SNTP query on nRF7002-DK failed to send over UDP socket
Hello everyone,
I received my nRF7002-DK board and I wanted to get the time using sntp client.
I wrote a small code (which is mostly a fusion between this code and the sntp_client sample) that connects to my network, setup a sntp context and sends a query to get the time but I keep getting this error : <err> net_sntp: Failed to send over UDP socket -1.
I suspect that something is wrong in my prj.conf but as I am just discovering Zephyr OS, I can't figure out what I am missing...
Any piece of help or advice would be greatly appreciated.
The SNTP part of my code :
	//SNTP Test
	memset(&addr,  0, sizeof(addr));
	addr.sin_family = AF_INET;
	addr.sin_port = htons(SNTP_PORT);
	zsock_inet_pton(AF_INET, SNTP_SERVER, &addr.sin_addr);
	sntp_status = sntp_init(&ctx, (struct sockaddr *) &addr, sizeof(addr));
	if(sntp_status < 0){
		printk("Init SNTP socket : Failure - Error %d\n", sntp_status);
	else{
		printk("Init SNTP socket : Success\n");
		sntp_status = sntp_query(&ctx, 4*MSEC_PER_SEC, &s_time);
			printk("Send SNTP query : Failure - Error %d\n", sntp_status);
		else{
			printk("Send SNTP query : Success %d\n");
	sntp_close(&ctx);
My complete code :
#include <zephyr/kernel.h>
#include <zephyr/net/net_if.h>
#include <zephyr/net/wifi_mgmt.h>
#include <zephyr/net/net_event.h>
#include <errno.h>
#include <zephyr/net/sntp.h>
#include <arpa/inet.h>
#define SSID MYSSID
#define PSK MYPSK
#define SNTP_SERVER "ntp.midway.ovh"
#define SNTP_PORT 123
static K_SEM_DEFINE(wifi_connected, 0, 1);
static K_SEM_DEFINE(ipv4_address_obtained, 0, 1);
static struct net_mgmt_event_callback wifi_cb;
static struct net_mgmt_event_callback ipv4_cb;
//SNTP Test
static struct sntp_ctx ctx;
static struct sockaddr_in addr;
static struct sntp_time s_time;
static void handle_wifi_connect_result(struct net_mgmt_event_callback *cb)
    const struct wifi_status *status = (const struct wifi_status *)cb->info;
    if (status->status)
        printk("Connection request failed (%d)\n", status->status);
        printk("Connected\n");
        k_sem_give(&wifi_connected);
static void handle_wifi_disconnect_result(struct net_mgmt_event_callback *cb)
    if (status->status)
        printk("Disconnection request (%d)\n", status->status);
        printk("Disconnected\n");
        k_sem_take(&wifi_connected, K_NO_WAIT);
static void handle_ipv4_result(struct net_if *iface)
    int i = 0;
    for (i = 0; i < NET_IF_MAX_IPV4_ADDR; i++) {
        char buf[NET_IPV4_ADDR_LEN];
        if (iface->config.ip.ipv4->unicast[i].addr_type != NET_ADDR_DHCP) {
            continue;
        printk("IPv4 address: %s\n",
                net_addr_ntop(AF_INET,
                                &iface->config.ip.ipv4->unicast[i].address.in_addr,
                                buf, sizeof(buf)));
        printk("Subnet: %s\n",
                                &iface->config.ip.ipv4->netmask,
                                buf, sizeof(buf)));
        printk("Router: %s\n",
                                &iface->config.ip.ipv4->gw,
                                buf, sizeof(buf)));
        k_sem_give(&ipv4_address_obtained);
static void wifi_mgmt_event_handler(struct net_mgmt_event_callback *cb, uint32_t mgmt_event, struct net_if *iface)
    switch (mgmt_event)
        case NET_EVENT_WIFI_CONNECT_RESULT:
            handle_wifi_connect_result(cb);
        case NET_EVENT_WIFI_DISCONNECT_RESULT:
            handle_wifi_disconnect_result(cb);
        case NET_EVENT_IPV4_ADDR_ADD:
            handle_ipv4_result(iface);
void wifi_connect(void)
    struct net_if *iface = net_if_get_default();
    struct wifi_connect_req_params wifi_params = {0};
    wifi_params.ssid = SSID;
    wifi_params.psk = PSK;
    wifi_params.ssid_length = strlen(SSID);
    wifi_params.psk_length = strlen(PSK);
    wifi_params.channel = WIFI_CHANNEL_ANY;
    wifi_params.security = WIFI_SECURITY_TYPE_PSK;
    wifi_params.band = WIFI_FREQ_BAND_2_4_GHZ;
    wifi_params.mfp = WIFI_MFP_OPTIONAL;
    printk("Connecting to SSID: %s\n", wifi_params.ssid);
	int8_t status = net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &wifi_params, sizeof(struct wifi_connect_req_params));
    if (status)
        printk("WiFi Connection Request Failed\n");
void wifi_status(void)
    struct wifi_iface_status status = {0};
    if (net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &status,	sizeof(struct wifi_iface_status)))
        printk("WiFi Status Request Failed\n");
    printk("\n");
    if (status.state >= WIFI_STATE_ASSOCIATED) {
        printk("SSID: %-32s\n", status.ssid);
        printk("Band: %s\n", wifi_band_txt(status.band));
        printk("Channel: %d\n", status.channel);
        printk("Security: %s\n", wifi_security_txt(status.security));
        printk("RSSI: %d\n", status.rssi);
void wifi_disconnect(void)
    if (net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0))
        printk("WiFi Disconnection Request Failed\n");
void main(void)
	int sntp_status;
    printk("WiFi Example\nBoard: %s\n", CONFIG_BOARD);
    net_mgmt_init_event_callback(&wifi_cb, wifi_mgmt_event_handler,
                                 NET_EVENT_WIFI_CONNECT_RESULT | NET_EVENT_WIFI_DISCONNECT_RESULT);
    net_mgmt_init_event_callback(&ipv4_cb, wifi_mgmt_event_handler, NET_EVENT_IPV4_ADDR_ADD);
    net_mgmt_add_event_callback(&wifi_cb);
    net_mgmt_add_event_callback(&ipv4_cb);
#ifdef CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP
    // Delay to prevent "Unable to get wpa_s handle for wlan0" on nRF Connect SDK 2.3.0.?
    printk("Sleeping for 1 second while wlan0 comes up\n");
    k_sleep(K_SECONDS(1));
    wifi_connect();
    k_sem_take(&wifi_connected, K_FOREVER);
    wifi_status();
    k_sem_take(&ipv4_address_obtained, K_FOREVER);
    printk("Ready...\n\n");
	//SNTP Test
	else{
		else{
	sntp_close(&ctx);
And my prj.conf file :
# Copyright (c) 2022 Nordic Semiconductor ASA
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
# WPA supplicant
CONFIG_WPA_SUPP=y
CONFIG_NET_L2_WIFI_SHELL=y
# System settings
CONFIG_NEWLIB_LIBC=y
#CONFIG_NEWLIB_LIBC_NANO=n
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_POSIX_API=y
CONFIG_NET_LOG=y
CONFIG_NET_IPV6=y
CONFIG_NET_IPV4=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
CONFIG_DNS_RESOLVER=y
CONFIG_NET_STATISTICS=y
CONFIG_NET_STATISTICS_WIFI=y
CONFIG_NET_STATISTICS_USER_API=y
CONFIG_NET_PKT_RX_COUNT=8
CONFIG_NET_PKT_TX_COUNT=8
# Below section is the primary contributor to SRAM and is currently
# tuned for performance, but this will be revisited in the future.
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_HEAP_MEM_POOL_SIZE=153600
CONFIG_NET_TC_TX_COUNT=1
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=4
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=5
CONFIG_NET_MAX_CONTEXTS=5
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_INIT_STACKS=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_SHELL=y
# SNTP
CONFIG_SNTP=y
# Memories
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SHELL_STACK_SIZE=4096
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
# Debugging
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
CONFIG_SHELL_CMDS_RESIZE=n
#CONFIG_DEBUG=y
CONFIG_WPA_SUPP_LOG_LEVEL_INF=y
# Kernel options
CONFIG_ENTROPY_GENERATOR=y
# Logging
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_SHELL=y
CONFIG_SHELL_GETOPT=y
CONFIG_DEVICE_SHELL=y
CONFIG_POSIX_CLOCK=y
CONFIG_DATE_SHELL=y
CONFIG_NET_CONFIG_AUTO_INIT=n
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_WIFI_MGMT_EXT=y
CONFIG_WIFI_CREDENTIALS=y
CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
#CONFIG_NET_SOCKETS_POSIX_NAMES = y
#CONFIG_NET_SOCKETS_POLL_MAX = 4
Thanks
