JEDEC id [00 00 00] expect [c2 28 17] in Matter template sample
I'm developing my custom board with nrf52840 to work with Matter. I designed the board to make it as similar as possible to the development kit so I used the same external flash (mx25r6435f). When flashing Matter template sample (sdk v2.3.0) I see the following error in the console:
I: nRF5 802154 radio initialized
E: JEDEC id [00 00 00] expect [c2 28 17]
I: 4 Sectors of 4096 bytes
I: alloc wra: 1, f80
I: data wra: 1, 1c8
However, when testing external flash with spi_flash everything works. What can cause problems with the external flash only in Matter examples?
This is part of my dts file:
&qspi {
	status = "okay";
	pinctrl-0 = <&qspi_default>;
	pinctrl-1 = <&qspi_sleep>;
	mx25r64: mx25r6435f@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		/* MX25R64 supports only pp and pp4io */
		writeoc = "pp4io";
		/* MX25R64 supports all readoc options */
		readoc = "read4io";
		sck-frequency = <8000000>;
		jedec-id = [c2 28 17];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
and according to the example I created this overlay for my custom board:
/* Copyright (c) 2021 Nordic Semiconductor ASA
	chosen {
		nordic,pm-ext-flash = &mx25r64;
	* In some default configurations within the nRF Connect SDK,
	* e.g. on nRF52840, the chosen zephyr,entropy node is &cryptocell.
	* This devicetree overlay ensures that default is overridden wherever it
	* is set, as this application uses the RNG node for entropy exclusively.
	chosen {
		zephyr,entropy = &rng;
/* Disable unused peripherals to reduce power consumption */
&adc {
	status = "disabled";
&uart1 {
&pwm0 {
&spi1 {
&spi3 {
&usbd {
The spi_flash code I used to test external flash:
 * Copyright (c) 2016 Intel Corporation.
#include <zephyr/kernel.h>
#include <zephyr/drivers/flash.h>
#include <zephyr/device.h>
#include <stdio.h>
#include <string.h>
#if defined(CONFIG_BOARD_ADAFRUIT_FEATHER_STM32F405)
#define SPI_FLASH_TEST_REGION_OFFSET 0xf000
#elif defined(CONFIG_BOARD_ARTY_A7_ARM_DESIGNSTART_M1) || \
	defined(CONFIG_BOARD_ARTY_A7_ARM_DESIGNSTART_M3)
/* The FPGA bitstream is stored in the lower 536 sectors of the flash. */
#define SPI_FLASH_TEST_REGION_OFFSET \
	DT_REG_SIZE(DT_NODE_BY_FIXED_PARTITION_LABEL(fpga_bitstream))
#elif defined(CONFIG_BOARD_NPCX9M6F_EVB) || \
	defined(CONFIG_BOARD_NPCX7M6FB_EVB)
#define SPI_FLASH_TEST_REGION_OFFSET 0x7F000
#else
#define SPI_FLASH_TEST_REGION_OFFSET 0xff000
#define SPI_FLASH_SECTOR_SIZE        8192
void single_sector_test(const struct device *flash_dev)
	const uint8_t expected[] = { 0x55, 0xaa, 0x66, 0x99 };
	const size_t len = sizeof(expected);
	uint8_t buf[sizeof(expected)];
	int rc;
	printf("\nPerform test on single sector");
	/* Write protection needs to be disabled before each write or
	 * erase, since the flash component turns on write protection
	 * automatically after completion of write and erase
	 * operations.
	printf("\nTest 1: Flash erase\n");
	/* Full flash erase if SPI_FLASH_TEST_REGION_OFFSET = 0 and
	 * SPI_FLASH_SECTOR_SIZE = flash size
	rc = flash_erase(flash_dev, SPI_FLASH_TEST_REGION_OFFSET,
			 SPI_FLASH_SECTOR_SIZE);
	if (rc != 0) {
		printf("Flash erase failed! %d\n", rc);
	} else {
		printf("Flash erase succeeded!\n");
	printf("\nTest 2: Flash write\n");
	printf("Attempting to write %zu bytes\n", len);
	rc = flash_write(flash_dev, SPI_FLASH_TEST_REGION_OFFSET, expected, len);
	if (rc != 0) {
		printf("Flash write failed! %d\n", rc);
		return;
	while (true) {
		memset(buf, 0, len);
		rc = flash_read(flash_dev, SPI_FLASH_TEST_REGION_OFFSET, buf, len);
		if (rc != 0) {
			printf("Flash read failed! %d\n", rc);
			return;
		if (memcmp(expected, buf, len) == 0) {
			printf("Data read matches data written. Good!!\n");
		} else {
			const uint8_t *wp = expected;
			const uint8_t *rp = buf;
			const uint8_t *rpe = rp + len;
			printf("Data read does not match data written!!\n");
			while (rp < rpe) {
				printf("%08x wrote %02x read %02x %s\n",
					(uint32_t)(SPI_FLASH_TEST_REGION_OFFSET + (rp - buf)),
					*wp, *rp, (*rp == *wp) ? "match" : "MISMATCH");
				++rp;
				++wp;
		k_msleep(100);
	const struct device *flash_dev = DEVICE_DT_GET(DT_ALIAS(spi_flash0));
	if (!device_is_ready(flash_dev)) {
		printk("%s: device not ready.\n", flash_dev->name);
		return 0;
	printf("\n%s SPI flash testing\n", flash_dev->name);
	printf("==========================\n");
	single_sector_test(flash_dev);
	return 0;
