Hello everyone,
I received my nRF7002-DK board and I wanted to get the time using sntp client.
I wrote a small code (which is mostly a fusion between this code and the sntp_client sample) that connects to my network, setup a sntp context and sends a query to get the time but I keep getting this error : <err> net_sntp: Failed to send over UDP socket -1.
I suspect that something is wrong in my prj.conf but as I am just discovering Zephyr OS, I can't figure out what I am missing...
Any piece of help or advice would be greatly appreciated.
The SNTP part of my code :
//SNTP Test memset(&addr, 0, sizeof(addr)); addr.sin_family = AF_INET; addr.sin_port = htons(SNTP_PORT); zsock_inet_pton(AF_INET, SNTP_SERVER, &addr.sin_addr); sntp_status = sntp_init(&ctx, (struct sockaddr *) &addr, sizeof(addr)); if(sntp_status < 0){ printk("Init SNTP socket : Failure - Error %d\n", sntp_status); } else{ printk("Init SNTP socket : Success\n"); sntp_status = sntp_query(&ctx, 4*MSEC_PER_SEC, &s_time); if(sntp_status < 0){ printk("Send SNTP query : Failure - Error %d\n", sntp_status); } else{ printk("Send SNTP query : Success %d\n"); } } sntp_close(&ctx);
My complete code :
#include <zephyr/kernel.h> #include <zephyr/net/net_if.h> #include <zephyr/net/wifi_mgmt.h> #include <zephyr/net/net_event.h> #include <errno.h> #include <zephyr/net/sntp.h> #include <arpa/inet.h> #define SSID MYSSID #define PSK MYPSK #define SNTP_SERVER "ntp.midway.ovh" #define SNTP_PORT 123 static K_SEM_DEFINE(wifi_connected, 0, 1); static K_SEM_DEFINE(ipv4_address_obtained, 0, 1); static struct net_mgmt_event_callback wifi_cb; static struct net_mgmt_event_callback ipv4_cb; //SNTP Test static struct sntp_ctx ctx; static struct sockaddr_in addr; static struct sntp_time s_time; static void handle_wifi_connect_result(struct net_mgmt_event_callback *cb) { const struct wifi_status *status = (const struct wifi_status *)cb->info; if (status->status) { printk("Connection request failed (%d)\n", status->status); } else { printk("Connected\n"); k_sem_give(&wifi_connected); } } static void handle_wifi_disconnect_result(struct net_mgmt_event_callback *cb) { const struct wifi_status *status = (const struct wifi_status *)cb->info; if (status->status) { printk("Disconnection request (%d)\n", status->status); } else { printk("Disconnected\n"); k_sem_take(&wifi_connected, K_NO_WAIT); } } static void handle_ipv4_result(struct net_if *iface) { int i = 0; for (i = 0; i < NET_IF_MAX_IPV4_ADDR; i++) { char buf[NET_IPV4_ADDR_LEN]; if (iface->config.ip.ipv4->unicast[i].addr_type != NET_ADDR_DHCP) { continue; } printk("IPv4 address: %s\n", net_addr_ntop(AF_INET, &iface->config.ip.ipv4->unicast[i].address.in_addr, buf, sizeof(buf))); printk("Subnet: %s\n", net_addr_ntop(AF_INET, &iface->config.ip.ipv4->netmask, buf, sizeof(buf))); printk("Router: %s\n", net_addr_ntop(AF_INET, &iface->config.ip.ipv4->gw, buf, sizeof(buf))); } k_sem_give(&ipv4_address_obtained); } static void wifi_mgmt_event_handler(struct net_mgmt_event_callback *cb, uint32_t mgmt_event, struct net_if *iface) { switch (mgmt_event) { case NET_EVENT_WIFI_CONNECT_RESULT: handle_wifi_connect_result(cb); break; case NET_EVENT_WIFI_DISCONNECT_RESULT: handle_wifi_disconnect_result(cb); break; case NET_EVENT_IPV4_ADDR_ADD: handle_ipv4_result(iface); break; default: break; } } void wifi_connect(void) { struct net_if *iface = net_if_get_default(); struct wifi_connect_req_params wifi_params = {0}; wifi_params.ssid = SSID; wifi_params.psk = PSK; wifi_params.ssid_length = strlen(SSID); wifi_params.psk_length = strlen(PSK); wifi_params.channel = WIFI_CHANNEL_ANY; wifi_params.security = WIFI_SECURITY_TYPE_PSK; wifi_params.band = WIFI_FREQ_BAND_2_4_GHZ; wifi_params.mfp = WIFI_MFP_OPTIONAL; printk("Connecting to SSID: %s\n", wifi_params.ssid); int8_t status = net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &wifi_params, sizeof(struct wifi_connect_req_params)); if (status) { printk("WiFi Connection Request Failed\n"); } } void wifi_status(void) { struct net_if *iface = net_if_get_default(); struct wifi_iface_status status = {0}; if (net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &status, sizeof(struct wifi_iface_status))) { printk("WiFi Status Request Failed\n"); } printk("\n"); if (status.state >= WIFI_STATE_ASSOCIATED) { printk("SSID: %-32s\n", status.ssid); printk("Band: %s\n", wifi_band_txt(status.band)); printk("Channel: %d\n", status.channel); printk("Security: %s\n", wifi_security_txt(status.security)); printk("RSSI: %d\n", status.rssi); } } void wifi_disconnect(void) { struct net_if *iface = net_if_get_default(); if (net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0)) { printk("WiFi Disconnection Request Failed\n"); } } void main(void) { int sntp_status; printk("WiFi Example\nBoard: %s\n", CONFIG_BOARD); net_mgmt_init_event_callback(&wifi_cb, wifi_mgmt_event_handler, NET_EVENT_WIFI_CONNECT_RESULT | NET_EVENT_WIFI_DISCONNECT_RESULT); net_mgmt_init_event_callback(&ipv4_cb, wifi_mgmt_event_handler, NET_EVENT_IPV4_ADDR_ADD); net_mgmt_add_event_callback(&wifi_cb); net_mgmt_add_event_callback(&ipv4_cb); #ifdef CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP // Delay to prevent "Unable to get wpa_s handle for wlan0" on nRF Connect SDK 2.3.0.? printk("Sleeping for 1 second while wlan0 comes up\n"); k_sleep(K_SECONDS(1)); #endif wifi_connect(); k_sem_take(&wifi_connected, K_FOREVER); wifi_status(); k_sem_take(&ipv4_address_obtained, K_FOREVER); printk("Ready...\n\n"); //SNTP Test memset(&addr, 0, sizeof(addr)); addr.sin_family = AF_INET; addr.sin_port = htons(SNTP_PORT); zsock_inet_pton(AF_INET, SNTP_SERVER, &addr.sin_addr); sntp_status = sntp_init(&ctx, (struct sockaddr *) &addr, sizeof(addr)); if(sntp_status < 0){ printk("Init SNTP socket : Failure - Error %d\n", sntp_status); } else{ printk("Init SNTP socket : Success\n"); sntp_status = sntp_query(&ctx, 4*MSEC_PER_SEC, &s_time); if(sntp_status < 0){ printk("Send SNTP query : Failure - Error %d\n", sntp_status); } else{ printk("Send SNTP query : Success %d\n"); } } sntp_close(&ctx); }
And my prj.conf file :
# # Copyright (c) 2022 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_WIFI=y CONFIG_WIFI_NRF700X=y # WPA supplicant CONFIG_WPA_SUPP=y CONFIG_NET_L2_WIFI_SHELL=y # System settings CONFIG_NEWLIB_LIBC=y #CONFIG_NEWLIB_LIBC_NANO=n # Networking CONFIG_NETWORKING=y CONFIG_NET_SOCKETS=y CONFIG_POSIX_API=y CONFIG_NET_LOG=y CONFIG_NET_IPV6=y CONFIG_NET_IPV4=y CONFIG_NET_UDP=y CONFIG_NET_TCP=y CONFIG_NET_DHCPV4=y CONFIG_DNS_RESOLVER=y CONFIG_NET_STATISTICS=y CONFIG_NET_STATISTICS_WIFI=y CONFIG_NET_STATISTICS_USER_API=y CONFIG_NET_PKT_RX_COUNT=8 CONFIG_NET_PKT_TX_COUNT=8 # Below section is the primary contributor to SRAM and is currently # tuned for performance, but this will be revisited in the future. CONFIG_NET_BUF_RX_COUNT=16 CONFIG_NET_BUF_TX_COUNT=16 CONFIG_NET_BUF_DATA_SIZE=128 CONFIG_HEAP_MEM_POOL_SIZE=153600 CONFIG_NET_TC_TX_COUNT=1 CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=4 CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=5 CONFIG_NET_MAX_CONTEXTS=5 CONFIG_NET_CONTEXT_SYNC_RECV=y CONFIG_INIT_STACKS=y CONFIG_NET_L2_ETHERNET=y CONFIG_NET_SHELL=y # SNTP CONFIG_SNTP=y # Memories CONFIG_MAIN_STACK_SIZE=4096 CONFIG_SHELL_STACK_SIZE=4096 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_NET_TX_STACK_SIZE=4096 CONFIG_NET_RX_STACK_SIZE=4096 # Debugging CONFIG_STACK_SENTINEL=y CONFIG_DEBUG_COREDUMP=y CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y CONFIG_SHELL_CMDS_RESIZE=n #CONFIG_DEBUG=y CONFIG_WPA_SUPP_LOG_LEVEL_INF=y # Kernel options CONFIG_ENTROPY_GENERATOR=y # Logging CONFIG_LOG=y CONFIG_PRINTK=y CONFIG_SHELL=y CONFIG_SHELL_GETOPT=y CONFIG_DEVICE_SHELL=y CONFIG_POSIX_CLOCK=y CONFIG_DATE_SHELL=y CONFIG_NET_CONFIG_AUTO_INIT=n CONFIG_NET_CONFIG_SETTINGS=y CONFIG_WIFI_MGMT_EXT=y CONFIG_WIFI_CREDENTIALS=y CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_SETTINGS_NVS=y #CONFIG_NET_SOCKETS_POSIX_NAMES = y #CONFIG_NET_SOCKETS_POLL_MAX = 4
Thanks
