DevAcademy Bluetooth LE connection problems
I am going through the DevAcademy Bluetooth LE lessons, using nRF5 DK. But I run into problems directly in the exercise of the first lesson. Everything goes fine to step 4.2, but connecting doesn’t work. Connection is established, but almost immediately disconnection happens. LED2 is lit for a short moment. The print outs are like this:
No matter how many times I try, disconnection always happens this way. I have also tested to connect via the Bluetooth low energy desktop app using the Nordic BLE dongle. Then the connection works fine. I have tested with both nRF Connect SDK 2.3.0 and 2.0.0, and the scenario is the same for both versions.
In the desktop app it is possible to read the button state and activate notifications (and receive updates when the button is pressed). But I am not able to control LED3. I have put a breakpoint in write_led() in lbs.c (C:\...\v2.3.0\nrf\subsys\bluetooth\services\lbs.c), but the breakpoint isn't hit when I write to the LED characteristic. Though, a breakpoint in read_button() will be hit when I click "Nordic LED and Button Service", so I should be in the correct file.
Lars
  • Hello
    What phone and OS are you using when the connection doesn't work? It could be the case that the connection parameters aren't compatible with your phone OS or something similar.
    If you could set up a BLE sniffer and share logs of the communication between your devices as the disconnection happens, that would be very helpful.
    Einar
    I have a Samsung S21 5G with Android version 13. My computer runs Windows 10.
    Now I have installed the BLE Sniffer and captured some communication. In this file I should have recorded two attempts to connect.
    Lars
    4214.Capture.pcapng
    You also seem to have recorded a lot of other things.
    If you could let me know which of these addresses belong to your devices, I might be able to help you.
  • Yes, I know there is a lot of data. I am new to this and have problems with filtering. So a fast solution now was to take my laptop and go to a place where there should be no other BLE-devices within range. I have added two capture files, one with only the dk powered, and one where I have turned on Bluetooth on my phone and tried to connect two times. I am quite confuced around what is captured. I thought the DK, phone and computer would be the only BLE devices around, but there are more Sources than three. How come? Can my phone and computer have several sources? Is it possible to figure out what is happening when the connection doesn't work?
    Capture dk.pcapng
    Capture dk and phone, 2 tries.pcapng
    Seems like these are the only devices around this time from what I can see.
    f7 seems to be your DK, 35 has a Microsoft tag so I assume that's your laptop, 5a has a Google tag and seems to be your Android phone scanning for devices.
    But yes your phone seems to use a different source when trying to connect.
    What I think is weird is that after the initial connect packet from your phone, nothing more seems to happen until your DK continues advertising 500ms later.
    Are you filtering for LE LL packets? In that case I would be interested in seeing this log without such a filter because some of the communication on setting up a connection happens on different protocols.
    With that said, this is what error code 42 refers to:
    Might be a problem specific to your phone, have you tried with other Android phones?
    -Einar
