Unable to advertise with BT_LE_ADV_OPT_FILTER_SCAN_REQ option
I want to use advertising filtering policy in order to be connectable with all the devices and want to reject all the scan response in order to conserve current consumption.
I
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/kernel.h>
#include <soc.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <zephyr/settings/settings.h>
#include <dk_buttons_and_leds.h>
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
bt_addr_le_t deviceAddr={
.type = BT_ADDR_LE_PUBLIC,
.a = {
	.val={0x11,0x22,0x33,0x44,0x55,0x66}
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		uint32_t user_button_state = button_state & USER_BUTTON;
		bt_lbs_send_button_state(user_button_state);
		app_button_state = user_button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
static struct bt_bond_info bond_info={
	.addr=BT_ADDR_LE_PUBLIC,
static int setup_accept_list_cb(const struct bt_bond_info *info, void *user_data)
	int err;
    err = bt_le_filter_accept_list_add(&deviceAddr);
	if(err){
		printk("Failed to add device to whitelist (err %d)\n",err);
	return err;
void main(void)
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
		printk("Button init failed (err %d)\n", err);
		return;
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return;
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err=setup_accept_list_cb(&bond_info,NULL);
    if(err)
		printk("Device not added\n");
		return;
	printk("Device Successfully added to accept list\n");
	err = bt_le_adv_start(BT_LE_ADV_SCANN_ACCEPT_LIST, ad, ARRAY_SIZE(ad),
			      NULL, 0);
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
    printk("Advertising successfully started\n");
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
#define BT_LE_ADV_SCANN_ACCEPT_LIST BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE|BT_LE_ADV_OPT_FILTER_SCAN_REQ,\
                                    BT_GAP_ADV_FAST_INT_MIN_2,\
                                    BT_GAP_ADV_FAST_INT_MAX_2,NULL)
I tried handling scan response as well but still it sends scan response with empty data. I implemented the above code by taking reference from Bluetooth Low Energy Fundamentals course.
Below is proj.config file:
# Copyright (c) 2018 Nordic Semiconductor
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_LBS"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
CONFIG_BT_FILTER_ACCEPT_LIST=y
Errors: It is not advertising and also filter accept list does not work as intended.
Kindly let me know how to implement the accept filter list for filtering  scan responses.
