No hard fault with SoftDevice and RAM off after WFI
Hi Folks,
i have implementet a sleep mode by using only the RTC timer with the 32KHz OSC and the WFI instruction. The current consumtion is around 1.7µA (all peripherals including the RAM and HSXOSC is turned off). On timeout, the chip wake up and a hard fault interrupt is generated. In the Hard_Fault() handler the NVIC_SystemReset() is called and the controller will restart. The wakeup / restart reason is detected with the "NRF_POWER->GPREGRET" register. I have assigned a special value to the register before go to sleep mode. This works fine without SoftDevice. But if i use the SoftDevice (SD310 in this case) the controller hangs after wake up. The SD is disabled before power down the peripherals. It seems to be there is no hard fault condition generated in this case. Why?
