NRF24L01+ no transmit
I'm trying to get a module with an NFR24L01+ on board to send a simple data transmission from a pic micro but after a couple of days of trying various combinations without success i'm asking for help.
I can see data and commands being clocked in and out of the SPI. the pulse on CE is present on the chip. VDD_PA never rises. No power noted on a monitoring SA. Status 0x0E returned from chip.
My send byte code:
unsigned char SPI_RW(unsigned char DATA) {
  while (! SSPIF);
  SSPSTATbits.BF = 0;
  SSPBUF = DATA;
  while(SSPSTATbits.BF == 0);
  return SSPBUF;
My send register code:
unsigned char SPI_RW_Register(unsigned char reg, unsigned char value){
  int status;
  CSN_PIN=0;
  status=SPI_RW(reg);
  SPI_RW(value);
  CSN_PIN=1;
  return status;
My write buffer code:
unsigned char SPI_Write_Buffer(unsigned char reg, unsigned char *pBuf, unsigned char bytes){
  unsigned char status,i;
  CSN_PIN=0;                   // Set CSN low, init SPI tranaction
  status = SPI_RW(reg);             // Select register to write to and read status unsigned char
  for(i=0;i<bytes; i++)             // then write all unsigned char in buffer(*pBuf)
    SPI_RW(*pBuf++);
  CSN_PIN=1;
  return(status);                  // return nRF24L01 status unsigned char
My init code:
  CE_PIN=0;
    SPI_RW_Register(WRITE_REG + CONFIG,0x00110000);// PRX, no CRC , mask a couple of ints
    __delay_ms(100);
    SPI_RW_Register(WRITE_REG + SETUP_RETR,0x00);// autoretransmit off
    SPI_RW_Register(WRITE_REG + SETUP_AW,0x00000011);// address width = 5
    SPI_RW_Register(WRITE_REG + RF_SETUP, 0x00100110); //data rate 250KB 0dBm
    SPI_RW_Register(WRITE_REG + RF_CH,0x02);// set channel
    SPI_Write_Buffer(WRITE_REG + TX_ADDR,TX_ADDRESS,5);
    SPI_Write_Buffer(WRITE_REG + RX_ADDR_P0,TX_ADDRESS,5);
    SPI_RW_Register(WRITE_REG + EN_AA,0x00); //disable auto-ack
My TX code:
void NRFtx(){
  CE_PIN=0;
  SPI_RW_Register(WRITE_REG + STATUS,0x7e); // clear previous interrupts
  SPI_RW_Register(WRITE_REG + CONFIG,0x00110010);// PTX, no CRC, mask a couple of ints
  __delay_us(150);
  SPI_RW_Command(FLUSH_TX);//clear tx fifo
  SPI_Write_Buffer(WR_TX_PAYLOAD,tx_buf,TX_PAYLOAD_WIDTH);
  CE_PIN=1;
  __delay_ms(15);
  CE_PIN=0;
Can anyone please tell me where i'm going wrong with this?
Thank you,
S
