Warning: "attempt to assign the value 'y' to the undefined symbol"
I'm having issues when building the peripheral_nfc_pairing and central_nfc_pairing samples from ncs 2.2.0 in VSCode. I've build before and haven't gotten any errors. I saw that post and try to update SDK via Toolchain Manager and run "west update" with the command prompt, but this doesn't work. When building I get the following in the terminal:
Building central_nfc_pairing
/bin/sh -c west build --build-dir /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/build /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing --pristine --board nrf52dk_nrf52832 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf"
WARNING: ZEPHYR_BASE=/home/andreribeiro/zephyrproject/zephyr in the calling environment will be used,
but the zephyr.base config option in /home/andreribeiro/ncs/v2.2.0 is "zephyr"
which implies a different ZEPHYR_BASE=/home/andreribeiro/ncs/v2.2.0/zephyr
To disable this warning in the future, execute 'west config --global zephyr.base-prefer env'
-- Application: /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing
-- CMake version: 3.20.5
-- Found Python3: /home/andreribeiro/ncs/toolchains/v2.2.0/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: /home/andreribeiro/.cache/zephyr
-- Zephyr version: 3.3.99 (/home/andreribeiro/zephyrproject/zephyr)
-- Board: nrf52dk_nrf52832
-- Found host-tools: zephyr 0.15.1 (/home/andreribeiro/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (/home/andreribeiro/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: /home/andreribeiro/ncs/toolchains/v2.2.0/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: /home/andreribeiro/zephyrproject/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
-- Found devicetree overlay: /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/nrf52dk_nrf52832.overlay
-- Generated zephyr.dts: /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/build/zephyr/dts.cmake
Parsing /home/andreribeiro/zephyrproject/zephyr/Kconfig
Loaded configuration '/home/andreribeiro/zephyrproject/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
Merged configuration '/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf'
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:7: warning: attempt to assign the value 'y' to the undefined symbol NCS_SAMPLES_DEFAULTS
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:16: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:17: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN_FILTER_ENABLE
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:18: warning: attempt to assign the value '1' to the undefined symbol BT_SCAN_ADDRESS_CNT
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:34: warning: attempt to assign the value 'y' to the undefined symbol ST25R3911B_LIB
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:37: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:38: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_RECORD
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:39: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_TEXT_RECORD
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:40: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_MSG
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:41: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_PARSER
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:42: warning: attempt to assign the value 'y' to the undefined symbol NFC_T2T_PARSER
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:43: warning: attempt to assign the value 'y' to the undefined symbol NFC_T4T_HL_PROCEDURE
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:44: warning: attempt to assign the value 'y' to the undefined symbol NFC_TNEP_POLLER
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:45: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_LE_OOB_REC
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:46: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_LE_OOB_REC_PARSER
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:47: warning: attempt to assign the value 'y' to the undefined symbol NFC_NDEF_CH_MSG
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:48: warning: attempt to assign the value 'y' to the undefined symbol NFC_TNEP_CH
/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf:66: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
error: Aborting due to Kconfig warnings
CMake Error at /home/andreribeiro/zephyrproject/zephyr/cmake/modules/kconfig.cmake:329 (message):
  command failed with return code: 1
  /home/andreribeiro/zephyrproject/zephyr/cmake/modules/zephyr_default.cmake:113 (include)
  /home/andreribeiro/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/andreribeiro/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:9 (find_package)
FATAL ERROR: command exited with status 1: /home/andreribeiro/ncs/toolchains/v2.2.0/usr/local/bin/cmake -DWEST_PYTHON=/home/andreribeiro/ncs/toolchains/v2.2.0/usr/local/bin/python3.8 -B/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/build -GNinja -DBOARD=nrf52dk_nrf52832 -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing/prj.conf -S/home/andreribeiro/ncs/v2.2.0/nrf/samples/bluetooth/central_nfc_pairing
Any advice would be greatly appreciated.
