IAR + Debugging won't hit main
I am new to the Nordic Enviornment am having problem getting my first application running.
I am using IAR 7.40 with the nRF mbed dev board that has a nRF51422 on it. I have programmed the S110 SoftDevice on the board using the nRFgo Studio and am trying to run and debug the ble_app_uart example.
Everything compiles and downloads without warnings or errors. BUT for some reason it won't run to main on startup. When I pause the debugger...
The disassembly appears to be here: 0x164ca: 0xe7fd, B.N 0x164c8
Did I miss something in my setup?
Ryan
  • In Project Options - Debugger->Setup enable Run to main. In Debugger->Extra Options enable Use command line and add --drv_vector_table_base=0x0
  • those were already set, no luck...
  • I found the problem...
    when it was downloaded I clicked "No" when J-link asked if I wanted to pick the specific ARM device.
    Note to everyone else... make sure you say yes and select the proper Nordic Part or else it won't work!
    -Ryan
  • Go Project Options->C/C++ Compiler->Output and Check 'Generate output information'
