Generate Zip file for FOTA DFu
Hello ,
i am using nrfutil tool and generate zip file but i am getting error which is mention in picture. i try ble_app_blinky code and generated ZIP file successfully, can you tell me how to solve this error
i am using
1 ..nRF5SDK1500a53641a sdk
2.  nrfutil 7.4.1
3. windows 11 home
  • DG, you might have misunderstood me. By
    Hieu said:
    You can remove the SoftDevice Requirement by removing the --sd-req parameters from the command.
    However, this recommendation from me is not correct. I reviewed your reply and see that you already flashed the SoftDevice onto the DK. I am sorry about this.
    I meant that --sd-req should not be removed.
    DG said:
    1. Is there a BLE code that already integrates AES CTR or any other form of AES? Our goal is to make sure that the communication between the mobile phone and our hardware is encrypted.
    We were following the methodology of integrating the nrf_crypto_aes_ctr_pca10056 with the BLE uart code. This is the place where we got stuck. We, furthermore, also want to integrate other services like the battery level and some others with our firmware. This is just FYI
    If your goal is encryption of the message, then you should know that all BLE messages are encrypted when after pairing or bonding is done.
    We explain those concepts in the free Bluetooth Low Energy Fundamentals course in DevAcademy. The course is based on the nRF Connect SDK. However, as you seem to be starting a new project, I think it is also better for you to work with this SDK instead.
    DG said:
    2. If we are to combine the two examples how should we go about doing this? We want to combine the BLE uart and the nrf_crypto_aes_ctr_pca10056. . On this same point we also understand that both these codes have a different project file and we are not sure how to combine them. Can you advice how to proceed forward on this?
    My steps are usually as followed
    1. Understand the API calls in main.c.
    2. Understand what source files and header files are used.
    3. Understand what configuration are in used in sdk_config.h.
    4. Rarely, but sometimes necessarily, understand what configurations are in used in the project configuration file (for SEGGER Embedded Studio projects).
    5. Replicate the above understanding in the based project.
    As you start out with the SDK, each step can be intimidating, but please trust me that it will get better.
    Finally, please remember my recommendation to consider the nRF Connect SDK instead.
    Hieu
  • Hello Hieo,
    i am trying to combine ble_uart and AES_Ctr file but i am getting some error which in mention in
    picture ,can you tell me how to solve it.
    BR
    DG
  • Building ‘ble_app_uart_pca10056_s140’ from solution ‘ble_app_uart_pca10056_s140’ in configuration ‘Release’
    1> Compiling ‘nrf_log_backend_rtt.c’
    2> Compiling ‘nrf_log_backend_uart.c’
    3> Compiling ‘nrf_log_frontend.c’
    4> Compiling ‘nrf_log_default_backends.c’
    5> Compiling ‘nrf_log_str_formatter.c’
    6> Compiling ‘app_timer.c’
    7> Compiling ‘app_scheduler.c’
    8> Compiling ‘app_error_weak.c’
    9> Compiling ‘app_uart_fifo.c’
    10> Compiling ‘nrf_balloc.c’
    11> Compiling ‘nrf_atomic.c’
    12> Compiling ‘nrf_atfifo.c’
    1> C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_log\src\nrf_log_backend_rtt.c:46:10: fatal error: nrf_delay.h: No such file or directory
    1> compilation terminated.
    9> C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\uart\app_uart_fifo.c:43:10: fatal error: app_fifo.h: No such file or directory
    9> compilation terminated.
    2> C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_log\src\nrf_log_backend_uart.c:45:10: fatal error: nrf_drv_uart.h: No such file or directory
    2> compilation terminated.
    6> C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\timer\app_timer.c:48:10: fatal error: nrf_delay.h: No such file or directory
    6> compilation terminated.
    Build failed
  • Hi DG,
    You will need to update the list of include directories. Please:
    1. Go into Project Options
      1. By right click on the Project in the Project Explorer window
      2. Or by using the menu Project > Options (remember to move up/down until the options is being displayed for the Project)
    2. Go to Code > Preprocessors > User include Directories
    3. Add the folders where the missing header files can be found to the list
  • HI Hieu ,
    can you tell me what should add exactly .because i am adding path but still getting same error .i am sending you ble_uart and aes_ctr merge emproject file
    1> Assembling ‘thumb_crt0.s’
    2> Compiling ‘nrf_log_backend_serial.c’
    3> Compiling ‘nrf_log_backend_rtt.c’
    4> Compiling ‘nrf_log_backend_uart.c’
    5> Compiling ‘nrf_log_default_backends.c’
    6> Compiling ‘nrf_log_frontend.c’
    7> Compiling ‘nrf_log_str_formatter.c’
    8> Compiling ‘app_button.c’
    9> Compiling ‘app_error.c’
    10> Compiling ‘app_error_handler_gcc.c’
    11> Compiling ‘app_error_weak.c’
    12> Compiling ‘app_fifo.c’
    1> Compiling ‘app_scheduler.c’
    3> In file included from C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_log\src\nrf_log_backend_rtt.c:46:
    3> ../../../../../../components/libraries/delay/nrf_delay.h:44:10: fatal error: nrfx.h: No such file or directory
    3> compilation terminated.
    4> C:\Users\firmw\Desktop\AES_BLE\nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_log\src\nrf_log_backend_uart.c:45:10: fatal error: nrf_drv_uart.h: No such file or directory
    4> compilation terminated.
    Build failed
    <!DOCTYPE CrossStudio_Project_File>
    <solution Name="ble_app_uart_pca10056_s140" target="8" version="2">
      <project Name="ble_app_uart_pca10056_s140">
        <configuration
          Name="Common"
          arm_architecture="v7EM"
          arm_core_type="Cortex-M4"
          arm_endian="Little"
          arm_fp_abi="Hard"
          arm_fpu_type="FPv4-SP-D16"
          arm_linker_heap_size="8192"
          arm_linker_process_stack_size="0"
          arm_linker_stack_size="8192"
          arm_linker_treat_warnings_as_errors="No"
          arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
          arm_target_device_name="nRF52840_xxAA"
          arm_target_interface_type="SWD"
          c_preprocessor_definitions="BOARD_PCA10056;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=6;S140;SOFTDEVICE_PRESENT;SWI_DISABLE0;"
          c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_link_ctx_manager;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/drivers_nrf/usbd;../../../../../../components/libraries/atomic;../../../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/crypto/backend/cc310;../../../../../../components/libraries/crypto/backend/cc310_bl;../../../../../../components/libraries/crypto/backend/cifra;../../../../../../components/libraries/crypto/backend/mbedtls;../../../../../../components/libraries/crypto/backend/micro_ecc;../../../../../../components/libraries/crypto/backend/nrf_hw;../../../../../../components/libraries/crypto/backend/nrf_sw;../../../../../../components/libraries/crypto/backend/oberon;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_log;../../../../../../components/libraries/experimental_log/src;../../../../../../components/libraries/experimental_memobj;../../../../../../components/libraries/experimental_mpu;../../../../../../components/libraries/experimental_ringbuf;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_stack_guard;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../../../components/libraries/fifo;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hardfault/nrf52;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/stack_info;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/strerror;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../../../components/libraries/uart;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/usbd/config;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_lib/hal_t2t;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_lib/hal_t4t;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s140/headers;../../../../../../components/softdevice/s140/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../..;../../../../../../external/cifra_AES128-EAX;../../../../../../external/fprintf;../../../../../../external/mbedtls/include;../../../../../../external/micro-ecc/micro-ecc;../../../../../../external/nrf_cc310/include;../../../../../../external/nrf_oberon../../../../../../external/nrf_oberon/include;../../../../../../external/nrf_tls/mbedtls/nrf_crypto/config;../../../../../../external/segger_rtt;../../../../../../../../integration/nrfx;../../../../../../../../integration/nrfx/legacy;../../../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config"
          debug_additional_load_file="../../../../../../components/softdevice/s140/hex/s140_nrf52_6.0.0_softdevice.hex"
          debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52840.svd"
          debug_start_from_entry_point_symbol="No"
          debug_target_connection="J-Link"
          gcc_debugging_level="Level 3"
          gcc_entry_point="Reset_Handler"
          linker_output_format="hex"
          linker_printf_fmt_level="long"
          linker_printf_width_precision_supported="Yes"
          linker_section_placement_file="flash_placement.xml"
          linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x26000;FLASH_SIZE=0xda000;RAM_START=0x20002a98;RAM_SIZE=0x3d568"
          linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000"
          macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
          project_directory=""
          project_type="Executable" />
        <folder Name="Segger Startup Files">
          <file file_name="$(StudioDir)/source/thumb_crt0.s" />
        </folder>
        <folder Name="nrf_cc310">
          <file file_name="../../../../../../external/nrf_cc310/lib/libnrf_cc310_0.9.9.a" />
        </folder>
        <folder Name="nRF_Log">
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_backend_rtt.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_backend_serial.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_backend_uart.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_default_backends.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_frontend.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_str_formatter.c" />
        </folder>
        <folder Name="nRF_Libraries">
          <file file_name="../../../../../../components/libraries/button/app_button.c" />
          <file file_name="../../../../../../components/libraries/util/app_error.c" />
          <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
          <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
          <file file_name="../../../../../../components/libraries/fifo/app_fifo.c" />
          <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
          <file file_name="../../../../../../components/libraries/timer/app_timer.c" />
          <file file_name="../../../../../../components/libraries/uart/app_uart_fifo.c" />
          <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
          <file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
          <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
          <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
          <file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
          <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
          <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
          <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
          <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
          <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
          <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
          <file file_name="../../../../../../components/libraries/experimental_memobj/nrf_memobj.c" />
          <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
          <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
          <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
          <file file_name="../../../../../../../../components/libraries/uart/retarget.c" />
        </folder>
        <folder Name="None">
          <file file_name="../../../../../../modules/nrfx/mdk/ses_nRF_Startup.s" />
          <file file_name="../../../../../../modules/nrfx/mdk/ses_nrf52840_Vectors.s" />
          <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52840.c" />
        </folder>
        <folder Name="Board Definition">
          <file file_name="../../../../../../components/boards/boards.c" />
        </folder>
        <folder Name="nRF_Crypto backend uECC">
          <file file_name="../../../../../../components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecc.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecdh.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecdsa.c" />
        </folder>
        <folder Name="nRF_Drivers">
          <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
          <file file_name="../../../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_power_clock.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
        </folder>
        <folder Name="nRF_Crypto backend mbed TLS">
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_aes.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_aes_aead.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_ecc.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_ecdh.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_ecdsa.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_hash.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_hmac.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/mbedtls/mbedtls_backend_init.c" />
        </folder>
        <folder Name="nRF_Crypto">
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aead.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aes.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aes_shared.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecc.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecdh.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecdsa.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_error.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hash.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hkdf.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hmac.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_init.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_rng.c" />
          <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_shared.c" />
        </folder>
        <folder Name="Board Support">
          <file file_name="../../../../../../components/libraries/bsp/bsp.c" />
          <file file_name="../../../../../../components/libraries/bsp/bsp_btn_ble.c" />
        </folder>
        <folder Name="nRF_Crypto backend nRF HW">
          <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_init.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_rng.c" />
          <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_rng_mbedtls.c" />
        </folder>
        <folder Name="Application">
          <file file_name="../../../main.c" />
          <file file_name="../config/sdk_config.h" />
        </folder>
        <folder Name="nRF_micro-ecc">
          <file file_name="../../../../../../../../external/micro-ecc/nrf52hf_armgcc/armgcc/micro_ecc_lib_nrf52.a" />
        </folder>
        <folder Name="nRF_TLS">
          <file file_name="../../../../../../../../external/mbedtls/library/aes.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/aesni.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/arc4.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/asn1parse.c" />
          <file file_name="../../../../../../../../external/nrf_tls/mbedtls/replacements/asn1write.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/base64.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/bignum.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/blowfish.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/camellia.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ccm.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/certs.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/cipher.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/cipher_wrap.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/cmac.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ctr_drbg.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/debug.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/des.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/dhm.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ecdh.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ecdsa.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ecp.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ecp_curves.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/entropy.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/entropy_poll.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/error.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/gcm.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/havege.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/hmac_drbg.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/md.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/md2.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/md4.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/md5.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/md_wrap.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/memory_buffer_alloc.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/oid.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/padlock.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pem.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pk.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pk_wrap.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pkcs11.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pkcs12.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pkcs5.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pkparse.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/pkwrite.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/platform.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ripemd160.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/rsa.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/sha1.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/sha256.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/sha512.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_cache.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_ciphersuites.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_cli.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_cookie.c" />
          <file file_name="../../../../../../../../external/nrf_tls/mbedtls/replacements/ssl_srv.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_ticket.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/ssl_tls.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/threading.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/version.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/version_features.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/x509.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/x509_create.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/x509_crl.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/x509_crt.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/x509_csr.c" />
          <file file_name="../../../../../../../../external/mbedtls/library/xtea.c" />
        </folder>
        <folder Name="nRF_Oberon_Crypto">
          <file file_name="../../../../../../../../external/nrf_oberon/lib/nrf52/liboberon_2.0.4.a" />
        </folder>
        <folder Name="nRF_Segger_RTT">
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
        </folder>
        <folder Name="nRF_BLE">
          <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
          <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
          <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
          <file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
          <file file_name="../../../../../../components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c" />
          <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
          <file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
          <file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
        </folder>
        <folder Name="nRF_BLE_Services">
          <file file_name="../../../../../../components/ble/ble_services/ble_nus/ble_nus.c" />
        </folder>
        <folder Name="nRF_SoftDevice">
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
        </folder>
        <configuration
          Name="Release"
          c_user_include_directories="../../../../../../components/libraries/delay." />
      </project>
      <configuration
        Name="Release"
        c_preprocessor_definitions="NDEBUG"
        gcc_optimization_level="Optimize For Size" />
      <configuration
        Name="Debug"
        c_preprocessor_definitions="DEBUG; DEBUG_NRF"
        gcc_optimization_level="None" />
    </solution>
