structure memory allocation error nrf9160
I'm working on a project with nrf9160. i have develop my code to send frame in LTE.
It's works great during less than 1 hour and after i receive a printk message that said : "structure memory allocation error"
To send my frame, i use 2 memory allocation that i free when i call my work handler.
I have disable the part which use my send frame and the issue don't appear.
For the moment i don't have found any clue that allow me to explain this problem, maybe i miss something.
Could give me an advice about this ?
uint8_t send_frame(uint8_t *data_buffer, uint8_t data_len, uint8_t message_type){
    // Allocate memory for the work item data
    struct comm_item_data *work_data = k_malloc(sizeof(struct comm_item_data));
    if (!work_data) {
        printk("structure memory allocation error\n");
        // Handle memory allocation failure of structure
        return(1);
    work_data->data_buffer = k_malloc(data_len);
    if (!work_data->data_buffer) {
        printk("data memory allocation error\n");
        // Handle memory allocation failure of data buffer
        return(1);
    // Initialize the work item
    k_work_init(&work_data->work, comm_work_handler);
    memcpy(work_data->data_buffer, data_buffer, data_len);
    work_data->data_len = data_len;
    work_data->message_type = message_type;
    k_work_submit_to_queue(&comm_workqueue, &work_data->work);
    return(0);
void comm_work_handler(struct k_work *work) {
    uint8_t encoded_buffer[MAX_ENC_FRAME_LEN];
    uint8_t enc_buff_len;
    uint8_t ret = false;
    struct comm_item_data *work_data = CONTAINER_OF(work, struct comm_item_data, work);
    printk("start comm work\n");
    if(device_info.modem_state == 0 ){
        printk("Turn modem on\n");
        lte_lc_normal();
    //Wait for the LTE link UP
    k_sem_take(&lte_connected, K_FOREVER);
    printk("Send frame type %s : ", work_data->message_type == MESSAGE_TYPE_OOB ? "OOB":"STD");
    print_bin(work_data->data_buffer, work_data->data_len, 0);
    //encode and crypt the message
    enc_buff_len = encode_frame(encoded_buffer, work_data->data_buffer, work_data->data_len, work_data->message_type);
    if(enc_buff_len > 0){
        switch( send_data_udp(encoded_buffer, enc_buff_len) ){
            case 0:
                ret = true;
                ret = false;
    if(work_data->message_type == MESSAGE_TYPE_STD){
        send_uart_data_char(ret == 0 ?"+SEND OK\r\n":"+SEND ERROR\r\n");
    printk("send data ret %d\n",ret);
    k_free(work_data->data_buffer);
    k_free(work_data);
    k_sem_give(&lte_connected);
    printk("psm state %d\n", device_info.psm_state);
    if(device_info.modem_state == 1 && device_info.psm_state == 0){
        printk("Turn modem off\n");
        lte_lc_offline();
        device_info.modem_state = 0;
//In my file.h
struct comm_item_data {
    struct k_work work;
    uint8_t *data_buffer;
    uint8_t data_len;
    uint8_t message_type;
best regards,
Lam
