Radio Test Example to perform FCC certification
We have a device that will be launched soon in the market, but before launching we need that device should pass FCC certification.
To do this I have searched on the online forum, in order to pass the FCC certification Radio Test is the best place to start testing the device.
Unfortunately, I don't have a spectrum analyzer to see the results, but the good thing is that this can be done with two boards having the same Radio example flashed.
Test Board 1: configurations
uart_cli:~$ parameters_print
Parameters:
Data rate: NRF_RADIO_MODE_BLE_1MBIT
TX power: NRF_RADIO_TXPOWER_0DBM
Transmission pattern: TRANSMIT_PATTERN_11001100
Start Channel: 0
End Channel: 80
Time on each channel: 10 ms
Duty cycle: 50 percent
uart_cli:~$
Test Board 2: configurations
Parameters:
Start Channel: 0
End Channel: 80
uart_cli:~$
When a use print_rx command I get this:
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Data: 0
Number of packets: 0
I have no idea what's going ON
Please guide me on how to perform these test steps
Thanks
    I would recommend that you use the random pattern for actual RX/TX communication between two kits instead of the 0xCC pattern, but it will work regardless.
    On the receiver kit #1:
    /*Set same RF channel, modulation, etc. on BOTH RX and TX */
    transmit_pattern pattern_11001100
    start_rx
    On the transmitter kit #2:
    start_tx_modulated_carrier
    Now, I print the payload on the RX side, ie. kit #1:
    uart:~$ print_rx
    Received payload:
    00000000: ff cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000010: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000020: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000030: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000040: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000050: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000060: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000070: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000080: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    00000090: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000A0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000B0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000C0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000D0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000E0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    000000F0: cc cc cc cc cc cc cc cc  cc cc cc cc cc cc cc cc |........ ........|
    Number of packets: 3464
    Håkon
  • Thanks for the reply!
    It worked! I am able to exchange data between the two test kits.
    Now the basic is done, I have worked on the last two-year developing product, It is based on BLE-Mesh Network.
    Now that it's completed I need to test the device which will pass the FFC test, especially FCC Part 15 Subpart C
    The documents seem scarce to me.
    The test setup so far contains:
    RSSI viewer from the nrfConnect Application, which shows the BLE channels and their power in dBm's.
    And two test kits.
    I did try the commands and performed some tests!
    Can you please guide me on how to use the Radio Test example to perform the tests to pass the certification? Do I need to modify the Radio Test example?
    Please guide me on this, what steps do I need to take?
    Thanks, Salman
  • Hi Salman,
    It is usually requested by the test house that you provide them some way of setting up to transmit modulated carrier and RX on low/mid/high channels.
    So you either modify or provide the test house with direct commands via the radio_test sample to setup the following modes:
    * TX 2
    * TX 40
    * TX 80
    * RX 2
    * RX 40
    * RX 80
    You can ofcourse send an inquiry to the test house and ask if there's anything else they need.
    Håkon
  • Okay!
    Some follow-up questions it would be great to answer these questions
    You mentioned
    * TX 2
    * TX 40
    * TX 80
    * RX 2
    * RX 40
    * RX 80
    Does the number represent the channel numbers?
    Does the Radio test example specifically for testing the radio to pass the FCC certification?
    Would I need this example to integrate it into the BLE-Mesh firmware? or it does not require it?
    NOTE: BLE-Mesh Network is using an insta-burst feature.
    Thanks!
    Regards Salman.
    Yes, channel 2 = 2402 MHz etc.
    radio_test is specifically targeted for RF PHY evaluation. This is used for teleregulatory certification (ETSI/FCC/etc)
    No, it can be a standalone firmware. It is your design that is being evaluated in this process.
    Håkon
