Mesh and peripheral coexistence nRF5340
I need help with the example "ble_peripheral_lbs_coex "from the sdk-nrf V2.4.0 for the nRF5340.
I just added a hci_rpmsg.conf file in the child_image folder. with follow content:
# Copy controller configuration from prj.conf
CONFIG_BT_CTLR_DATA_LENGTH_MAX=37
# Disable unused Bluetooth features
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
The output is as follows:
Initializing...
[00:00:00.259,216] <inf> fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.259,216] <inf> fs_nvs: alloc wra: 0, fa8
[00:00:00.259,246] <inf> fs_nvs: data wra: 0, 6c
[00:00:00.285,675] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.285,705] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.285,736] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.286,285] <inf> bt_hci_core: No ID address. App must call settings_load()
Bluetooth initialized
[00:00:00.515,808] <inf> bt_hci_core: Identity: E9:9B:27:0A:4F:67 (random)
[00:00:00.515,838] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.515,869] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Mesh initialized
Created a new identity for LBS: 1
ASSERTION FAIL @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:330
[00:00:10.534,912] <err> os: r0/a1: 0x00000003 r1/a2: 0x20002b50 r2/a3: 0x20002b50
[00:00:10.534,912] <err> os: r3/a4: 0x20003bd0 r12/ip: 0x00000003 r14/lr: 0x00006f7d
[00:00:10.534,942] <err> os: xpsr: 0x61000000
[00:00:10.534,942] <err> os: Faulting instruction address (r15/pc): 0x00006f88
[00:00:10.534,973] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:10.535,003] <err> os: Current thread: 0x20002b50 (unknown)
�*** Booting Zephyr OS build v3.3.99-ncs1 ***ng system
Apparently a timeout occurs in hci_core.c:
BT_ASSERT_MSG(err == 0, "command opcode 0x%04x timeout with err %d", opcode, err);
Can anyone please make the example compatible for the nrf5340?
Thank you in advance, for your assistance.
Fluke
  • now I have added this to the conf file of the net core: CONFIG_BT_EXT_ADV_MAX_ADV_SET=6
    the hci_rpmsg.conf now:
    CONFIG_BT_BUF_ACL_RX_SIZE=73
    CONFIG_BT_BUF_ACL_TX_SIZE=37
    # 5 sets are used by Bluetooth mesh, 1 is needed for the sample advs.
    then I get the following output with errors:
    [00:00:00.516,357] <inf> bt_hci_core: Identity[0]: CD:DF:93:AB:12:3E (random)
    [00:00:00.516,510] <inf> bt_hci_core: Identity[1]: F3:B9:D5:9D:A2:D9 (random)
    [00:00:00.516,540] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
    [00:00:00.516,540] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
    Mesh initialized
    Recovered identity for LBS: 1
    Advertising successfully started
    [00:00:00.619,720] <wrn> bt_hci_core: opcode 0x2039 status 0x0d
    [00:00:00.619,781] <err> bt_adv: Failed to start advertiser
    [00:00:00.619,781] <err> bt_mesh_adv_ext: Advertising failed: err -5
    If I understand corectly, Bluetooth mesh uses the advertiser as its main channel of communication.
    So I need  to enable the extended advertising with two simultaneous advertising sets.
    BLE-Mesh is on the top of Bluetooth V4. I guess that Mesh uses the legacy advertising and normal BLE-Services use the extended advertising feature of Bluetooth V5?
    Why in the sample the CONFIG_BT_EXT_ADV_MAX_ADV_SET is set to 6 and not 2 sets?
    It seems that only one advertising channel can be started successfully.
    Is there any conflict with the netcore?
    Kind regards
    Fluke
  • Hi.
    Apologize for the long delay in response.
    As you can see from the documentation (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrf/samples/bluetooth/mesh/ble_peripheral_lbs_coex/README.html)  this sample currently doesn't support the nRF5340, so I haven't tested this yet.
    I will try to get some time this week and see if I'm able to get the example working on the nRF5340.
    Br,
    Joakim
    have you had time to try out the example?
    In the meantime I found out something else. If I reduce CONFIG_BT_ID_MAX from 2 to 1, the advertising works on both channels. However, only until I connect on BLE or do a provisioning. After that, advertising on the other channel no longer works. When I disconnect or perform a mesh reset (depending on how I was connected), then the advertising works again.
    Kind regards
    Fluke
  • Hello?
    Are you still working on a solution?
  • I guess I found a workaround.
    I came across it in the Mesh light example. There, besides Mesh, the SMP service is also started for a DFU. It is interesting that for the nrf53 the extended advertising does not work. However, point-to-point DFU over Bluetooth is supported by default. You only have to enable it via the Kconfig CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU. I have tested it and it works. What is not quite clear to me, the advertising is not explicitly started in the code?
    you can test it yourself. Just use the example sdk-nrf/samples/bluetooth/mesh
    /light the prj.conf with the following options extend with the nrf53 build:
    # Enable point to point DFU over SMP
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
