Hi, I am working on using nrf7002dk to connect to AWS over WiFi. So far I have been able to connect to WiFi and send a HTTP get request through DHCPV4. When I continue to aws_iot library, I have been able to call init, subscribe to topics, and provisioning certificates work (or not return error when they return). But whenever I call aws_iot_connect, I get
<err> aws_iot: mqtt_connect, error: -22 and
<wrn> aws_iot: connect_client failed, error: -7
Looking up the error numbers, I find that -22 stands for Invalid argument, and -7 stands for bad private key. I have tried to format my certificates header according to the library’s example and some posts here on nordic so I am pretty sure my certificates are not wrong. It would be great if I can get some help on the issue! Thank you for reading, and looking forward to any help that may come. Attached are a rough outline of my aws_iot function calls, my certificate header, and my prj.conf file. I have taken out sensitive parts in the code, please let me know if more info is needed!
// Standard library
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/kernel.h>
// Zephyr network library
#include <zephyr/net/net_if.h>
#include <zephyr/net/wifi_mgmt.h>
#include <zephyr/net/net_event.h>
#include <zephyr/net/ethernet.h>
#include <zephyr/net/ethernet_mgmt.h>
#include <zephyr/net/socket.h>
#include <zephyr/net/net_context.h>
// HTTP Module
#include <zephyr/net/http/client.h>
// AWS Module
#include <net/aws_iot.h>
#include "certs.h"
// ---AWS MODULE BEGIN---
static int aws_iot_certificates_provision(void)
static bool certs_added;
int err;
if (!IS_ENABLED(CONFIG_NET_SOCKETS_SOCKOPT_TLS) || certs_added) {
return 0;
err = tls_credential_add(CONFIG_AWS_IOT_SEC_TAG,
TLS_CREDENTIAL_CA_CERTIFICATE,
ca_certificate,
sizeof(ca_certificate));
if (err < 0) {
LOG_ERR("Failed to register CA certificate: %d",
err);
return err;
TLS_CREDENTIAL_PRIVATE_KEY,
private_key,
sizeof(private_key));
if (err < 0) {
LOG_ERR("Failed to register private key: %d", err);
return err;
TLS_CREDENTIAL_SERVER_CERTIFICATE,
device_certificate,
sizeof(device_certificate));
if (err < 0) {
LOG_ERR("Failed to register public certificate: %d", err);
return err;
certs_added = true;
return 0;
static bool cloud_connected;
void aws_iot_event_handler(const struct aws_iot_evt *const evt)
switch (evt->type) {
case AWS_IOT_EVT_CONNECTING:
LOG_INF("AWS_IOT_EVT_CONNECTING");
case AWS_IOT_EVT_CONNECTED:
LOG_INF("AWS_IOT_EVT_CONNECTED");
cloud_connected = true;
if (evt->data.persistent_session) {
LOG_INF("Persistent session enabled");
case AWS_IOT_EVT_READY:
LOG_INF("AWS_IOT_EVT_READY");
case AWS_IOT_EVT_DISCONNECTED:
LOG_INF("AWS_IOT_EVT_DISCONNECTED");
cloud_connected = false;
case AWS_IOT_EVT_DATA_RECEIVED:
LOG_INF("AWS_IOT_EVT_DATA_RECEIVED");
// TODO: Handle received data
// print_received_data(evt->data.msg.ptr, evt->data.msg.topic.str,
// evt->data.msg.topic.len);
case AWS_IOT_EVT_PUBACK:
LOG_INF("AWS_IOT_EVT_PUBACK, message ID: %d", evt->data.message_id);
case AWS_IOT_EVT_FOTA_START:
LOG_INF("AWS_IOT_EVT_FOTA_START");
case AWS_IOT_EVT_FOTA_ERASE_PENDING:
LOG_INF("AWS_IOT_EVT_FOTA_ERASE_PENDING");
LOG_INF("Disconnect LTE link or reboot");
case AWS_IOT_EVT_FOTA_ERASE_DONE:
LOG_INF("AWS_FOTA_EVT_ERASE_DONE");
LOG_INF("Reconnecting the LTE link");
case AWS_IOT_EVT_FOTA_DONE:
LOG_INF("AWS_IOT_EVT_FOTA_DONE");
LOG_INF("FOTA done, rebooting device");
aws_iot_disconnect();
sys_reboot(0);
case AWS_IOT_EVT_FOTA_DL_PROGRESS:
LOG_INF("AWS_IOT_EVT_FOTA_DL_PROGRESS, (%d%%)", evt->data.fota_progress);
case AWS_IOT_EVT_ERROR:
LOG_INF("AWS_IOT_EVT_ERROR, %d", evt->data.err);
case AWS_IOT_EVT_FOTA_ERROR:
LOG_INF("AWS_IOT_EVT_FOTA_ERROR");
LOG_WRN("Unknown AWS IoT event type: %d", evt->type);
static int app_topics_subscribe(char *topic)
int err;
// Just subscribe to 1 topic for now...
const struct aws_iot_topic_data topics_list[CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT] = {
[0].str = topic,
[0].len = strlen(topic),
err = aws_iot_subscription_topics_add(topics_list, ARRAY_SIZE(topics_list));
if (err) {
LOG_ERR("aws_iot_subscription_topics_add, error: %d", err);
return err;
// ---AWS MODULE END---
LOG_INF("Hello World! %s\n", CONFIG_BOARD);
LOG_INF("AWS MODULE BEGIN");
int error = 0;
error = aws_iot_certificates_provision();
if (error < 0)
LOG_ERR("Error while provisioning AWS certificates! err %d", error);
struct aws_iot_config config = {
// AWS Configs
// socket is left blank as it will be set in connect_client(), in aws_iot_connect()
LOG_INF("AWS IOT initializing");
error = aws_iot_init(&config, aws_iot_event_handler);
if (error < 0)
LOG_ERR("Error while initializing AWS IOT class! err %d", error);
LOG_INF("Subscribing to one AWS topic!");
error = app_topics_subscribe("nrf72/6969");
if (error < 0)
LOG_ERR("Error subscribing to AWS topic! err %d", error);
error = aws_iot_connect(&config);
if (error < 0)
LOG_ERR("Error connectoing to aws iot! err %d", error);
-Eric
