Hello im trying to implement SPI connection to my mesh project. I tried to add Spi but when i add this line to my prj.conf:
CONFIG_SPI=y
this error imidietly appears after programing the device (standard evaluation board nrf52833):
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 E: Current thread: 0x20002e98 (main) ASSERTION FAIL @ WEST_TOPDIR/zephyr/include/zephyr/drivers/gpio.h:730 E: r0/a1: 0x00000004 r1/a2: 0x000002da r2/a3: 0x00000001 E: r3/a4: 0x0002dcb9 r12/ip: 0x00000000 r14/lr: 0x0002ec75 E: xpsr: 0x41000000 E: Faulting instruction address (r15/pc): 0x00036dfa
when i delete this line from prj.conf the program runs normaly, can you help me get this working, thanks.
my versions :
v3.12.0 - nrf Connect
v1.2.4 - Toolchain
v2.1.2 - nrf Connect SDK
the rest of prj.conf:
# # Copyright (c) 2020 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y # General configuration CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_HWINFO=y CONFIG_DK_LIBRARY=y CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000 # Bluetooth configuration CONFIG_BT=y CONFIG_BT_COMPANY_ID=0x0059 CONFIG_BT_DEVICE_NAME="Mesh Chat" CONFIG_BT_L2CAP_TX_MTU=69 CONFIG_BT_L2CAP_TX_BUF_COUNT=8 CONFIG_BT_OBSERVER=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_SETTINGS=y # Disable unused Bluetooth features CONFIG_BT_CTLR_DUP_FILTER_LEN=0 CONFIG_BT_CTLR_LE_ENC=n CONFIG_BT_DATA_LEN_UPDATE=n CONFIG_BT_PHY_UPDATE=n CONFIG_BT_CTLR_CHAN_SEL_2=n CONFIG_BT_CTLR_MIN_USED_CHAN=n CONFIG_BT_CTLR_PRIVACY=n # Bluetooth Mesh configuration CONFIG_BT_MESH=y CONFIG_BT_MESH_RELAY=y CONFIG_BT_MESH_FRIEND=y CONFIG_BT_MESH_ADV_BUF_COUNT=13 CONFIG_BT_MESH_RX_SEG_MAX=10 CONFIG_BT_MESH_TX_SEG_MAX=10 CONFIG_BT_MESH_PB_GATT=y CONFIG_BT_MESH_GATT_PROXY=y CONFIG_BT_MESH_DK_PROV=y # Enable Bluetooth mesh models debug logs CONFIG_BT_DEBUG_LOG=y CONFIG_BT_MESH_DEBUG=y CONFIG_BT_MESH_DEBUG_MODEL=y # Enable Shell module and use UART as a backend CONFIG_SHELL=y CONFIG_SHELL_BACKEND_SERIAL=y
