nRF9160dk Bluetooth HCI LPUART "Empty receiver state:4"
I am using an nRF9160dk with the nRF52840 acting as the BT controller running the Bluetooth: HCI low power UART sample (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/hci_lpuart/README.html).
Development setup:
- nRF Connect SDK v2.3.0
- nRF9160DK, revision 1.1.0
The board scans correctly and I can connect successfully with an advertising device, however every time I reset the nRF9160DK (with the reset button) I get the following error:
[00:00:00.529,144] <wrn> lpuart: req pin low when expected high
[00:00:00.529,235] <err> lpuart: Empty receiver state:4
[00:00:01.226,196] <wrn> bt_hci_core: opcode 0x0000 pool id 3 pool 0x2000cc50 != &hci_cmd_pool 0x2000cca8
I use the following code on the nRF9160:
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/console/console.h>
#include <zephyr/bluetooth/uuid.h>
#include <bluetooth/scan.h>
LOG_MODULE_REGISTER(main);
/** @brief Random generated UUID. **/
#define BT_UUID_RAND_VAL \
    BT_UUID_128_ENCODE(0xf249bbe7, 0x4d87, 0x4322, 0xb9b2, 0x52b56dd0108e)
#define BT_UUID_RAND \
    BT_UUID_DECLARE_128(BT_UUID_RAND_VAL)
static int start_scan(void) {
    int err = bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
    if (err) {
        LOG_ERR("Scanning failed to start (err %d)", err);
	LOG_INF("Scanning successfully started");
    return err;
static void scan_filter_match(struct bt_scan_device_info *device_info, struct bt_scan_filter_match *filter_match, bool connectable)
	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
	LOG_INF("Device found: %s", addr);
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info, struct bt_conn *conn)
	LOG_INF("Connecting to device: %s", addr);
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, scan_connecting_error, scan_connecting);
static void scan_init(void)
    int err;
	struct bt_le_scan_param scan_param = {
		.type = BT_LE_SCAN_TYPE_ACTIVE,
		.options = BT_LE_SCAN_OPT_FILTER_DUPLICATE,
		.interval = 0x0010,
		.window = 0x0010,
    struct bt_scan_init_param scan_init = {
        .scan_param = &scan_param,
		.connect_if_match = true,
		.conn_param = BT_LE_CONN_PARAM_DEFAULT,
    bt_scan_init(&scan_init);
    bt_scan_cb_register(&scan_cb);
	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_RAND);
	if (err)
		LOG_ERR("Scanning filters cannot be set, err %d", err);
		return;
	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
	if (err)
		LOG_ERR("Filters cannot be turned on, err %d", err);
        return;
    start_scan();
static void ble_ready(int err) {
    LOG_INF("Bluetooth ready");
    scan_init();
void main() {
	int err;
    LOG_INF("Initializing Bluetooth..");
    err = bt_enable(ble_ready);
    if (err) {
        LOG_ERR("Bluetooth init failed (err %d)", err);
        return;
Here is the prj.conf:
# Logging
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
# Enable Bluetooth stack and libraries
CONFIG_BT=y
CONFIG_BT_H4=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
nrf9160dk_nrf9160_ns.conf:
CONFIG_NRF_SW_LPUART=y
CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
CONFIG_UART_2_ASYNC=y
CONFIG_UART_2_INTERRUPT_DRIVEN=n
CONFIG_UART_2_NRF_HW_ASYNC=y
CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
Devicetree overlay for the nRF9160:
#include <nrf9160dk_nrf52840_reset_on_if5.dtsi>
	chosen {
		zephyr,bt-uart=&lpuart;
&gpiote {
	interrupts = <49 NRF_DEFAULT_IRQ_PRIORITY>;
&uart2 {
	current-speed = <1000000>;
	status = "okay";
	/delete-property/ hw-flow-control;
	pinctrl-0 = <&uart2_default_alt>;
	pinctrl-1 = <&uart2_sleep_alt>;
	lpuart: nrf-sw-lpuart {
		compatible = "nordic,nrf-sw-lpuart";
		status = "okay";
		req-pin = <21>; /* <&interface_to_nrf52840 3 0>; */
		rdy-pin = <19>; /* <&interface_to_nrf52840 2 0>; */
&pinctrl {
	uart2_default_alt: uart2_default_alt {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 18)>,
				<NRF_PSEL(UART_RX, 0, 17)>;
	uart2_sleep_alt: uart2_sleep_alt {
		group1 {
			low-power-enable;
Any help would be greatly appreciated.
    Thank you for contacting DevZone at NordicSemi.
    How are you testing your application?
    Are you using 2 DKs?
    Can you help me reproduce the error?
    I will look into it if I could reproduce.
    Naeem
  • I am using the nRF Connect for Mobile app on Android to advertise.
    The Random generated UUID is part of the advertising data.
    Niels
  • Hello Niels,
    Thank you for your patience. I am sorry that I could not replicate the issue you are having.
    I started with programming both the nrf52840 and nrf9160 on the nrf9160dk by loading simple programs.
    I could see the correct functionality when pressing reset button.
    Next, I used HCI LP UART Sample (/sample/bluetooth/hci_lpuart) and built it for NRF52840 chip on the NRF9160DK (by selecting target board nrf9160dk_nrf52840) and putting SW10 into nrf52 position.
    I could see reset button working normal and no error shown. I could reset 9160 and 52840 (depending upon the position of SW10).
    Next, I tried to use your code and configurations you have provided, but the code is not compiling. Maybe I am missing something.
    Could you please provide minimal sample project that is compiling and could be used to replicate problem.
    Also, it will be great if you could describe a bit more about how you are testing.
    Naeem
  • i'm having the same issue, basically the same as he is, using the same examples. also using v2.3.0 of the board.
    a slight difference is that i see the errors while transferring sensor data, if i run lte_lc_init before doing the bluetooth scan. not sure why that would be.
    with lte_lc running i am able to get rid of this error by adjusting the baud rate from 1000000 to 115200 in the board overlays for both the nrf52 and nrf91.
  • I had the same problems. I even tried to port my code to v2.5.2 but BLE application still stopped working somewhere after 12/24 hours. I am using Thingy91. After I lowered the baud rate as you have suggested the BLE application is running stable now for a couple of days, let's see.
