FatFs f_readdir() never indicates end of directory if file count is max (65536 files)
  • SDK: 15.2
  • SoftDevice: s140_nrf52_6.1.0
  • FreeRTOS
  • Hardware: nRF52840 (Custom boards)
  • SD card formatted as FAT32 (No ExFAT)
I have been stress testing the FatFS library provided in the Nordic SDK (Elm-Chan FatFs) using an 8 GB SD card. The directory structure is as follows:
/dir1/dir2/dir3
'dir3' contains 65534 files of size 12 KB. They each have unique files names but their contents are identical.
My code scans all files in the directory similar to the following (I am omitting f_opendir() etc as it is not related to the issue).
FRESULT fresult;
DIR dir;
FILINFO fileInfo;
while((fresult = f_readdir(&dir, &fileInfo)) == FR_OK)
   if(fileInfo.fname[0] == NULL)
      break;  /* end of files */
   printf("File name: %s", fileInfo.fname);
The issue is that this while() loop will never exit because f_readdir() will always return FR_OK. After digging into the FatFS library, I discovered the following:
FRESULT f_readdir (
	DIR* dp,			/* Pointer to the open directory object */
	FILINFO* fno		/* Pointer to file information to return */
	FRESULT res;
	FATFS *fs;
	DEF_NAMBUF
	res = validate(&dp->obj, &fs);	/* Check validity of the directory object */
	if (res == FR_OK) {
		if (!fno) {
			res = dir_sdi(dp, 0);			/* Rewind the directory object */
		} else {
			INIT_NAMBUF(fs);
			res = dir_read(dp, 0);			/* Read an item */
			if (res == FR_NO_FILE) res = FR_OK;	/* Ignore end of directory */
			if (res == FR_OK) {				/* A valid entry is found */
				get_fileinfo(dp, fno);		/* Get the object information */
				res = dir_next(dp, 0);		/* Increment index for next */
				if (res == FR_NO_FILE) res = FR_OK;	/* Ignore end of directory now */   <--------- ISSUE
			FREE_NAMBUF();
	LEAVE_FF(fs, res);
See the line above "if (res == FR_NO_FILE) res = FR_OK; /* Ignore end of directory now */"
Looking into dir_next() you see the following:
ofs = dp->dptr + SZDIRE;	/* Next entry */
if (!dp->sect || ofs >= (DWORD)((_FS_EXFAT && fs->fs_type == FS_EXFAT) ? MAX_DIR_EX : MAX_DIR)) return FR_NO_FILE;	/* Report EOT when offset has reached max value */
Summary:
  • dir_next() is returning FR_NO_FILE when it tries to increment the directory pointer because it now equals MAX_DIR.
  • f_readdir() checks for FR_NO_FILE, and doesn't return it. Instead, it returns FR_OK.
  • The while loop never exits and continues to read the same file over and over because the directory pointer cannot be incremented beyond MAX_DIR resulting in fresult always returning FR_OK.
Questions:
1. Is this a bug in the FatFs library, or is this intended behavior?
2. If a bug, how should this be fixed? If not a bug, what is the best practice to handle this scenario where a directory contains the maximum number of files supported by FAT32?
Derek
  • I found a temporary solution...
    FRESULT fresult;
    DIR dir;
    FILINFO fileInfo;
    char prevFileName[FAT_MAX_FILE_NAME_LEN + 1] = {NULL}; // +1 for NULL
       // Check for the last file. This handles the edge case where a directory contains the
       // maximum number of files (65536). If this happens, f_readdir() will always return FR_OK
       // and fileInfo.fname[0] will always point to the last file in the directory.
       if (strcmp(fileInfo.fname, prevFileName) == NULL)
          // Last file reached, exit the loop
       // Update the previous file name
       strncpy(prevFileName, fileInfo.fname, sizeof(prevFileName));
  • I am glad to hear that you found something that works.
    The fatfs library that is used in our nRF5 SDK is an external library, so I don't have that much in-depth knowledge of its workings and limitations, but I agree that it shouldn't hang in that while loop forever. That doesn't seem like the intended behavior.
    BR,
    Edvin
