Modem trace not working in nrf9160
Hello everyone,
I have been using an application based on the Asset Tracker v2 for nrf9160 (similar to the original application but with some differences in the data sent to the cloud and the sampling frequencies). I am using the Icarus IoT board, which includes the nrf9160 rev1.
I need to obtain a modem trace to debug some communication issues, but I am encountering difficulties.
The first approach I tried was adding the following line to the prj.conf file:
CONFIG_NRF_MODEM_LIB_TRACE=y
However, this resulted in a build error:
gen_isr_tables.py: error: multiple registrations at table_index 9 for irq 9 (0x9) Existing handler 0x6173b, new handler 0x62915 Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?Code
I thought the issue might be due to using UART for logging, so I modified the code to get the logs through RTT by adding the following lines to the prj.conf:
CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=nCode
Unfortunately, this caused the same IRQ error.
I also attempted to obtain the modem trace via RTT using the line CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT=y. However, in this case, I am receiving log messages through both UART and RTT, which is not my intended outcome.
Do any of you have any ideas on how I can successfully obtain the modem trace?
Thank you in advance for your assistance.
    Can you please provide the build log from when it fails to build?
    Also, what version of nRF Connect SDK are you using? Does it work with default Asset Tracker v2?'
    Øyvind
  • Hi, I'm using SDK v2.1.0. Here is the build log:
    -- west build: making build dir /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns pristine
    -- Application: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2
    -- Found Python3: /home/AD/ncs/toolchains/v2.1.0/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: /home/AD/.cache/zephyr
    -- Zephyr version: 3.1.99 (/home/AD/ncs/v2.1.0/zephyr)
    -- Board: actinius_icarus_ns, Revision: 2.0.0
    -- Found host-tools: zephyr 0.14.1 (/home/AD/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
    -- Found dtc: /home/AD/ncs/toolchains/v2.1.0/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (/home/AD/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
    -- Found BOARD.dts: /home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns.dts
    -- Found devicetree overlay: /home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns_2_0_0.overlay
    -- Found devicetree overlay: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/boards/actinius_icarus_ns.overlay
    -- Generated zephyr.dts: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/dts.cmake
    Parsing /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/Kconfig
    Loaded configuration '/home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns_defconfig'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/prj.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/boards/actinius_icarus_ns.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/overlay-aws.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/overlay-debug.conf'
    Configuration saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/.config'
    Kconfig header saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 10.3.0
    -- The CXX compiler identification is GNU 10.3.0
    -- Found assembler: /home/AD/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    loading initial cache file /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/child_image_preload.cmake
    -- Application: /home/AD/ncs/v2.1.0/nrf/samples/bootloader
    -- Board: actinius_icarus, Revision: 2.0.0
    -- Found BOARD.dts: /home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus.dts
    -- Found devicetree overlay: /home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_2_0_0.overlay
    -- Generated zephyr.dts: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/dts.cmake
    Parsing /home/AD/ncs/v2.1.0/zephyr/Kconfig
    Loaded configuration '/home/AD/ncs/v2.1.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_defconfig'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/samples/bootloader/prj.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/.config'
    Kconfig header saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/b0
    -- Found Python3: /home/AD/ncs/toolchains/v2.1.0/usr/local/bin/python3.8 (found version "3.8.2") found components: Interpreter
    loading initial cache file /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/child_image_preload.cmake
    -- Application: /home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: /home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/dts.cmake
    Parsing /home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration '/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/boards/actinius_icarus.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/subsys/bootloader/image/multi_image_mcuboot.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/subsys/bootloader/image/fw_info.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/subsys/bootloader/image/build_s1.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/.config'
    Kconfig header saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/mcuboot
    -- Generated zephyr.dts: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/dts.cmake
    Merged configuration '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/.config'
    Kconfig header saved to '/home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/s1_image
    -- Configuring done
    -- Generating done
    [0/443] Generating extra provision key files
    [1/443] Preparing syscall dependency handling
    [8/443] Generating include/generated/version.h
    -- Zephyr version: 3.1.99 (/home/AD/ncs/v2.1.0/zephyr), build: v3.1.99-ncs1-2-gd5792880033f
    [69/443] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [70/443] Performing build step for 'b0_subimage'
    [1/165] Preparing syscall dependency handling
    [2/165] Generating include/generated/version.h
    [3/165] Generating misc/generated/syscalls_subdirs.trigger
    [4/165] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/165] Generating include/generated/driver-validation.h
    [6/165] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [7/165] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [8/165] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/165] Generating include/generated/offsets.h
    [10/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [11/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [12/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [13/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [14/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [15/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [16/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [17/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [18/165] Building C object CMakeFiles/app.dir/src/main.c.obj
    [19/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [20/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [21/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [22/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [23/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [24/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [25/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [26/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [27/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [28/165] Linking C static library app/libapp.a
    [29/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [30/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [31/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [32/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [33/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [34/165] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [35/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [36/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [37/165] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [38/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [39/165] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [40/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [41/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [42/165] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [43/165] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [44/165] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [45/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [46/165] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [47/165] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [48/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [49/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [50/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [51/165] Linking C static library zephyr/arch/common/libisr_tables.a
    [52/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [53/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [54/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [55/165] Generating linker_zephyr_pre0.cmd
    [56/165] Linking C static library zephyr/libzephyr.a
    [57/165] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [58/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [59/165] Generating linker_zephyr_pre1.cmd
    [60/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [61/165] Linking C static library zephyr/arch/common/libarch__common.a
    [62/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [63/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [64/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [65/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [66/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [67/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [68/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [69/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [70/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [71/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [72/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [73/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [74/165] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [75/165] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [76/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [77/165] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [78/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [79/165] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [80/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [81/165] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [82/165] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [83/165] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [84/165] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [85/165] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [86/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [87/165] Linking C static library zephyr/lib/posix/liblib__posix.a
    [88/165] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [89/165] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
    [90/165] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [91/165] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [92/165] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
    [93/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_common.c.obj
    [94/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
    [95/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_ecdsa.c.obj
    [96/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_hash.c.obj
    [97/165] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
    [98/165] Linking C static library modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a
    [99/165] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [100/165] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [101/165] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [102/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [103/165] Linking C static library modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a
    [104/165] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [105/165] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [106/165] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
    [107/165] Linking C static library modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a
    [108/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [109/165] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [110/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [111/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [112/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [113/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [114/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [115/165] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [116/165] Linking C static library modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a
    [117/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [118/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [119/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [120/165] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [121/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [122/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [123/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [124/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [125/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [126/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [127/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [128/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [129/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [130/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [131/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [132/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [133/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [134/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [135/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [136/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [137/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [138/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [139/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [140/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [141/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [142/165] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [143/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [144/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [145/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [146/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [147/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [148/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [149/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [150/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [151/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [152/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [153/165] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [154/165] Linking C static library zephyr/kernel/libkernel.a
    [155/165] Linking C executable zephyr/zephyr_pre0.elf
    [156/165] Generating dev_handles.c
    [157/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [158/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [159/165] Linking C executable zephyr/zephyr_pre1.elf
    [160/165] Generating linker.cmd
    [161/165] Generating isr_tables.c, isrList.bin
    [162/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [163/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [164/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [165/165] Linking C executable zephyr/zephyr.elf
               FLASH:       22984 B        32 KB     70.14%
                SRAM:       37288 B     195352 B     19.09%
            IDT_LIST:          0 GB         2 KB      0.00%
    [74/443] Generating ../../tfm/CMakeCache.txt
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/tfm
    [79/443] No configure step for 'tfm'
    [80/443] Generating signing key
    [82/443] Completed 'b0_subimage'
    [83/443] Performing build step for 'mcuboot_subimage'
    [1/195] Preparing syscall dependency handling
    [2/195] Generating include/generated/version.h
    [3/195] Generating misc/generated/syscalls_subdirs.trigger
    [4/195] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/195] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [6/195] Generating include/generated/driver-validation.h
    [7/195] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [8/195] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/195] Generating include/generated/offsets.h
    [10/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj
    [11/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [12/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [13/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [14/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [15/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [16/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [17/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [18/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [19/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [20/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [21/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [22/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [23/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [24/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [25/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [26/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [27/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [28/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [29/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [30/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [31/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [32/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [33/195] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [34/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [35/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [36/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [37/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [38/195] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [39/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [40/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [41/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [42/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [43/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [44/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [45/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [46/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/serial_recovery_cbor.c.obj
    [47/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [48/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_decode.c.obj
    [49/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_encode.c.obj
    [50/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [51/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_common.c.obj
    [52/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    [53/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [54/195] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
    [55/195] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [56/195] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [57/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [58/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [59/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [60/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [61/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [62/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [63/195] Generating linker_zephyr_pre0.cmd
    [64/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [65/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [66/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [67/195] Linking C static library zephyr/arch/common/libisr_tables.a
    [68/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [69/195] Generating linker_zephyr_pre1.cmd
    [70/195] Linking C static library zephyr/libzephyr.a
    [71/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [72/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [73/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [74/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [75/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [76/195] Linking C static library zephyr/arch/common/libarch__common.a
    [77/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [78/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [79/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [80/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [81/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [82/195] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [83/195] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [84/195] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [85/195] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [86/195] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [87/195] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [88/195] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [89/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [90/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [91/195] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [92/195] Linking C static library zephyr/lib/posix/liblib__posix.a
    [93/195] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [94/195] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [95/195] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [96/195] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [97/195] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [98/195] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [99/195] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [100/195] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [101/195] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [102/195] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [103/195] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [104/195] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [105/195] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [106/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [107/195] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [108/195] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [109/195] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [110/195] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [111/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [112/195] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [113/195] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [114/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [115/195] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [116/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [117/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [118/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [119/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [120/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [121/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [122/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [123/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [124/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [125/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [126/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [127/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [128/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [129/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [130/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [131/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [132/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [133/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [134/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [135/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [136/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [137/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [138/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [139/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [140/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [141/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [142/195] Generating zephyr/autogen-pubkey.c
    [143/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [144/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [145/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [146/195] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [147/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [148/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [149/195] Building C object CMakeFiles/app.dir/os.c.obj
    [150/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [151/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [152/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [153/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [154/195] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [155/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [156/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [157/195] Building C object CMakeFiles/app.dir/keys.c.obj
    [158/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [159/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [160/195] Building C object CMakeFiles/app.dir/main.c.obj
    [161/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [162/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [163/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [164/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    [165/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [166/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [167/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [168/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [169/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [170/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [171/195] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [172/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [173/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [174/195] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [175/195] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [176/195] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [177/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [178/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [179/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [180/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [181/195] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [182/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [183/195] Linking C static library app/libapp.a
    [184/195] Linking C static library zephyr/kernel/libkernel.a
    [185/195] Linking C executable zephyr/zephyr_pre0.elf
    [186/195] Generating dev_handles.c
    [187/195] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [188/195] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [189/195] Linking C executable zephyr/zephyr_pre1.elf
    [190/195] Generating linker.cmd
    [191/195] Generating isr_tables.c, isrList.bin
    [192/195] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [193/195] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [194/195] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [195/195] Linking C executable zephyr/zephyr.elf
               FLASH:       40068 B        48 KB     81.52%
                SRAM:       25144 B     195352 B     12.87%
    [84/443] Generating zephyr/b0_container.hex
    [85/443] Creating public key from private key used for signing
    [87/443] Completed 'mcuboot_subimage'
    [88/443] Performing build step for 's1_image_subimage'
    [5/195] Generating include/generated/driver-validation.h
    [6/195] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [11/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [12/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [13/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [14/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [16/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [17/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [18/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [20/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [21/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [22/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [23/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [24/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [25/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [26/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [27/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [28/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [29/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [32/195] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [37/195] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [38/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [39/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [40/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [41/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [42/195] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [43/195] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [50/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_common.c.obj
    [51/195] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [52/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [53/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [54/195] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    [56/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [57/195] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
    [58/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [59/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [61/195] Linking C static library zephyr/arch/common/libisr_tables.a
    [62/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [63/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [64/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [65/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [66/195] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [67/195] Generating linker_zephyr_pre1.cmd
    [69/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [70/195] Generating linker_zephyr_pre0.cmd
    [71/195] Linking C static library zephyr/libzephyr.a
    [72/195] Linking C static library zephyr/arch/common/libarch__common.a
    [73/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [74/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [75/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [76/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [77/195] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [78/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [80/195] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [81/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [82/195] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [86/195] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [87/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [89/195] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [90/195] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [91/195] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [92/195] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [93/195] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [94/195] Linking C static library zephyr/lib/posix/liblib__posix.a
    [95/195] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [96/195] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [97/195] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [98/195] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [99/195] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [100/195] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [101/195] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [102/195] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [104/195] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [105/195] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [107/195] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [108/195] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [109/195] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [110/195] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [111/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [112/195] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [113/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [114/195] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [115/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [116/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [117/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [118/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [119/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [120/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [122/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [123/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [124/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [125/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [126/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [127/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [128/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [129/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [130/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [131/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [132/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [133/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [134/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [135/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [136/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [137/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [138/195] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [139/195] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [140/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [141/195] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [142/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [143/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [144/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [146/195] Generating zephyr/autogen-pubkey.c
    [147/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [149/195] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [150/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [151/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [152/195] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [153/195] Building C object CMakeFiles/app.dir/os.c.obj
    [154/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [155/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [156/195] Building C object CMakeFiles/app.dir/main.c.obj
    [157/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [158/195] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [159/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [160/195] Building C object CMakeFiles/app.dir/keys.c.obj
    [161/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [162/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [163/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [164/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [165/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [166/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    [167/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [168/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [169/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [170/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [171/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [172/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [173/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [174/195] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [175/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [176/195] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [177/195] Building C object CMakeFiles/app.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [178/195] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [179/195] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [181/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [182/195] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [90/443] Generating zephyr/s0.hex
    [91/443] Creating data to be provisioned to the Bootloader, storing to provision.hex
    [93/443] Completed 's1_image_subimage'
    [94/443] Creating signature of application
    [95/443] Creating signature of application
    [96/443] Creating validation for zephyr.hex, storing to
    [97/443] Creating validation for zephyr.hex, storing to
    [98/443] Generating zephyr/s1.hex
    [99/443] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/170] Generating liboberon_mbedcrypto__psa_3.0.12.a
    [2/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/asn1parse.o
    [3/170] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [4/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/base64.o
    [5/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/oid.o
    [6/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/nist_kw.o
    [7/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/padlock.o
    [8/170] Linking C static library lib/fih/libtfm_fih_implementation.a
    [9/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/asn1write.o
    [10/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/bignum.o
    [11/170] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [12/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/platform.o
    [13/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [14/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [15/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [16/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [17/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [18/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [19/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [20/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o
    [21/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [22/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [23/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [24/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [25/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [26/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [27/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o
    [28/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [29/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [30/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [31/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [32/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [33/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [34/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [35/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [36/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [37/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [38/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [39/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [40/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [41/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [42/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [43/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [44/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [45/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [46/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [47/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o
    [48/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [49/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [50/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [51/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [52/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [53/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [54/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [55/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [56/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [57/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [58/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [59/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [60/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [61/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o
    [62/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [63/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [64/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [65/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [66/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [67/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [68/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [69/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [70/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [71/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [72/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [73/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/version.o
    [74/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/platform_util.o
    [75/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [76/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/home/AD/ncs/v2.1.0/mbedtls/library/constant_time.o
    [77/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [78/170] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libmbedcrypto_base.a
    [79/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [80/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_cipher.o
    [81/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/memory_buffer_alloc.o
    [82/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_aead.o
    [83/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_client.o
    [84/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_ecp.o
    [85/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_hash.o
    [86/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_storage.o
    [87/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_mac.o
    [88/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pem.o
    [89/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pkcs12.o
    [90/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [91/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_rsa.o
    [92/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pkcs5.o
    [93/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pkwrite.o
    [94/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pkparse.o
    [95/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/dhm.o
    [96/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/md.o
    [97/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [98/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/cipher_wrap.o
    [99/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pk.o
    [100/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/pk_wrap.o
    [101/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto_slot_management.o
    [102/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/sha1.o
    [103/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/sha256.o
    [104/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/sha512.o
    [105/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/md5.o
    [106/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/aria.o
    [107/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ripemd160.o
    [108/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/des.o
    [109/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/camellia.o
    [110/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/aesni.o
    [111/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/cmac.o
    [112/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ccm.o
    [113/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/chachapoly.o
    [114/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ecdh.o
    [115/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ecdsa.o
    [116/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/cipher.o
    [117/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/gcm.o
    [118/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/hmac_drbg.o
    [119/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ecp_curves.o
    [120/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/hkdf.o
    [121/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/ecp.o
    [122/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [123/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/rsa_alt_helpers.o
    [124/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/rsa.o
    [125/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [126/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [127/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [128/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [129/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [130/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [131/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [132/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [133/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [134/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [135/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [136/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [137/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [138/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [139/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [140/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [141/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [142/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [143/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o
    [144/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [145/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [146/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [147/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [148/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [149/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [150/170] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [151/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [152/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [153/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [154/170] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [155/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [156/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [157/170] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o
    [158/170] Building C object platform/CMakeFiles/platform_s.dir/home/AD/ncs/v2.1.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [159/170] Linking C static library platform/libplatform_s.a
    [160/170] Linking C static library secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a
    [161/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/home/AD/ncs/v2.1.0/mbedtls/library/psa_crypto.o
    [162/170] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a
    [163/170] Linking C static library secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a
    [164/170] Linking C static library secure_fw/partitions/lib/sprt/libtfm_sprt.a
    [165/170] Linking C static library secure_fw/spm/libtfm_spm.a
    [166/170] Linking C executable bin/tfm_s.axf
    [167/170] Generating ../bin/tfm_s.bin
    [168/170] Generating ../bin/tfm_s.hex
    [169/170] Generating ../bin/tfm_s.elf
    [170/170] Linking C static library secure_fw/libtfm_s_veneers.a
    [100/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s0_image_update.bin
    sign the payload
    [101/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s1_image_update.bin
    sign the payload
    [102/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s0_image_signed.hex
    sign the payload
    [103/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s0_image_test_update.hex
    sign the payload
    [105/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s1_image_test_update.hex
    sign the payload
    [106/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s1_image_signed.hex
    sign the payload
    [107/443] Generating ../../zephyr/signed_by_mcuboot_and_b0_s1_image_moved_test_update.hex
    [109/443] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [110/443] Completed 'tfm'
    [111/443] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [112/443] Generating zephyr/tfm_secure.hex
    [113/443] Generating include/generated/offsets.h
    [114/443] Building C object CMakeFiles/app.dir/src/modules/gnss_module.c.obj
    ../src/modules/gnss_module.c:514:13: warning: 'inactive_send' defined but not used [-Wunused-function]
      514 | static void inactive_send(void)
    [115/443] Building C object CMakeFiles/app.dir/src/main.c.obj
    ../src/main.c:40:12: warning: 'first_time' defined but not used [-Wunused-variable]
       40 | static int first_time=1;
    [116/443] Building C object CMakeFiles/app.dir/src/modules/modules_common.c.obj
    [117/443] Building C object CMakeFiles/app.dir/src/modules/modem_module.c.obj
    [118/443] Building C object CMakeFiles/app.dir/src/modules/cloud_module.c.obj
    [119/443] Building C object CMakeFiles/app.dir/src/modules/sensor_module.c.obj
    [120/443] Building C object CMakeFiles/app.dir/src/modules/util_module.c.obj
    [121/443] Building C object CMakeFiles/app.dir/src/modules/data_module.c.obj
    [122/443] Building C object CMakeFiles/app.dir/src/modules/debug_module.c.obj
    [123/443] Building C object CMakeFiles/app.dir/src/events/app_module_event.c.obj
    [124/443] Building C object CMakeFiles/app.dir/src/events/gnss_module_event.c.obj
    [125/443] Building C object CMakeFiles/app.dir/src/events/cloud_module_event.c.obj
    [126/443] Building C object CMakeFiles/app.dir/src/events/modem_module_event.c.obj
    [127/443] Building C object CMakeFiles/app.dir/src/events/data_module_event.c.obj
    [128/443] Building C object CMakeFiles/app.dir/src/events/sensor_module_event.c.obj
    [129/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/json_helpers.c.obj
    [130/443] Building C object CMakeFiles/app.dir/src/events/debug_module_event.c.obj
    [131/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/base64.c.obj
    [132/443] Building C object CMakeFiles/app.dir/src/events/util_module_event.c.obj
    [133/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/aws_iot/aws_iot_codec.c.obj
    [134/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/cloud_codec_ringbuffer.c.obj
    [135/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/common.c.obj
    [136/443] Building C object CMakeFiles/app.dir/src/cloud/aws_iot_integration.c.obj
    [137/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [138/443] Building C object CMakeFiles/app.dir/src/cloud/cloud_codec/json_common.c.obj
    [139/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [140/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [141/443] Building C object CMakeFiles/app.dir/src/ext_sensors/ext_sensors.c.obj
    [142/443] Building C object CMakeFiles/app.dir/src/ext_sensors/adc_battery_voltage.c.obj
    [143/443] Building C object CMakeFiles/app.dir/src/watchdog/watchdog_app.c.obj
    [144/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [145/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [146/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [147/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [148/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [149/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [150/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [151/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [152/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [153/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [154/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [155/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [156/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [157/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [158/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [159/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [160/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [161/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [162/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [163/443] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [164/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [165/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [166/443] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [167/443] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [168/443] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [169/443] Linking C static library app/libapp.a
    [170/443] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [171/443] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [172/443] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [173/443] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [174/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_analyzer.c.obj
    [175/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [176/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [177/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_append.c.obj
    [178/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [179/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb.c.obj
    [180/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_uart.c.obj
    [181/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_elem_info.c.obj
    [182/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_rotate.c.obj
    [183/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [184/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_getnext.c.obj
    [185/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_walk.c.obj
    [186/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
    [187/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [188/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sntp/sntp.c.obj
    [189/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
    [190/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
    [191/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [192/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sntp/sntp_simple.c.obj
    [193/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
    [194/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
    [195/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [196/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [197/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [198/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [199/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [200/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [201/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [202/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_fcb.c.obj
    [203/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [204/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [205/443] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [206/443] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/app_event_manager/app_event_manager.c.obj
    [207/443] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/caf/events/module_state_event.c.obj
    [208/443] Building C object zephyr/CMakeFiles/zephyr.dir/home/AD/ncs/v2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [209/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [210/443] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [211/443] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [212/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [213/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [214/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [215/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [216/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [217/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [218/443] Generating linker_zephyr_pre0.cmd
    [219/443] Linking C static library zephyr/arch/common/libisr_tables.a
    [220/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [221/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [222/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [223/443] Generating linker_zephyr_pre1.cmd
    [224/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [225/443] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [226/443] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [227/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [228/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [229/443] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [230/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [231/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [232/443] Linking C static library zephyr/arch/common/libarch__common.a
    [233/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [234/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [235/443] Linking C static library zephyr/libzephyr.a
    [236/443] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [237/443] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [238/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [239/443] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [240/443] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [241/443] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [242/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/clock.c.obj
    [243/443] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [244/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [245/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [246/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/timer.c.obj
    [247/443] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [248/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [249/443] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/sleep.c.obj
    [250/443] Building C object zephyr/boards/arm/actinius_icarus/CMakeFiles/boards__arm__actinius_icarus.dir/board.c.obj
    [251/443] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [252/443] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a
    [253/443] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [254/443] Building C object zephyr/subsys/dfu/boot/CMakeFiles/subsys__dfu__boot.dir/mcuboot.c.obj
    [255/443] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [256/443] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [257/443] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [258/443] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [259/443] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [260/443] Linking C static library zephyr/lib/posix/liblib__posix.a
    [261/443] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [262/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_decoder.c.obj
    [263/443] Linking C static library zephyr/boards/arm/actinius_icarus/libboards__arm__actinius_icarus.a
    [264/443] Linking C static library zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a
    [265/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_encoder.c.obj
    [266/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_rx.c.obj
    [267/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt.c.obj
    [268/443] Linking C static library zephyr/subsys/net/libsubsys__net.a
    [269/443] Linking C static library zephyr/subsys/net/ip/libsubsys__net__ip.a
    [270/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_transport.c.obj
    [271/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_transport_socket_tls.c.obj
    [272/443] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/AD/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [273/443] Building C object zephyr/subsys/net/lib/mqtt/CMakeFiles/subsys__net__lib__mqtt.dir/mqtt_transport_socket_tcp.c.obj
    [274/443] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [275/443] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_common.c.obj
    [276/443] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_nrfx_saadc.c.obj
    [277/443] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [278/443] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [279/443] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [280/443] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [281/443] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [282/443] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [283/443] Building C object zephyr/drivers/sensor/lis2dh/CMakeFiles/drivers__sensor__lis2dh.dir/lis2dh.c.obj
    [284/443] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [285/443] Linking C static library zephyr/subsys/net/lib/mqtt/libsubsys__net__lib__mqtt.a
    [286/443] Linking C static library zephyr/drivers/adc/libdrivers__adc.a
    [287/443] Building C object zephyr/drivers/sensor/lis2dh/CMakeFiles/drivers__sensor__lis2dh.dir/lis2dh_i2c.c.obj
    [288/443] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [289/443] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [290/443] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [291/443] Building C object zephyr/drivers/sensor/lis2dh/CMakeFiles/drivers__sensor__lis2dh.dir/lis2dh_spi.c.obj
    [292/443] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [293/443] Building C object zephyr/drivers/sensor/lis2dh/CMakeFiles/drivers__sensor__lis2dh.dir/lis2dh_trigger.c.obj
    [294/443] Building C object zephyr/drivers/watchdog/CMakeFiles/drivers__watchdog.dir/wdt_nrfx.c.obj
    [295/443] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [296/443] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [297/443] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [298/443] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/home/AD/ncs/v2.1.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [299/443] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [300/443] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [301/443] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [302/443] Linking C static library zephyr/drivers/sensor/lis2dh/libdrivers__sensor__lis2dh.a
    [303/443] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [304/443] Linking C static library zephyr/drivers/watchdog/libdrivers__watchdog.a
    [305/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [306/443] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [307/443] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [308/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [309/443] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [310/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [311/443] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [312/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf91_sockets.c.obj
    [313/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib_trace.c.obj
    [314/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/trace_backends/uart/uart.c.obj
    [315/443] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [316/443] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [317/443] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/..__nrf__lib__at_cmd_parser.dir/at_cmd_parser.c.obj
    [318/443] Building C object modules/nrf/lib/at_host/CMakeFiles/..__nrf__lib__at_host.dir/at_host.c.obj
    [319/443] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/..__nrf__lib__at_cmd_parser.dir/at_params.c.obj
    [320/443] Building C object modules/nrf/lib/at_monitor/CMakeFiles/..__nrf__lib__at_monitor.dir/at_monitor.c.obj
    [321/443] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc.c.obj
    [322/443] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc_helpers.c.obj
    [323/443] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc_modem_hooks.c.obj
    [324/443] Building C object modules/nrf/lib/modem_info/CMakeFiles/..__nrf__lib__modem_info.dir/modem_info.c.obj
    [325/443] Linking C static library modules/nrf/lib/at_cmd_parser/lib..__nrf__lib__at_cmd_parser.a
    [326/443] Linking C static library modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a
    [327/443] Building C object modules/nrf/lib/modem_info/CMakeFiles/..__nrf__lib__modem_info.dir/modem_info_params.c.obj
    [328/443] Building C object modules/nrf/lib/modem_info/CMakeFiles/..__nrf__lib__modem_info.dir/modem_info_json.c.obj
    [329/443] Linking C static library modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a
    [330/443] Building C object modules/nrf/lib/pdn/CMakeFiles/..__nrf__lib__pdn.dir/esm.c.obj
    [331/443] Linking C static library modules/nrf/lib/at_monitor/lib..__nrf__lib__at_monitor.a
    [332/443] Building C object modules/nrf/lib/pdn/CMakeFiles/..__nrf__lib__pdn.dir/pdn.c.obj
    [333/443] Linking C static library modules/nrf/lib/lte_link_control/lib..__nrf__lib__lte_link_control.a
    [334/443] Building C object modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time.c.obj
    [335/443] Building C object modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time_ntp.c.obj
    [336/443] Building C object modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time_modem.c.obj
    [337/443] Linking C static library modules/nrf/lib/modem_info/lib..__nrf__lib__modem_info.a
    [338/443] Building C object modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time_core.c.obj
    [339/443] Building C object modules/nrf/lib/qos/CMakeFiles/..__nrf__lib__qos.dir/qos.c.obj
    [340/443] Building C object modules/nrf/subsys/net/lib/download_client/CMakeFiles/..__nrf__subsys__net__lib__download_client.dir/src/download_client.c.obj
    [341/443] Linking C static library modules/nrf/lib/pdn/lib..__nrf__lib__pdn.a
    [342/443] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_download_util.c.obj
    [343/443] Building C object modules/nrf/subsys/net/lib/download_client/CMakeFiles/..__nrf__subsys__net__lib__download_client.dir/src/parse.c.obj
    [344/443] Building C object modules/nrf/subsys/net/lib/download_client/CMakeFiles/..__nrf__subsys__net__lib__download_client.dir/src/sanity.c.obj
    [345/443] Building C object modules/nrf/subsys/net/lib/download_client/CMakeFiles/..__nrf__subsys__net__lib__download_client.dir/src/http.c.obj
    [346/443] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_download.c.obj
    [347/443] Linking C static library modules/nrf/lib/date_time/lib..__nrf__lib__date_time.a
    [348/443] Linking C static library modules/nrf/lib/qos/lib..__nrf__lib__qos.a
    [349/443] Building C object modules/nrf/subsys/net/lib/aws_fota/CMakeFiles/..__nrf__subsys__net__lib__aws_fota.dir/src/aws_fota.c.obj
    [350/443] Building C object modules/nrf/subsys/net/lib/aws_iot/CMakeFiles/..__nrf__subsys__net__lib__aws_iot.dir/src/aws_iot.c.obj
    [351/443] Building C object modules/nrf/subsys/net/lib/aws_jobs/CMakeFiles/..__nrf__subsys__net__lib__aws_jobs.dir/src/aws_jobs.c.obj
    [352/443] Building C object modules/nrf/subsys/net/lib/aws_fota/CMakeFiles/..__nrf__subsys__net__lib__aws_fota.dir/src/aws_fota_json.c.obj
    [353/443] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target.c.obj
    [354/443] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_stream.c.obj
    [355/443] Linking C static library modules/nrf/subsys/net/lib/fota_download/lib..__nrf__subsys__net__lib__fota_download.a
    [356/443] Linking C static library modules/nrf/subsys/net/lib/download_client/lib..__nrf__subsys__net__lib__download_client.a
    [357/443] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_modem_delta.c.obj
    [358/443] Linking C static library modules/nrf/subsys/net/lib/aws_jobs/lib..__nrf__subsys__net__lib__aws_jobs.a
    [359/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [360/443] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_mcuboot.c.obj
    [361/443] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [362/443] Linking C static library modules/nrf/subsys/net/lib/aws_iot/lib..__nrf__subsys__net__lib__aws_iot.a
    [363/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [364/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj
    [365/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj
    [366/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj
    [367/443] Linking C static library modules/nrf/subsys/net/lib/aws_fota/lib..__nrf__subsys__net__lib__aws_fota.a
    [368/443] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [369/443] Building C object modules/cjson/CMakeFiles/cjson.dir/home/AD/ncs/v2.1.0/modules/lib/cjson/cJSON_Utils.c.obj
    [370/443] Building C object modules/cjson/CMakeFiles/cjson.dir/home/AD/ncs/v2.1.0/modules/lib/cjson/cJSON.c.obj
    [371/443] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [372/443] Linking C static library modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a
    [373/443] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [374/443] Linking C static library modules/nrf/modules/tfm/zephyr/libtfm_api_nrf.a
    [375/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [376/443] Building C object modules/cjson/CMakeFiles/cjson.dir/os/cJSON_os.c.obj
    [377/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [378/443] Linking C static library modules/trusted-firmware-m/libtfm_api.a
    [379/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [380/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [381/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [382/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [383/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
    [384/443] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/home/AD/ncs/v2.1.0/mbedtls/library/platform.c.obj
    [385/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [386/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [387/443] Linking C static library modules/cjson/libcjson.a
    [388/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [389/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [390/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [391/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [392/443] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/AD/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [393/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [394/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [395/443] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [396/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [397/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [398/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [399/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [400/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [401/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [402/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [403/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [404/443] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [405/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [406/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [407/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [408/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [409/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [410/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [411/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [412/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [413/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [414/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [415/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [416/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [417/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [418/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/events.c.obj
    [419/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/usage.c.obj
    [420/443] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [421/443] Linking C static library zephyr/kernel/libkernel.a
    [422/443] Linking C executable zephyr/zephyr_pre0.elf
    [423/443] Generating dev_handles.c
    [424/443] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [425/443] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [426/443] Linking C executable zephyr/zephyr_pre1.elf
    [427/443] Generating linker.cmd
    [428/443] Generating isr_tables.c, isrList.bin
    FAILED: zephyr/isr_tables.c zephyr/isrList.bin
    cd /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr && /home/AD/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy --input-target=elf32-littlearm --output-target=binary --only-section=.intList /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/zephyr_pre1.elf isrList.bin && /home/AD/ncs/toolchains/v2.1.0/usr/local/bin/python3.8 /home/AD/ncs/v2.1.0/zephyr/scripts/build/gen_isr_tables.py --output-source isr_tables.c --kernel /home/AD/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/zephyr_pre1.elf --intlist isrList.bin --sw-isr-table --vector-table
    gen_isr_tables.py: error: multiple registrations at table_index 9 for irq 9 (0x9)
    Existing handler 0x62495, new handler 0x6366f
    Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
    I haven't tried the original asset tracker yet.
    Thanks
  • Thank you. I tried to build and got a lot of issues with LEDs. Will retry. Are you building with the default nrf\applications\asset_tracker_v2\overlay-debug.conf?
    Are you using our VS Code extension? How are you building the project?
  • I have the same problem.It is also with AT client sample.
  • Hi  , can you please open a new ticket with your issue with an elaborate explanation of your issue. Please provide the board you are using along with modem fw and nRF Connect SDK version.
    Thanks.
