Direct XIP partition manager
Nordic nrf5340, ncs v2.1.0
We have an application that needs a backup image.  We were under the impression that mcuboot would handle the case that an image was corrupted and revert to a known good image, but that appears to not be the case.  From from I've read on this forum, this is possible using the Direct XIP method with REVERT enabled.
For reference, this is the partition map of the application before adding XIP
I'm disappointed by the lack of documentation on this topic, but from reading for forum posts it looks like this is how you enable XIP with revert
#prj.conf
CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT=y
#child_image/mcuboot.conf
CONFIG_BOOT_DIRECT_XIP=y
CONFIG_BOOT_DIRECT_XIP_REVERT=y
When I add these config options, the partition manager freaks out about the mcuboot_secondary partition.  In the original memory map, mcuboot_secondary starts at address 0x84000, and it appears that this is the same with XIP, but partition manager wants it to start at 0x84001?
Partition manager failed: Error when inspecting mcuboot_secondary_pad, invalid address 0x84000, expected 0x84001,
Failed to partition region flash_primary, size of region: 1048576
Partition Configuration:
mcuboot:
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  placement:
    align:
      start: 16384
    before:
    - mcuboot_primary_app
mcuboot_secondary_app:
  placement:
    after:
    - mcuboot_secondary_pad
mcuboot_secondary_pad:
  placement:
    after:
    - mcuboot_primary
    align:
      start: 16384
settings_storage:
  placement:
    before:
    - end
A few questions..
1.  Is this the correct way to configure XIP?
2.  If so... how do I fix this partition error?
  • Hi Roedy,
    Unfortunately, Direct XIP with Revert is not working as of NCS v2.4.0. However, if you want to proceed with Direct XIP without Revert, then could you please describe your issues in more details? I would be happy to help you with that.
    Hieu
  • Hi Hieu,
    I had some other bugs related to the 2.4.0 update which were fixed.
    What I was seeing is that the banner message is printed on a reset, but nothing appearing afterwords
    *** Booting Zephyr OS build v3.3.99-ncs1 ***
    I assume that something happened to the serial output... but I just determined that my application was not running.
    At your suggestion, removing "CONFIG_BOOT_DIRECT_XIP_REVERT=y" from mcuboot.conf fixed the problem.
    To summarize:  The problem was resolved with NCS v2.4.0 and the config settings
    #prj.conf
  • Hi Hieu,
    #prj.conf
