Hello and thank you for your help.
I am working on a project that requires a separate initiator and reflector for MCPD distance measurement. I believe the sample assumes a dual initiator-reflector role for all devices involved in the measurement. I am attempting to use the distance measurement library from the API documentation, but I seem to have issues synchronising the initiator and reflector.
I am using the same method of synchronising DM request additions as the sample. The reflector adds requests as part of the callback when its advertisement is scanned:
static void adv_scanned_cb(struct bt_le_ext_adv *adv, struct bt_le_ext_adv_scanned_info *info) { struct dm_request req; bt_addr_le_copy(&req.bt_addr, info->addr); req.role = DM_ROLE_REFLECTOR; req.ranging_mode = DM_RANGING_MODE_MCPD; req.rng_seed = sys_rand32_get(); req.start_delay_us = 0; req.extra_window_time_us = 0; int err = dm_request_add(&req); if (err) printk("Error adding DM request: %d\n", err); else printk("DM request added.\n"); }
The initiator adds DM requests when its BLE scan filters match the advertisement sent by the relfector:
bool handle_adv(struct bt_data *data, void *user_data) { struct dm_request req; switch(data->type) { case BT_DATA_UUID128_ALL: bt_addr_le_copy(&req.bt_addr, user_data); req.role = DM_ROLE_INITIATOR; req.ranging_mode = DM_RANGING_MODE_MCPD; req.rng_seed = sys_rand32_get(); req.start_delay_us = 0; req.extra_window_time_us = 0; int err = dm_request_add(&req); if (err) printk("Error adding DM request:%d\n", err); else printk("DM request added.\n"); return false; default: return true; } return true; }
The data_ready callback set with dm_init was never called on either side. I found that the calculation() function in dm.h was never called in the dm_thread, where the nrf_dm_status was always set to 1 (NRF_DM_STATUS_FAIL_SYNC).
if (dm_context.nrf_dm_status == NRF_DM_STATUS_SUCCESS) { calculation(); } else { LOG_DBG("Ranging failed (nrf_dm status: %d)", dm_context.nrf_dm_status); }
And this was because nrf_dm_proc_execute() would always fail in mpsl_timeslot_callback().
nrf_dm_status = nrf_dm_configure(&dm_config); LOG_DBG("Status after configuration: %d\n", nrf_dm_status); // always 0 if (nrf_dm_status == NRF_DM_STATUS_SUCCESS) { nrf_dm_status = nrf_dm_proc_execute(timeslot_ctx.curr_req.window_length_us); LOG_DBG("Status after proc_execute: %d\n", nrf_dm_status); // always 1 }
A previous question (Concerns about Distance Measurement library ) was asked regarding a similar problem, and the response mentioned using the delay and extending the length of the measurement window. May I know whether this is supposed to be on the initiator or reflector side and what the typical values might be? I've tried a large range and still had the same problem so I was hoping for some clarity on this.
I have CONFIG_DM_MIN_TIME_BETWEEN_TIMESLOTS_US set to 5000 on both initiator and reflector and CONFIG_DM_INITIATOR_DELAY_US at 2000 on the initiator.
Device used: 2 nRF52840DKs
SDK: nRF Connect v2.2.99
Thank you.
