nrfx SAADC values missing when combined with BLE
I have been developing an embedded system where, data would be captured from analog sensors and then processed and sent by Bluetooth to a android device. In my project, I am capturing ECG data from one of the analog pin of nRF52840 DevKit. Then, I save data in a buffer and send them by BLE. In the Android phone, we have a custom App where, we would receive those data and plot them.
Problem: I face an issue of missing ADC data on the mobile App side when I am trying to send 96 samples in a Bluetooth packet (96 samples are converted to 192 bytes, as each sample is 2 bytes). When I send 48 samples (96 bytes) in a Bluetooth packet, I still have some data missed on the Mobile App side but, the problem is not severe in that case. When ADC data checked without combining the BLE part, they look fine.
Description: I have taken the SAADC example from here and merged it with blue_app_uart example. I am sampling the ADC at a rate of 1kHz and storing 96 samples in the buffer. Few of the important BLE settings are as follows,
Min Conn Interval 95 ms
Max Conn Interval 105 ms
BLE GAP EVENT LENGTH 76 (95 MS)
GAP DATA LENGTH 251
Thank you for reading my post. I would be very grateful if anyone can point out a possible solution for this case. I can also share the code here if it seems required. Please let me know.
    Thank a lot for your support.
    I have gone through few more debugging and my observations are as follows,
    1. The piece of code for queue size extension is removed from nrf_sdh_ble.c. Will follow this practice from now. I have adjusted the RAM size accordingly. Regarding the ring buffer, I think that can be a good way to handle the data processing. I plan to implement the ring buffer. I will update you as soon as I implement that.
    2. I tried some more error handling with the ble_nus_data_send function. Looks like, the error code was 0x5 when it was not connected. As the device is discovered and data Tx is started from the App side, the error code changes to 0x8 and 0x13 (I had to remove the App_Error_Check to see the error message in this case).
    i) Going further, I tried to check the error messages during BLE Tx. From the observation, it looks like I am getting a number of error code 0x13 (BLE_GATTS_HVN_TX_COMPLETE retry message) in between successful BLE Tx. I am adding part of logs from the Debug window. Here it is:
    <info> app: NUS returned:0x0
    <debug> nrf_sdh_ble: BLE event: 0x57.
    <info> app: NUS returned:0x13
    <debug> nrf_NUS returned:0x13
    This repeats during the BLE Tx process. I am not exactly sure if this is something as expected.
    ii) Following the error messages, I then added a BLE_GATTS_HVN_TX_COMPLETE case inside ble_evt_handler() function. After adding this case, the BLE Tx tends to become slower than earlier and also looks like there is a queue for BLE Tx. I am adding part of logs from the Debug window. Here it is:
    <debug> app: HVN_TX_COMPLETE: 1
    <warning> app: Queue full, waiting
    The code added inside the ble_evt_handler is as follows:
    Code:
    case BLE_GATTS_EVT_HVN_TX_COMPLETE:
                NRF_LOG_DEBUG("HVN_TX_COMPLETE: %d", p_ble_evt->evt.gatts_evt.params.hvn_tx_complete.count);
                m_notifications_queue_full = false;
    The error handlers for ble_nus_data_send is as follows (inside main loop):
    Code:
    if (BF1==1){
    do {
    err_code = ble_nus_data_send(&m_nus,printf_buffer, &length, m_conn_handle);
    NRF_LOG_INFO("NUS returned:0x%x",err_code);
    if(err_code == NRF_ERROR_RESOURCES) {
        NRF_LOG_WARNING("Queue full, waiting");
        NRF_LOG_FLUSH();
        m_notifications_queue_full = true;
        while(m_notifications_queue_full) {
            nrf_pwr_mgmt_run();
    } while (err_code == NRF_ERROR_RESOURCES);
                        BF1=0;
    I have also changed the interrupt priority to 7 for nrfx_saadc and nrfx_timer following this post. But, the problem exists.
    My question is,
    Am I going to right direction with this problem?
    Can this issue be related to improper handling of "notification enabled" from peripheral side?
    When would be appropriate time to call the ble_nus_data_send function in my case?
    Please let me know if you need any info. Thank you.
    Glad to hear that you're making progress. I had a chat with a colleague of mine regarding the next steps and your questions and this is what we landed on
    This sounds great!
    The function will always return the invalid connection handle error when you attempt to call it without being in a connection. To avoid this, you should only start to send data after you have gotten the CONNECTED event. If you need to collect data also outside of a connection then you will need to implement a storage for this data for the time until a connection is made - the ring buffer could be used for this as well, just keep in mind that old data will be overwritten if the buffer is filled before a connection is made.
    What do you mean you had to remove the APP_ERROR_CHECK to see these errors?
    Please make sure that you have added the DEBUG define to your preprocessor definitions like shown in the picture, to have the logger module output a detailed error message whenever a non-NRF_SUCCESS error code is passed to an APP_ERROR_CHECK: This makes it much easier to check the meaning of the error codes against the returning functions API reference.
    This event is useful to know how many of the queued notifications that were sent in the previous connection event. If you are using a ring-buffer then this becomes less important since you will always keep the SoftDevice buffer full, but if you did not have a ring buffer you could use this event to know that 'the SoftDevice BLE NUS notification buffer now has 3 freed up slots', for instance.
    If the SAADC is triggered by the TIMER through PPI then there will be no issue with their triggering taking CPU priority over the main loop. Also, the SoftDevice always has the highest priority, and so there is no way that the SAADC activity can interrupt it when it needs to send data or perform any other timing-critical tasks.
    Andreas
    Sorry for late reply. I am changing the code according to your suggestions. Meanwhile, I though it would be better if I share what is my approach for modification.
    With the APP_ERROR_CHECK I was stuck at ble_nus_data_send. That's why I removed this line to check further. But, I understand we need this to avoid any potential problem through out the development. I will put it back in the code Slight smile.
    Okay. Got it. Thanks!
    Ok. I am changing my code based on this suggestion. As I understand, I have to send data through BLE after a connection is established and store data in ring buffer as well so that no data is lost. To deal with the "Connected event", would it be a proper way, if I set a flag inside "BLE_GAP_EVT_CONNECTED" of ble_evt_handler() and send data based on the flag status?
    In this case, what would be the strategy to determine the ring buffer size? Also, SAADC_BUF_SIZE is 96 right now. Should I change it to 1 sample in buffer and save sample by sample in ring buffer? Moreover, what should be GAP_EVENT_LENGTH in that case? Right now it is 6. I am planning to dump 96 samples(or, 192 bytes) from the ring buffer during each BLE Tx. Pardon me as, I am asking a lot of questions. So far, the discussion has helped me a lot Smiley!
    Thank you for your continuous support throughout this issue. I really appreciate your time and support. Please let me know if any info is required.
    Glad to hear that you're making progress!
    Just to clarify: A ring buffer will also loose data if there aren't room to store additional data.
    Yes, this is one way to do this. Another option is to queue the data as a part of the SAADC DONE-event handling
    I would recommend that you decide the ring buffer size based on how fast you generate the data and how long history/how many samples back in time you wish to store
    The GAP_EVENT_LENGTH could be equal to the connection interval. This would mean that you would be able to send several packs in one connection event, up to event_length. Do note that this will increase the power consumption, but you will get a higher throughput.
    I recommend you to have a look at the Online POwer Profiler to get a look at how tweaking the various parameters will influence your transmission
    Online Power Profiler for Bluetooth LE - opp - Online Power Profiler - Nordic DevZone (nordicsemi.com)
    Andreas
