Need help finding documentation or tutorial that explains USB CDC ACM.
I want to create a virtual com port on my pc from my nRF52840 dongle program. And direct the output of printx statements to it so I can monitor it with putty.
I have tried very diligently to search for this information on your website; I get covered up with hits, all, seemingly irrelevant. For the life of me I don't understand how anyone ever finds anything in your documentation.  I can search on terms like "nRF52 USB CDC ACM tutorial" and your search engine ignores the quotes and I get over 700 hits.
I have also tried to search your examples for this information with no success.  Why is it so dang hard to find information here?
Jerry
  • The following is a program from the BLE tutorial; I post it here because it does what I want to in that it causes the device driver on my PC to create a virtual com port, COM10, and directs the output of the printk statements to it.  I have carefully gone through the code but I can't figure out how it works, can someone explain how this works?
    * Copyright (c) 2023 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    #include <zephyr/bluetooth/gap.h>
    #include <dk_buttons_and_leds.h>
    /* STEP 2.1 - Declare the Company identifier (Company ID) */
    #define COMPANY_ID_CODE 0x0059
    /* STEP 2.2 - Declare the structure for your custom data */
    typedef struct adv_mfg_data {
    uint16_t company_code; /* Company Identifier Code. */
    uint16_t number_press; /* Number of times Button 1 is pressed*/
    } adv_mfg_data_type;
    #define USER_BUTTON DK_BTN1_MSK
    /* STEP 1 - Create an LE Advertising Parameters variable */
    static struct bt_le_adv_param *adv_param = BT_LE_ADV_PARAM(BT_LE_ADV_OPT_NONE, /* No options spesified*/
    800, /*Min Advertising Interval 500ms (800*0.625ms) */
    801, /*Max Advertising Interval 500.625ms (801*0.625ms)*/
    NULL); /* Set to NULL for undirected advertising*/
    /* STEP 2.3 - Define and initialize a variable of type adv_mfg_data_type */
    static adv_mfg_data_type adv_mfg_data = {COMPANY_ID_CODE,0x00};
    static unsigned char url_data[] ={0x17,'/','/','a','c','a','d','e','m','y','.','n','o','r','d','i','c','s'
    LOG_MODULE_REGISTER(Lesson2_Exercise2, LOG_LEVEL_INF);
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
    #define RUN_STATUS_LED DK_LED1
    #define RUN_LED_BLINK_INTERVAL 1000
    static const struct bt_data ad[] = {
    BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
    BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    /* STEP 3 - Include the Manufacturer Specific Data in the advertising packet. */
    BT_DATA(BT_DATA_MANUFACTURER_DATA,(unsigned char *)&adv_mfg_data, sizeof(adv_mfg_data)),
    static const struct bt_data sd[] = {
    BT_DATA(BT_DATA_URI, url_data,sizeof(url_data)),
    /* STEP 5 - Add the definition of callback function and update the advertising data dynamically */
    static void button_changed(uint32_t button_state, uint32_t has_changed)
    printk("Button Pressed, button_state = %d, has_changed = %d USER_BUTTON = %d, adv_mfg_data.number_pres
    if (has_changed & button_state & USER_BUTTON) {
    adv_mfg_data.number_press += 1;
    bt_le_adv_update_data(ad, ARRAY_SIZE(ad),
    sd, ARRAY_SIZE(sd));
    /* STEP 4.1 - Define the initialization function of the buttons and setup interrupt. */
    static int init_button(void)
    int err;
    err = dk_buttons_init(button_changed);
    if (err) {
    printk("Cannot init buttons (err: %d)\n", err);
    return err;
    void main(void)
    int blink_status = 0;
    int err;
    LOG_INF("Starting Lesson 2 - Exercise 1 \n");
    err = dk_leds_init();
    if (err) {
    LOG_ERR("LEDs init failed (err %d)\n", err);
    return;
    /* STEP 4.2 - Setup buttons on your board */
    err = init_button();
    if (err) {
    printk("Button init failed (err %d)\n", err);
    return;
    err = bt_enable(NULL);
    if (err) {
    LOG_ERR("Bluetooth init failed (err %d)\n", err);
    return;
    LOG_INF("Bluetooth initialized\n");
    err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad),
    if (err) {
    LOG_ERR("Advertising failed to start (err %d)\n", err);
    return;
    LOG_INF("Advertising successfully started\n");
    for (;;) {
    dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
    k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
  • Hi, I will look into this case and return with more information tomorrow
    Sigurd Hellesvik
    Which BLE tutorial?
    As an alternative, you can use google with "site". It sometimes returns better results.
    To create a sample which might be useful to you, I did the following:
    nRF Connect SDK v2.3.0.
    Use the Hello World sample as a base.
    Copy the app.overlay and prj.conf from Console over CDC ACM UART Sample into Hello World.
    Add usb_enable() to hello world.
    Add hello world printk into loop
    I tested this on a DK, so I think that it should work on the dongle as well:
    hello_world_over_cdc_acm.zip
    Sigurd Hellesvik
  • The BLE tutorial, "
    Bluetooth Low Energy Fundamentals
    " is here: https://academy.nordicsemi.com/topic/blefund-lesson-2-exercise-1/
    You can get the example programs here: https://github.com/NordicDeveloperAcademy/bt-fund.git
    Each Lesson Exercise comes with two source files a student working copy and a solution copy; I am working with the solution copy.
    I am sure the solution you provided will work for me; I haven't had a chance to try it; I'll try it straight away and give you some feedback. Thank you so much for your efforts.
    Jerry
  • Hi Sigurd,
    Your example works great! Thank You ever so much!
    Jerry
