I installed nRF Connect SDK version v2.4.0, and the Zephyr RTOS version included with this release has a bug in the flash_map_shell that prevents it from being built.
In flash_map_shell.c, in fa_cb(), a pointer to the shell object is stored in the variable "shell". But in shell_print(), "sh" is referenced as the shell object (but this should be "shell").
In cmd_flash_map_list(), it is the other way around. This function has "sh" as the pointer to a shell object. And in "flash_area_foreach()" the "shell" is referenced instead of "sh".
static void fa_cb(const struct flash_area *fa, void *user_data) { struct shell *shell = user_data; shell_print(sh, "%2d 0x%0*"PRIxPTR" %-26s 0x%-10x 0x%-12x", (int)fa->fa_id, sizeof(uintptr_t) * 2, (uintptr_t)fa->fa_dev, fa->fa_dev->name, (uint32_t) fa->fa_off, fa->fa_size); } static int cmd_flash_map_list(const struct shell *sh, size_t argc, char **argv) { shell_print(sh, "ID | Device | Device Name " "| Offset | Size"); shell_print(sh, "-----------------------------------------" "------------------------------"); flash_area_foreach(fa_cb, (struct shell *)shell); return 0; }
In later versions of the Zephyr SDK (including v3.4.0-rc1), this problem does not persist.
Tim
