Hi
Based on NCS2.3.0 version,hci_uart sample,I use ubuntu as the hci host,Reference link nRF5x support within the Zephyr Project RTOS - Blogs - Nordic Blog - Nordic DevZone (nordicsemi.com),Using the hciconfig and btmgmt tool info commands, the BD address is displayed as 00:00:00:00:00:00,I think the correct phenomenon will display an address
Is this related to my disable hw-flow-control,Here is my configuration,May I ask if the method of disable flow control and modifying the serial port pin is correct
v2.3.0\zephyr\samples\bluetooth\hci_uart\boards\nrf52833dk_nrf52833.overlay
* Copyright (c) 2022 Nordic Semiconductor ASA
&uart0 {
current-speed = <115200>;
status = "okay";
//hw-flow-control;
&uart1 {
status = "disabled";
&pinctrl {
uart0_default: uart0_default {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 8)>;
group2 {
psels = <NRF_PSEL(UART_RX, 1, 8)>;
bias-pull-up;
uart0_sleep: uart0_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 8)>,
low-power-enable;
v2.3.0\zephyr\samples\bluetooth\hci_uart\prj.conf:
CONFIG_CONSOLE=n CONFIG_STDOUT_CONSOLE=n CONFIG_UART_CONSOLE=n CONFIG_GPIO=y CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_BT=y CONFIG_BT_HCI_RAW=y CONFIG_BT_HCI_RAW_H4=y CONFIG_BT_HCI_RAW_H4_ENABLE=y CONFIG_BT_BUF_ACL_RX_SIZE=255 CONFIG_BT_BUF_CMD_TX_SIZE=255 CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255 CONFIG_BT_CTLR_ASSERT_HANDLER=y CONFIG_BT_MAX_CONN=16 CONFIG_BT_TINYCRYPT_ECC=n CONFIG_BT_CTLR_DTM_HCI=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512 # Workaround: Unable to allocate command buffer when using K_NO_WAIT since # Host number of completed commands does not follow normal flow control. CONFIG_BT_BUF_CMD_TX_COUNT=10
