nRF5340 Audio DK: LE Audio and UART2 Concurrently
I have problems with the nRF5340 Audio DK to get LE Audio and UART2 concurrently on the same CIS stream to work.
GOAL
Use 2 x nRF5340 Audio DKs to transfer audio both directions via Line IN and at the same time send UART2 data from and to the 2 kits concurrently.  Exactly like the Walkie-Talkie demo but with LINE IN instead of Microphone.  And the UART must be a physical one and UART2 was chosen with a UART/RS232 converter.  So full duplex audio and serial data.
What I did so far
I did manage to modify the Application "<Path to ncs folder>\v2.2.0\nrf\applications\nrf5340_audio" to work with the LINE IN port. See my Forum post:
nRF5340 Audio DK: Walkie Talkie Demo - LINE IN instead of MIC
I also managed to modify both these samples to work with UART2 instead of the CDC Com port UART0.  I used the 2 Samples "Central UART" and "Peripheral UART". See my Forum post:
 Central and Peripheral UART Samples on UART2 - nRF5340 Audio DK
Then I created a third Project with 2 applications that I want to combine the 2 projects. However, I only manage to get the "GATEWAY" paired with the NUS Server to work. But on the HEADSET side I can't get the NUS Client to work.  I tested the combined GATEWAY and NUS Server (Peripheral UART) with a HEADSET only and with the NUS Client (Central UART). That is why I know the GATEWAY/NUS Server side works.
The Audio still works but I cannot receive or sent serial data on the NUS client side which is on the HEADSET application side.
Application
We need to transfer Audio and Data in a full duplex Intercom system over a short distance because the wiring of an audio and data line is not possible due to moving parts.
Could you please help me combine the 4 projects into 2 please?  Is concurrent UART and LE Audio even possible?
Kind Regards
    Which version of NCS are you using?
    Do you test the HEADSET merged with the NUS client and Peripheral UART sample?
    Could you provide the output log on both sides and the sniffer log?
    Amanda H.
  • Hi Amanda,
    2.2.0.   (Was using 2.3.0 originally but had a problem earlier with the board so I went one version down. )
    I tried both (first Central and lastly Peripheral) with the HEADSET, currently Peripheral UART on the HS.
    I do not have a 3rd device that can run the sniffer application.
    I am having issues with the logging because of the UART2 change.  Here is my log, I had to add a lot of printk() lines to log to UART0:
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    InitLEAudio()
    nRF5340 APP core started
    bt_dev.drv
    atomic_clear_bit
    atomic_test_and_set_bit
    bt_settings_init
    bt_monitor_send
    k_work_submit
    LE Audio Setup Done.
    InitUART2()
    Starting Bluetooth Central UART example
    bt_conn_auth_cb_register
    bt_conn_auth_info_cb_register
    Bluetooth initialized
    settings_load
    module_init
    Scan module initialized
    Scanning successfully started
    UART2 Setup Done.
    *** In ble_write_thread ***
    * Entering Loop *
    Failed to send data over BLE connection(err -128)
    NUS send timeout
    Thank you
    Fritz
    Error -128 means that Socket is not connected.
    Please make sure Central and Peripheral UART are connected.
    -Amanda H.
    If I knew how to I would not have asked for help.
    I have disabled the code because it creates another problem:
        // printk("  bt_enable.\n");
        // err = bt_enable(NULL);
        // if (err)
        //  printk("Failed to Enable UART service (err: %d)", err);
        //  error();
    If I disable the LE Audio code and uncomment the code "bt_enable(NULL);" then it works. But If I enable the LE Audio code again, then It doesn't work anymore.
        printk("  bt_enable\n");
        if (err)
            printk("Bluetooth init failed (err %d)", err);
            LOG_ERR("Bluetooth init failed (err %d)", err);
            return;
    InitLEAudio()
    bt_dev.drv
    atomic_clear_bit
    bt_settings_init
    bt_monitor_send
    k_work_submit
    InitUART2()
    bt_enable
    bt_dev.drv
    atomic_clear_bit
    Bluetooth init failed (err -120)
    Some further testing here is a log with more detail:
    InitLEAudio()
    bt_dev.drv
    atomic_clear_bit
    bt_settings_init
    bt_monitor_send
    k_work_submit
    InitUART2()
    settings_load
    module_init
    uart_init
    UART device is ready
    NUS Client module initialized
    Scanning
    UART2 Setup Done.
    Filters matched. Address: FC:55:67:78:B1:1F (random) connectable: 1
    Connecting failed
    connected
    bt_addr_le_to_str
    Connected: FC:55:67:78:B1:1F (random)
    * Entering Loop *
    bt_addr_le_to_str
    Security changed: FC:55:67:78:B1:1F (random) level 2
    gatt_discover
    MTU exchange done
    Isn't the Init error related to there being already a LE Audio stream going and BT is already initialized and connected?
  • yes, err -120 means Operation is already in progress.
    From the second part of the log, it seems you fix the issue, right? There is no error in the second part of the ble_write_thread
    -Amanda H.
