CHIP:IN: UDP::Init bound to port=5550
[1685017302.421036][7164:7164] CHIP:IN: TransportMgr initialized
[1685017302.421358][7164:7166] CHIP:DL: CHIP task running
[1685017302.421461][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1685017302.421577][7164:7166] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1685017302.421652][7164:7166] CHIP:CTL: Setting attestation nonce to random value
[1685017302.421691][7164:7166] CHIP:CTL: Setting CSR nonce to random value
[1685017302.422007][7164:7166] CHIP:CTL: Generating NOC
[1685017302.422252][7164:7166] CHIP:FP: Validating NOC chain
[1685017302.422546][7164:7166] CHIP:FP: NOC chain validation successful
[1685017302.422617][7164:7166] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1685017302.422625][7164:7166] CHIP:TS: Last Known Good Time: 2023-05-25T11:03:16
[1685017302.422629][7164:7166] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1685017302.422633][7164:7166] CHIP:TS: Retaining current Last Known Good Time
[1685017302.423523][7164:7166] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1685017302.425626][7164:7166] CHIP:TS: Committing Last Known Good Time to storage: 2023-05-25T11:03:16
[1685017302.426678][7164:7166] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 466BD5809740C9A4)
[1685017302.426716][7164:7166] CHIP:IN: UDP::Init bind&listen port=5550
[1685017302.426730][7164:7166] CHIP:IN: UDP::Init bound to port=5550
[1685017302.426732][7164:7166] CHIP:IN: UDP::Init bind&listen port=5550
[1685017302.426738][7164:7166] CHIP:IN: UDP::Init bound to port=5550
[1685017302.426739][7164:7166] CHIP:IN: TransportMgr initialized
[1685017302.431445][7164:7166] CHIP:CTL: Setting thread operational dataset from parameters
[1685017302.431559][7164:7166] CHIP:CTL: Setting attestation nonce to random value
[1685017302.431568][7164:7166] CHIP:CTL: Setting CSR nonce to random value
[1685017302.431571][7164:7166] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1685017302.433957][7164:7165] CHIP:DL: TRACE: Bus acquired for name C-1bfc
[1685017302.436276][7164:7166] CHIP:DL: PlatformBlueZInit init success
[1685017302.438096][7164:7165] CHIP:BLE: BLE removing known devices.
[1685017302.440852][7164:7165] CHIP:BLE: BLE initiating scan.
[1685017302.569612][7164:7165] CHIP:BLE: Device 71:89:01:DF:D4:0F does not look like a CHIP device.
[1685017302.569797][7164:7165] CHIP:BLE: Device 49:90:D7:F0:BF:AF does not look like a CHIP device.
[1685017302.569930][7164:7165] CHIP:BLE: Device 61:FB:36:A9:E4:8B does not look like a CHIP device.
[1685017302.603234][7164:7165] CHIP:BLE: Device DA:C7:D8:31:75:72 does not look like a CHIP device.
[1685017302.768769][7164:7165] CHIP:BLE: Device 46:BC:14:42:F8:9C does not look like a CHIP device.
[1685017302.909510][7164:7165] CHIP:BLE: Device F8:04:2E:BF:12:6F does not look like a CHIP device.
[1685017302.909682][7164:7165] CHIP:BLE: Device 31:98:21:A2:32:FE does not look like a CHIP device.
[1685017303.046906][7164:7165] CHIP:BLE: Device 06:23:7C:C9:86:E4 does not look like a CHIP device.
[1685017303.072700][7164:7165] CHIP:BLE: Device 5C:88:E7:CC:A1:23 does not look like a CHIP device.
[1685017303.072979][7164:7165] CHIP:BLE: Device 6D:56:CB:65:1F:BB does not look like a CHIP device.
[1685017303.103993][7164:7165] CHIP:BLE: Device 71:89:01:DF:D4:0F does not look like a CHIP device.
[1685017303.165368][7164:7165] CHIP:BLE: Device 47:96:20:DB:E4:DA does not look like a CHIP device.
[1685017303.165602][7164:7165] CHIP:BLE: Device 17:54:E4:00:B8:4A does not look like a CHIP device.
[1685017303.194150][7164:7165] CHIP:BLE: Device C0:97:27:4E:83:C3 does not look like a CHIP device.
[1685017303.194377][7164:7165] CHIP:BLE: Device F4:FE:FB:75:E4:0D does not look like a CHIP device.
[1685017303.389456][7164:7165] CHIP:BLE: Device A8:B1:3B:3F:69:16 does not look like a CHIP device.
[1685017303.389770][7164:7165] CHIP:BLE: Device 7C:1C:4E:8A:6F:79 does not look like a CHIP device.
[1685017303.389929][7164:7165] CHIP:BLE: Device 40:24:B2:29:7B:55 does not look like a CHIP device.
[1685017303.447756][7164:7165] CHIP:BLE: Device 47:26:BA:38:28:12 does not look like a CHIP device.
[1685017303.542549][7164:7165] CHIP:BLE: Device A0:9E:1A:1C:06:5B does not look like a CHIP device.
[1685017303.542668][7164:7165] CHIP:BLE: Device 5C:88:E7:CC:A1:23 does not look like a CHIP device.
[1685017303.570851][7164:7165] CHIP:BLE: Device F8:04:2E:BF:12:6F does not look like a CHIP device.
[1685017303.624924][7164:7165] CHIP:BLE: Device 49:90:D7:F0:BF:AF does not look like a CHIP device.
[1685017303.626276][7164:7165] CHIP:BLE: Device 70:09:71:AB:3C:FD does not look like a CHIP device.
[1685017303.626440][7164:7165] CHIP:BLE: Device 54:5D:D9:75:63:0B does not look like a CHIP device.
[1685017303.626570][7164:7165] CHIP:BLE: Device 4C:F0:DC:80:76:A2 does not look like a CHIP device.
[1685017303.694486][7164:7165] CHIP:BLE: Device A8:B1:3B:3F:69:16 does not look like a CHIP device.
[1685017303.694850][7164:7165] CHIP:BLE: Device F8:04:2E:BF:12:6F does not look like a CHIP device.
[1685017303.695269][7164:7165] CHIP:BLE: Device 1D:CE:55:AE:22:02 does not look like a CHIP device.
[1685017303.789196][7164:7165] CHIP:BLE: Device 4D:DB:70:50:F4:A3 does not look like a CHIP device.
[1685017303.814071][7164:7165] CHIP:BLE: New device scanned: FA:FE:EA:D2:27:71
[1685017303.814206][7164:7165] CHIP:BLE: Device discriminator match. Attempting to connect.
[1685017306.193297][7164:7165] CHIP:DL: ConnectDevice complete
[1685017307.304886][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304944][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304949][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304950][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304951][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304952][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304955][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304956][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304958][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304959][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304961][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304962][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304963][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304964][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304967][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304968][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304969][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304971][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304972][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0001
[1685017307.304973][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304975][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304976][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304978][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304979][7164:7165] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_FE_EA_D2_27_71/service0010
[1685017307.304982][7164:7165] CHIP:DL: New BLE connection 0x7fccb40710e0, device FA:FE:EA:D2:27:71, path /org/bluez/hci0/dev_FA_FE_EA_D2_27_71
[1685017307.305094][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1685017307.305139][7164:7166] CHIP:DIS: Closing all BLE connections
[1685017307.305155][7164:7166] CHIP:IN: BleConnectionComplete: endPoint 0x55cfca5ecda0
[1685017307.305363][7164:7166] CHIP:IN: SecureSession[0x7fccac00acf0]: Allocated Type:1 LSID:31218
[1685017307.305402][7164:7166] CHIP:SC: Assigned local session key ID 31218
[1685017307.305446][7164:7166] CHIP:EM: <<< [E:24724i S:0 M:116781971] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1685017307.305454][7164:7166] CHIP:IN: (U) Sending msg 116781971 to IP address 'BLE'
[1685017307.305458][7164:7166] CHIP:IN: Message appended to BLE send queue
[1685017307.305460][7164:7166] CHIP:SC: Sent PBKDF param request
[1685017307.723724][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017307.814464][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1685017307.814503][7164:7166] CHIP:BLE: subscribe complete, ep = 0x55cfca5ecda0
[1685017307.815203][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017307.815430][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017307.815441][7164:7166] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1685017307.815446][7164:7166] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1685017307.815449][7164:7166] CHIP:BLE: local and remote recv window size = 5
[1685017307.815936][7164:7166] CHIP:IN: BLE EndPoint 0x55cfca5ecda0 Connection Complete
[1685017307.901863][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017307.903674][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017307.903854][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017307.903932][7164:7166] CHIP:EM: >>> [E:24724i S:0 M:149081705] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1685017307.903941][7164:7166] CHIP:EM: Found matching exchange: 24724i, Delegate: 0x7fccac00d9a0
[1685017307.903949][7164:7166] CHIP:SC: Received PBKDF param response
[1685017307.903961][7164:7166] CHIP:SC: Peer assigned session ID 13409
[1685017307.904203][7164:7166] CHIP:SC: Found MRP parameters in the message
[1685017307.905587][7164:7166] CHIP:EM: <<< [E:24724i S:0 M:116781972] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1685017307.905637][7164:7166] CHIP:IN: (U) Sending msg 116781972 to IP address 'BLE'
[1685017307.905988][7164:7166] CHIP:SC: Sent spake2p msg1
[1685017307.994929][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017309.928189][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017309.928328][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017309.928358][7164:7166] CHIP:EM: >>> [E:24724i S:0 M:149081706] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1685017309.928363][7164:7166] CHIP:EM: Found matching exchange: 24724i, Delegate: 0x7fccac00d9a0
[1685017309.928368][7164:7166] CHIP:SC: Received spake2p msg2
[1685017309.928599][7164:7166] CHIP:EM: <<< [E:24724i S:0 M:116781973] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1685017309.928676][7164:7166] CHIP:IN: (U) Sending msg 116781973 to IP address 'BLE'
[1685017309.928944][7164:7166] CHIP:SC: Sent spake2p msg3
[1685017310.017477][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.017572][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.017614][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.017644][7164:7166] CHIP:EM: >>> [E:24724i S:0 M:149081707] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1685017310.017649][7164:7166] CHIP:EM: Found matching exchange: 24724i, Delegate: 0x7fccac00d9a0
[1685017310.017710][7164:7166] CHIP:SC: SecureSession[0x7fccac00acf0, LSID:31218]: State change 'kEstablishing' --> 'kActive'
[1685017310.017747][7164:7166] CHIP:IN: SecureSession[0x7fccac00acf0]: Activated - Type:1 LSID:31218
[1685017310.017750][7164:7166] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:31218 PSID:13409!
[1685017310.017755][7164:7166] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1685017310.017758][7164:7166] CHIP:TOO: Pairing Success
[1685017310.017759][7164:7166] CHIP:TOO: PASE establishment successful
[1685017310.017761][7164:7166] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1685017310.017764][7164:7166] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1685017310.017766][7164:7166] CHIP:CTL: Sending request for commissioning information
[1685017310.017800][7164:7166] CHIP:DMG: SendReadRequest ReadClient[0x7fccac015b70]: Sending Read Request
[1685017310.017890][7164:7166] CHIP:EM: <<< [E:24725i S:31218 M:130712331] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1685017310.017928][7164:7166] CHIP:IN: (S) Sending msg 130712331 on secure session with LSID: 31218
[1685017310.018186][7164:7166] CHIP:DMG: MoveToState ReadClient[0x7fccac015b70]: Moving to [AwaitingIn]
[1685017310.108711][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.154036][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.154127][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.242736][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.242830][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.243070][7164:7166] CHIP:EM: >>> [E:24725i S:31218 M:110006082] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1685017310.243076][7164:7166] CHIP:EM: Found matching exchange: 24725i, Delegate: 0x7fccac015b80
[1685017310.243116][7164:7166] CHIP:DMG: ReportDataMessage =
[1685017310.243164][7164:7166] CHIP:DMG: {
[1685017310.243167][7164:7166] CHIP:DMG: 	AttributeReportIBs =
[1685017310.243170][7164:7166] CHIP:DMG: 	[
[1685017310.243171][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243174][7164:7166] CHIP:DMG: 		{
[1685017310.243175][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243177][7164:7166] CHIP:DMG: 			{
[1685017310.243198][7164:7166] CHIP:DMG: 				DataVersion = 0x4bee5a87,
[1685017310.243231][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243235][7164:7166] CHIP:DMG: 				{
[1685017310.243237][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243239][7164:7166] CHIP:DMG: 					Cluster = 0x31,
[1685017310.243241][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0003,
[1685017310.243243][7164:7166] CHIP:DMG: 				}
[1685017310.243245][7164:7166] CHIP:DMG:
[1685017310.243247][7164:7166] CHIP:DMG: 				Data = 20,
[1685017310.243248][7164:7166] CHIP:DMG: 			},
[1685017310.243251][7164:7166] CHIP:DMG:
[1685017310.243252][7164:7166] CHIP:DMG: 		},
[1685017310.243255][7164:7166] CHIP:DMG:
[1685017310.243257][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243259][7164:7166] CHIP:DMG: 		{
[1685017310.243260][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243262][7164:7166] CHIP:DMG: 			{
[1685017310.243264][7164:7166] CHIP:DMG: 				DataVersion = 0xb3a20987,
[1685017310.243265][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243267][7164:7166] CHIP:DMG: 				{
[1685017310.243268][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243270][7164:7166] CHIP:DMG: 					Cluster = 0x28,
[1685017310.243272][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0004,
[1685017310.243274][7164:7166] CHIP:DMG: 				}
[1685017310.243276][7164:7166] CHIP:DMG:
[1685017310.243277][7164:7166] CHIP:DMG: 				Data = 32773,
[1685017310.243279][7164:7166] CHIP:DMG: 			},
[1685017310.243281][7164:7166] CHIP:DMG:
[1685017310.243282][7164:7166] CHIP:DMG: 		},
[1685017310.243285][7164:7166] CHIP:DMG:
[1685017310.243287][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243289][7164:7166] CHIP:DMG: 		{
[1685017310.243320][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243324][7164:7166] CHIP:DMG: 			{
[1685017310.243326][7164:7166] CHIP:DMG: 				DataVersion = 0xb3a20987,
[1685017310.243328][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243330][7164:7166] CHIP:DMG: 				{
[1685017310.243332][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243333][7164:7166] CHIP:DMG: 					Cluster = 0x28,
[1685017310.243335][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0002,
[1685017310.243337][7164:7166] CHIP:DMG: 				}
[1685017310.243339][7164:7166] CHIP:DMG:
[1685017310.243341][7164:7166] CHIP:DMG: 				Data = 65521,
[1685017310.243342][7164:7166] CHIP:DMG: 			},
[1685017310.243345][7164:7166] CHIP:DMG:
[1685017310.243346][7164:7166] CHIP:DMG: 		},
[1685017310.243349][7164:7166] CHIP:DMG:
[1685017310.243350][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243353][7164:7166] CHIP:DMG: 		{
[1685017310.243354][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243355][7164:7166] CHIP:DMG: 			{
[1685017310.243357][7164:7166] CHIP:DMG: 				DataVersion = 0xfbcc58e9,
[1685017310.243359][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243360][7164:7166] CHIP:DMG: 				{
[1685017310.243362][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243364][7164:7166] CHIP:DMG: 					Cluster = 0x30,
[1685017310.243365][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0003,
[1685017310.243367][7164:7166] CHIP:DMG: 				}
[1685017310.243369][7164:7166] CHIP:DMG:
[1685017310.243371][7164:7166] CHIP:DMG: 				Data = 0,
[1685017310.243402][7164:7166] CHIP:DMG: 			},
[1685017310.243406][7164:7166] CHIP:DMG:
[1685017310.243408][7164:7166] CHIP:DMG: 		},
[1685017310.243411][7164:7166] CHIP:DMG:
[1685017310.243413][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243415][7164:7166] CHIP:DMG: 		{
[1685017310.243416][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243418][7164:7166] CHIP:DMG: 			{
[1685017310.243420][7164:7166] CHIP:DMG: 				DataVersion = 0xfbcc58e9,
[1685017310.243421][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243423][7164:7166] CHIP:DMG: 				{
[1685017310.243425][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243427][7164:7166] CHIP:DMG: 					Cluster = 0x30,
[1685017310.243428][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0002,
[1685017310.243430][7164:7166] CHIP:DMG: 				}
[1685017310.243432][7164:7166] CHIP:DMG:
[1685017310.243434][7164:7166] CHIP:DMG: 				Data = 0,
[1685017310.243435][7164:7166] CHIP:DMG: 			},
[1685017310.243437][7164:7166] CHIP:DMG:
[1685017310.243439][7164:7166] CHIP:DMG: 		},
[1685017310.243442][7164:7166] CHIP:DMG:
[1685017310.243443][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243446][7164:7166] CHIP:DMG: 		{
[1685017310.243447][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243449][7164:7166] CHIP:DMG: 			{
[1685017310.243450][7164:7166] CHIP:DMG: 				DataVersion = 0xfbcc58e9,
[1685017310.243482][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243485][7164:7166] CHIP:DMG: 				{
[1685017310.243487][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243489][7164:7166] CHIP:DMG: 					Cluster = 0x30,
[1685017310.243491][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0001,
[1685017310.243493][7164:7166] CHIP:DMG: 				}
[1685017310.243495][7164:7166] CHIP:DMG:
[1685017310.243496][7164:7166] CHIP:DMG: 				Data =
[1685017310.243498][7164:7166] CHIP:DMG: 				{
[1685017310.243500][7164:7166] CHIP:DMG: 					0x0 = 60,
[1685017310.243502][7164:7166] CHIP:DMG: 					0x1 = 900,
[1685017310.243504][7164:7166] CHIP:DMG: 				},
[1685017310.243505][7164:7166] CHIP:DMG: 			},
[1685017310.243508][7164:7166] CHIP:DMG:
[1685017310.243509][7164:7166] CHIP:DMG: 		},
[1685017310.243513][7164:7166] CHIP:DMG:
[1685017310.243514][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243516][7164:7166] CHIP:DMG: 		{
[1685017310.243518][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243519][7164:7166] CHIP:DMG: 			{
[1685017310.243521][7164:7166] CHIP:DMG: 				DataVersion = 0xfbcc58e9,
[1685017310.243522][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243524][7164:7166] CHIP:DMG: 				{
[1685017310.243526][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243527][7164:7166] CHIP:DMG: 					Cluster = 0x30,
[1685017310.243530][7164:7166] CHIP:DMG: 					Attribute = 0x0000_0000,
[1685017310.243561][7164:7166] CHIP:DMG: 				}
[1685017310.243565][7164:7166] CHIP:DMG:
[1685017310.243567][7164:7166] CHIP:DMG: 				Data = 0,
[1685017310.243569][7164:7166] CHIP:DMG: 			},
[1685017310.243572][7164:7166] CHIP:DMG:
[1685017310.243573][7164:7166] CHIP:DMG: 		},
[1685017310.243576][7164:7166] CHIP:DMG:
[1685017310.243578][7164:7166] CHIP:DMG: 		AttributeReportIB =
[1685017310.243580][7164:7166] CHIP:DMG: 		{
[1685017310.243582][7164:7166] CHIP:DMG: 			AttributeDataIB =
[1685017310.243583][7164:7166] CHIP:DMG: 			{
[1685017310.243585][7164:7166] CHIP:DMG: 				DataVersion = 0x4bee5a87,
[1685017310.243586][7164:7166] CHIP:DMG: 				AttributePathIB =
[1685017310.243588][7164:7166] CHIP:DMG: 				{
[1685017310.243590][7164:7166] CHIP:DMG: 					Endpoint = 0x0,
[1685017310.243592][7164:7166] CHIP:DMG: 					Cluster = 0x31,
[1685017310.243594][7164:7166] CHIP:DMG: 					Attribute = 0x0000_FFFC,
[1685017310.243595][7164:7166] CHIP:DMG: 				}
[1685017310.243597][7164:7166] CHIP:DMG:
[1685017310.243599][7164:7166] CHIP:DMG: 				Data = 2,
[1685017310.243601][7164:7166] CHIP:DMG: 			},
[1685017310.243603][7164:7166] CHIP:DMG:
[1685017310.243604][7164:7166] CHIP:DMG: 		},
[1685017310.243606][7164:7166] CHIP:DMG:
[1685017310.243607][7164:7166] CHIP:DMG: 	],
[1685017310.243614][7164:7166] CHIP:DMG:
[1685017310.243646][7164:7166] CHIP:DMG: 	SuppressResponse = true,
[1685017310.243649][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017310.243651][7164:7166] CHIP:DMG: }
[1685017310.243802][7164:7166] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1685017310.243861][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1685017310.243866][7164:7166] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1685017310.243869][7164:7166] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1685017310.243872][7164:7166] CHIP:CTL: Arming failsafe (60 seconds)
[1685017310.243893][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017310.244009][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017310.244028][7164:7166] CHIP:EM: <<< [E:24726i S:31218 M:130712332] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017310.244032][7164:7166] CHIP:IN: (S) Sending msg 130712332 on secure session with LSID: 31218
[1685017310.244322][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017310.333490][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.335663][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.335931][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.336011][7164:7166] CHIP:EM: >>> [E:24726i S:31218 M:110006083] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017310.336017][7164:7166] CHIP:EM: Found matching exchange: 24726i, Delegate: 0x7fccb4035aa8
[1685017310.336021][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017310.336030][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017310.336031][7164:7166] CHIP:DMG: {
[1685017310.336033][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017310.336034][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017310.336037][7164:7166] CHIP:DMG: 	[
[1685017310.336070][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017310.336075][7164:7166] CHIP:DMG: 		{
[1685017310.336077][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017310.336079][7164:7166] CHIP:DMG: 			{
[1685017310.336081][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017310.336083][7164:7166] CHIP:DMG: 				{
[1685017310.336085][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017310.336087][7164:7166] CHIP:DMG: 					ClusterId = 0x30,
[1685017310.336088][7164:7166] CHIP:DMG: 					CommandId = 0x1,
[1685017310.336090][7164:7166] CHIP:DMG: 				},
[1685017310.336092][7164:7166] CHIP:DMG:
[1685017310.336094][7164:7166] CHIP:DMG: 				CommandFields =
[1685017310.336095][7164:7166] CHIP:DMG: 				{
[1685017310.336097][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017310.336100][7164:7166] CHIP:DMG: 					0x1 = "" (0 chars),
[1685017310.336102][7164:7166] CHIP:DMG: 				},
[1685017310.336103][7164:7166] CHIP:DMG: 			},
[1685017310.336106][7164:7166] CHIP:DMG:
[1685017310.336107][7164:7166] CHIP:DMG: 		},
[1685017310.336109][7164:7166] CHIP:DMG:
[1685017310.336110][7164:7166] CHIP:DMG: 	],
[1685017310.336113][7164:7166] CHIP:DMG:
[1685017310.336114][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017310.336116][7164:7166] CHIP:DMG: },
[1685017310.336125][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1685017310.336243][7164:7166] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1685017310.336251][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1685017310.336253][7164:7166] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1685017310.336256][7164:7166] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1685017310.336257][7164:7166] CHIP:CTL: Setting Regulatory Config
[1685017310.336259][7164:7166] CHIP:CTL: Device does not support configurable regulatory location
[1685017310.336295][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017310.336324][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017310.336370][7164:7166] CHIP:EM: <<< [E:24727i S:31218 M:130712333] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017310.336375][7164:7166] CHIP:IN: (S) Sending msg 130712333 on secure session with LSID: 31218
[1685017310.336794][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017310.336806][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017310.431189][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.431281][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.431494][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.431545][7164:7166] CHIP:EM: >>> [E:24727i S:31218 M:110006084] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017310.431551][7164:7166] CHIP:EM: Found matching exchange: 24727i, Delegate: 0x7fccac009fe8
[1685017310.431555][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017310.431564][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017310.431598][7164:7166] CHIP:DMG: {
[1685017310.431602][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017310.431603][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017310.431607][7164:7166] CHIP:DMG: 	[
[1685017310.431608][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017310.431611][7164:7166] CHIP:DMG: 		{
[1685017310.431612][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017310.431614][7164:7166] CHIP:DMG: 			{
[1685017310.431616][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017310.431618][7164:7166] CHIP:DMG: 				{
[1685017310.431620][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017310.431622][7164:7166] CHIP:DMG: 					ClusterId = 0x30,
[1685017310.431624][7164:7166] CHIP:DMG: 					CommandId = 0x3,
[1685017310.431625][7164:7166] CHIP:DMG: 				},
[1685017310.431627][7164:7166] CHIP:DMG:
[1685017310.431629][7164:7166] CHIP:DMG: 				CommandFields =
[1685017310.431631][7164:7166] CHIP:DMG: 				{
[1685017310.431633][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017310.431635][7164:7166] CHIP:DMG: 					0x1 = "" (0 chars),
[1685017310.431637][7164:7166] CHIP:DMG: 				},
[1685017310.431639][7164:7166] CHIP:DMG: 			},
[1685017310.431641][7164:7166] CHIP:DMG:
[1685017310.431642][7164:7166] CHIP:DMG: 		},
[1685017310.431645][7164:7166] CHIP:DMG:
[1685017310.431646][7164:7166] CHIP:DMG: 	],
[1685017310.431648][7164:7166] CHIP:DMG:
[1685017310.431650][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017310.431651][7164:7166] CHIP:DMG: },
[1685017310.431660][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1685017310.431706][7164:7166] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1685017310.431714][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1685017310.431717][7164:7166] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1685017310.431720][7164:7166] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1685017310.431722][7164:7166] CHIP:CTL: Sending request for PAI certificate
[1685017310.431723][7164:7166] CHIP:CTL: Sending Certificate Chain request to 0x7fccac00d950 device
[1685017310.431735][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017310.431742][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017310.431758][7164:7166] CHIP:EM: <<< [E:24728i S:31218 M:130712334] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017310.431761][7164:7166] CHIP:IN: (S) Sending msg 130712334 on secure session with LSID: 31218
[1685017310.432103][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017310.432501][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017310.511569][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.516104][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.516424][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.604113][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.604250][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.692352][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.692469][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.692547][7164:7166] CHIP:EM: >>> [E:24728i S:31218 M:110006085] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017310.692557][7164:7166] CHIP:EM: Found matching exchange: 24728i, Delegate: 0x7fccb4035aa8
[1685017310.692571][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017310.692582][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017310.692587][7164:7166] CHIP:DMG: {
[1685017310.692591][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017310.692598][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017310.692606][7164:7166] CHIP:DMG: 	[
[1685017310.692627][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017310.692636][7164:7166] CHIP:DMG: 		{
[1685017310.692643][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017310.692653][7164:7166] CHIP:DMG: 			{
[1685017310.692661][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017310.692672][7164:7166] CHIP:DMG: 				{
[1685017310.692682][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017310.692694][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017310.692705][7164:7166] CHIP:DMG: 					CommandId = 0x3,
[1685017310.692716][7164:7166] CHIP:DMG: 				},
[1685017310.692727][7164:7166] CHIP:DMG:
[1685017310.692801][7164:7166] CHIP:DMG: 				CommandFields =
[1685017310.692846][7164:7166] CHIP:DMG: 				{
[1685017310.692858][7164:7166] CHIP:DMG: 					0x0 = [
[1685017310.692882][7164:7166] CHIP:DMG: 					0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1685017310.692903][7164:7166] CHIP:DMG: 					] (463 bytes)
[1685017310.692914][7164:7166] CHIP:DMG: 				},
[1685017310.692923][7164:7166] CHIP:DMG: 			},
[1685017310.692933][7164:7166] CHIP:DMG:
[1685017310.692940][7164:7166] CHIP:DMG: 		},
[1685017310.692948][7164:7166] CHIP:DMG:
[1685017310.692954][7164:7166] CHIP:DMG: 	],
[1685017310.692962][7164:7166] CHIP:DMG:
[1685017310.692968][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017310.692974][7164:7166] CHIP:DMG: },
[1685017310.692987][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1685017310.692996][7164:7166] CHIP:CTL: Received certificate chain from the device
[1685017310.693006][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1685017310.693011][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1685017310.693018][7164:7166] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1685017310.693022][7164:7166] CHIP:CTL: Sending request for DAC certificate
[1685017310.693026][7164:7166] CHIP:CTL: Sending Certificate Chain request to 0x7fccac00d950 device
[1685017310.693040][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017310.693046][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017310.693068][7164:7166] CHIP:EM: <<< [E:24729i S:31218 M:130712335] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017310.693075][7164:7166] CHIP:IN: (S) Sending msg 130712335 on secure session with LSID: 31218
[1685017310.693205][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017310.693221][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017310.781735][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017310.785334][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.785430][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.874522][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.874625][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.962398][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017310.962504][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017310.962557][7164:7166] CHIP:EM: >>> [E:24729i S:31218 M:110006086] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017310.962566][7164:7166] CHIP:EM: Found matching exchange: 24729i, Delegate: 0x7fccb4072f48
[1685017310.962575][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017310.962586][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017310.962591][7164:7166] CHIP:DMG: {
[1685017310.962596][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017310.962731][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017310.962743][7164:7166] CHIP:DMG: 	[
[1685017310.962749][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017310.962758][7164:7166] CHIP:DMG: 		{
[1685017310.962766][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017310.962775][7164:7166] CHIP:DMG: 			{
[1685017310.962784][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017310.962795][7164:7166] CHIP:DMG: 				{
[1685017310.962834][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017310.962848][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017310.962859][7164:7166] CHIP:DMG: 					CommandId = 0x3,
[1685017310.962870][7164:7166] CHIP:DMG: 				},
[1685017310.962881][7164:7166] CHIP:DMG:
[1685017310.962890][7164:7166] CHIP:DMG: 				CommandFields =
[1685017310.962900][7164:7166] CHIP:DMG: 				{
[1685017310.962911][7164:7166] CHIP:DMG: 					0x0 = [
[1685017310.962935][7164:7166] CHIP:DMG: 					0x30, 0x82, 0x01, 0xe8, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x6f, 0xdc, 0xb6, 0xed, 0x06, 0xf3, 0x58, 0xf9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x35, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x7e, 0xf2, 0xf1, 0x08, 0x2b, 0x2a, 0x56, 0x4a, 0x05, 0x44, 0xc0, 0xa6, 0x13, 0xd2, 0x1b, 0x15, 0x75, 0x00, 0x55, 0x2d, 0x03, 0x5f, 0x23, 0x02, 0x25, 0x2f, 0xce, 0xe8, 0x1d, 0x6e, 0xc6, 0x74, 0x17, 0x34, 0x18, 0xa9, 0x4a, 0x88, 0xdb, 0x
[1685017310.962957][7164:7166] CHIP:DMG: 					] (492 bytes)
[1685017310.962997][7164:7166] CHIP:DMG: 				},
[1685017310.963008][7164:7166] CHIP:DMG: 			},
[1685017310.963018][7164:7166] CHIP:DMG:
[1685017310.963026][7164:7166] CHIP:DMG: 		},
[1685017310.963034][7164:7166] CHIP:DMG:
[1685017310.963041][7164:7166] CHIP:DMG: 	],
[1685017310.963048][7164:7166] CHIP:DMG:
[1685017310.963054][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017310.963060][7164:7166] CHIP:DMG: },
[1685017310.963072][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1685017310.963082][7164:7166] CHIP:CTL: Received certificate chain from the device
[1685017310.963091][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1685017310.963186][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1685017310.963242][7164:7166] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1685017310.963247][7164:7166] CHIP:CTL: Sending Attestation Request to the device.
[1685017310.963252][7164:7166] CHIP:CTL: Sending Attestation request to 0x7fccac00d950 device
[1685017310.963268][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017310.963274][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017310.963297][7164:7166] CHIP:EM: <<< [E:24730i S:31218 M:130712336] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017310.963304][7164:7166] CHIP:IN: (S) Sending msg 130712336 on secure session with LSID: 31218
[1685017310.963398][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017310.963404][7164:7166] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1685017310.963412][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017311.051408][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017311.098884][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.099097][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.189119][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.189328][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.279367][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.279467][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.279515][7164:7166] CHIP:EM: >>> [E:24730i S:31218 M:110006087] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017311.279522][7164:7166] CHIP:EM: Found matching exchange: 24730i, Delegate: 0x7fccb4073208
[1685017311.279530][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017311.279542][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017311.279644][7164:7166] CHIP:DMG: {
[1685017311.279651][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017311.279657][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017311.279666][7164:7166] CHIP:DMG: 	[
[1685017311.279672][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017311.279681][7164:7166] CHIP:DMG: 		{
[1685017311.279688][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017311.279697][7164:7166] CHIP:DMG: 			{
[1685017311.279705][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017311.279715][7164:7166] CHIP:DMG: 				{
[1685017311.279725][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017311.279736][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017311.279747][7164:7166] CHIP:DMG: 					CommandId = 0x1,
[1685017311.279886][7164:7166] CHIP:DMG: 				},
[1685017311.279898][7164:7166] CHIP:DMG:
[1685017311.279907][7164:7166] CHIP:DMG: 				CommandFields =
[1685017311.279917][7164:7166] CHIP:DMG: 				{
[1685017311.279927][7164:7166] CHIP:DMG: 					0x0 = [
[1685017311.279952][7164:7166] CHIP:DMG: 					0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1685017311.279972][7164:7166] CHIP:DMG: 					] (583 bytes)
[1685017311.279983][7164:7166] CHIP:DMG: 					0x1 = [
[1685017311.279997][7164:7166] CHIP:DMG: 					0xd2, 0xc4, 0xed, 0xaf, 0xcd, 0xaf, 0x59, 0x6e, 0xa9, 0x65, 0xe2, 0xac, 0x60, 0x31, 0xfa, 0x7b, 0x11, 0x91, 0x0c, 0x86, 0xa3, 0xf9, 0x2d, 0xce, 0xfe, 0x37, 0xe2, 0xc2, 0x01, 0x2f, 0x8f, 0x73, 0xc2, 0x20, 0x6f, 0xd8, 0x76, 0xfa, 0x20, 0xcd, 0x14, 0x0c, 0x6c, 0xc4, 0x4a, 0xc8, 0x19, 0x08, 0x97, 0x52, 0x5b, 0x7a, 0x98, 0x59, 0xfd, 0x9a, 0x2e, 0x11, 0xde, 0x7f, 0x6e, 0x23, 0x63, 0x60,
[1685017311.280196][7164:7166] CHIP:DMG: 					] (64 bytes)
[1685017311.280209][7164:7166] CHIP:DMG: 				},
[1685017311.280218][7164:7166] CHIP:DMG: 			},
[1685017311.280228][7164:7166] CHIP:DMG:
[1685017311.280236][7164:7166] CHIP:DMG: 		},
[1685017311.280244][7164:7166] CHIP:DMG:
[1685017311.280250][7164:7166] CHIP:DMG: 	],
[1685017311.280258][7164:7166] CHIP:DMG:
[1685017311.280263][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017311.280269][7164:7166] CHIP:DMG: },
[1685017311.280282][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1685017311.280290][7164:7166] CHIP:CTL: Received Attestation Information from the device
[1685017311.280299][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1685017311.280305][7164:7166] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
[1685017311.280319][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1685017311.280325][7164:7166] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1685017311.280330][7164:7166] CHIP:CTL: Verifying attestation
[1685017311.287305][7164:7166] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
[1685017311.287394][7164:7166] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
[1685017311.287402][7164:7166] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
[1685017311.287411][7164:7166] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
[1685017311.287436][7164:7166] CHIP:CTL: Sending CSR request to 0x7fccac00d950 device
[1685017311.287463][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017311.287470][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017311.287504][7164:7166] CHIP:EM: <<< [E:24731i S:31218 M:130712337] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017311.287548][7164:7166] CHIP:IN: (S) Sending msg 130712337 on secure session with LSID: 31218
[1685017311.287816][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017311.287854][7164:7166] CHIP:CTL: Sent CSR request, waiting for the CSR
[1685017311.287868][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017311.366301][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017311.639922][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.640318][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.728019][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.728367][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.728428][7164:7166] CHIP:EM: >>> [E:24731i S:31218 M:110006088] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017311.728436][7164:7166] CHIP:EM: Found matching exchange: 24731i, Delegate: 0x7fccb4073368
[1685017311.728445][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017311.728457][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017311.728462][7164:7166] CHIP:DMG: {
[1685017311.728466][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017311.728473][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017311.728481][7164:7166] CHIP:DMG: 	[
[1685017311.728487][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017311.728496][7164:7166] CHIP:DMG: 		{
[1685017311.728503][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017311.728513][7164:7166] CHIP:DMG: 			{
[1685017311.728521][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017311.728532][7164:7166] CHIP:DMG: 				{
[1685017311.728542][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017311.728554][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017311.728565][7164:7166] CHIP:DMG: 					CommandId = 0x5,
[1685017311.728576][7164:7166] CHIP:DMG: 				},
[1685017311.728587][7164:7166] CHIP:DMG:
[1685017311.728596][7164:7166] CHIP:DMG: 				CommandFields =
[1685017311.728607][7164:7166] CHIP:DMG: 				{
[1685017311.728617][7164:7166] CHIP:DMG: 					0x0 = [
[1685017311.728639][7164:7166] CHIP:DMG: 					0x15, 0x30, 0x01, 0xcd, 0x30, 0x81, 0xca, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x40, 0xa6, 0x94, 0x50, 0xe9, 0xf3, 0xc2, 0xe5, 0x4d, 0x0d, 0x58, 0xab, 0xaf, 0x8b, 0x4d, 0xcf, 0xa1, 0x2c, 0x61, 0x82, 0x4a, 0x72, 0x58, 0xf1, 0x1a, 0x7b, 0xdc, 0x10, 0xe0, 0x75, 0xee, 0xe5, 0x2f, 0x4c, 0x6d, 0x7e, 0x5d, 0x06, 0x2b, 0x0b, 0x86, 0xc3, 0xa3, 0x3b, 0xeb, 0x32, 0xac, 0x2a, 0xbe, 0xdf, 0x91, 0xf5, 0x3f, 0x84, 0x26, 0x16, 0xd8, 0x9f, 0x73, 0x47, 0xa9, 0x17, 0x51, 0x3c, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x48, 0x00, 0x30, 0x45, 0x02, 0x20, 0x6e, 0x1e, 0x09, 0x11, 0x9f, 0x75, 0xa4, 0xb7, 0xb9, 0x2c, 0xc7, 0x5c, 0xd3, 0x23, 0xc6, 0xf9, 0x85, 0x7e, 0x61, 0x9c, 0x78, 0xcb, 0x36, 0x50, 0x4c, 0x35, 0xae, 0xea, 0x06, 0x83, 0xca, 0x3b, 0x02, 0x21, 0x00, 0x8a, 0x26, 0x43, 0xdc, 0x5a, 0x66, 0x10, 0x6c, 0x1d, 0xbc, 0x4c, 0x81, 0x15, 0x19, 0xce, 0xe4, 0x8c, 0xee, 0x72, 0x81, 0x67, 0xcf, 0x4c, 0xd7, 0x88, 0xf6, 0x19, 0x58, 0xbf, 0xa0, 0x1d, 0x8f, 0x30, 0x02, 0x20, 0xb9, 0xae, 0x11, 0x87, 0x3f, 0x34, 0x99, 0x0a, 0xa6, 0x11, 0x85, 0x6f, 0x1c, 0x6f, 0x89, 0xfa, 0xdd, 0xc0, 0x2f, 0x30, 0xd8, 0x69, 0xe5, 0xfc, 0x47, 0x8a, 0x3d, 0xc2, 0x88, 0x18, 0x11, 0x4c, 0x18,
[1685017311.728659][7164:7166] CHIP:DMG: 					] (245 bytes)
[1685017311.728670][7164:7166] CHIP:DMG: 					0x1 = [
[1685017311.728856][7164:7166] CHIP:DMG: 					0x8d, 0x26, 0x45, 0xad, 0x84, 0x7d, 0x23, 0x72, 0xaf, 0xbc, 0x8e, 0x77, 0x0e, 0x56, 0xb8, 0x2d, 0x01, 0x98, 0xb2, 0xa2, 0xc8, 0x49, 0x0e, 0x58, 0x84, 0xe6, 0x61, 0xd1, 0x2e, 0xdb, 0x9d, 0xc3, 0x63, 0xb4, 0x35, 0x5d, 0xbf, 0xc9, 0xa1, 0x14, 0x7b, 0x78, 0x8a, 0x2c, 0xd5, 0xa2, 0x78, 0xfe, 0xeb, 0x2e, 0x29, 0x9f, 0xab, 0x57, 0xd6, 0x78, 0x80, 0x0a, 0xc6, 0x81, 0x12, 0xc7, 0x14, 0xdc,
[1685017311.728873][7164:7166] CHIP:DMG: 					] (64 bytes)
[1685017311.728884][7164:7166] CHIP:DMG: 				},
[1685017311.728894][7164:7166] CHIP:DMG: 			},
[1685017311.728905][7164:7166] CHIP:DMG:
[1685017311.728912][7164:7166] CHIP:DMG: 		},
[1685017311.728920][7164:7166] CHIP:DMG:
[1685017311.728927][7164:7166] CHIP:DMG: 	],
[1685017311.728934][7164:7166] CHIP:DMG:
[1685017311.728940][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017311.728946][7164:7166] CHIP:DMG: },
[1685017311.728959][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
[1685017311.728987][7164:7166] CHIP:CTL: Received certificate signing request from the device
[1685017311.728996][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
[1685017311.729013][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
[1685017311.729020][7164:7166] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
[1685017311.730977][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
[1685017311.731014][7164:7166] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
[1685017311.731033][7164:7166] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
[1685017311.731049][7164:7166] CHIP:CTL: Getting certificate chain for the device from the issuer
[1685017311.732106][7164:7166] CHIP:CTL: Verifying Certificate Signing Request
[1685017311.732670][7164:7166] CHIP:CTL: Generating NOC
[1685017311.732765][7164:7166] CHIP:CTL: Providing certificate chain to the commissioner
[1685017311.732785][7164:7166] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
[1685017311.732806][7164:7166] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
[1685017311.732845][7164:7166] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
[1685017311.732863][7164:7166] CHIP:CTL: Sending root certificate to the device
[1685017311.732895][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017311.732914][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017311.732955][7164:7166] CHIP:EM: <<< [E:24732i S:31218 M:130712338] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017311.732975][7164:7166] CHIP:IN: (S) Sending msg 130712338 on secure session with LSID: 31218
[1685017311.733212][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017311.733244][7164:7166] CHIP:CTL: Sent root certificate to the device
[1685017311.733331][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017311.824914][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017311.906982][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017311.997275][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017311.997375][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017311.997434][7164:7166] CHIP:EM: >>> [E:24732i S:31218 M:110006089] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017311.997443][7164:7166] CHIP:EM: Found matching exchange: 24732i, Delegate: 0x7fccb4073208
[1685017311.997450][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017311.997461][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017311.997466][7164:7166] CHIP:DMG: {
[1685017311.997470][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017311.997477][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017311.997485][7164:7166] CHIP:DMG: 	[
[1685017311.997491][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017311.997500][7164:7166] CHIP:DMG: 		{
[1685017311.997508][7164:7166] CHIP:DMG: 			CommandStatusIB =
[1685017311.997524][7164:7166] CHIP:DMG: 			{
[1685017311.997533][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017311.997544][7164:7166] CHIP:DMG: 				{
[1685017311.997699][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017311.997721][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017311.997791][7164:7166] CHIP:DMG: 					CommandId = 0xb,
[1685017311.997803][7164:7166] CHIP:DMG: 				},
[1685017311.997880][7164:7166] CHIP:DMG:
[1685017311.997891][7164:7166] CHIP:DMG: 				StatusIB =
[1685017311.997902][7164:7166] CHIP:DMG: 				{
[1685017311.997912][7164:7166] CHIP:DMG: 					status = 0x00 (SUCCESS),
[1685017311.997960][7164:7166] CHIP:DMG: 				},
[1685017311.997972][7164:7166] CHIP:DMG:
[1685017311.997981][7164:7166] CHIP:DMG: 			},
[1685017311.997992][7164:7166] CHIP:DMG:
[1685017311.997999][7164:7166] CHIP:DMG: 		},
[1685017311.998008][7164:7166] CHIP:DMG:
[1685017311.998047][7164:7166] CHIP:DMG: 	],
[1685017311.998057][7164:7166] CHIP:DMG:
[1685017311.998063][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017311.998069][7164:7166] CHIP:DMG: },
[1685017311.998081][7164:7166] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
[1685017311.998089][7164:7166] CHIP:CTL: Device confirmed that it has received the root certificate
[1685017311.998098][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
[1685017311.998135][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
[1685017311.998144][7164:7166] CHIP:CTL: Performing next commissioning step 'SendNOC'
[1685017311.998166][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017311.998174][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017311.998204][7164:7166] CHIP:EM: <<< [E:24733i S:31218 M:130712339] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017311.998246][7164:7166] CHIP:IN: (S) Sending msg 130712339 on secure session with LSID: 31218
[1685017311.998375][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017311.998384][7164:7166] CHIP:CTL: Sent operational certificate to the device
[1685017311.998395][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017312.086583][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017312.180195][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017312.266677][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017312.468639][7164:7166] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:174: CHIP Error 0x00000032: Timeout
[1685017312.627303][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017312.627408][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017312.627592][7164:7166] CHIP:EM: >>> [E:24733i S:31218 M:110006090] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017312.627637][7164:7166] CHIP:EM: Found matching exchange: 24733i, Delegate: 0x7fccb4073368
[1685017312.627647][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017312.627659][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017312.627663][7164:7166] CHIP:DMG: {
[1685017312.627667][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017312.627674][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017312.627682][7164:7166] CHIP:DMG: 	[
[1685017312.627688][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017312.627697][7164:7166] CHIP:DMG: 		{
[1685017312.627704][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017312.627713][7164:7166] CHIP:DMG: 			{
[1685017312.627721][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017312.627732][7164:7166] CHIP:DMG: 				{
[1685017312.627742][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017312.627754][7164:7166] CHIP:DMG: 					ClusterId = 0x3e,
[1685017312.627764][7164:7166] CHIP:DMG: 					CommandId = 0x8,
[1685017312.627775][7164:7166] CHIP:DMG: 				},
[1685017312.627786][7164:7166] CHIP:DMG:
[1685017312.627827][7164:7166] CHIP:DMG: 				CommandFields =
[1685017312.627839][7164:7166] CHIP:DMG: 				{
[1685017312.627850][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017312.627861][7164:7166] CHIP:DMG: 					0x1 = 1,
[1685017312.627873][7164:7166] CHIP:DMG: 				},
[1685017312.627882][7164:7166] CHIP:DMG: 			},
[1685017312.627892][7164:7166] CHIP:DMG:
[1685017312.627899][7164:7166] CHIP:DMG: 		},
[1685017312.627908][7164:7166] CHIP:DMG:
[1685017312.628224][7164:7166] CHIP:DMG: 	],
[1685017312.628234][7164:7166] CHIP:DMG:
[1685017312.628240][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017312.628246][7164:7166] CHIP:DMG: },
[1685017312.628258][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
[1685017312.628270][7164:7166] CHIP:CTL: Device returned status 0 on receiving the NOC
[1685017312.628275][7164:7166] CHIP:CTL: Operational credentials provisioned on device 0x7fccac00d950
[1685017312.628280][7164:7166] CHIP:TOO: Secure Pairing Success
[1685017312.628284][7164:7166] CHIP:TOO: CASE establishment successful
[1685017312.628292][7164:7166] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
[1685017312.628299][7164:7166] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1685017312.628331][7164:7166] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
[1685017312.628337][7164:7166] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
[1685017312.628352][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017312.628367][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017312.628387][7164:7166] CHIP:EM: <<< [E:24734i S:31218 M:130712340] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017312.628391][7164:7166] CHIP:IN: (S) Sending msg 130712340 on secure session with LSID: 31218
[1685017312.628551][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017312.628562][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017312.716228][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017312.717697][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017312.717742][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017312.717927][7164:7166] CHIP:EM: >>> [E:24734i S:31218 M:110006091] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017312.717973][7164:7166] CHIP:EM: Found matching exchange: 24734i, Delegate: 0x7fccb4073208
[1685017312.717983][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017312.717994][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017312.717999][7164:7166] CHIP:DMG: {
[1685017312.718003][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017312.718009][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017312.718182][7164:7166] CHIP:DMG: 	[
[1685017312.718191][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017312.718200][7164:7166] CHIP:DMG: 		{
[1685017312.718208][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017312.718217][7164:7166] CHIP:DMG: 			{
[1685017312.718225][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017312.718235][7164:7166] CHIP:DMG: 				{
[1685017312.718281][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017312.718294][7164:7166] CHIP:DMG: 					ClusterId = 0x31,
[1685017312.718305][7164:7166] CHIP:DMG: 					CommandId = 0x5,
[1685017312.718316][7164:7166] CHIP:DMG: 				},
[1685017312.718326][7164:7166] CHIP:DMG:
[1685017312.718335][7164:7166] CHIP:DMG: 				CommandFields =
[1685017312.718345][7164:7166] CHIP:DMG: 				{
[1685017312.718356][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017312.718367][7164:7166] CHIP:DMG: 					0x2 = 0,
[1685017312.718378][7164:7166] CHIP:DMG: 				},
[1685017312.718387][7164:7166] CHIP:DMG: 			},
[1685017312.718397][7164:7166] CHIP:DMG:
[1685017312.718404][7164:7166] CHIP:DMG: 		},
[1685017312.718443][7164:7166] CHIP:DMG:
[1685017312.718446][7164:7166] CHIP:DMG: 	],
[1685017312.718449][7164:7166] CHIP:DMG:
[1685017312.718451][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017312.718452][7164:7166] CHIP:DMG: },
[1685017312.718461][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
[1685017312.718512][7164:7166] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
[1685017312.718520][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
[1685017312.718523][7164:7166] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'FailsafeBeforeThreadEnable'
[1685017312.718528][7164:7166] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeThreadEnable'
[1685017312.718534][7164:7166] CHIP:CTL: Arming failsafe (76 seconds)
[1685017312.718545][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017312.718548][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017312.718569][7164:7166] CHIP:EM: <<< [E:24735i S:31218 M:130712341] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017312.718574][7164:7166] CHIP:IN: (S) Sending msg 130712341 on secure session with LSID: 31218
[1685017312.718635][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017312.718682][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017312.806149][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017312.808066][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017312.808401][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017312.808514][7164:7166] CHIP:EM: >>> [E:24735i S:31218 M:110006092] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017312.808566][7164:7166] CHIP:EM: Found matching exchange: 24735i, Delegate: 0x7fccb4073368
[1685017312.808573][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017312.808582][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017312.808584][7164:7166] CHIP:DMG: {
[1685017312.808585][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017312.808587][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017312.808590][7164:7166] CHIP:DMG: 	[
[1685017312.808591][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017312.808594][7164:7166] CHIP:DMG: 		{
[1685017312.808595][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017312.808597][7164:7166] CHIP:DMG: 			{
[1685017312.808598][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017312.808601][7164:7166] CHIP:DMG: 				{
[1685017312.808603][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017312.808605][7164:7166] CHIP:DMG: 					ClusterId = 0x30,
[1685017312.808606][7164:7166] CHIP:DMG: 					CommandId = 0x1,
[1685017312.808608][7164:7166] CHIP:DMG: 				},
[1685017312.808678][7164:7166] CHIP:DMG:
[1685017312.808721][7164:7166] CHIP:DMG: 				CommandFields =
[1685017312.808771][7164:7166] CHIP:DMG: 				{
[1685017312.808821][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017312.808851][7164:7166] CHIP:DMG: 					0x1 = "" (0 chars),
[1685017312.808869][7164:7166] CHIP:DMG: 				},
[1685017312.808885][7164:7166] CHIP:DMG: 			},
[1685017312.808901][7164:7166] CHIP:DMG:
[1685017312.808914][7164:7166] CHIP:DMG: 		},
[1685017312.808929][7164:7166] CHIP:DMG:
[1685017312.808941][7164:7166] CHIP:DMG: 	],
[1685017312.808954][7164:7166] CHIP:DMG:
[1685017312.808959][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017312.808972][7164:7166] CHIP:DMG: },
[1685017312.808990][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1685017312.809011][7164:7166] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1685017312.809032][7164:7166] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
[1685017312.809044][7164:7166] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
[1685017312.809057][7164:7166] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
[1685017312.809080][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017312.809098][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017312.809127][7164:7166] CHIP:EM: <<< [E:24736i S:31218 M:130712342] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017312.809146][7164:7166] CHIP:IN: (S) Sending msg 130712342 on secure session with LSID: 31218
[1685017312.809278][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017312.809340][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017312.896675][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017315.372319][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017315.372510][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017317.982254][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017320.457437][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017320.457673][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017323.069568][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017325.542355][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017325.542595][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017325.992748][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017325.992839][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017325.992889][7164:7166] CHIP:EM: >>> [E:24736i S:31218 M:110006093] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017325.992894][7164:7166] CHIP:EM: Found matching exchange: 24736i, Delegate: 0x7fccb4073208
[1685017325.992900][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017325.992909][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017325.992911][7164:7166] CHIP:DMG: {
[1685017325.992912][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017325.992914][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017325.992922][7164:7166] CHIP:DMG: 	[
[1685017325.992957][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017325.992962][7164:7166] CHIP:DMG: 		{
[1685017325.992964][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017325.992966][7164:7166] CHIP:DMG: 			{
[1685017325.992968][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017325.992970][7164:7166] CHIP:DMG: 				{
[1685017325.992972][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017325.992974][7164:7166] CHIP:DMG: 					ClusterId = 0x31,
[1685017325.992976][7164:7166] CHIP:DMG: 					CommandId = 0x7,
[1685017325.992977][7164:7166] CHIP:DMG: 				},
[1685017325.992979][7164:7166] CHIP:DMG:
[1685017325.992981][7164:7166] CHIP:DMG: 				CommandFields =
[1685017325.992983][7164:7166] CHIP:DMG: 				{
[1685017325.992985][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017325.992987][7164:7166] CHIP:DMG: 					0x2 = NULL
[1685017325.992989][7164:7166] CHIP:DMG: 				},
[1685017325.992990][7164:7166] CHIP:DMG: 			},
[1685017325.992993][7164:7166] CHIP:DMG:
[1685017325.993024][7164:7166] CHIP:DMG: 		},
[1685017325.993028][7164:7166] CHIP:DMG:
[1685017325.993030][7164:7166] CHIP:DMG: 	],
[1685017325.993033][7164:7166] CHIP:DMG:
[1685017325.993034][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017325.993036][7164:7166] CHIP:DMG: },
[1685017325.993045][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
[1685017325.993054][7164:7166] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
[1685017325.993060][7164:7166] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
[1685017325.993063][7164:7166] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
[1685017325.993066][7164:7166] CHIP:CTL: Performing next commissioning step 'FindOperational'
[1685017325.993068][7164:7166] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
[1685017325.993070][7164:7166] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
[1685017325.993076][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
[1685017325.993748][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017325.994394][7164:7166] CHIP:DIS: Lookup clearing interface for non LL address
[1685017325.994448][7164:7166] CHIP:DIS: UDP:[fd11:22::add3:c4f7:a475:2c77%otbr0]:5540: new best score: 4
[1685017325.994451][7164:7166] CHIP:DIS: Checking node lookup status after 2 ms
[1685017325.994452][7164:7166] CHIP:DIS: Keeping DNSSD lookup active
[1685017325.994720][7164:7166] CHIP:DIS: UDP:[fd11:22::add3:c4f7:a475:2c77%otbr0]:5540: score has not improved: 4
[1685017325.994761][7164:7166] CHIP:DIS: Checking node lookup status after 2 ms
[1685017325.994764][7164:7166] CHIP:DIS: Keeping DNSSD lookup active
[1685017325.994786][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017325.994792][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017325.994797][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017325.994810][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017325.994853][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017325.996008][7164:7166] CHIP:DIS: UDP:[fd11:22::add3:c4f7:a475:2c77%otbr0]:5540: score has not improved: 4
[1685017325.996054][7164:7166] CHIP:DIS: Checking node lookup status after 3 ms
[1685017325.996060][7164:7166] CHIP:DIS: Keeping DNSSD lookup active
[1685017326.193508][7164:7166] CHIP:DIS: Checking node lookup status after 201 ms
[1685017326.193691][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd11:22::add3:c4f7:a475:2c77]:5540 while in state 2
[1685017326.193709][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
[1685017326.193790][7164:7166] CHIP:IN: SecureSession[0x7fccac013ee0]: Allocated Type:2 LSID:31219
[1685017326.193814][7164:7166] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
[1685017326.194380][7164:7166] CHIP:EM: <<< [E:24737i S:0 M:116781974] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
[1685017326.194570][7164:7166] CHIP:IN: (U) Sending msg 116781974 to IP address 'UDP:[fd11:22::add3:c4f7:a475:2c77]:5540'
[1685017326.194864][7164:7166] CHIP:SC: Sent Sigma1 msg
[1685017326.194890][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
[1685017327.486801][7164:7166] CHIP:EM: Retransmitting MessageCounter:116781974 on exchange 24737i Send Cnt 1
[1685017327.486992][7164:7166] CHIP:IN: (U) Sending msg 116781974 to IP address 'UDP:[fd11:22::add3:c4f7:a475:2c77]:5540'
[1685017327.567850][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017327.568256][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017327.568268][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017327.568276][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017327.568285][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.109630][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017328.571646][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.571711][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.571721][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.571730][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.571738][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017328.711525][7164:7166] CHIP:EM: Retransmitting MessageCounter:116781974 on exchange 24737i Send Cnt 2
[1685017328.711603][7164:7166] CHIP:IN: (U) Sending msg 116781974 to IP address 'UDP:[fd11:22::add3:c4f7:a475:2c77]:5540'
[1685017330.575386][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017330.575651][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017330.575688][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017330.575723][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017330.575766][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017330.582724][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017330.582998][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017330.772520][7164:7166] CHIP:EM: Retransmitting MessageCounter:116781974 on exchange 24737i Send Cnt 3
[1685017330.772662][7164:7166] CHIP:IN: (U) Sending msg 116781974 to IP address 'UDP:[fd11:22::add3:c4f7:a475:2c77]:5540'
[1685017333.192386][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017334.100934][7164:7166] CHIP:EM: Retransmitting MessageCounter:116781974 on exchange 24737i Send Cnt 4
[1685017334.101021][7164:7166] CHIP:IN: (U) Sending msg 116781974 to IP address 'UDP:[fd11:22::add3:c4f7:a475:2c77]:5540'
[1685017334.588850][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017334.589056][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017334.589085][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017334.589109][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017334.589132][7164:7166] CHIP:DIS: SRV record already actively processed.
[1685017335.667296][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017335.667462][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017338.329580][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017339.465474][7164:7166] CHIP:EM: Failed to Send CHIP MessageCounter:116781974 on exchange 24737i sendCount: 4 max retries: 4
[1685017340.797616][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017340.797860][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017342.300358][7164:7166] CHIP:SC: CASESession timed out while waiting for a response from the peer. Current state was 1
[1685017342.300490][7164:7166] CHIP:IN: SecureSession[0x7fccac013ee0]: Released - Type:2 LSID:31219
[1685017342.300520][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
[1685017342.300533][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
[1685017342.300544][7164:7166] CHIP:DIS: OperationalSessionSetup:attempts done: 1, attempts left: 2, retry delay 1s, status src/system/SystemLayerImplSelect.cpp:167: Success
[1685017342.300548][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 6
[1685017342.300561][7164:7166] CHIP:CTL: Session establishment failed for <0000000000000001, 1>, error: src/protocols/secure_channel/CASESession.cpp:496: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 8 seconds
[1685017342.300570][7164:7166] CHIP:CTL: Arming failsafe (68 seconds)
[1685017342.300602][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017342.300610][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017342.300669][7164:7166] CHIP:EM: <<< [E:24738i S:31218 M:130712343] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017342.300803][7164:7166] CHIP:IN: (S) Sending msg 130712343 on secure session with LSID: 31218
[1685017342.301897][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017342.372857][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017342.372957][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017342.373193][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017342.373247][7164:7166] CHIP:EM: >>> [E:24738i S:31218 M:110006094] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017342.373291][7164:7166] CHIP:EM: Found matching exchange: 24738i, Delegate: 0x7fccb4073368
[1685017342.373298][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017342.373307][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017342.373309][7164:7166] CHIP:DMG: {
[1685017342.373310][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017342.373312][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017342.373315][7164:7166] CHIP:DMG: 	[
[1685017342.373316][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017342.373319][7164:7166] CHIP:DMG: 		{
[1685017342.373320][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017342.373322][7164:7166] CHIP:DMG: 			{
[1685017342.373324][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017342.373326][7164:7166] CHIP:DMG: 				{
[1685017342.373360][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017342.373363][7164:7166] CHIP:DMG: 					ClusterId = 0x30,
[1685017342.373365][7164:7166] CHIP:DMG: 					CommandId = 0x1,
[1685017342.373367][7164:7166] CHIP:DMG: 				},
[1685017342.373369][7164:7166] CHIP:DMG:
[1685017342.373371][7164:7166] CHIP:DMG: 				CommandFields =
[1685017342.373373][7164:7166] CHIP:DMG: 				{
[1685017342.373375][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017342.373378][7164:7166] CHIP:DMG: 					0x1 = "" (0 chars),
[1685017342.373379][7164:7166] CHIP:DMG: 				},
[1685017342.373381][7164:7166] CHIP:DMG: 			},
[1685017342.373383][7164:7166] CHIP:DMG:
[1685017342.373385][7164:7166] CHIP:DMG: 		},
[1685017342.373387][7164:7166] CHIP:DMG:
[1685017342.373388][7164:7166] CHIP:DMG: 	],
[1685017342.373391][7164:7166] CHIP:DMG:
[1685017342.373392][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017342.373393][7164:7166] CHIP:DMG: },
[1685017342.373403][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1685017342.373410][7164:7166] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
[1685017342.373445][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017343.312350][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 6 --> 2
[1685017343.515730][7164:7166] CHIP:DIS: Checking node lookup status after 203 ms
[1685017344.982532][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017347.458241][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017347.458663][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017350.021998][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017352.498963][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017352.499193][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017355.062025][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017357.538064][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017357.538524][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017360.102028][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017362.577348][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017362.577478][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017365.142940][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017367.617372][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017367.617486][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017370.182206][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017372.658197][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017372.658447][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017374.324628][7164:7166] CHIP:DIS: Timeout waiting for mDNS resolution.
[1685017375.230382][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017377.697277][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017377.697436][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017380.262025][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017382.759080][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017382.759205][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017385.347073][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017387.823839][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017387.824377][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017388.314214][7164:7166] CHIP:DIS: Checking node lookup status after 45002 ms
[1685017388.314279][7164:7166] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1685017388.314283][7164:7166] CHIP:DIS: Retrying operational DNS-SD discovery. Attempts remaining: 1
[1685017388.315346][7164:7166] CHIP:CTL: Session establishment failed for <0000000000000001, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 60 seconds
[1685017388.315474][7164:7166] CHIP:CTL: Arming failsafe (120 seconds)
[1685017388.315493][7164:7166] CHIP:DMG: ICR moving to [AddingComm]
[1685017388.315496][7164:7166] CHIP:DMG: ICR moving to [AddedComma]
[1685017388.315561][7164:7166] CHIP:EM: <<< [E:24739i S:31218 M:130712344] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1685017388.315568][7164:7166] CHIP:IN: (S) Sending msg 130712344 on secure session with LSID: 31218
[1685017388.315800][7164:7166] CHIP:DMG: ICR moving to [CommandSen]
[1685017388.406902][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017388.408503][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017388.408586][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017388.408701][7164:7166] CHIP:EM: >>> [E:24739i S:31218 M:110006095] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1685017388.408739][7164:7166] CHIP:EM: Found matching exchange: 24739i, Delegate: 0x7fccb4073368
[1685017388.408746][7164:7166] CHIP:DMG: ICR moving to [ResponseRe]
[1685017388.408755][7164:7166] CHIP:DMG: InvokeResponseMessage =
[1685017388.408756][7164:7166] CHIP:DMG: {
[1685017388.408758][7164:7166] CHIP:DMG: 	suppressResponse = false,
[1685017388.408760][7164:7166] CHIP:DMG: 	InvokeResponseIBs =
[1685017388.408763][7164:7166] CHIP:DMG: 	[
[1685017388.408764][7164:7166] CHIP:DMG: 		InvokeResponseIB =
[1685017388.408767][7164:7166] CHIP:DMG: 		{
[1685017388.408768][7164:7166] CHIP:DMG: 			CommandDataIB =
[1685017388.408770][7164:7166] CHIP:DMG: 			{
[1685017388.408772][7164:7166] CHIP:DMG: 				CommandPathIB =
[1685017388.408774][7164:7166] CHIP:DMG: 				{
[1685017388.408776][7164:7166] CHIP:DMG: 					EndpointId = 0x0,
[1685017388.408778][7164:7166] CHIP:DMG: 					ClusterId = 0x30,
[1685017388.408780][7164:7166] CHIP:DMG: 					CommandId = 0x1,
[1685017388.408781][7164:7166] CHIP:DMG: 				},
[1685017388.408783][7164:7166] CHIP:DMG:
[1685017388.408785][7164:7166] CHIP:DMG: 				CommandFields =
[1685017388.408787][7164:7166] CHIP:DMG: 				{
[1685017388.408789][7164:7166] CHIP:DMG: 					0x0 = 0,
[1685017388.408791][7164:7166] CHIP:DMG: 					0x1 = "" (0 chars),
[1685017388.408824][7164:7166] CHIP:DMG: 				},
[1685017388.408827][7164:7166] CHIP:DMG: 			},
[1685017388.408830][7164:7166] CHIP:DMG:
[1685017388.408831][7164:7166] CHIP:DMG: 		},
[1685017388.408834][7164:7166] CHIP:DMG:
[1685017388.408835][7164:7166] CHIP:DMG: 	],
[1685017388.408838][7164:7166] CHIP:DMG:
[1685017388.408839][7164:7166] CHIP:DMG: 	InteractionModelRevision = 1
[1685017388.408840][7164:7166] CHIP:DMG: },
[1685017388.408850][7164:7166] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1685017388.408856][7164:7166] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
[1685017388.408861][7164:7166] CHIP:DMG: ICR moving to [AwaitingDe]
[1685017388.514952][7164:7166] CHIP:DIS: Checking node lookup status after 200 ms
[1685017390.981222][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017393.447371][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017393.447720][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017396.057416][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017398.532978][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017398.533211][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017401.144438][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017403.618599][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017403.618747][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017406.182824][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017408.659082][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017408.659142][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017411.267695][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017413.742923][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017413.743486][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017416.357414][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017418.828777][7164:7165] CHIP:DL: Indication received, conn = 0x7fccb40710e0
[1685017418.829059][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1685017419.321870][7164:7166] CHIP:DIS: Timeout waiting for mDNS resolution.
[1685017421.437699][7164:7166] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1685017422.424051][7164:7164] CHIP:CTL: Shutting down the commissioner
[1685017422.424128][7164:7164] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1685017422.424319][7164:7164] CHIP:DIS: Closing all BLE connections
[1685017422.424362][7164:7164] CHIP:IN: Clearing BLE pending packets.
[1685017422.425129][7164:7164] CHIP:BLE: Auto-closing end point's BLE connection.
[1685017422.425179][7164:7164] CHIP:DL: Closing BLE GATT connection (con 0x7fccb40710e0)
[1685017422.425196][7164:7165] CHIP:DL: BluezDisconnect peer=FA:FE:EA:D2:27:71
[1685017422.608868][7164:7165] CHIP:DL: Bluez disconnected
[1685017422.609036][7164:7165] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1685017422.609026][7164:7164] CHIP:IN: SecureSession[0x7fccac00acf0]: MarkForEviction Type:1 LSID:31218
[1685017422.609072][7164:7164] CHIP:SC: SecureSession[0x7fccac00acf0, LSID:31218]: State change 'kActive' --> 'kPendingEviction'
[1685017422.609091][7164:7164] CHIP:IN: SecureSession[0x7fccac00acf0]: Released - Type:1 LSID:31218
[1685017422.609101][7164:7164] CHIP:CTL: Shutting down the controller
[1685017422.609110][7164:7164] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Cancelling incomplete address resolution as device is being deleted.
[1685017422.609128][7164:7164] CHIP:CTL: Device connection failed. Error src/app/OperationalSessionSetup.cpp:450: CHIP Error 0x00000074: The operation has been cancelled
[1685017422.609136][7164:7164] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1685017422.609143][7164:7164] CHIP:FP: Forgetting fabric 0x1
[1685017422.609155][7164:7164] CHIP:TS: Pending Last Known Good Time: 2023-05-25T11:03:16
[1685017422.609219][7164:7164] CHIP:TS: Previous Last Known Good Time: 2023-05-25T11:03:16
[1685017422.609225][7164:7164] CHIP:TS: Reverted Last Known Good Time to previous value
[1685017422.609242][7164:7164] CHIP:CTL: Shutting down the commissioner
[1685017422.609246][7164:7164] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1685017422.609270][7164:7164] CHIP:CTL: Shutting down the controller
[1685017422.609274][7164:7164] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1685017422.609342][7164:7164] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1685017422.609403][7164:7164] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1685017422.609416][7164:7164] CHIP:FP: Shutting down FabricTable
[1685017422.609422][7164:7164] CHIP:TS: Pending Last Known Good Time: 2023-05-25T11:03:16
[1685017422.609449][7164:7164] CHIP:TS: Previous Last Known Good Time: 2023-05-25T11:03:16
[1685017422.609453][7164:7164] CHIP:TS: Reverted Last Known Good Time to previous value
[1685017422.609598][7164:7164] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-B9qI0K)
[1685017422.609815][7164:7164] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1685017422.609845][7164:7164] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1685017422.609853][7164:7164] CHIP:DL: Inet Layer shutdown
[1685017422.609860][7164:7164] CHIP:DL: BLE shutdown
[1685017422.610283][7164:7164] CHIP:DL: System Layer shutdown
[1685017422.610428][7164:7164] CHIP:TOO: Run command failure: ../examples/chip-tool/commands/common/CHIPCommand.cpp:537: CHIP Error 0x00000032: Timeout
Can you please help me?
Thanks in advance
Paula.
    I've been looking into the logs, but as of yet I haven't found anything conclusive to what might cause the commissioning to fail. I will continue to look into it.
    I have some checks I would like you to go through which is from a case with similar issues observed. Do note that the tips are for a setup using a RPI for the OTBR, so disregard steps that are solely for the RPi
    1. Ensure that the chip-tool cache is cleaned after each unsuccessful command:
      rm -rf /tmp/chip_*
    2. Ensure that the RPi OS is 64 bit (we use Ubuntu 20.04 LTS 64 bit on daily basis, this distro is also used for Matter certification)
    3. It might be that the docker setup blocks the router advertisements on the RPi. Following lines may help is such a case (run on RPi host, replace the wlan0 with proper WiFi iface name if needed)
      1. sudo sysctl net.ipv6.conf.wlan0.accept_ra=2
      2. sudo sysctl net.ipv6.conf.wlan0.accept_ra_rt_info_max_plen=128
    4. Also I advice to run the otbr container in the following fashion on the RPi:
      1. sudo docker run --rm -it --privileged -d --network host --name otbr --volume /dev/ttyACM0:/dev/ttyACM0 nrfconnect/otbr:1813352 --radio-url spinel+hdlc+uart:///dev/ttyACM0 -B wlan0
    It is also worth mentioning that there might be some complications when running the OTBR in VM. If the co-processor restarts for some reason, it is not guaranteed that the VM automatically gets access to the device after the device reboots. If so, then you will have to manually give access to it every time. If possible, could you also check if you see the same behavior if you swap to a non-VM Linux distro (Ubuntu 20.04) to run Docker and CHIP?
    Andreas
